valve cover gasket help
Old 05-26-2011, 09:29 AM
joseph.mcgowen's Avatar
i just got my valve cover gasket in and i have never done one on a Maxima before so any tips would help and if any one has a link for the fsm so i can get the torque specs or if anyone has the torque specs on hand it would help
joseph.mcgowen is offline
Old 05-26-2011, 10:48 AM
deezo's Avatar
Why not just run to Autozone or Advanced and get a Hanes Manual?
deezo is offline
Old 05-26-2011, 12:18 PM
i wasn't thinking when i was there got home and started taking the car apart now i can't get back up there till my girl gets back just wanted to find out a lil sooner plus its cheaper and easier to just download it i had a link to it i forgot where i got it from
Old 05-26-2011, 12:53 PM
luke95gxe's Avatar
dudes username is fallenone he has the fsm download
he started this thread llook at the bottom of his sig u will see the links
http://forums.maxima.org/4th-generat...r-3-weeks.html
luke95gxe is offline
Old 05-26-2011, 05:42 PM
thanx ill look him up n download it i already did the valve cover gasket though i had someone grab the specs for me and bring em by thanx anyway
Old 05-26-2011, 05:51 PM
Hope you put the RTV in the corners as specified in the FSM....
The Wizard is offline
Old 05-26-2011, 09:35 PM
max ride 41's Avatar
otherwise he'll be doing it again soon.
max ride 41 is offline
Old 05-26-2011, 10:44 PM
cartman854's Avatar
Definitely use the rtv
cartman854 is offline
Old 05-27-2011, 08:26 AM
neocry's Avatar
http://www.nicoclub.com/FSM/maxima/
Select your year of the car and go to section EM.
neocry is offline
Old 05-27-2011, 08:31 AM
tigersharkdude's Avatar
hope this helps some
http://forums.maxima.org/4th-generat...im-w-pics.html
http://forums.maxima.org/4th-generat...ion-guide.html
tigersharkdude is offline
Old 05-27-2011, 08:38 AM
Kevlo for President
Kevlo911's Avatar
Torque is in INCH POUNDS not FOOT POUNDS
Kevlo911 is offline
Old 05-27-2011, 09:17 AM
Dcarlton's Avatar
Yep, that RTV is required!
I didn't read that part when I did mine. I did the back one when I replaced a fuel injector put her all back together and still had a leak. I researched it after the fact and saw the need for the RTV. I had another back fuel injector need replacing so while I was there, removed the valve cover, corrected that problem and it doesn't leak anymore! Coincidentally I've also noticed that my oil light doesn't flicker as much when I start the car, not sure if there is something to that or not, but glad the oil leak is gone!
Dcarlton is offline
Old 05-27-2011, 11:32 PM
maxed_out_99's Avatar
prolly not still apart but... i usually like to clean the LIM and UIM just a tip
maxed_out_99 is offline
Old 05-28-2011, 04:39 PM
nope didnt have the fsm till after but im gonna take it apart and rtv it
thanks for the help it only took about an hour anyways it will get done in the morning i am just happy doing the spark plug tube seals fixed my miss thats been my biggest problem with this car since i got it
Old 06-30-2011, 10:44 PM
pwmaxgle's Avatar
My 95 FSM calls for "Use genuine liquid gasket or equivalent".
Which RTV do you guys recommend for applying to the corners of valve covers per FSM?
Would one of below Permatex RTVs work perfectly in aiding VC gaskets to seal up corners as shown in FSM?
Permatex Ultra Black RTV Silicone Gasket Maker
Permatex High-Temp Red RTV Silicone Gasket
Permatex Sensor Safe Blue Silicone RTV Gasket
pwmaxgle is offline
Old 07-01-2011, 06:51 AM
sjonesist's Avatar
I used the black.
sjonesist is offline
Old 07-01-2011, 09:27 AM
Originally Posted by sjonesist
I used the black.
Yup, me too.
Old 07-01-2011, 09:53 AM
pwmaxgle's Avatar
Cool thanks guys!
I'll use Permatex Ultra Black RTV when I replace both VC gaskets this month.
pwmaxgle is offline
TKHanson
11-24-2018 01:39 AM
jonreidhead
01-06-2016 09:38 AM
knight_yyz
11-01-2015 01:34 PM
tseng1023
10-15-2015 08:30 AM
Quick Reply: valve cover gasket help
