Correct Tire pressure for 18x8 235/40 tires
Old 08-19-2002, 07:49 AM
Pele 96's Avatar
Does anyone know what the correct tire pressure is for 235/40 18x 8 tires. Just got them installed with Eibach's and KYB AGX's.
Pele 96 is offline
Old 08-19-2002, 08:06 AM
Thats a pretty low profile tire. I'd run 35/32 cold.
Old 08-19-2002, 08:42 AM
Pele 96's Avatar
Pele 96 is offline
Old 08-19-2002, 09:11 AM
I am Roid Rage
Bluebird's Avatar
Under Pressure
On the side of my tires it says 44 psi max. I called Nitto and they said the number on the side is what you should have in there. So I get my tires good and warm and then make sure there is 44 psi in there. My gf has 205/40/17's with a recommended psi of 50 and you can definately feel if there is only 40 in there. Slopier handling & harsher ride. For you, I think 35 would be too soft and risk possible rim damage. But then again, what the hell do I know?
Bluebird is offline
Old 08-19-2002, 09:40 AM
voltman's Avatar
Re: Under Pressure
The key to the sidewall rating is 44 psi max. You don't want to inflate it to that number.
voltman is offline
Old 08-19-2002, 11:25 AM
I am Roid Rage
Bluebird's Avatar
Re: Re: Under Pressure
Thats what I always thought, but not according to the rep at Nitto. Thats why I drive the car a while and then inflate. That way the air is good and hot whats in there will be the max pressure. It's probably at like 41 psi when cold (44 hot). The ride is much better than 32 psi and my tires aren't wearing unevenly so it seems to be working. If anybody knows for certain I would love to hear from you. I'm just going on what the guy told me.
Bluebird is offline
Old 08-20-2002, 07:39 AM
Pele 96's Avatar
DOes anyone else know???
Pele 96 is offline
hez8813
03-12-2020 12:06 AM
alahjahwan09
18
09-21-2015 09:12 PM
Serotta33
09-17-2015 12:14 PM
Y2kMaxima
Wheels/Tires
09-14-2015 10:56 PM
jfl330
09-04-2015 01:44 PM
Quick Reply: Correct Tire pressure for 18x8 235/40 tires
