IL Remnants of my Maxima
Remnants of my Maxima (springs, sway, MAF, etc...)
Since my Maxima is gone, I have a few random parts for sale. This is a collection of item I either used, intended to use or kept as spares. Pictures follow the descriptions.
The next customer which spends greater than $40 will receive an IAT thermistor.
Prices do not include shipping, which may be unavailable for the larger items, and preference is given to locals that can pick-up the parts.
3) Stillen rear sway bar, purchased from a 4th gen owner, never personally used; hardware is in rough shape and there is some material missing from the bar due to rubbing ($125)
5) New Nissan fuel filter and pump assembly O-ring ($10)
6) Stillen muffler section, used on two vehicles with unknwon total mileage, scraps on the tip's bottom and some rust on mating flange (should seal without a problem) ($75)
7) Used (105k mile) MAF with a new MAF tube, was replaced trying to remedy a driveability issue but the new unit made no improvement ($45)
8) Purolator PureOne air filter ($5)
9) Ignition coils (3), purchased from another .orger, but never personally used ($17/coil)
10) Random Technologies high flow catalytic convertor, again purchesed used, but never personally installed ($80)
12) Floor mats in good condition and in charcoal, all but drivers side ($20)
13) Brake and clutch master cylinder rebuild kits; I got lazy and bought new masters rather than use these ($7.50)
14) MOOG 23mm SE sway bar bushings ($5)
15) POS engine cover ($7.50)
Worn out OEM parts removed from my vehicle which may benefit others. These are free for pick-up (beer donations accepted), or shipping (you pay).
-LCAs with bad ball joints, good for those looking to swap in ES bushings and MOOG ball joints
-Struts (fronts) to cut-up for use Koni inserts
-Motor/transmission mounts for ES bushings or polyurethane filling; the lower mounts were actually in good condition and could be reused (I'll try to get pictures later)
-5.5 gen OE front brake calipers
-5.5 6MT 114k mile axles; removed to troubleshoot a noise and never reinstalled; passenger side carrier bearing has some play
3)
5)
6)
7)
8)
3)
5)
6)
7)
8)
9)
10)
10)
I didn't record the build date, but I'm fairly certain it was built in late '01.
PM'd.
I haven't, but there purchased from a respected orger so I assumed they were kosher. As tested per this thread, I have the following which seemingly indicates they are all good.
$15 for the pair.
PM'd.
I apologize to those who replied/PM'd without response; I stopped coming here since there wasn't much interest and I no longer have a Maxima.
So, I'm back to finally sell this stuff and free up some space in my basement. The first post has been updated.
