Add to crazy97's post : "Starting problem"
Old 11-16-2007, 02:51 PM
oVeRdOsE's Avatar
Hi,
since 2 years now I changed my tranny and get starting problem (5-10 sec to start). I read and follow and install exactly crazy97's gounding kit.
Wasn't the problem. So, i decided to remove all the big screws engine/tranny. They're paint to prevent the rust....
So , I sand every single screws (even the tread) , put dielectric grease, sand the tranny parts and inside the tread AND IT STARTS like a new.
Conclusion : Even if I've the grounding kit, the electricity cant pass trow the tranny to the engine block, because it was too resistive; the grounding kit was putting all the power back to the battery(kind of loop). The tranny need to work with the engine on every points. Not just under and on the starter. (btw my tranny was plugged also on the oem engine ground)
Do it, takes me 20 minutes.
Good luck
oVeRdOsE is offline
Old 11-16-2007, 03:08 PM
crazy97's Avatar
Hey glad it worked. It makes sense.I added it in the link on the first page...Did you have any leaking problems after all the screws were removed and replaced?
crazy97 is offline
Old 11-16-2007, 03:23 PM
oVeRdOsE's Avatar
No leaking, because I did it one by one. So the seal didnt move.
oVeRdOsE is offline
Old 11-16-2007, 05:48 PM
andrei3333's Avatar
cant you just put a new ground on the tranny to the frame ? also sading down both contact points ?
i mean whats the deal with the actual tranny bolts here ?
andrei3333 is offline
Old 11-16-2007, 06:14 PM
oVeRdOsE's Avatar
It can work for some one, but I tried it and nothing. Like I said, I suppose that the tranny need to be ground on the block.
Just the grounding kit help, but it makes a loop and return directly to the battery.
If you have no contact at all with the block ( because of paint or corrosion) the grounding kit isnt enough. Like my case (rare).
oVeRdOsE is offline
Old 11-16-2007, 06:34 PM
andrei3333's Avatar
things is that i have electrical problems of myself that i cannot track down for the last 3 months or more
i have installed a new battery, starter, alternator, active tuning grounding kit, and this weekend i will put a new 4 gauge ground wire from the starter to the frame and from the tranny to the frame
i hope it helps, but my car never left me stranded - just shows the ! and Battery light randomly for no reason
Old 11-16-2007, 09:54 PM
crazy97's Avatar
cant you just put a new ground on the tranny to the frame ? also sanding down both contact points ?
Yes
i mean whats the deal with the actual tranny bolts here?
They have paint on them and don't conduct electricity very well is my guess.
crazy97 is offline
Old 11-16-2007, 10:55 PM
No more Maximas...
pmohr's Avatar
What seal? Are you talking about the bellhousing to block bolts?
pmohr is offline
Old 11-24-2007, 05:30 PM
hermtm2's Avatar
I made 5 new grounds as you guys said. It still has a starting problem.
hermtm2 is offline
JRod28
12-29-2023 09:56 PM
Slamrod
09-03-2015 07:38 PM
305head
08-26-2015 09:03 PM
FlaMark
08-21-2015 11:06 AM
mikekay
08-10-2015 12:52 PM
Quick Reply: Add to crazy97's post : "Starting problem"
