Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 02-14-2007, 11:33 AM   #1
Cleaning Throttle Body On 5.5 gen (2002-2003 only) - Yes or No
I have tried to find information on this both in the FAQ/How-To threads but could not find it. The search either results in too many irrelevant results or non-specific info. Anyways, I apologize if I missed the definitive thread on this subject and if this is a repost. :-)
What is the general consensus regarding cleaning the throttle body on 5.5 gen (2002-2003) Maxima - is it OK to clean it or is it not recommended?
What I found is different opinions here and there but nothing that most .org members agreed on. Some say it's OK and they had no ill effects, some say they could not get their idle to normal until they spent a few hundred $$ on new parts, etc.
If you have cleaned your throttle body and have no ill effects I would appreciate it if you could briefly describe how you did it so we know how to safely do it.
If you have cleaned your throttle body and messed your car up please also briefly describe how you did it so we know how not to do it.
(Why did they start using the drive-by-wire; what does that improve? I am sure there are many other aspects of automotive technology that actually need improvement.)
Whiggy is offline   Reply With Quote
Old 02-14-2007, 12:33 PM   #2
Send a message via AIM to Foglght
I've been cleaning throttle bodies on every type of car imaginable, including maximas. The reason the car would not idle properly would be due to pieces of carbon flaking off and getting stuck in the idle air control solenoid and keeping it from doing its job.
If you want to clean it, take the thing off, go buy a bottle of brake clean or throttle body cleaner, and spray the crap out of it, trying not to get the outside plastic parts too coated (it eats plastic). After that is done get some compressed air to spray through it. If you don't have compressed air, go buy a cheap compressor, you'll need it if you want to do little jobs like this in the garage. I like to use an old toothbrush.
Foglght is offline   Reply With Quote
Old 02-14-2007, 12:55 PM   #3
Quote:
Originally Posted by Foglght
I've been cleaning throttle bodies on every type of car imaginable, including maximas. ...
I have been doing the same on all my cars too, but from what I understand the 2002 and up Maximas have a different throttle body with no throttle cable but 4(?) sensors instead and if you are not careful you can screw things up. That is why I said both in the title and the post itself - pertains to 5.5 gen only.
Old 02-14-2007, 01:07 PM   #4
LA02MAX's Avatar
Send a message via AIM to LA02MAX Send a message via MSN to LA02MAX
Good thread. I was contemplating the same thing because mine is very dirty, but as you mentioned our throttle bodies are not operated by cable, they are electronic, and it's very easy to screw things up. I'm afraid to try anything, but if I hear a lot of positive advice, I'll go ahead and try.
__________________
LTB, RSB, FSTB, H-techs and Illuminas, 6.5 gen wheels, 6th gen front brakes
PB: 14.338 @ 98.27 with a 2.300 60' stock.
LA02MAX is offline   Reply With Quote
Old 02-14-2007, 01:11 PM   #5
Super Moderator
Send a message via AIM to nismology
The thread topic is specifically about 2002-2003 maximas which don't have an idle air control valve. The idle is controlled by the throttle body itself, which is controlled electronically by the ECM.
Edit: I guess the others beat me to it...
I would imagine the idle air volume learning procedure would need to be performed after cleaning it.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
nismology is offline   Reply With Quote
Old 02-14-2007, 01:12 PM   #6
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Quote:
Don't be a . Give it a whirl.
I'd recommend it.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 02-14-2007, 01:16 PM   #7
Not true on the 5.5 gens. Not true at all. If you clean the throttle body on a 5.5 gen with any chemicals, you will get a code 0507 and need to go to Nissan and have them connect CONSULT II up to have the ECU relearn IAV settings.
http://www.nissanhelp.com/Ownership/...NTB05-067-.htm
I believe some org members have been lucky and followed a IAV relearn procedure, but slim chance it works for the higher perecentage of individuals.
Only way to safely clean 5.5 gen throttle bodies is to use a lint free cloth and wipe it out. Or just don't touch it.
__________________
nismopc is offline   Reply With Quote
Old 02-14-2007, 01:18 PM   #8
Super Moderator
Quote:
Originally Posted by nismopc
Not true on the 5.5 gens. Not true at all. If you clean the throttle body on a 5.5 gen with any chemicals, you will get a code 0507 and need to go to Nissan and have them connect CONSULT II up to have the ECU relearn IACV settings.
I believe some org members have been lucky and followed a IACV relearn procedure, but slim chance it works for the higher perecentage of individuals.
There is no IACV relearn, since there is no IACV. I assume you're referring to the idle air volume relearn. How many people has it NOT worked for using the non-consult II procedure?
__________________
Old 02-14-2007, 01:19 PM   #9
Quote:
I'd recommend it.
Bad advice. Highly not recommended! I've personally experienced the 0507 code and had to pay dealer $68 (normally $100+) to have CONSULT II set ECU to relearn. Luckily dealer gave me a discount because I was just in there a few weeks back to have the stuttering idle fixed with a ECU reflash.
__________________
Old 02-14-2007, 01:20 PM   #10
Certified Hooptie
NmexMAX's Avatar
You dont' NEED a Consult II.
I've done a few things to my APPS & TPS sensors and they get mad at me for a short time, but then come back to me after an ECU reset and IAVL.
Old 02-14-2007, 01:21 PM   #11
Super Moderator
Did you even ATTEMPT to do it yourself?
__________________
Old 02-14-2007, 01:23 PM   #12
Quote:
edited - thanks!
Not sure, but when I did a search, it appeared more dealer visits had to occur because no one could get the non-CONSULT procedure to work. That was why I went to dealer. After trying myself 3 times, I gave up.
__________________
Old 02-14-2007, 01:25 PM   #13
Am I wrong or do you not own a 5th gen? A33 Ti ? This is in refernce to the 5.5 gens and newer.
__________________
Old 02-14-2007, 01:32 PM   #14
Certified Hooptie
NmexMAX's Avatar
I don't own it, I'm still paying the darn thing
But, I have a 2003 Nissan Maxima Polished Titanium, build date 10/02.
I have had all the fun codes. 0507, 2122, 2138, 1705. Don't ask..
I can do the ECU reset, and IAVL in minutes. It's very easy, just get the hang of it. I call it the pedal dance.
Old 02-14-2007, 01:36 PM   #15
Ah, gotcha. Wonder why I couldnt get it to take. I am able to reset the ECU within approx. 1-2 mins once the car warms up, but could not get the procedure to take for the IAVL.
I've dealt with a few minor codes and they were easy. Clean and retighten gas cap, dual O2 sim, etc., but this one got me.
__________________
Old 02-14-2007, 01:43 PM   #16
Send a message via AIM to Gle03Max
I'd imagine that if you disconnect the negative battery terminal, then take all the sensors off ( or unplug and then take off after throttle body is off, whichever is easier ) , physically take the throttle body off the car clean with toothbrush and carb/throttle body cleaner, dry with lint free cloth and put back on then there could be no problem as long as u thoroughly dryed.
If the car has no power when sensors unplugged and then put everything back and then reconnect battery I can't imagine how the ecu would even knoe anything happened.
Just my 2 cents, I haven't done yet.
__________________
*2003 Nissan Maxima SE 6 Speed*
|HLSD|Greddy Evo 2|Berk Intake|FSTB|8k Fogs|8k Headlights|White LEDs|Tint|Diamond Plate Floor Mats|Zex Wet Kit|Clear Sidemarkers|Zex Bottle Warmer|Zex Remote Bottle Opener|Fidanze Flywheel|Spec Stage 3 Clutch|Toyo Proxes 4|ES Motor Mounts|
http://www.cardomain.com/ride/2655734
Gle03Max is offline   Reply With Quote
Old 02-14-2007, 01:45 PM   #17
Certified Hooptie
NmexMAX's Avatar
Why don't you try it and post back?
Old 02-14-2007, 01:53 PM   #18
absoundlab
I use carb cleaner and a rag wheb I do it I take the tb off the car so I can get in there good and get it done. I clean it every oil chabge and everytime I do it I notice better throttle response.
Old 02-14-2007, 01:54 PM   #19
Certified Hooptie
NmexMAX's Avatar
Quote:
This thread does NOT apply to you.
Old 02-14-2007, 02:09 PM   #20
Super Moderator
If you do that you will DEFINITELY have to perform the idle air volume learning procedure.
__________________
Old 02-14-2007, 02:12 PM   #21
Certified Hooptie
NmexMAX's Avatar
When I was a VQ35 I actually managed to change my plugs & IM w/o d/c the TB. It was a biitch.
Old 02-14-2007, 03:09 PM   #22
First let me start by saying that I do have a 2003...
I cleaned my TB about a year ago, before I knew it was an E-throttle... Without taking the TB off of the car I manually moved the butterfly valve back and forth while spraying the TB cleaner into it. I used a rag to catch the runoff and rub the butterfly valve. I had a CEL on then did the ECU reset procedure. After that the CEL went away. I may have had to do the idle air volume learning procedure. I think I was one of the lucky ones b/c others who have tried cleaning their TBs in a similar fashion have had to get thiers replaced.
All this time later I've had no problems with it.
__________________
UGAd13 is offline   Reply With Quote
Old 02-14-2007, 04:29 PM   #23
...then take all the sensors off ( or unplug and then take off after throttle body is off, whichever is easier )...
I would not recommend this to anyone unless it's absolutely unavoidable. I had to take the TPS (Throttle Position Sensor) off on my '95 GXE once and that thing was a biatch to adjust after putting it back on. I can't imagine what it would take to get the sensor(s) adjusted to specs on the 5.5 gen. Maybe it's not even doable without the Consult tool...
Old 02-14-2007, 04:31 PM   #24
LA02MAX's Avatar
I'd recommend it.
meh, I'll try it when I get the chance. I just don't want to mess anything up because I have no spare time to let my car sit with the battery unplugged, or take it to the dealer, etc. so I just wanna be cautious...
__________________
Old 02-14-2007, 08:41 PM   #25
Certified Hooptie
NmexMAX's Avatar
Quote:
They are different systems and your advice has nothing to back it so why not try and keep th facts straight here.
The 5.5 adjusts electronically on it's own, so unlike the A32, it's easier. I used to adjust my idle on my A32 via ECU screw.
I don't have a Consult and I can adjust my idle (+/- 250) on my 5.5g.
__________________
Old 02-14-2007, 08:55 PM   #26
Send a message via AIM to oldskooljdm
i cleaned my throttle body about 2 days ago on my 2k3. i was doing an oil change and decided to clean the TB. It was filthy in there...i spent a good while on it cleaning it..opening and closing the valve with my finger and spraying crc tb cleaner inside and wiping clean. now today my ses light came on and i had the code checked and it was code p0507. So i followed the steps to reset the ecu and did the iavl and the ses light is gone. so i recommend cleaning the tb and just reset the ecu.
__________________
oldskooljdm is offline   Reply With Quote
Old 02-14-2007, 09:16 PM   #27
If you wanna talk facts let's do it. You have your IACV and TPS mixed up. IACV controls the idle (allows a certain amount of air to pass through/by the throttle body even with the throttle plate closed so your engine does not die when you are not applying any throttle); TPS, on the other hand, senses the position of the throttle plate and sends the signal to the ECU so it can regulate A/F mixture ratio (also sends signal to the TCU to help determine shift points in AT).
To the best of my knowledge the 5.5 gen does not have a mechanical IACV but electronic (therefore no screw to adjust idle).
Now we all (should) know that electronic components do not react well to most liquids (throttle body cleaner) and therein lies my concern that some of those sensors may be screwed up by introducing liquids to their environment.
Capisce?
Old 02-14-2007, 09:32 PM   #28
Super Moderator
Preaching to the choir so far...
Capisce?
I don't see how spraying the throttle plate would damage the throttle control motor...
__________________
Old 02-14-2007, 10:04 PM   #29
Send a message via AIM to BLK2BLU
When I cleaned mine the idle went to around 1200 but I just reset the ECU and did the IAVL. 15K later...no problems
__________________
Injen intake, All Alpine System, 17* Adv., TEIN H-tech, FSTB, Tokico Blues, Home made STS, Hot Shot Headers, VAFC-II
BLK2BLU is offline   Reply With Quote
Old 02-15-2007, 05:06 AM   #30
I was just getting the facts straight for NmexMax.
Who said anything about the motor?
Anyways, has anyone else had any experience, good or bad, with cleaning the throttle body on 2002 and up Maximas?
Old 02-15-2007, 05:34 AM   #31
I just cleaned mine 2 weeks ago, and since then have had the SES light on (P0507). I dont exactly know what doest it but this is how i cleaned mine. I manually opened the valve sprayed TB cleaner in and wiped it off, waited like 30 min and as soon as i turned the car on the SES came on. Also when u get that code it effects your transmision and everytime u slow down the car surges. I tried IAVL couple of times but couldnt get rid of the code. I know everybody who used consult II could get rid of the code and everything went back to normal, so if u have one or can get hold of one go ahead and clean it cuase mine was nasty. Goodluck.
artin64 is offline   Reply With Quote
Old 02-15-2007, 06:30 AM   #32
I also cleaned my throttle body and got the p0507 code with the surging problem. Tried the idle volume air relearn procedure and it worked but still had the transmission surging problem. Took the car to the dealer and they replaced the throttle body under warranty but still have the surging problem. Don't know what to do about the surging problem now.
Jason_03_Max is offline   Reply With Quote
Old 02-15-2007, 06:50 AM   #33
Play with my balls
Deckdout2's Avatar
Send a message via AIM to Deckdout2
My definitive way of cleaning my throttle body. Worked everytime I floored it with the system activated, and no CEL.
__________________
GI: 19" x 8.5" +33 Offset Rare Millie Miglia Evo5
In One's Own Tune, Balance Is Found In The "Area Under The Curve".....
Deckdout2 is offline   Reply With Quote
Old 02-15-2007, 09:00 AM   #34
Certified Hooptie
NmexMAX's Avatar
Throttle control motor. (Small servo motor that controls the opening and closing of the throttle plate)
Apparently it's not the chemical that causes bad things.
I and many other members have done a pre' cleaning, and it didn't do anything as far as codes/idle goes. Pre cleaning = having someone apply throttle while I sprayed TB cleaner in the TB while it was still connected to the car.
It seems as if manually moving the throttle plate has some affect.
On the 5.5g, it's APPS & RPM that sends the signal to the TCM.
I cleaned my TB, got the code, did the reset and IAVL = FTW.
Capisce?
__________________
Old 02-05-2009, 02:16 PM   #35
good info here-thanks guys
i know...2 years old omg...its all good
__________________
'01 GLE Pearl White|Stillen Strut Bar|GAB2|Rotora Drilled&Slotted Rotors|Hawk HPS Pads|Cooper Zeons|Angel Eye Fogs
'02 SE Sterling Mist|Nokya Hyper Yellow Fogs|Orion V2's|GAB2|Vibrant FSTB|Progress Springs|Illuminas
nissandrvr98 is offline   Reply With Quote
Old 02-05-2009, 03:59 PM   #36
That's Mr. Detail to you
Scottwax's Avatar
Send a message via AIM to Scottwax
If you leave the key turned to the run position, you can move the throttle plate. I had my Dad's mechanic clean mine because it was stalling occasionally after a hot restart (or at the very least, the rpms would drop way down before kicking back up) and it was only idling at 600 rpms. What he did was turn the key on to the run position, then sprayed the throttle body, plate etc down and then wiped everything out. Took about 15 seconds to start after cleaning, but no SES light, no more hot start stalls and the idle is about 725 rpm or so.
I talked to the mechanic about the risks of cleaning a DBW throttle body and he says the problems arise when you move the thottle plate with no power going to it. With the key turned to the run position, you can move the throttle plate without messing anything up.
__________________
2002 Maxima SE, NWP block plate, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Want smilies? I got smilies.
http://www.scottwax.com/smilies.htm
How to wash your car with Optimum No Rinse: http://www.youtube.com/watch?v=mYOAyxsEIuQ
Scottwax is online now   Reply With Quote
Old 02-05-2009, 06:58 PM   #37
yup he is exactly right. I did the same thing with a friend of mine to clean the throttle body and no SES and my car ran 10xs better.
__________________
Blitzfist is offline   Reply With Quote
Old 02-06-2009, 07:13 AM   #38
When you say throttle plate do you mean the butterfly inside? I was actually going to clean mine this weekend after you posting about you having yours cleaned in a different thread. I've seen the post about removing the TB from the car, cleaning it and putting it back on. It sounded likes yours wasn't removed though so I was going to try the same. I have a low idle after the car is fully warmed up and get a little bit of a stumble at idle as well. My gas mileage is great, about 28 so it's efficient but that low idle and stumble irritates me.
Klutch is offline   Reply With Quote
Old 02-06-2009, 08:25 AM   #39
found this write-up, not Max specific but pretty comprehensive and he appears to be sensitive the the position of the "throttle plate" http://forums.vwvortex.com/zerothread?id=1116399
After reading this and hearing what Scottwax's experience was with what the mechanic said it sounds like that is the key. I'm curious if the people that cleaned their TB and had trouble afterward touched the "throttle plate" and moved it
Old 02-06-2009, 08:39 AM   #40
Scottwax's Avatar
Quote:
Yes, the butterfly valve. I was charged $42 so the TB was definitely not removed. Remember, the key has to be in the "run" position (where the key is when the car is started) to be able to move the throttle plate.
Someone else did a write-up that says to secure the gas pedal fully floored: http://forums.maxima.org/6848584-post28.html
Unplug the MAF connector
Remove an intake/air cleaner assembly from the TB
Turn ignition switch "on" (don't start the engine)
Put transmission on any gear (6 MT)
Floor the accelerator and secure it somehow at this position (I usually push it with a long wooden stick and hang on to a metallic frame of the bottom of the driver seat)
Now you get the throttle fully open and can start cleaning TB and butterfly valve.
Use dedicated TB cleaner (AutoZone ~$3). Spray, let it soak, wipe with a soft cotton rag. Don't use a paper as its' tiny abrasive particles can damage the special coating inside of TB. Do it several times till it's clean.
Use toothbrush to reach dip areas
Don't apply any significant force to the butterfly valve to avoid damaging the servo motor (important!)
When all done you may get some MAF related code, just erase it. Also, you'll get higher idle due to the better air flow (around 700 - 750 RPM). You can live with it or perform an idle relearn procedure. However, driving in this condition I noticed, the pinging that my car usually emits is completely gone. It's back after reseting an idle
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
