4th gen How to's
General 4th Gen How-To List
PM phenryiv1 with dead links!
Lights/Lighting
How to install strobe lights in your Clearance And/Or Bumper Lights
http://www.cardomain.com/memberpage/496421/7
and http://www.rankmyride.com/?page=cars...ID=5714&pnum=2
How to make your clearance lights brighter
http://forums.maxima.org/showthread....64#post2904464
How To Make Tinted Tails
http://forums.maxima.org/showpost.ph...59&postcount=1
How to make all-red Tails
http://forums.maxima.org/showpost.ph...34&postcount=1
How to make your clearance lights brighter http://forums.maxima.org/showthread....64#post2904464
How to Smoke Corner/Signal Lights http://www.maximafreak.com/bumper/
How to create a completely pointless rear fog light http://forums.maxima.org/showthread.php?t=336888
How to convert Headlights 9004 to 9007 http://forums.maxima.org/showthread.php?t=312531
How to Perform Skyline Tail Light Mod (done to altezza tail lights) http://www.vqpower.com/v2/modules.ph...howpage&pid=14
How to Perform a Red/Clear Tail Light Conversion http://www.vqpower.com/v2/modules.ph...howpage&pid=34
How to Red Out 95-96 Tail Lights http://www.vqpower.com/v2/modules.ph...howpage&pid=41
How to Change Your Head Lights http://www.vqpower.com/v2/modules.ph...howpage&pid=47
How to Rewire Your 95-96 Clear Corners (and make them brighter) http://www.vqpower.com/v2/modules.ph...howpage&pid=50
How to Make AE Head Lights http://www.vqpower.com/v2/modules.ph...howpage&pid=52
How to Rewire Your Bumper Lenses http://www.vqpower.com/v2/modules.ph...howpage&pid=53
How to Rewire Your Fog Lights Independantly http://forums.maxima.org/showthread.php?t=256440
How to Make Your Own Angel Headlights http://www.geocities.com/jvxdriver/eagle_eyes.htm
How to Clear 97-99 Tails http://www.brianv.net/mods/taillights
How to Do a 97-99 Fog Light Rewire http://www.vqpower.com/v2/modules.ph...showpage&pid=6
Engine
How to replace a Water Pump http://forums.maxima.org/showthread.php?t=308680
How to Analyize/Reset a Check Engine Light http://forums.maxima.org/showthread.php?t=104931
How to Change Knock Sensor http://www.motorvate.ca/mvp.php/507
How to Change Engine Oil http://www.motorvate.ca/mvp.php/511
How to Change Engine Coolant http://www.motorvate.ca/mvp.php/502
How to Replace Power Steering Fluid http://www.motorvate.ca/mvp.php/702
How to Replace Fuel Pump http://vbxmaxima.8m.com/fuel%20pump.html
How to Install a Basic UDP http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/Underdrive%20Pulley.htm
How to troubleshoot EGR problems
http://img52.photobucket.com/albums/v158/evilBIGD/EGR/
How to replace drive belts
http://www.greghome.com/images/Maxim...DriveBelts.jpg
How to Change Your Spark Plugs http://www.vqpower.com/v2/modules.ph...howpage&pid=33
How to Install a Mevi (Middle Eastern Variable Intake)http://www.vqpower.com/v2/modules.ph...howpage&pid=40
How to Change Clutch Slave Cylander Hose http://www.vqpower.com/v2/modules.ph...howpage&pid=67
How to Remove/ Replace Your Power Steering http://www.motorvate.ca/mvp.php/702
How to Examine/Change Your Fuel Filter http://vbxmaxima.8m.com/fuelfilter.html
How to Trouble Shoot TPS (Throttle Position Sensor) Problems http://vbxmaxima.8m.com/tps.html
How to Re-Grease Starter http://www.motorvate.ca/mvp.php/516
How to Wire Your Cooling Fans For Manual Use http://forums.maxima.org/showthread.php?threadid=129181
How to Install a Pathfinder Throttle Body http://forums.maxima.org/showthread.php?t=257931
How to install a stillen SC - http://maxima.ericj.org/doc/scifd.pdf
How to change fuel injectors http://www.cardomain.com/memberpage/443899/2
How to change Thermostat - http://forums.maxima.org/showpost.ph...4&postcount=43
How to change timing chain tensioner
http://forums.maxima.org/showthread....t=timing+chain
Interior
How to Change your Hazard/Rear Defroster LEDs http://www.petah.org/maxima/hazard.htm
How to Change your Manual Climate Control LEDs http://www.petah.org/maxima/climate.htm
How to read your VIN http://www.pbase.com/cleanmaxx_brian/image/19276707
How to stop center pannel squeeks http://forums.maxima.org/showthread.php?t=326505
How to install shifter/e-brake boots http://forums.maxima.org/showthread.php?t=331338
How to remove your door panel (pics currently broken) http://forums.maxima.org/showthread....32#post2815832
How to Remove Guage Needles http://forums.maxima.org/showpost.ph...46&postcount=2
How to change window switches LEDs (new/improved link)
http://www.cardomain.com/memberpage/479058/3
How to make LED needles http://www.petah.org/maxima/gauge.htm
How to make an LED dome light http://www.petah.org/maxima/dome.htm
How to install autometer gauges http://vbxmaxima.8m.com/gauges.html
How To Change Guage Bulbs -
http://www.geocities.com/amixam69/nissan/dash/
also: http://www.richardjasaitis.com/MaximaDash.htm
How to Make Climate Control Lighting Blue http://www.z3d.com/maxima/blueclimate.html
How to Install an Auto-Dim Mirror http://www.fourthrock.com/maxima/mirrorinstall/
How to Change Gauge Cluster Lights http://www.geocities.com/amixam69/nissan/dash/
How to Change Color of the Clock http://forums.maxima.org/showthread....hreadid=207107
How to Change Your Ignition Switch http://forums.maxima.org/showthread....gnition+switch
How to Install I30 Interior Accessories https://maxima.org/shoptalk/sub_modi...t1/index.shtml
How to Always Illuminate Your Clock http://www.vqpower.com/v2/modules.ph...showpage&pid=8
How to Install Indiglo Gauges http://www.vqpower.com/v2/modules.ph...showpage&pid=8
How to Install LEDs For Rear Window Switches (original links)
http://www.geocities.com/multiplexor...edinstall.html
How to Maintain/Service Your Sun Roof http://www.vqpower.com/v2/modules.ph...howpage&pid=43
How to Repair Broken Sun Roof
http://forums.maxima.org/showthread....4&page=1&pp=40
How to Paint Dash Center Console Pieces http://www.vqpower.com/v2/modules.ph...howpage&pid=55
How to Install/Change In-Cabin Microfilter http://www.greghome.com/Greg's%20Garage/2002MaxSE/In-Cabin%20Microfilter%20Change.htm
Exterior
How to Make a Mesh Grill for a 97-99 http://www.vqpower.com/v2/modules.ph...howpage&pid=38
How to Install an "Ionic" Body Kit http://www.vqpower.com/v2/modules.ph...howpage&pid=51
How to make your door pillars the color of your car http://forums.maxima.org/showthread....6&page=1&pp=30
How to Debadge Your Maxima http://forums.maxima.org/showthread.php?t=258753
How to convert 95/96 to 97-99 Front end -
Bumper:
http://forums.maxima.org/showthread.php?threadid=46513
http://forums.maxima.org/showthread.php?threadid=17750
http://forums.maxima.org/showthread.php?threadid=88129
Headlights:
http://forums.maxima.org/showthread.php?threadid=21563
http://forums.maxima.org/showthread.php?threadid=89942
Grill:
http://forums.maxima.org/showthread.php?threadid=10646
Rear end:
http://forums.maxima.org/showthread.php?threadid=42806
http://forums.maxima.org/showthread.php?threadid=73032
How to make a mesh grill for 95-96 http://forums.maxima.org/showthread.php?t=275284
How to repair your broken sun roof http://forums.maxima.org/showthread....4&page=1&pp=40
How to paint your wheels (shown on stock rims) http://forums.maxima.org/showpost.ph...2&postcount=17
another one http://forums.maxima.org/showthread.php?t=446094
How To Install 2001 Mitsubishi Galant GTZ Spoiler http://forums.maxima.org/showpost.ph...19&postcount=1
How to Polish Your Rims
http://www.honda-tech.com/zerothread?id=804963
Exterior
Bumper:
Headlights:
Grill:
Rear end:
Brakes
How to break in brakes http://zeckhausen.com/bedding_in_brakes.htm
How to Change Front Brakes http://www.motorvate.ca/mvp.php/300
How to Fix Parking Brake http://www.motorvate.ca/mvp.php/303
How to Paint Your Calipers http://www.fourthrock.com/maxima/caliperpainting/
How to Install Stainless Steel Brakelines https://maxima.org/shoptalk/sub_modi...es/index.shtml
How to Add Speed Bleeders http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/SpeedBleeders.htm
Handling
How to install Koni adjustable struts http://vbxmaxima.8m.com/koni.html
How to Change Shocks
http://vbxmaxima.8m.com/shocks.html
How to Remove/Replace Your Front Wheel Bearing
http://www.motorvate.ca/mvp.php/704
How to Fix Your Front Strut Bearing
http://www.motorvate.ca/mvp.php/703
How to Install Front and Rear Strut Bars https://maxima.org/shoptalk/sub_modi...rs/index.shtml
How to Install Koni Front Inserts http://www.vqpower.com/v2/modules.ph...howpage&pid=10
How to Install ADDCO RSB http://www.vqpower.com/v2/modules.ph...howpage&pid=12
How to Measure Your Tires http://www.motorvate.ca/mvp.php/900
How to Change Shocks And Struts http://web.archive.org/web/200111091...x/springs.html
How to make a rear strut bar brace http://forums.maxima.org/showthread.php?t=321967
Handling
Exhaust
How to install y-pipe http://www.cardomain.com/member_page...=255278&page=3
How to Install a B Pipe http://greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/Courtesy%20B-Pipe.htm
Intake
How to Clean Throttle Body
http://www.motorvate.ca/mvp.php/517
How to Make/Install Intake
http://www.brianv.net/mods/filter
How to Install a Place Racing CAI
http://www.geocities.com/nismorg/Maxima/cai.html
How to Make a OSCAI
http://maxima.cardomain.com/memberpage/419549/5
How to Make Poorman's CAI/Hacked air box
http://forums.maxima.org/showthread.php?t=181899
2nd Link http://maxima.cardomain.com/memberpage/370660/7
Intake
How to Make a OSCAI
Drivetrain/ Transmission
How To change Motor Mounts http://forums.maxima.org/showpost.ph...2&postcount=10
How to cheaply improve manual shifter feeling http://forums.maxima.org/showthread.php?t=331517
How to Fix CV Joints http://www.motorvate.ca/mvp.php/401
How to Change/Replace Your Clutch http://www.motorvate.ca/mvp.php/801
How to Remove/Rebuild Your Tranny (5 Speed) http://www.motorvate.ca/mvp.php/805
How to Install a Short Throw Shifter http://www.vbxmaxima.8m.com/shifter.html
How to Install Hayden Transmission Cooler https://maxima.org/shoptalk/sub_modi...er/index.shtml
How to Convet Your Auto to 5 Speed (pretty serious and involved) http://www.vqpower.com/v2/modules.ph...howpage&pid=30
How to Install a Valve Body http://www.vqpower.com/v2/modules.ph...howpage&pid=60
Electrical
How to add an AUX input to your stock bose headunit
http://forums.maxima.org/showthread.php?p=4083400
How to fix a non-working Bose display, and trouble shoot general issues (95-96) http://madchef.5u.com/maxima/bose/fixes.html
How to replace 95-96 O2 sensors (upstream and downstream) http://forums.maxima.org/showpost.ph...2&postcount=24
How to activate the Low Washer Fluid light (for cars without cold/deluxe packages) http://www.cardomain.com/memberpage/259701/13
How to change alternator http://www.motorvate.ca/mvp.php/500
How to Fix Starter Noise http://www.motorvate.ca/mvp.php/516
How to make your cruise control always ready http://www.vqpower.com/v2/modules.ph...showpage&pid=4
and http://forums.maxima.org/showthread.php?threadid=37016
How to Install a Glass/Shock Sensor to Stock Alarm http://www.vqpower.com/v2/modules.ph...howpage&pid=13
How to Remove Your Top Speed Limiter http://www.vqpower.com/v2/modules.ph...howpage&pid=15
2nd link http://www.sprintmax.com/tails/bensecumod.htm
How to Remove Your Rear Speakers http://www.vqpower.com/v2/modules.ph...howpage&pid=16
How to Make Your Sun Roof One Touch Open http://www.vqpower.com/v2/modules.ph...howpage&pid=17
How to Make Your Wipers Variable Intermittent http://www.vqpower.com/v2/modules.ph...howpage&pid=19
How to Make Your Alarm Beep http://www.vqpower.com/v2/modules.ph...howpage&pid=39
How to dissasemble your Bose Headunit (95-96) http://madchef.5u.com/maxima/bose/bose.html
How to Add an Air Horn to Your Car http://web.archive.org/web/200111091...max/horns.html
How to set up Home Link http://forums.maxima.org/showthread.php?t=320939
Electrical
imported_Nismo_max
09-21-2015 07:24 PM
Violator
09-09-2015 10:14 AM
