Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-09-2008, 09:05 PM   #1
Bose Woofer Cut Off Fix For 2000 Maxima
I've read several threads that deal with the intermittent and sometimes terminal Bose woofer cut off problem, woofer stops working. Some have identified what was thought to be the cause of the problem; little black box shorted, bad connectors, amp not working, and etc. All are good probable causes but none seemed to really nail down the problem and in turn provide a repair that absolutely corrected the problem without removing or modifying parts or having the problem return.
In any case, this is my humble attempt to provide a definitive cause and solution that eliminates the problem for the 2000 Maxima.
The harness and circuit board pictured below appeared to have no continuity problems. I then examined the circuit board under a magnifying glass and found the 5 soldered joints that are circled in the last picture which connect the little black box to the circuit board were all broken. I could barely see the broken joints. I re-soldered each joint. This has eliminated the woofer cut off problem.
Repair Procedure
  1. Remove the harness in the picture below which is located on the side of the woofer housing(do so by sliding the two connectors off of the black housing of the woofer)
  2. Slide the zip tie off of the two joined connections
  3. Unplug the 2 connectors
  4. Remove the harness by detaching the 2 tie downs from the base that the woofer is attached to (do this by removing the woofer grill on the rear parcel shelf and pushing the tie downs through their holes)
  5. Carefully cut through the foam and plastic cover under the foam to fully expose the circuit board (see picture below)
  6. Re-solder the joints circled in the picture below
  7. Recover circuit board with plastic and foam
  8. Re-install part
Teddie18 is offline   Reply With Quote
Old 03-10-2008, 05:10 AM   #2
I will this a try and let you know if it works for me. Thanks for the write up.
neowhitemaximase is offline   Reply With Quote
Old 03-22-2008, 06:10 PM   #3
Send a message via AIM to WasatchY2KMax Send a message via MSN to WasatchY2KMax
I did this exact same fix about 2 years ago and the sub has never cut out again. It was hard to see the bad solder joint without a magnifying glass.
__________________
Your Village Called... Their Missing An Idiot
Sterling Mist '00 SE 5 Speed/Leather/17's/Bose/No Bra anymore
WasatchY2KMax is offline   Reply With Quote
Old 03-23-2008, 06:39 AM   #4
have to try this...just purchased my '00 maxima and the sub will turn on every once in a while... Hopefully this will fix the problem
__________________
'00 Nissan Maxima GLE
Engine-VQ30DE-K
Audio-Subwoofers: 2x 12" Kenwood 4-Ohm Single Voice Coil Subs (KFC-W3011) Amp: Kenwood 1000 watt Class D Amp (KAC-8104D) Headunit: Alpine Headunit (CDA-9884), Front: Stock Bose Speakers Rear: 2x 6 1/2" Kenwood Excelon 4-Ohm Speakers
Exterior-Silverstar 4100K UltraVision Headlights, Bosch Icon Wiper Blades, Chrome Exhaust Tips
Performance-Bosch Fusion (Platinum/Iridium) Spark Plugs, K&N Filter, Bridgestone Potenza GO19 Grids
maxdriver10 is offline   Reply With Quote
Old 03-27-2008, 08:19 PM   #5
this did not work for me ...does anyone know if it is at all possible to purchase another circut board for the sub?
__________________
Engine-VQ30DE-K
Old 03-28-2008, 07:15 AM   #6
mine use to just turn on in cold weather...its been playing for 2weeks straight..knock on wood
phatboislim is offline   Reply With Quote
Old 03-28-2008, 09:07 AM   #7
unfortunately i don't think that will help mine...nights are sub freezing here with days in the mid forty's....
__________________
Engine-VQ30DE-K
Old 03-29-2008, 11:45 AM   #8
Send a message via AIM to Dballs P.
I'm planning on doing a total replacement of the speakers, HU, wiring, etc in the next week or two. Since I am having the intermittancy problem of my sub working on occasion right now, i'll try this out before hand and let ya'll know how it worked for me. I located the problem to this area yesterday, however, i thought the problem was in the connecting bracket (plug) going comming out of the amp into the woofer. Thanks for the tip.
__________________
White '03 Max GLE: Bone Stock (For Now)
Dballs P. is offline   Reply With Quote
Old 03-29-2008, 04:23 PM   #9
Send a message via AIM to PadawanKnight Send a message via Yahoo to PadawanKnight
Quote:
It's possible to completely remove the "circuit board". As far as I understand it (my stereo knowledge is limited) that board is used to cutoff higher frequencies being sent to the sub. If you completely bypass it, the sub should work, but all frequencies will be sent. It's a double-edged sword since you'll get some noise you're not used to, but also here some of the lows that weren't low enough to make it through the filter.
__________________
Always Give 100% at Work
12% on Monday
23% on Tuesday
40% on Wednesday
20% on Thursday
5% on Friday
PadawanKnight is offline   Reply With Quote
Old 03-30-2008, 07:44 PM   #10
any idea how I would do that...I mean have the circut board bypassed?
__________________
Engine-VQ30DE-K
Old 03-31-2008, 02:52 PM   #11
I'm just guessing, since i haven't taken it out and looked at it yet, but he probably just snipped the wires and tied them off together (or soldered them), making sure he matched up which the wires going into the board with the ones comming out.
I haven't seen the board yet though, so if this just seems laughable or isn't right i appologize, but that is where i would start unless told otherwise.
__________________
Old 03-31-2008, 11:22 PM   #12
I'm watching you, boy...
SilverGLE's Avatar
Just undo the connectors that go to the CB and hook the remaining ends together... I did this and the only downside is the turn-on "thump." But then again, I removed my sub amp a while back (or rather, I misplaced it...).
__________________
Old: 2000 Maxima GLE, Sold
New: 2007 Subaru STI Limited, "The Gentleman's STI"
SilverGLE is offline   Reply With Quote
Old 04-01-2008, 07:46 AM   #13
i may just pass on the headache and spend that nice rebate check our president is giving us on a decent aftermarket setup
__________________
Engine-VQ30DE-K
Old 04-01-2008, 08:39 AM   #14
Send a message via AIM to jdm01se
Dude, you're the maaaaaan!
Just a question though:
What kind of soldering tool are you using? It obviously can't be as insane as what's located on a plumbers toolbelt...?
jdm01se is offline   Reply With Quote
Old 04-01-2008, 03:30 PM   #15
well i'm not sure exactly what i used when i attempted to fix the problem, one of my granfathers tools. it was just a handheld soldering tool that pluged into an electrical outlet, just make sure if you tryu this that the "wire" you solder with is resin based
__________________
Engine-VQ30DE-K
Old 04-01-2008, 09:15 PM   #16
You unplug the 'circuit board' from the sub and the wiring harness and then plug the harness directly into the sub.
__________________
12% on Monday
23% on Tuesday
40% on Wednesday
20% on Thursday
5% on Friday
Old 08-11-2008, 07:31 AM   #17
is what u repaired (soldered) in that silver 'box' in the black piece that is just below the bose subwoofer?
Old 08-11-2008, 10:28 AM   #18
Quote:
Look at the first picture at the top of the thread. What you repair is circled. It is enclosed in foam padding and plastic underneath the foam.
Old 08-11-2008, 10:38 AM   #19
ok i'm going to check that today on lunch..hopefully i can have time to break it down and get it off so i can get it resoldered. thanks
Old 08-11-2008, 12:40 PM   #20
Good Call -- mine just started cutting out.
I'll be yanking this piece o sheet out and attempting to solder -- hopefully that will be it.
I'd LOVE to replace the whole "Blows" system - but practicality dictates that I leave it stock -- hence, I shall attempt the fix.
thanks for the timesly post!
gr
__________________
"I never saw a wild thing feel sorry for itself. A small bird will drop frozen dead from a bough without ever having felt sorry for itself." ~D H Lawrence
ghostrider17 is offline   Reply With Quote
Old 08-13-2008, 07:28 AM   #21
well i have that piece exposed...time to get it resoldered..hopefully by this w/e
Old 08-13-2008, 07:32 AM   #22
I shoulda known better - the 5.5 gen Blows Sub is totally different.
took it all apart - found no anomalies on the circuit board.
Best I cud do was to squirt some di-electric silicone grease in the molex connector on the back of the sub when I reassembled it.
It still works - but no idea if that fixed it.
2002-2003 guys be warned -- our bose subs ARE different from the 00-01 guys.
gr
__________________
Old 08-13-2008, 08:48 AM   #23
i'm tempted to just splice and connect the wires together..that piece as was said was to stop the popping sound when the car starts...
Old 08-14-2008, 08:16 AM   #24
I did this and it sounds fine, just remove the piggy back plug that is between the reg power cord and the sub female adapter it works fine. My sub cut out and i just did this quick fix sounds fine!!
__________________
Whered that VQ go??
1. 2003 titanium edit blacked out,Hks Exhaust, Jim wolf Pop Charger, 17Deg advance, Nex Coilovers, staggered 20" (yaya i know)
2. 2000 pearl white 5 spd all basic bolt ons g35 whls, it was good while it lasted.
3 87 stang Project 306ci built motor full susp. (in garage) its sloow .....
perkman87 is offline   Reply With Quote
Old 08-14-2008, 08:18 AM   #25
take out the middle conector that goes between the power wire and the sub, it is wrapped in foam. It wil work fine did it about a year ago still sounds great!!
__________________
Whered that VQ go??
Old 08-14-2008, 08:37 AM   #26
Bose is the best decision Nissan made
ser_altima is offline   Reply With Quote
Old 08-14-2008, 09:12 AM   #27
Quote:
show me what u mean middle connector please....i'm audio uninclined
Old 12-29-2008, 07:48 PM   #28
Could someone post a pic of the joints soldered? I'm not exactly clear what you are to solder..
Emaximus is offline   Reply With Quote
Old 12-29-2008, 08:25 PM   #29
Quote:
There is a picture. It's the third picture in the first post, under step number 6.
Old 12-29-2008, 08:37 PM   #30
It's business time.
Progress's Avatar
Send a message via AIM to Progress
FWIW, I just removed that part altogether and plugged the sub in directly. The only, noticeable, difference is the thump sound when you turn the stereo on.
I've had it like this for well over a year with no adverse affect. I've also had it like this on stock and aftermarket HUs.
__________________
Quote:
Originally Posted by Donkey®
You guys win.
Progress is offline   Reply With Quote
Old 12-30-2008, 06:50 AM   #31
Quote:
Oh ok, so those joints are already soldered then. I thought that was a before picture.
Old 12-30-2008, 06:51 AM   #32
this didnt work for me
Old 01-01-2009, 11:59 AM   #33
That is a before picture. As the directions say, RE-solder the joints. That means solder them again. Carefully read the post again. It states what the problem was, the condition of the circuit board and the corrective action.
Old 01-01-2009, 06:04 PM   #34
Ha, I see now. I missed that part because I was just looking at the pics (duh). Got it and now I'm going to try this. Thanks..
Old 01-14-2009, 07:47 PM   #35
All Paid Up
The CB in my 01 AE is different than the one pictured. There is no small CB like this one, only one inside the outer cover that bolts onto the back of the bose sub. I pulled it apart and I don't see any broken solder joints on either side of the board. With the CB installed, the sub cuts in and out when I tap the box that holds the CB.
As far as bypassing it, there are 5 wires going into that cirquit board. Full 12V power, ground, and 3 smaller (maybe 18 guage) wires. I'd rather not give the sub the whole range anyway.
Any thoughts?
My next step if nothing comes up here is to send it to these folks (orger linked in another thread):
http://www.carstereohelp.com/nissanBoseMax.htm
__________________
01 Maxima AE: Stock, fast.
89 LandCruiser FJ62: Unstock, slow.
euclid is offline   Reply With Quote
Old 01-14-2009, 09:03 PM   #36
Any thoughts?
The 2001 woofer set up is different than the 2000. That is why the fix is for 2000 Maximas, hence the title of the thread.
Old 01-17-2009, 04:10 PM   #37
Send a message via AIM to bigpopaj369
i had trouble with my subs cutting out and i had eliminated the 8'' bose one and the pLte for it so more air could pass through and i all of a sudden had no subs i had used the idea of removing the entire circuit board and have found this the best solution this site rocks!
bigpopaj369 is offline   Reply With Quote
Old 03-02-2009, 04:20 PM   #38
HELP!!!! Okay, so first I tried soldering the parts on the circuit board that were circled above. Well, that didnt work but it didnt surprise me because I didnt really know what i was doing--I just got the solder hot and tried to get some to stick to each joint, but it was difficult for me to do this because it seemed like the solder wouldnt stick because it would solidfy(sp?) so quickly after being melted. So, now I disconnected the wires to the circuit board and stripped some of the rubber wire coating from each wire and have tied(wrapped I guess) wires from the same color of wire together. STILL MY BASS HAS NOT COME BACK. Any idea what I might be doing wrong? I believe there are three colors of wires--red, blue, and black. I really want my bass back...Any help or insight is appreciated!
AutoMaxic is offline   Reply With Quote
Old 03-02-2009, 09:51 PM   #39
Just wanted to say this worked for me and it was so easy. Only took a few minutes. Thank you for this write up.
__________________
98 200SX SE
-SR20VE N1
00 Maxima SE
-NWP Spacers
200SXSE is offline   Reply With Quote
Old 03-03-2009, 05:46 AM   #40
SilverGLE's Avatar
Quote:
That's the point of solder... Heat it up, it melts to flow and adhere to the wires, then quickly solidifies. You can try to add some extra solder to the connections, but I'd recommend you remove the whole black box via the connectors. Bypass it entirely and you should be good. You'll get the turn on thump, but so what?
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
