Go Back   Maxima Forums > Maxima Discussions > Infiniti I30/I35
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-17-2005, 11:19 AM   #1
00-01 Transmission Info an FYI
Here is some useful (I hope) info about the Automatic Transaxle for an 01 I30.
(USE AT YOUR OWN RISK!)
This info comes in handy if you are buying a VB shift kit, solenoid assembly or rebuilt transmission for your 00-01 I30.
A/T model identification:
The 00-01 I30 models use an RE4F04B (the I30t uses a RE4F04W which contains a limited slip differential) transaxle which is not to be confused with the RE4F04A used on older models. To confirm this, check the spec plate located to the right of the VIN engraved on the firewall in the engine compartment. You can also tell the difference between the two transmissions by looking at the color of the solenoid harness terminal connector color located at the back left of the transmission Tan = RE4F04A and Black = RE4F04B).
Limited slip identification:
On the top left of the transmission bell-housing there should be an 85X05 or 85X06 cast onto the housing (85X05 = without limited slip and 85X06 = with limited slip). The corresponding Nissan part numbers are 3102085X05 (~$1900) and 3102085X06 (~$2470).
TransGo VB mod:
There are two kits available for the 00-01 I30 models. Both kits do not come with an oil pan gasket ($3 at Trans Exchange, $12 at EverythingInfiniti) but they do come with an installation video.
Here is one of the biggest distributors of TransGo products.
Trans Exchange - http://www.txchange.com/sk.htm
(1) SK RE4F04B – Standard shift kit which improves shifting for stock engine applications (~$45).
(2) RE4F04B-HD2 – Performance shift/reprogramming kit which decreases shift delay. This is what you should use if you plan on NOS or Boosting your engine (don’t have price info). NOTE: shifts are more aggressive and can be a real tire chirper.
The rep at Trans Exchange highly recommends upgrading the oil cooler with filter (~$50) as the Nissan/Infiniti stock coolers are difficult to clean. However, they do sell a trans cooler cleaner kit with filter (~$33).
Solenoid assembly:
If your 00-01 I30 Slips from first to second or second to third gear and your VIN is JNKCA31A1T015622 or earlier, there is a TSB (ITB00-028a) which is suppose to resolve the problem. Basically it’s a problem with the solenoid assembly (3194085X03) or transmission control module (310363Y160 for 00 models and 310365Y001 for 01 models). Unfortunately, EverythingNissan does not list these parts. I called Teckpak/Fitzall who manufacturers solenoid kits and was told this is only available through OE.
skeetch is offline   Reply With Quote
Old 06-05-2005, 10:29 PM   #2
Quote:
Originally Posted by skeetch
Solenoid assembly:
I just found this post and how would I know if my VIN is earlier that the one posted?
The Legend is offline   Reply With Quote
Old 06-05-2005, 10:57 PM   #3
Send a message via AIM to CreativeDesignz
or u can just call maximum tuning and have a valvebody shipped to you
__________________
Paradox Cefiro Kit, Cefiro Sports grille, Black Housing Cefiros, 8000k HIDS, Eyelids, Addco RSB, FSTB, Eibach Pro-kit, KYB AGX Shocks, 18" Arceo Dynostars, LED mirrors, Shaved Trunk, 6 Piece Whelen Strobe Kit, CAI, WarpSpeed Y-Pipe, Stage 2+ VB, Polished Valve cover, Intake Manifold, Optima Yellow Top, 215 Amp Alternator, ID Max 12's,Alpine MRV-1005, DLS Iridiums, Eclipse AVN 5435
CreativeDesignz is offline   Reply With Quote
Old 06-06-2005, 04:35 PM   #4
Quote:
Yeah, but the Maxtuning VB is quite a bit more expensive.
Old 06-06-2005, 05:16 PM   #5
do you know if the I30 and the I35 VB are the same?
Old 06-07-2005, 04:21 PM   #6
Quote:
According to this link the I30 and I35 transmissions are the same.
http://efisakh.autodata.ru/at_nissan.htm
BTW if the last 6 numbers in the Vin indicate whether you are before or after the recall JNKCA31A1T015622.
Old 06-07-2005, 04:29 PM   #7
my vin is after that so im in the clear. thanks.
Old 07-01-2009, 10:09 AM   #8
Send a message via ICQ to ScorpionHD Send a message via AIM to ScorpionHD Send a message via MSN to ScorpionHD Send a message via Skype™ to ScorpionHD
Ok I know this is an old thread but! It helped me to go in the right direction.
I have a 00 Maxima Se and the problems that I have a described by this Kit:
Quote:
SK® RE4F04B
Nissan Maxima, Altima and Infinity i30 1993-2004
Corrects/Prevents/Reduces:
Rough 1-2nd when cold
; no 3rd after 3-2 4-2 kickdown; leaky, worn inner clutch seal; hard or soft 1-2 shift; long shift. Includes high temp low shrink rings. Improved shifts firmer 4th & lockup.
My vin is JN1CA31DXYT528641 as it seems its after the number you have posted.
My question is, which exacly kit I need (http://shop.ebay.com/?_from=R40&_trk...All-Categories)
And how easy is it to DIY?
ScorpionHD is offline   Reply With Quote
Old 07-26-2009, 12:48 PM   #9
that would yield 245hp 260tq
kizzmyazz is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
