Maxima Forums
Maxima Discussions
4th gen How to's
User Name
Remember Me?
Password
Register
Photo Gallery
FAQ
Timeslips
Members List
Calendar
Search
Today's Posts
Mark Forums Read
Visit the 4th Generation forum to ask specific questions or find out more about the 4th Generation Maxima.
Display Modes
10-07-2003, 04:49 PM
SXN
General 4th Gen How-To List
PM phenryiv1 with dead links!
Lights/Lighting
How to install strobe lights in your Clearance And/Or Bumper Lights
http://www.cardomain.com/memberpage/496421/7
and
http://www.rankmyride.com/?page=cars...ID=5714&pnum=2
How to make your clearance lights brighter
http://forums.maxima.org/showthread....64#post2904464
How To Make Tinted Tails
http://forums.maxima.org/showpost.ph...59&postcount=1
How to make all-red Tails
http://forums.maxima.org/showpost.ph...34&postcount=1
How to Smoke Corner/Signal Lights
http://www.maximafreak.com/bumper/
How to create a completely pointless rear fog light
http://forums.maxima.org/showthread.php?t=336888
How to convert Headlights 9004 to 9007
Leather Seat Back
How to Perform Skyline Tail Light Mod (done to altezza tail lights)
http://www.vqpower.com/v2/modules.ph...howpage&pid=14
How to Perform a Red/Clear Tail Light Conversion
http://www.vqpower.com/v2/modules.ph...howpage&pid=34
How to Red Out 95-96 Tail Lights
http://www.vqpower.com/v2/modules.ph...howpage&pid=41
How to Change Your Head Lights
http://www.vqpower.com/v2/modules.ph...howpage&pid=47
How to Rewire Your 95-96 Clear Corners (and make them brighter)
http://www.vqpower.com/v2/modules.ph...howpage&pid=50
How to Make AE Head Lights
http://www.vqpower.com/v2/modules.ph...howpage&pid=52
How to Rewire Your Bumper Lenses
http://www.vqpower.com/v2/modules.ph...howpage&pid=53
How to Rewire Your Fog Lights Independantly
02 sensors
How to Make Your Own Angel Headlights
http://www.geocities.com/jvxdriver/eagle_eyes.htm
How to Clear 97-99 Tails
http://www.brianv.net/mods/taillights
How to Do a 97-99 Fog Light Rewire
http://www.vqpower.com/v2/modules.ph...showpage&pid=6
Engine
How to replace a Water Pump
http://forums.maxima.org/showthread.php?t=308680
How to Analyize/Reset a Check Engine Light
Johnson Park pics
How to Change Knock Sensor
http://www.motorvate.ca/mvp.php/507
How to Change Engine Oil
http://www.motorvate.ca/mvp.php/511
How to Change Engine Coolant
http://www.motorvate.ca/mvp.php/502
How to Replace Power Steering Fluid
http://www.motorvate.ca/mvp.php/702
How to Replace Fuel Pump
http://vbxmaxima.8m.com/fuel%20pump.html
How to Install a Basic UDP http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/Underdrive%20Pulley.htm
How to troubleshoot EGR problems
http://img52.photobucket.com/albums/v158/evilBIGD/EGR/
How to replace drive belts
http://www.greghome.com/images/Maxim...DriveBelts.jpg
How to Change Your Spark Plugs
http://www.vqpower.com/v2/modules.ph...howpage&pid=33
How to Install a Mevi (Middle Eastern Variable Intake)
http://www.vqpower.com/v2/modules.ph...howpage&pid=40
How to Change Clutch Slave Cylander Hose
http://www.vqpower.com/v2/modules.ph...howpage&pid=67
How to Remove/ Replace Your Power Steering
How to Examine/Change Your Fuel Filter
http://vbxmaxima.8m.com/fuelfilter.html
How to Trouble Shoot TPS (Throttle Position Sensor) Problems
http://vbxmaxima.8m.com/tps.html
How to Re-Grease Starter
http://www.motorvate.ca/mvp.php/516
How to Wire Your Cooling Fans For Manual Use
I30/I35 question....
How to Install a Pathfinder Throttle Body
I'm hit, and pissed.
How to install a stillen SC -
http://maxima.ericj.org/doc/scifd.pdf
How to change fuel injectors
http://www.cardomain.com/memberpage/443899/2
How to change Thermostat -
http://forums.maxima.org/showpost.ph...4&postcount=43
How to change timing chain tensioner
What mod should i do next....looking for least expensive
10-08-2003, 10:00 PM
SXN
Interior
How to Change your Hazard/Rear Defroster LEDs
http://www.petah.org/maxima/hazard.htm
How to Change your Manual Climate Control LEDs
http://www.petah.org/maxima/climate.htm
How to read your VIN
http://www.pbase.com/cleanmaxx_brian/image/19276707
How to stop center pannel squeeks
'02 Maxima STS
How to install shifter/e-brake boots
http://forums.maxima.org/showthread.php?t=331338
How to remove your door panel (pics currently broken)
http://forums.maxima.org/showthread....32#post2815832
How to Remove Guage Needles
http://forums.maxima.org/showpost.ph...46&postcount=2
How to change window switches LEDs (new/improved link)
http://www.cardomain.com/memberpage/479058/3
How to make LED needles
http://www.petah.org/maxima/gauge.htm
How to make an LED dome light
http://www.petah.org/maxima/dome.htm
How to install autometer gauges
http://vbxmaxima.8m.com/gauges.html
How To Change Guage Bulbs -
http://www.geocities.com/amixam69/nissan/dash/
also:
http://www.richardjasaitis.com/MaximaDash.htm
How to Make Climate Control Lighting Blue
http://www.z3d.com/maxima/blueclimate.html
How to Install an Auto-Dim Mirror
http://www.fourthrock.com/maxima/mirrorinstall/
How to Change Gauge Cluster Lights
How to Change Color of the Clock
Where can I find maxima commercials to d/l?
How to Change Your Ignition Switch
99 max seats fit a 00?
How to Install I30 Interior Accessories
http://www.maxima.org/shoptalk/sub_m...t1/index.shtml
How to Always Illuminate Your Clock
http://www.vqpower.com/v2/modules.ph...showpage&pid=8
How to Install Indiglo Gauges
How to Install LEDs For Rear Window Switches (original links)
http://www.geocities.com/multiplexor...edinstall.html
How to Maintain/Service Your Sun Roof
http://www.vqpower.com/v2/modules.ph...howpage&pid=43
How to Repair Broken Sun Roof
Red Out Tails (96 Max)
How to Paint Dash Center Console Pieces
http://www.vqpower.com/v2/modules.ph...howpage&pid=55
How to Install/Change In-Cabin Microfilter http://www.greghome.com/Greg's%20Garage/2002MaxSE/In-Cabin%20Microfilter%20Change.htm
Exterior
How to Make a Mesh Grill for a 97-99
http://www.vqpower.com/v2/modules.ph...howpage&pid=38
How to Install an "Ionic" Body Kit
http://www.vqpower.com/v2/modules.ph...howpage&pid=51
How to make your door pillars the color of your car
Is The Rear Disk Brake Hardware Kit Necessary?
How to Debadge Your Maxima
Airbag Allen Key How to get one?
How to convert 95/96 to 97-99 Front end -
Bumper:
y-pipe installation, sockets?
Yo Ken
need some system advice
Headlights:
Tranny stuff
UPS dropped off a suprise for me..
Grill:
How to stop trunk vibration?
Rear end:
competition? Factory riced out, 304 hp BOOSTED focus
Can Life Be Any More Unfair!
How to make a mesh grill for 95-96
FnF max
How to repair your broken sun roof
How to paint your wheels (shown on stock rims)
http://forums.maxima.org/showpost.ph...2&postcount=17
another one
http://forums.maxima.org/showthread.php?t=446094
How To Install 2001 Mitsubishi Galant GTZ Spoiler
http://forums.maxima.org/showpost.ph...19&postcount=1
How to Polish Your Rims
http://www.honda-tech.com/zerothread?id=804963
10-08-2003, 10:06 PM
SXN
Brakes
How to break in brakes
http://zeckhausen.com/bedding_in_brakes.htm
How to Change Front Brakes
http://www.motorvate.ca/mvp.php/300
How to Fix Parking Brake
http://www.motorvate.ca/mvp.php/303
How to Paint Your Calipers
http://www.fourthrock.com/maxima/caliperpainting/
How to Install Stainless Steel Brakelines
http://www.maxima.org/shoptalk/sub_m...es/index.shtml
How to Add Speed Bleeders http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/SpeedBleeders.htm
Handling
How to install Koni adjustable struts
http://vbxmaxima.8m.com/koni.html
How to Change Shocks
http://vbxmaxima.8m.com/shocks.html
How to Remove/Replace Your Front Wheel Bearing
http://www.motorvate.ca/mvp.php/704
How to Fix Your Front Strut Bearing
http://www.motorvate.ca/mvp.php/703
How to Install Front and Rear Strut Bars
http://www.maxima.org/shoptalk/sub_m...rs/index.shtml
How to Install Koni Front Inserts
http://www.vqpower.com/v2/modules.ph...howpage&pid=10
How to Install ADDCO RSB
http://www.vqpower.com/v2/modules.ph...howpage&pid=12
How to Measure Your Tires
http://www.motorvate.ca/mvp.php/900
How to Change Shocks And Struts
http://web.archive.org/web/200111091...x/springs.html
How to make a rear strut bar brace
http://forums.maxima.org/showthread.php?t=321967
10-08-2003, 10:09 PM
SXN
Exhaust
How to install y-pipe
http://www.cardomain.com/member_page...=255278&page=3
How to Install a B Pipe http://greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/Courtesy%20B-Pipe.htm
Intake
How to Clean Throttle Body
http://www.motorvate.ca/mvp.php/517
How to Make/Install Intake
http://www.brianv.net/mods/filter
How to Install a Place Racing CAI
http://www.geocities.com/nismorg/Maxima/cai.html
How to Make a OSCAI
http://maxima.cardomain.com/memberpage/419549/5
How to Make Poorman's CAI/Hacked air box
G-Tech Pro Competition settings - engine redline
2nd Link
http://maxima.cardomain.com/memberpage/370660/7
10-08-2003, 10:32 PM
SXN
Drivetrain/ Transmission
How To change Motor Mounts
http://forums.maxima.org/showpost.ph...2&postcount=10
How to cheaply improve manual shifter feeling
http://forums.maxima.org/showthread.php?t=331517
How to Fix CV Joints
http://www.motorvate.ca/mvp.php/401
How to Change/Replace Your Clutch
http://www.motorvate.ca/mvp.php/801
How to Remove/Rebuild Your Tranny (5 Speed)
http://www.motorvate.ca/mvp.php/805
How to Install a Short Throw Shifter
http://www.vbxmaxima.8m.com/shifter.html
How to Install Hayden Transmission Cooler
http://www.maxima.org/shoptalk/sub_m...er/index.shtml
How to Convet Your Auto to 5 Speed (pretty serious and involved)
http://www.vqpower.com/v2/modules.ph...howpage&pid=30
How to Install a Valve Body
http://www.vqpower.com/v2/modules.ph...howpage&pid=60
Electrical
How to add an AUX input to your stock bose headunit
http://forums.maxima.org/detailing/181250-maxima-org-detailing-product-review-thread-post4083400.html
How to fix a non-working Bose display, and trouble shoot general issues (95-96)
http://madchef.5u.com/maxima/bose/fixes.html
How to replace 95-96 O2 sensors (upstream and downstream)
http://forums.maxima.org/showpost.ph...2&postcount=24
How to activate the Low Washer Fluid light (for cars without cold/deluxe packages)
http://www.cardomain.com/memberpage/259701/13
How to change alternator
http://www.motorvate.ca/mvp.php/500
How to Fix Starter Noise
How to make your cruise control always ready
http://www.vqpower.com/v2/modules.ph...showpage&pid=4
and
Fast & Furious is Avail for Download
How to Install a Glass/Shock Sensor to Stock Alarm
http://www.vqpower.com/v2/modules.ph...howpage&pid=13
How to Remove Your Top Speed Limiter
http://www.vqpower.com/v2/modules.ph...howpage&pid=15
2nd link
http://www.sprintmax.com/tails/bensecumod.htm
How to Remove Your Rear Speakers
http://www.vqpower.com/v2/modules.ph...howpage&pid=16
How to Make Your Sun Roof One Touch Open
http://www.vqpower.com/v2/modules.ph...howpage&pid=17
How to Make Your Wipers Variable Intermittent
http://www.vqpower.com/v2/modules.ph...howpage&pid=19
How to Make Your Alarm Beep
http://www.vqpower.com/v2/modules.ph...howpage&pid=39
How to dissasemble your Bose Headunit (95-96)
http://madchef.5u.com/maxima/bose/bose.html
How to Add an Air Horn to Your Car
http://web.archive.org/web/200111091...max/horns.html
How to set up Home Link
The Sexiest sedan starts at sixty five grand
Previous Thread
Next Thread
Show Printable Version
Email this Page
Display Modes
Linear Mode
Switch to Hybrid Mode
Switch to Threaded Mode
Posting Rules
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Trackbacks
are
On
Pingbacks
are
On
Refbacks
are
Off
07:46 PM
-- Default Style
---- Maxima.org Dark Style
Advertising
Terms of Use
Privacy Policy
Jobs
Maxima Forums
Archive
Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO
3.2.0 RC7
