HomeDepot: PCV Blowby Oil Catch Reservoir
Old 07-14-2005, 11:06 AM
retired moderator
irish44j's Avatar
Although there has been a thread on this for the 3.5L, I hadn't seen one on a 3.0 yet, at least not written up. So, for about $15 in materials, decided to make one from Home Depot supplies (surprise, surprise). Shiny, pretty "name brand" catch cans can be bought on ebay or performance shops for $50-100, but what's the fun in that!?!?
So....here it is, and a quick writeup:
Materials: Air compressor in-line air/oil filter/reservoir, about 3' of 7/16 hose, a few hose clamps, and the correct fittings. Oh, and a piece of metal to make a bracket with.
As you can see, it is mounted in-line PCV valve>hose>reservoir>hose>intake manifold is the direction it goes in. I bent a steel L-bracket and secured it to one of the intake bracket bolts - seems to be secure.
I have also seen this done using a Fram G3 fuel filter - that is the way alot of Subaru guys do it. I decided to go the above route, but got one of the G3 filters just to mess with also.
As to results....just did it, so no oil buildup, but if you rev the engine under the hood to high rpms, you can see a fine mist of oil getting deposited into the clear reservoir, so looks like it's doing its job.
For those who don't know, this is meant to "intercept" the oil that comes through the PCV valve and is normally routed to the intake manifold, where it gunks up things, burns up, or reduces fuel octane (oil+fuel=reduced octane).
BTW, credit to the 3.5 guy who did it this way first (don't recall who it was)
so, some pics of course:
the Fram filter, just for reference
irish44j is offline
Old 07-14-2005, 11:22 AM
I Know Kwaliti
igzy's Avatar
Nice work Irish!!!
igzy is offline
Old 07-14-2005, 11:25 AM
GBAUER's Avatar
So I see you've been busy at your job again. I want to see it this weekend. I'll find ya, you post-whoring bish!
Good work. Can't wait to check it out.
GBAUER is offline
Old 07-14-2005, 11:31 AM
retired moderator
irish44j's Avatar
I don't have the roof rack on right now, so I don't think you'll be able to find me
irish44j is offline
Old 07-14-2005, 12:59 PM
Cletus
SoonerFan's Avatar
sweet josh. you gonna help me do mine? should reduce my oil burning problem.
SoonerFan is offline
Old 07-14-2005, 01:05 PM
jjames's Avatar
wouldn't it be easier, and cheaper, to just use the filter?
jjames is offline
Old 07-14-2005, 01:08 PM
Cletus
SoonerFan's Avatar
your arent filtering the oil...just storing it and preventing it from going into the intake manifold
Old 07-14-2005, 01:13 PM
jjames's Avatar
don't they kind of serve the same purpose though? seriously, i really don't know. either way, i think it's a cool idea. hell, i might even do it.
jjames is offline
Old 07-14-2005, 01:16 PM
I'm needing a caw
Jeff92se's Avatar
If you just use the filter, I assume you just install it inline and be done with it?
Jeff92se is offline
retired moderator
irish44j's Avatar
Yes, the filter was about $4, while the other pieces were a little more. BUT, the way I set it up, I can empty it periodically when it fills up. Using the fuel filter, I would have to buy a new one every time it filled up (probably every few months).
Either way would work, I just didn't feel like doing the fuel filter in-line...
irish44j is offline
Old 07-14-2005, 01:18 PM
retired moderator
irish44j's Avatar
yep....the only issue I can think of is that if the filter is not situated correctly, the oil could pour out one end -either back to the PCV or into the IM. The way I have it setup, the oil collects in the bottom and cannot possibly flow back. Like I said, either way works though ....
irish44j is offline
jjames's Avatar
in other words, installing an inline filter is just too damn easy.
good work.
jjames is offline
retired moderator
irish44j's Avatar
we'll have to get a gallon-sized filter for you
irish44j is offline
Old 07-14-2005, 01:19 PM
I'm needing a caw
Jeff92se's Avatar
I suppose in the extreme case. I would think the paper would just soak up the oil and keep it in one place. At least until there's enough oil to saturate and cause it to drip.
Jeff92se is offline
Old 07-14-2005, 01:21 PM
Kevlo for President
Kevlo911's Avatar
I have one of these on the 3.0 . Never made a write up. Krismax told me how to do it last year...
Kevlo911 is offline
Old 07-14-2005, 01:32 PM
GBAUER's Avatar
Think they make a 5 gallon version?
Oh, and I know what you look like. I'll find you next to the dumpster!
GBAUER is offline
Old 07-14-2005, 06:01 PM
retired moderator
irish44j's Avatar
no...that would be the "jason" area...I'm not allowed over there
irish44j is offline
Old 07-25-2005, 06:44 AM
spirilis's Avatar
Ah, sweet. Reminds me, I need to change my PCV valve (and the in-tank fuel filter again while I'm at it... sitting at 113K mi now)
spirilis is offline
Old 07-25-2005, 12:17 PM
seemymaxima's Avatar
Hay guy's i have a 2001 maxima with 53.000 miles runs great should i be concerned about this
seemymaxima is offline
Old 07-25-2005, 12:22 PM
irish44j does this happen to all 2000-2001 models
Old 07-25-2005, 02:22 PM
retired moderator
irish44j's Avatar
it happens on all cars out there that are equipped with a PCV valve (pretty much ALL cars)..the pcv is there specifically to vent oil vapors from the crankcase and burn it up in the IM. It doesn't hurt the car, per se, but certainly doesn't help it!
irish44j is offline
Old 07-25-2005, 02:47 PM
teamsinister's Avatar
Great writeup I am going to do this one tonight
teamsinister is offline
Old 07-25-2005, 07:13 PM
NOCturnalI30's Avatar
What if your still using the factory intake box???
NOCturnalI30 is offline
Old 07-26-2005, 04:14 PM
MDeezy's Avatar
Wow excellent advances for our cars, gotta add this under the hood
MDeezy is offline
Old 07-27-2005, 07:08 PM
Seoul Man
spiromax's Avatar
You find another place to mount the filter and run the lines...
spiromax is offline
Old 07-30-2005, 03:42 PM
MDeezy's Avatar
Loving this idea and will add this to my car next a week along with some other maintiance.
I'm a little scketchy on the write up and have a few questions:
4th gen Stock Intake.
I'll need:
One Oil reserve case
(http://www.lowes.com/lowes/lkn?actio...FA106&pad=true)
Two Of these
Two hose clamps
And 3feet of the 7/16 hose - Is there a more techincal term for that or just say that to any home depot employee and they should know what i'm talking about?
Then how exactly is the installation done?
MDeezy is offline
Old 07-30-2005, 03:55 PM
Turk's Avatar
Whats the benifits of using this setup?
Turk is offline
Old 07-30-2005, 03:58 PM
MDeezy's Avatar
less oil burned in the intake.
MDeezy is offline
Old 07-30-2005, 04:11 PM
Mauja He Mauja
ZIPPIN's Avatar
nice work irish. where did you buy the Air compressor ??
ZIPPIN is offline
Old 07-31-2005, 10:18 AM
Jackboot's Avatar
do you have a picture of where exactly the pcv valve is???
Jackboot is offline
Old 07-31-2005, 10:37 AM
retired moderator
irish44j's Avatar
look at the pic at the top. Note the hose that attaches in the MIDDLE of the TOP of the photo (it weaves down to the reservoir). See where it attaches? Now, originally the hose that goes from that particular place goes directly to the PCV valve...just follow the hose. The PCV is basically just below the VIAS actuator assembly.
irish44j is offline
Old 07-31-2005, 07:36 PM
Jackboot's Avatar
welp, i went to home depot and got all the crap to do this today and installed it. Pretty easy and it gave my bored *** something to do. I cant wait to see how much oil I collect!! thanks for the info irish, yet another thing that ive seen you done and then went out and did it myself. Keep it up man.
Jackboot is offline
Old 08-29-2005, 01:39 PM
chr0nos's Avatar
does any1 have a pic of where the pcv valve is on a 3.5 litre?
i cannot find it for ****, and the mechanic i went to must be handicapped. he did not see it either. unless it's under the engine cover, which he did not take off.
p.s. maybe some1 has a good desciption of where the pcv valve is, not nesessarily a pic.
chr0nos is offline
Old 08-29-2005, 01:58 PM
Seoul Man
spiromax's Avatar
Do you know where the intake manifold is? If not, follow your intake up past the MAF sensor until you reach the throttle body. That big thing that the throttle body is attached to is the intake manifold. The throttle body should be bolted on to it on the driver's side of the vehicle. Now go around to the passenger side of the car and look at the side of the intake manifold closest to the rear of the engine bay. You should see a short black rubber hose attached to a small metal tube on the intake manifold. That short black rubber hose goes down to the PCV. The hose connector on the PCV should be a piece of yellowish plastic.
spiromax is offline
Old 08-29-2005, 02:41 PM
Kevlo for President
Kevlo911's Avatar
Man I think my filter is fcked up. The oil level doesnt seem like it rises anymore.
Kevlo911 is offline
Old 08-29-2005, 05:05 PM
big_bogus's Avatar
Nice!!
I will keep an eye on mine. $15 fix is not too shabbly at all, plus it doesn't look bad at all.
big_bogus is offline
Old 08-30-2005, 05:18 AM
chr0nos's Avatar
thanks spiromax, i will mess with this tonite after work.
chr0nos is offline
Old 08-30-2005, 05:35 AM
Puppetmaster's Avatar
From the Stickies:
http://forums.maxima.org/showthread.php?t=265970
Puppetmaster is offline
Old 08-30-2005, 08:04 AM
I Know Kwaliti
igzy's Avatar
This is some good stuff. I installed the oil-separator 3 days ago and there is already some oil collected there! I used 3/8" hose and an inline separator, slightly different than Irish's... Will post a pic later...
igzy is offline
Old 08-30-2005, 11:00 AM
MAXGXE's Avatar
Air Compressor?
I think this was asked but maybe I missed the reply air compressor???? what is this and can it be seen from pics and is there any wiring involved? by the way I know what an actual air compressor is.
MAXGXE is offline
Quick Reply: HomeDepot: PCV Blowby Oil Catch Reservoir
