OEM Electrical System Upgrade I of II: OEM Ground Wire Upgrade (HOW-TO)
Old 08-25-2006, 09:16 PM
SHIFT_om nom nom nom
Metal Maxima's Avatar
This is the second section of my electrical system upgrade. You can read the first part, how to upgrade the OEM ground wire, here.
This how-to will be covering the details on how to perform the upgrade known as the 'Big Three'. Essentially, it will yeild the following:
1) Reduced dimming and smaller voltage drops
2) More stable voltage and better current flow
3) Less strain on your vehicle's charging system
The BIG THREE consists of:
(1) Battery negative to chassis
(2) Alternator to battery positive
(3) Engine Block to chassis
...it essentially does the same thing as a conventional grounding kit, however it does so in a different fashion. I am not a big fan of grounding kits as I prefer this method. People will argue this one way or another, but I swear by this. So, let's get started!
TOOLS/SUPPLIES
10mm Socket
12mm Socket
Ratchet
10ft. of 1/0AWG Power Cable
3 1/0AWG Ring Terminals
1 1/0AWG Fuse Terminal w/ 300-amp fuse
STEP I - BATTERY NEGATIVE TO CHASSIS
Simple enough. We are going to be making an attachement from the negative terminal of the battery to the chassis. If you peek behind the battery you will see a good place to plant the wire.
Remove the bolt with your 10mm socket and sand away the spot to bare steel. After that, attach about a 1-ft. length of wire to one of your terminals, crimp, and bolt everything back together.
STEP II - BATTERY POSITIVE TO ALTERNATOR POST
Alright, this one is a bit more tricky. You are going to need about 5ft of wire split into two equal 2.5ft. lengths. We are going to be attaching the wire to the battery positive to a fuse terminal, then fuse terminal to alternator post.
You can find the alternator just to the outside end of the engine block on the passenger side. Look for a rubber boot covering a bolt. That's your alternator post. We'll start there. Remove the bolt using a 12mm socket.
Attach one crimped end of the 1/0AWG wire to the bolt, then screw everything back together.
Take the lead attached to the alt. post and run this to the fuse. Take the other length of wire and run this from the opposite end of the fuse and lead it to the battery. We're almost done!
Metal Maxima is offline
Old 08-25-2006, 09:21 PM
STEP III - ENGINE BLOCK TO CHASSIS
The final step is simple enough. Start off by locating a spot where you want to land the lead on the chassis. I chose an empty bolt hole located by the engine block. Sand away as we have done before.
Next, simply ground this to the engine block. I chose one of the 10mm bolts located on the side of the block. You can choose just about anywhere on the block; for instance, you will see two grounding points on top of the block. Golden rule with grounding wires is to keep them as short as possible, so just keep that in mind when doing this...
...and now you're done! Here's a shot of the battery when all is said and done...pretty bada'ss if I say so myself!
Old 08-25-2006, 09:31 PM
Oh, and I want to make sure I thank Nilesh (djfrestyl) for giving me this suggestion.
Old 08-25-2006, 09:50 PM
I R The Law
The Law's Avatar
HOLY CRAP!!!!!! hows the start up?
The Law is offline
Old 08-25-2006, 09:52 PM
Good! I can't say there's this 'monstrous' change, but I am going to wait until I do the Big 3 in addition to this before I weigh in with the final verdict.
Old 08-25-2006, 10:00 PM
I R The Law
The Law's Avatar
big 3?? im lost about that....is there a thread on that?
The Law is offline
Old 08-25-2006, 10:04 PM
Not yet.
Old 08-25-2006, 10:10 PM
wat
AceofSpds's Avatar
Good write up metal... being the impatient and curious orger as I am, whats part 2
AceofSpds is offline
Old 08-25-2006, 10:19 PM
BLK2BLU's Avatar
There was in the audio forum a few months ago. It also had a link to another forum explaining in detail about how it worked.
BLK2BLU is offline
Old 08-25-2006, 10:23 PM
I R The Law
The Law's Avatar
thanks. i guess ill try and look it up when i have sometime and if i dont forget.
The Law is offline
Old 08-26-2006, 04:44 AM
You embarrass me.
zero2sixtyZ's Avatar
I've known about the Big 3, and have yet to do them... but your how-tos give me ambition to do them now because, well... Metal Maxima told me to...
Thanks man.
zero2sixtyZ is offline
Old 08-26-2006, 05:02 AM
Jfree's Avatar
Hey, I pm'ed on the car audio site and asked if you had done the big 3 on your Max some time ago, I guess I got my answer. Anyways, I have done the big 3 on my Max, I haven't had the amp tested to see how many volts I am getting yet. I didnt replace the stock ground, just added on to it, but it Im gonna yank it out soon as I get a battery terminal. I used 1/0 Stinger Hpm wire for the job.
I have noticed better cranking after doing the big 3, I have yet to see if my lights dim from my system anymore, since my sub amp is being repaired. Pics are on CarAudio.com in the electrical system forums.
http://www.caraudio.com/forum/showth...&highlight=big
Excuse my ghetto terminals, I was broke that day so no Stinger terminal!
Jfree is offline
Old 08-27-2006, 05:30 PM
Suspension Yoda
djfrestyl's Avatar
Looks good to me. I really need to get my a$$ in gear and do this. I have some knu 1/0 sitting aorund too.
Dan, if you want to clean it up even MORE, use electrical tape as your "ring terminal boot" instead of the red/black vinyl ones, which don't hold up very well under the engine bay.
djfrestyl is offline
Old 08-27-2006, 06:36 PM
Yeah, I was going to do that, but I am going to hit that up with some colored loom and tape it...that'll probably happen sometime during the spring.
D'amn straight you need to get this done!
Old 08-31-2006, 05:15 PM
TunerMaxima3000's Avatar
Question, isn't it better to ground the battery to the chassis? or should you ground the battery to the block and then from the block to the chassis?
TunerMaxima3000 is offline
Old 07-23-2007, 09:50 PM
Trurida18's Avatar
hey would any one have happened to COLLECTED those photos that Metal Maxima posted when he did the HOW TO write up?
Trurida18 is offline
Old 11-20-2007, 11:24 PM
eK9aT10pSi's Avatar
up for pix
eK9aT10pSi is offline
Old 11-21-2007, 05:04 AM
Suspension Yoda
djfrestyl's Avatar
Stop wasting your time.
Can this thread be locked?
Old 11-21-2007, 05:11 AM
Droppin logs
D-Bo's Avatar
RIP Dan...
D-Bo is offline
Old 11-21-2007, 06:12 AM
Professor's Avatar
what pics ?
Professor is offline
Old 04-05-2008, 11:13 PM
Suspension Yoda
djfrestyl's Avatar
Oh, why thank you so much! You've solved so many member's problems with your one single post!!
Old 04-05-2008, 11:43 PM
choiiiiiiiiiii's Avatar
Originally Posted by dc_maxima
REPLACE UR GROUNG CABLE... IT WILL SOLVE ALL UR ELECTRICAL PROBLEMS!!!!!!! BEST GROUND IS UR TRANNY MOUNT
http://forums.maxima.org/showthread.php?t=550035
hey buddy, you got four more posts to go till you hit 15!!! you're almost there!!!
choiiiiiiiiiii is offline
Old 01-24-2009, 05:11 PM
The Golden One
IlyaK's Avatar
Can someone please rehost these pictures? I'd appreciate it.
And yes, I am bumping an old thread. If you don't like it...too bad.
IlyaK is offline
Old 01-24-2009, 06:14 PM
Done and done. Let me know if you have any questions!
Old 01-24-2009, 06:17 PM
FUUUUUUKKKKKKK
Not only did I delete the original content, I posted the wrong thread!!!!
THIS IS FOR BIG THREE NOT GROUNDING CABLE
Old 01-24-2009, 06:19 PM
The Golden One
IlyaK's Avatar
Wait hold on...
This thread now has the same pics as this thread: http://forums.maxima.org/audio-elect...other-how.html
I was looking specifically for the pictures of the OEM ground wire.
EDIT: Just noticed your post above mine. Oops. The admins should have a backup...maybe they can backup an individual thread. I don't know if VBulletin allows that though.
IlyaK is offline
Old 01-24-2009, 09:00 PM
Wait hold on...
I just posted to see if the admins have access to restore the file. Fingers crossed.
Anyway, it's pretty simple. If you pull your battery out you'll see an 8AWG wire connected to the chassis with what I think is a 12mm bolt and a metal wire clip. All you simply need to do is removed the clip, the bolt, and replaced with a better wire. Piece o' cake.
D'amn I'm pissed for having done this to the thread.
Old 01-24-2009, 09:13 PM
The Golden One
IlyaK's Avatar
Sorry for causing you to.
Thanks for the explanation though. I plan on doing this soon. Along with the big three. Thanks.
IlyaK is offline
Old 01-24-2009, 09:49 PM
Meh, guns don't kill people...
GL and please let me know if you have any other questions.
Old 01-27-2009, 04:35 PM
dewd's Avatar
another awesome writeup i must say
ive been doing plenty of reading today!!!
dewd is offline
Old 01-27-2009, 07:45 PM
Suspension Yoda
djfrestyl's Avatar
Glad to hear you're reading. It prevents useless unnecessary redundant threads.
Slamrod
04-10-2016 05:24 PM
JMag90
08-25-2015 09:17 AM
MaximaDrvr
08-19-2015 08:20 PM
doobadoo
08-15-2015 06:43 PM
bassmann
08-03-2015 07:53 PM
Quick Reply: OEM Electrical System Upgrade I of II: OEM Ground Wire Upgrade (HOW-TO)
