problem starting
Old 12-11-2007, 10:06 PM
Olezhka's Avatar
problem starting
It'll turn over, but won't start right away. It was fine before I changed the battery the other day. What's going on?
Olezhka is offline
Old 12-12-2007, 11:13 AM
Olezhka's Avatar
Injectors? Plugs? What can it be? And why did it start right after i put in a new battery?
Olezhka is offline
Old 12-12-2007, 11:15 AM
19Maximus98's Avatar
Please do a simple search for "hard starting" "difficult starting" you will find a ton of information. I know becuase I had similar issues and searched the forums and found an answer.
19Maximus98 is offline
Old 12-12-2007, 11:17 AM
Didn;t mean to sound like a *****, but too often people post questions that they can answer themselves just by doing a search on the forums.
Now your problem, Did you replace the battery with the correct replacement? How about your terminals, is the negative cable in bad shape? If so change it for $6. Try grounding your starter and or Tranny. I did those things and it solved my problem.
Old 12-12-2007, 01:06 PM
TunerMaxima3000's Avatar
SEARCH
loose connections (terminals)
Poor ground(s)
TunerMaxima3000 is offline
Old 12-12-2007, 01:23 PM
Olezhka's Avatar
I tried searching and didn't find much. That's why I made this post.
Could it really ba a bad connection? The starter works fine, I doubt that it's a connection problem. The engine turns over, but it won't fire. If I try it again it starts fine. It sounds more like a spark problem to me.
I just thought that maybe this is a common problem and some people might know what to do.
I guess I'll just go search google.
Thanks anyway
Olezhka is offline
Old 12-12-2007, 02:34 PM
oVeRdOsE's Avatar
Thanks anyway
What?!?, we got like 2-3 post a month on that subject....
The search fonction doesnt work proprely, I got only two results with "starting problem".
Could be more than one thing.
My guess, you connection, this engine's very tricky on electricity issues.
oVeRdOsE is offline
Old 12-12-2007, 02:54 PM
Thanks anyway
you searched?
http://forums.maxima.org/showthread.php?t=543790
http://forums.maxima.org/showthread.php?t=338918
http://forums.maxima.org/showthread.php?t=545127
http://forums.maxima.org/showthread.php?t=544748
and yes of course it could be a bad connection.
Old 12-12-2007, 03:05 PM
Olezhka's Avatar
Thanks for the links.
I did search, but I didn't get a lot of results, most were crap. I tried typing in different combinations of words too, but I guess I was just typing in the wrong stuff.
Olezhka is offline
Old 12-12-2007, 04:14 PM
just keep in mind searching involves more than typing in the search bar, it also includes scanning through all the recent threads for similar issues (this works!)
There does seem to be a problem with the free search though, its bringing up next to no results for very common issues.
matts95max
09-09-2023 01:52 AM
sctludwig
09-01-2022 01:32 PM
mvm062
11-30-2020 09:00 AM
trungg86
09-04-2015 04:58 AM
dcardello
09-03-2015 11:44 PM
Quick Reply: problem starting
