10-29-2007, 07:13 PM
Knocking and Pinging
My '03 maxima knocks and pings pretty severely at 2K RPM, especially when I am going up hill or giving light throttle. Is this common and is there a common fix? Thanks.
10-29-2007, 07:47 PM
Pinging
I fixed it with one heat range colder plugs and Sunoco Ultra '94.
Joe.
10-29-2007, 07:49 PM
Quote:
Joe.
 new NGK plat spark plugs and premium octane should take care of it
10-29-2007, 07:51 PM
3-Peat!!!!!
take care of your car and use the proper fuel...
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
 O2 Sensor Locations and Corresponding Codes
10-29-2007, 09:44 PM
Certified Hooptie
 On cooler plugs/catch can/91+.
10-29-2007, 11:50 PM
Has your car had the 17* timing change? If so this may be the culprit. Should be an easy fix by using prelium gas and colder spark plugs.
10-30-2007, 09:28 AM
3-Peat!!!!!
Quote:
you should use premium fuel regardless
__________________
06 Mazda 6
10-30-2007, 10:46 AM
I always use premium fuel and the problem was still there.
Did plugs when i installed my headers and its gone now... or maybe i just cant hear it from the loud exhaust??
10-30-2007, 10:48 AM
Certified Hooptie
Did you happen to go to a cooler heat range on the plugs?
10-30-2007, 11:55 AM
Just Bosh Platinum +2
(yes i know everybody hates Bosch)
10-30-2007, 02:09 PM
I seem to have the same knocking problem. Thinking of going to NGK iridium one step cooler. Trying to get Nissan to talk to me about it but all I get is that they run the fuel very lean and the timing advanced for economy. Any way to use a bit more fuel in the 2k-3k rpm range to cool things off?  Nissan tech says we can retard the timing a bit but will loose power that way. What's with the 17* timing update?
10-30-2007, 09:45 PM
Quote:
Search
10-30-2007, 09:47 PM
3-Peat!!!!!
*NOOBIES* - The "I AM NEW HERE BUT HAVE A QUESTION" thread
__________________
06 Mazda 6
10-30-2007, 09:58 PM
Quote:
Originally Posted by soonerfan
Your too nice.
10-30-2007, 10:34 PM
3-Peat!!!!!
Your too nice.
i didnt give him the answer...just the link to the proper place to ask the question.
__________________
06 Mazda 6
10-30-2007, 11:33 PM
weird how its a different experience for everyone. i run my car pretty lean under high throttle (im at -10 on the vafc for everything over 4100) and i dont ever get pinging, even with 17* timing. in fact, the only time ive gotten pinging for the whole life of the car is when the dyno guy went 15.0 on the dyno after like 4 runs
10-31-2007, 01:55 PM
I gotta ticking initially when starting then, it goes away. Low rpm tapping is there and I use premium fuel. I need new plugs and im i need to definitely do the timing advance!
What is the favorable heat range on the cooler plugs that have been mentioned??
If i turn the radio up the problem never seems to be there!
10-31-2007, 04:01 PM
What is the drawback using colder plugs? Power loss, mileage, etc.?
10-31-2007, 04:33 PM
Not new, I re-registered.
Quote:
Originally Posted by Wheelie King
My '03 maxim knocks and pings pretty severely at 2K RPM, especially when I am going up hill or giving light throttle. Is this common and is there a common fix? Thanks.
Same thing happened to me after I put in a couple (maybe more) tanks of 87 octane gas. It went away as soon as I put in the higher octane.
10-31-2007, 05:00 PM
I agree with the getting better octane gas, I'd replace the stock spark plugs while your at it.
10-31-2007, 05:45 PM
Quote:
 i thought NGK plats were the best option for us
10-31-2007, 06:09 PM
www.carbuychoice.com
Search
there are way too many discussions on this subject
__________________
2002 Nissan Maxima SE
6MT Majestic Blue
Internet Manager
Car Buy Choice.Com
Exclusive Full Service Internet Auto Dealer
Buy Your Next Vehicle At Internet Wholesale
(800) 290-0660
10-31-2007, 06:26 PM
I know. I clicked the link for the hell of it.
I was being sarcastic.
10-31-2007, 07:00 PM
I use super unleaded/93 octane gas.
I checked my plugs this evening. I currently am using NGK R PLFR5A 11. I think NGK PLFR5A 11 are stock. I'm not sure what difference the "R" makes. I don't think it's a colder plug. As I understand plugs, a colder one is NGK LFR6AIX 11. Is that what people are using for colder plugs in their maximas?
11-03-2007, 10:29 AM
01 Maxima SE, 5-spd
My 01 had the pinging problem (but no knocking) and it was totally unrelated to plugs/coils/fuel. Mine was a MAF (but I don't know 5.5 gen's behavior with their faulty MAF).
11-03-2007, 09:31 PM
I added an oil catch can and changed my front 3 plugs. I'll change the other 3 next week. I also added some oil, a bottle of injector cleaner and reset the ECU. I'm driving it hard thinking that thousands of miles of highway driving in 6th gear may have resulted in weak ECU signals. From what I can tell, the pinging is a little better. We'll see once I replace the rest of the plugs run the car for a while.
06-13-2008, 12:37 AM
