Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Closed Thread
Thread Tools Display Modes
Old 03-22-2001, 09:34 AM   #1
Rice Boy in Denial =)
Y2KevSE's Avatar
Send a message via AIM to Y2KevSE
SES/Check Engine Codes, O2 Sensor Locations and Codes, and TSB's inside....
First Post: What to Do if you get a SES/Check Engine light
The Rest: Various TSB's (Technical Safety Bulletins)
!!!!DO NOT POST ASKING HOW DO I FIND OUT WHAT CODE IS CAUSING THE CEL/MIL **OR ** HOW TO FIX THE CEL WITHOUT THE PXXXX CODE!!!!(We are NOT psychic)
What you should do:
1)Get the DTC(Diagnostic Trouble Code) that is stored in your ECU that caused the CEL(check engine light), ie P0140, P0134, PXXXX, etc, from your local AutoZone/Parts store. THERE IS NO SCREW that you turn on the ECU like the older 4th gens had and it flashes you the codes. 2000-2001s must use the Autozone guys OBD(On Board Diagnostic) tools or buy one of the online OBD scanners like Alex Peppers' tool(google it). 2K2+ guys can get the SES light to flash the codes by following studmans' procedure off his website, click !!!HERE!!!.
2)Check the FAQ's !!!HERE!!! for what the DTC means and see if there is a possible link to posts from other members who might have ALREADY gone through this same issue and fixed it. If not, once you fix it, post and ask us to add it.
3)Check the TSB's, Technical Service Bulletins !!!HERE!!! that may cover the repair or at least tell you what needs to be done to fix it.
4)If there isn't a link for your DTC PXXXX, then use the SEARCH. If you don't know how to SEARCH, GO !!!HERE!!!
5)*AFTER* reading through the thread(s) that the search pulls up, if you don't know what to do **THEN** post your question with: "PXXXX - How do I fix this?"
!!!! ALL THREADS SUSPECTED OF NOT COMPLYING WILL BE LOCKED/DELETED !!!!
O2 SENSOR LOCATIONS AND CODES
CREDIT: Soonerfan
During my time here, I have learned that most SES threads are O2 sensor related.
Whenever people have a code that is related to an O2 sensor, they always have to figure out exactly which sensor that it corresponds to (bank 1 & 2 and sensor 1 & 2)....so i created this.
MODS: Please sticky.
EDIT: Here is the final version. I realized that the text on the picture from the TSB was very grainy and almost unreadable. With the magic of Powerpoint and Photoshop, I cleaned it up. While I was at it, I moved the sensors to separate the banks (bank 1 left and bank 2 right) so it was easier to read. This also allowed me to place the sensors so they would line up with where they belong.
Description of O2 Codes
BANK 1
FRONT (Sensor 1)
P0031 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 1)
P0051 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 1)
P0130 - Front O2 Sensor Circuit (Bank 1)
P0131 - Front O2 Sensor (Lean) (Bank 1)
P0132 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 1)
P0133 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 1)
P0134 - Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 1)
P0135 - Front O2 Sensor Heater (Bank 1)
P1143 - Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 1)
P1144 - Heated Oxygen Sensor 1 Rich Shift Monitoring (Bank 1)
P1148 - Closed Loop Control (Bank 1)
BANK 1
REAR (Sensor 2)
P0037 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 1)
P0057 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 1)
P0137 - Rear O2 Sensor Low Input (Bank 1)
P0138 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1)
P0139 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 1)
P0140 - Rear O2 Sensor High Input (Bank 1)
P0141 - Rear O2 Sensor Heater (Bank 1)
P1146 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 1)
P1147 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 1)
BANK 2
FRONT (Sensor 1)
P0032 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 2)
P0052 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 2)
P0150 - Front O2 Sensor Circuit (Bank 2)
P0151 - Front O2 Sensor (Lean) (Bank 2)
P0152 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 2)
P0153 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 2)
P0154 - Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 2)
P0155 - Front O2 Sensor Heater (Bank 2)
P1163 - Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 2)
P1164 - Heated Oxygen Sensor 1 Rich Shift Monitoring (Bank 2)
P1168 - Closed Loop Control (Bank 2)
BANK 2
REAR (Sensor 2)
P0038 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 2)
P0058 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 2)
P0157 - Rear O2 Sensor Low Input (Bank 2)
P0158 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 2)
P0159 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 2)
P0160 - Rear O2 Sensor High Input (Bank 2)
P0161 - Rear O2 Sensor Heater (Bank 2)
P1166 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 2)
P1167 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 2)
Y2KevSE is offline
Old 03-22-2001, 10:16 AM   #2
Send a message via ICQ to punkdork Send a message via AIM to punkdork
Here's the bulletin for the slipping auto transmission. It now covers 1st-2nd and 2nd-3rd slippage and lists vin numbers.
http://www.punkdork.net/max/tsb039a.pdf
punkdork is offline
Old 03-22-2001, 11:32 AM   #3
Squeaks and Rattles
Great idea. Here's the Squeaks and Rattles one. It's under "interior", issue 2 - a link to a scan of each page of the TSB.
http://www.fourthrock.com/maxima/issues/issues.html
Thanks, Kev
thorizeen is offline
Old 03-22-2001, 11:58 AM   #4
Y2KevSE's Avatar
Brake rotors are covered until the "3 years/36K mile" bumper to bumper warranty expires...
http://www.punkdork.net/max/rotor%20tsb.jpg
Thank you Redline for finding it and thank you punkdork for hosting it.
Y2KevSE is offline
Old 03-22-2001, 12:43 PM   #5
Y2KevSE's Avatar
Here's the National Highway Traffic Safety Administration website which you can use to find TSB numbers.
http://www.nhtsa.dot.gov is their homepage.
Y2KevSE is offline
Old 05-01-2001, 12:32 AM   #6
Full Brake Rotor TSB!!!
Finally updated my website and uploaded 5 pages of the Brake Rotor TSB in jpg format.
http://apollo799.50megs.com/Maxima/Maxima.htm
__________________
2002 Majestic Blue 6speed
Addco RSB, Generic FSTB, Injen Intake, Xpel Clear Bra
Coming soon - Metallic Tint and Maxspeed Springs
Visit the forums at Max-World.org
Lumbee799 is offline
Old 11-15-2001, 04:52 PM   #7
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
Latest Fuel-Cut TSB
There is a NEW/UPDATE TSB that came out in Sept or October along with a NEW Part Number. The TSB is NTB01-018A and the part number is 23710-4Y914.
This is for 2001 California Emission Maximas with V-rated(17") tires and a Manual Transmission.
Check this thread for my FIRST impression:
Someone told me of a website that sells cheap maxima floor mats
IceY2K1 is offline
Old 11-27-2001, 12:58 PM   #8
TSB on Ignition Coils
I visited my local nissan dealership/service department today after I experienced what the service foreman thinks was a "spark knock". He informed me that there is a TSB out for some Maximas concerning the (ignition) coils. TSB says that the ignition coils on thes maxima's may burn out.
Ther service foreman could not duplicate the "spark knock" but still as a precaution has ordered new coils and will replace them once they get in. Apparently the coils are on backorder.
Unfortunately I could not find that TSB online anywhere to put it up here, so if someone finds it please put it up here so that others know what I am talking about.
Thanks.
GhettoMAX is offline
Old 01-02-2002, 11:29 AM   #9
Wind Noise TSB
Click here to download the PDF for TSB01-029
Give 'em hell!
MichaelAE is offline
Old 02-27-2002, 09:40 AM   #10
Y2KevSE's Avatar
2000 Maxima TSBs
Here you go 2000 maxima guys
http://www.alldata.com/TSB/41/00416289.html
Visit the URL for the latest TSB information.
Credit: yongjun
Y2KevSE is offline
Old 02-27-2002, 09:41 AM   #11
Y2KevSE's Avatar
2001 Maxima TSBs
http://www.alldata.com/TSB/41/01416289.html
Credit: yongjun
Y2KevSE is offline
Old 03-01-2002, 09:36 AM   #12
Y2KevSE's Avatar
Some TSB's in .pdf format
http://home.att.net/~maximadriven/bu.../bulletins.htm
Credit: Frank Dixon
Y2KevSE is offline
Old 03-23-2002, 08:50 PM   #13
Y2KevSE's Avatar
2002 Recalls
Odometer Replacement
Previous TSB has turned into a recall:
Accelerator Pedal Stop
Correct Tire pressure for 18x8 235/40 tires
Credit: gtr_rider
Y2KevSE is offline
Old 05-02-2002, 02:00 PM   #14
Y2KevSE's Avatar
Buzz Noise TSB
http://boostedmaximas.com/tsb/buzz_noise1.jpg
http://boostedmaximas.com/tsb/buzz_noise2.jpg
http://boostedmaximas.com/tsb/buzz_noise3.jpg
Thanks thicknes, for converting them to PDF files!
http://boostedmaximas.com/tsb/buzz_noise1.pdf
http://boostedmaximas.com/tsb/buzz_noise2.pdf
http://boostedmaximas.com/tsb/buzz_noise3.pdf
Credit: Mr. A and thicknes
Y2KevSE is offline
Old 05-02-2002, 02:01 PM   #15
Y2KevSE's Avatar
Surge TSB
http://boostedmaximas.com/tsb/surge1.jpg
http://boostedmaximas.com/tsb/surge2.jpg
http://boostedmaximas.com/tsb/surge1.pdf
http://boostedmaximas.com/tsb/surge2.pdf
Y2KevSE is offline
Old 05-18-2002, 12:52 AM   #16
Y2KevSE's Avatar
2002 TSBs from www.alldata.com
01-025 JAN 02 Power Door Locks - Intermittently Lock By Themselves
01-042 JAN 02 Hood - Vibration
01-087A DEC 01 Paint - Removal of Environmental Particles
Credit: PrinzII
Y2KevSE is offline
Old 07-08-2002, 01:01 AM   #18
TSB's from Edmunds
http://applications.edmunds.com/main...&popup=current
K Pazzo 6 is offline
Old 07-23-2002, 04:46 PM   #19
autobrokerdave@gmail.com
maximadave's Avatar
Send a message via Yahoo to maximadave
2001-2002 Maxima Transverse Link Replacement
CHECK YOUR VIN NUMBER AND SEE IF YOU ARE ON THE LIST
Applies to 2001 Maxima, the following Vehicle Identification Number Ranges:
JN1CA31A*1T113697 - 113815;
JN1CA31A*1T319553 - 320204;
JN1CA31D*1T632735 - 633104;
JN1CA31D*1T841199 - 843066.
Applies to 2002 Maxima, the following Vehicle Identification Number Ranges:
JN1DA31A*2T000011 - 002829;
JN1DA31A*2T300022 - 317004;
JN1DA31D*2T200011 - 207916;
JN1DA31D*2T400020 - 442089.
The number of vehicles potentially affected is approximately 67,000.
Please review the disclaimer located at the bottom of this page for more instruction.
Reason for Recall
One of the parts of the front suspension on your vehicle which is called the transverse link may break where it is mounted to the frame. This may cause a knocking sound and abnormal steering. This may result in difficulty controlling the vehicle which, if ignored, could cause a crash.
What Nissan Will Do
In order to prevent this incident from occurring, your Nissan dealer will replace the transverse links on the left and right sides with new ones. This free service should take about two hours to complete, but your Nissan dealer may require your vehicle for a longer period of time based upon their work schedule.
What You Should Do
Contact your Nissan dealer at your earliest convenience in order to arrange an appointment to have your vehicle repaired. If you notice a knocking sound from the front of your vehicle and/or abnormal steering, you should stop driving and contact your Nissan dealer to arrange to have the vehicle towed to the dealer for repair.
If the dealer fails, or is unable to make the necessary repairs free of charge, you may contact the National Consumer Affairs Office, Nissan North America, Inc. at P.O. Box 191, Gardena, California 90248-0191. The toll free number is 1-800-NISSAN1 (1-800-647-7261). If you reside in Hawaii, please call 1-808-836-0888.
You may also contact the Administrator of the National Highway Traffic SafetyAdministration, 400 Seventh Street, S.W., Washington, D.C. 20590 or call the toll-free Safety Hotline at 1-888-327-4236.
Nissan recalls may apply to specific VIN ranges, and due to equipment variation, options, prior repairs, etc., your vehicle may or may not be involved in a recall. To determine if your specific vehicle is affected by any recall, please contact your local Nissan dealer. It will be necessary to supply the vehicle make, model and identification number (VIN) to the dealer.
maximadave is offline
Old 09-21-2002, 01:17 PM   #20
Alldata is Not all the data
I subscribed to Alldata for my 2000 Maxima. Imagine my surprise when service bulletins that had appeared months earlier on Maxima.org were NOT on Alldata. I emailed them and listed specific service bulletins that were missing on their database. I got an email back from Alldata which stated that Alldata "STRIVES" to post service bulletins in a 6 to 12 month period. Note - the word "strive" and the fact that Alldata made no guarantee! In fact, many of the missing service bulletins at Alldata had been issued far beyond the twelve month limit Alldata "strives" for.
Alldata may be better than Nothing but they sure aren't timely or thorough! And they certainly don't guarantee they will ever get around to entering data in a timely fashion. While Maxima.org may not have all the service bulletins that are posted on Alldata, Maxima.org does have more of the "important" service bulletins than Alldata.
In my view Alldata is sloppy, slow and incomplete but they are also the only game in Town.
To get a true view of the service bulletins relevant to your vehicle: you need Maxima.org, Alldata, and also a friend at a local Nissan dealership. The Best buy is Maxima.org.
daarrid is offline
Old 09-22-2002, 09:04 PM   #21
Y2KevSE's Avatar
NTB02-084
02 Maxima - Howl Noise When Clutch Is Released
NTB02-001C
00-03 Maxima - Driver Seat will Not Move Forward Or Backward
NTB02-073
97-98 Maxima - Alternator Recall Campaign
NTB02-064 (Infiniti - ITB02-038)
01-02 Maxima - Transverse Link Recall Campaign
NTB00-088A (Infiniti - ITB00-063B)
00-01 Maxima - Brake Judder
NTB02-056 (Infiniti - ITB02-032)
01-02 Maxima - Rear Suspension Bottoms Out
NTB02-058
01 Maxima - 20th Anniv Shift Knob Poor Appearance
Y2KevSE is offline
Old 10-16-2002, 01:05 PM   #22
nm
Just saw something interesting and usefull:
The official NHTSA TSB site
http://www.nhtsa.dot.gov/cars/problems/tsb/
now has PDFs of about a third of the TBS posted for download.
nm is offline
Old 03-11-2003, 08:31 AM   #23
Re: EQUIPMENT:ELECTRICAL:ANTI-THEFT DEVICES
HID Anti-Theft Kit Information
Put in NHTSA # 635806 into http://www.nhtsa.dot.gov/cars/problems/tsb/. Unfortunately there isn't a PDF of it on there.
bobcat is offline
Old 03-21-2003, 01:19 PM   #24
2002 - 2003 Hesitation TSB
ThurzNite- Happy Birthday
__________________
2003 Maxima SE 6 Speed SOLD
Clicky
tita6 is offline
Old 04-25-2003, 10:30 PM   #25
Send a message via AIM to studman
I'll host any TSB that isn't listed on my site, as long as it's for a 5th gen. If you have an actual TSB and it isn't listed on my site, email the TSB to me and I'll add it to the site.
http://maxima.theowensfamily.com/tsb/
studman is offline
Old 08-08-2003, 03:35 PM   #26
IceY2K1's Avatar
<~~~~~Click "Send a Private Message" with any NEW TSBs and I'll add them to this thread.
PLEASE post all questions in the forum.
Thanks!
IceY2K1 is offline
Old 10-11-2004, 11:58 AM   #27
IceY2K1's Avatar
Maxima TSB site:
http://www.nissanhelp.com/Bulletins/Maxima/Year.htm
Credit: GimmeTorq
IceY2K1 is offline
Old 11-08-2004, 12:20 PM   #28
IceY2K1's Avatar
Current TSBs(they keep changing the location/link, so you'll have to manually follow these direction vs. a simple link):
Click here: http://www.nissan-techinfo.com/nissan/
Hover mouse over "Inside Publications" and click "Nissan TSB's"
IceY2K1 is offline
Old 08-05-2006, 09:58 AM   #29
IceY2K1's Avatar
Right Click and Save As:
http://www.mortgagepartners.ca/images/maxima/TSB's/
Credit: mhadford
IceY2K1 is offline
Closed Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
