Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-20-2006, 04:15 PM   #1
Booyah grandma.... BOOYAH
bigfatty's Avatar
Got bad coils? I tested and only replaced 2. How to w/ Pics
I have been getting a few PMs on this from time to time, but most questions have been answered somewhere in this thread, take some time and read because there is alot of good info in here from people other than me.
I swapped only two coils in Jan of 2006 and through Oct 2007 have not had a single problem with any additional coils. If you can isolate the bad coil, why replace all 6?
Sooooooo, I had the frigging SES, TCS, SLIP lights which any 5th gen owner should now know is code P1320, which means, drum roll please, Bad Ignition Coil. I was also luckily enough not just to have code once, but twice and also to have a code P0300, which is multiple misfires. I was able to get the codes pulled for free from my Autozone and so I started my quest to fix my car.
Some background info: The original coils from Nissan are garbage and Nissan knows this, yet they have chosen to do nothing about it. They did however update the coils with "newer" ones with a gray dot, that were supposed to be awesome. Well I open my hood, take off the cover and guess what, all my coils have gray dots. So I guess that blows that idea up. I bought my car in 2003 with 80k in miles from Woodfield Nissan in Illinois. So at some point in time they had already been replaced.
Ok, back to my test, I donated to Maxima.org so I could search and spent a night reading about just bad coils. The general consensus is that you should replace all 6 when one goes bad. The rough best price was about $300 for all six. The only problem is that I have this in my life right now that causes me to be short on money.
So after reading, I found a few things that will help in changing just the bad coils as I have done. I can not take credit for this info as pretty much all of it has been tried before, I am just trying to make it as easy as possible for everyone else.
Step #1 - Autozone
You may be lucky enough to have an additional code stored in your cars computer. If you have code P1320 with any P0301, P0302, P0303, P0304, P0305 or P0306, that is a misfire on specific cylinder. You now know which one is bad just replace that one, see the pics below on how to remove the coil.
Step 2 - Unplug coil one at a time
Remove your cover by taking the four bolts off your cover, you will need a 4mm allen wrench.
This test will only work if your engine is running really bad idle. If your SES/TCS/SLIP only come on when your engine is under load this test will not work, skip to step 3. My engine was running really rough even at idle, so I started to unplug the coils on at a time. Just squeeze the clip and pull, it will come off.
The first one I tried cylinder #2, when unplugged, made no difference at all in how the engine ran. SO I instantly knew that one was bad. If your coil is good you engine will bog down and almost stall, as you are basically removing a running cylinder. Do this one at a time until you find the one, that when removed, your engine does not seem to run any rougher.
Step 3 - Testing the resistance
You will need a multimeter to do this. I have had mine for a while and it worked fine for this. Its nothing big, and you can pick mine up at Sears for only $19.99.
Remove all your coils. This is for 5th gen if you have a 5.5 here is a great write up for you to get to your rear coils from Greg5.5 Gen Write Up
The front three coils are right there held in by one 10mm bolt each. Unplug the clip, remove the bolt and pull. The coil will come right out.
__________________
SHIFT_FAT<==Visit my CarDomain Site
bigfatty is offline   Reply With Quote
Old 01-20-2006, 04:16 PM   #2
bigfatty's Avatar
The rears are little more difficult to get to, but the are doable. Some people remove this bracket but I didn't have to, I just slipped the cables out of the bracket and I got the coils out. If you are worried about dropping the screws an easy way to avoid this is to put two thin strips of electrical tape on your socket like this. It will all the bolt on the socket and it wont fall out. This is extremely useful for putting the bolts back on.
When you are done you will have 3 fronts and 3 rears. I labeled the pin #s I used to test them in the pics.
Your red Red probe is positive and Black one is negative. Set your meter to 20k on the ohm setting and start testing and make sure you write your results down.
My result were this. I already knew I had one bad coil, the one was making my engine run rough. The second one would only fail under a load, so that was the culprit I was looking for. The coil I knew was bad, is labeled bad, the two new coils I had bought were labeled as new.
I was looking for a reading from a coil that was different than the two good ones. If you look #4 had an infinite resistance reading (i) for +1,-2 and +1,-3, no other coil had that so I found the other bad coil! Also the weird thing was that the coil I knew was bad before had almost the exact same reading as the good ones other than the +2,-3 test (6.82) which is higher than any other coil. I replaced the one I knew was bad and #4 and have not had any problems since.
Where to buy: There many places to get the coils, but the Nissan dealership is waaaay too much. DaveB on the boards can hook you up for about $55 each roughly but you have to wait for shipping. What I did is if you have an O'Reilly's in you area they sell the coils for $51.99, but you have to have them shipped and wait the week again. O'Reilly Auto Front Part #UF348, Rear Part #UF363. AutoZoneAlso carries thecoils, Front Part #C1267 Rear Part #C1266 and I could pick them up tomorrow but they were $69.99. I told auto zone they O’Reilly’s has them $51.99 and they went ahead and price matched them. Perfect, 2 coils $51.99 each and I get them tomorrow.
Conclusions
I was able to replace only the bad coils and did not have to replace all and pay extra money. These test are not 100% proof positive but if followed, will give you a pretty good shot at replacing only the one you have to. If any body out has a for sure bad coil or has a brand new, gray dot coil and would like to put an ohm meter on it, please do. I would like to have your results and will make a spreadsheet to compare the results to see if we could figure out a 100% positive test. Just send them PM or email to me.
I hope this makes all us 5th gen owner’s life a little easier
Fat
__________________
Old 01-20-2006, 04:21 PM   #3
dkp
Nice write up and pictures!!!!
dkp is offline   Reply With Quote
Old 01-20-2006, 04:37 PM   #4
chr0nos's Avatar
good info. i think i may have to print this for future reference.
chr0nos is offline   Reply With Quote
Old 01-21-2006, 01:16 PM   #5
bigfatty's Avatar
Quote:
Thanks, I've taken a lot from the org, so it was about time I gave back.
Fat
Old 01-21-2006, 01:42 PM   #6
Do I get a tax break?
Great info. Let me restate (as you have found yourself), that the resistance test does not always provide "revealing results" - case in point, your coil labelled "Bad" doesn't differ in any significant way from those labeled "Good". (Other than the 6.8 vs. 6.2 measurement - and again, that difference is nominal enough that it may or may not indicate a true problem.
Good work in any case - it's a little disconcerting to see these grey-dot coils start failing too...
njmodi is offline   Reply With Quote
Old 01-21-2006, 07:31 PM   #7
Just wanted to say....Excellent write up..Probably the most thorough and well written I've ever seen...
I have quite a few engine performance books. "Computerized engine controls" "Automotive Engine performance", Etc....and you rerely see anything this descriptive.. Even on Alldata..
5thgenmaxima is offline   Reply With Quote
Old 01-21-2006, 09:00 PM   #8
Ok now heres a question (nice writeup by the way, i almost cant wait for my coils to fail) I work at autozone and am wondering if the coils we have are the new grey dot design or the old design that nissan had that failed all the time. I know it sounds silly but its an express order part and you have to pay for it to order, so i cant just compare them to something else. Also i dont get my discount on vendor parts, so the part # and price he gave is correct- i figured the best bet would be Dave B, since i have to wait for shipping either way and his are cheaper.
carsarecool is offline   Reply With Quote
Old 01-21-2006, 09:11 PM   #9
Quote:
Originally Posted by carsarecool
.. I work at autozone and am wondering if the coils we have are the new grey dot design or the old design that nissan had that failed all the time......
I'm guessing they are OEM quality or better?????
Seeing as how there is a TSB I would be willing to bet they are updated and don't have that problem.......They are also probably from an aftermarket parts supplier that maybe never initailly had the problem in the first place.
I'm not 100% positive though..So someone else could probably jump and tell you for sure..
Old 01-22-2006, 12:50 AM   #10
bigfatty's Avatar
They gave me Duralast Coils. UPC code 025889344311 and if they didn't have the gray dot on them I would have pitched a fit right there on the spot.
Fat
Old 01-22-2006, 01:14 AM   #11
Does Duralast make Nissan's coils as well??? I'm sure it's in FAQ's but figured you may know and would be good information to add to this post.
Old 01-22-2006, 06:30 AM   #12
Mauja He Mauja
ZIPPIN's Avatar
good info...i wish this would have been out when mine went bad,,
__________________
ZIPPIN is offline   Reply With Quote
Old 01-22-2006, 01:15 PM   #13
Great writeup!
__________________
* Trans Cooler Install * Grounding Kit Install *
808MAX-SPEC is offline   Reply With Quote
Old 01-22-2006, 01:27 PM   #14
retired moderator
2000 Nissan Maxima
My Garage
irish44j's Avatar
Good stuff...I have a set of old coils downstairs that another org'er sent me (1 good, 5 bad but he didn't know which) and I was going to do the same type of tests on them.....looks like you beat me to it.
irish44j is offline   Reply With Quote
Old 01-22-2006, 06:50 PM   #15
bigfatty's Avatar
I don't know for sure but visually there were identical, same molding, everything.
Quote:
Put the meter on them I am curious about the results, if we do enough tests we may be able to have a concrete result. If its easier, send the coils my and I will test them and post the results.
Fat
Old 01-22-2006, 07:36 PM   #16
The Definitive AE Master
Larrio's Avatar
good read up
you can find a similar how-to in the haynes manual also
Larrio is offline   Reply With Quote
Old 01-23-2006, 09:52 AM   #17
Awesome write up! I'm picking up an 02 Maxima this summer, hopefully this will have been fixed by prior owner. Bookmarked just in case.
Aquila76 is offline   Reply With Quote
Old 01-27-2006, 08:01 AM   #18
100% chingon
clive's Avatar
Testing the resistance of coils with a DMM is really a waste of time. The only meaningful reading you'll get is on the low-resistance primary winding and it is not the primary that fails.
Failure in these coils is on the HT (secondary) side and it's caused by the insulation breaking down. The only way to measure the insulation resistance is by using an insulation test meter such as a Comark or (old fashioned) Megger. These devices apply 25KV to the coil secondary and give a reading of the insulation resistance in Megohms.
Even then there are two modes of failure, insulation breakdown to earth - which the IT meter can test - and shorted turns (turn to turn) which is internal to the coil and can't be tested without an oscilloscope.
Overall, the best bet for testing coils is to use a scope and measure the amplitude of the spark waveform and view its duration compared with the others. An ordinary electronics workshop scope will do, provided you use a high-voltage divider probe on the input.
clive is offline   Reply With Quote
Old 01-27-2006, 08:15 AM   #19
bigfatty's Avatar
What? Pretend I am dumb, dont worry you wont be the first to think it, and help me understand a little better.
Old 01-27-2006, 08:28 AM   #20
Adrian
Good information, gotta love Big Fatty for this! Thanks man!
Adrian112597 is offline   Reply With Quote
Old 01-27-2006, 07:37 PM   #21
Send a message via AIM to MY2000MAX
Good post right here.
MY2000MAX is offline   Reply With Quote
Old 02-06-2006, 10:16 AM   #22
This is going to help me out a lot.. thanks for the info!
Maxipad20 is offline   Reply With Quote
Old 02-11-2006, 04:58 PM   #23
Great write up and good pics!
Wish I had this wite up when I replaced mine as well!
__________________
2000 Maximus is offline   Reply With Quote
Old 02-11-2006, 08:16 PM   #24
Great writeup!
60,000 And no problem yet!
spdfreak is offline   Reply With Quote
Old 02-12-2006, 11:43 AM   #25
retired moderator
2000 Nissan Maxima
My Garage
irish44j's Avatar
I just successfully used this method as well.
I threw an SES P1320 and P0306 - indicating coil 6 failure. Car ran fine except occasional misfires, but gotta fix it!
Had a set of 6 old (non-gray-dot) coils an org'er sent me last year (thanks, whoever it was) - which he said at least 1 was bad, but didn't know which.
My car HAS the gray-dot coils on it already, so I guess they still suck.
Did the multimeter test as indicated above and here are my results:
"----" is an infinite resistance reading, if you didn't figure that much out....
Old coils he sent me:
Front #1 (no dot)
+1-2 1.429
+1-3 9.82
-1+2 1.434
-1+3 ---
-2+3 ---
+2-3 9.61
Front #2 (no dot)
+1-2 1.457
+1-3 10.13
-1+2 1.462
-1+3 ---
-2+3 ---
+2-3 10.01
Front #3 (no dot)
+1-2 1.501
+1-3 9.85
-1+2 1.506
-1+3 ---
-2+3 ---
+2-3 9.75
Rear #1 (no dot)
+1-2 1.460
+1-3 10.50
-1+2 1.463
-1+3 ---
-2+3 ---
+2-3 10.47
Rear #2 (no dot)
+1-2 ----
+1-3 ----
-1+2 12.03
-1+3 ---
-2+3 ---
+2-3 10.20
THIS COIL IS A BAD ONE
Rear coil #3 (no dot)
+1-2 ----
+1-3 10.36
-1+2 ----
-1+3 ----
-2+3 ----
+2-3 ----
THIS COIL IS A REALLY BAD ONE!
Now, I pulled one of my gray-dot coils that I know is good off the car
Front #1 (cylinder 2) - gray dot - GOOD COIL
+1-2 1.551
+1-3 9.81
-1+2 1.543
-1+3 ---
-2+3 ---
+2-3 9.73
Then I pulled the bad coil off the car (cylinder 6), a gray dot coil that I KNOW is bad
+1-2 -----
+1-3 -----
-1+2 -----
-1+3 -----
-2+3 -----
+2-3 0.60
yuck!
I replaced my bad gray-dot coil with the "old" non-gray-dot coil #1 mentioned above, and not surprisingly, no misfires, SES light is off immediately.
Total cost: $0.00
this once again proves that just because one of your coils goes bad, don't throw out all your old non-gray-dot coils -you might need one later.
to Bigfatty for figuring this method out!
__________________
2000 Maxima SE (sold) - 2009 Subaru WRX Sedan - 1970 Triumph GT6+ - 2008 4Runner SportEdition
Old 02-12-2006, 06:54 PM   #26
† ErV †
sticky or an addition to the FAQ. awesome work.
Old 02-15-2006, 03:25 PM   #27
bigfatty's Avatar
OK, I got some more test results from Irish and I figure I would put them together and match them up with mine and see what we get.
First thanks to Irish for getting some more tests and I am happy to see that the tests are holding up when other people are using them and that it saved you from having to replace all 6. I still think nobody should have to replace all six at once.
I separated the results with good ones on the left and bad ones on the right. I found it very interesting that the no dot coils, the old ones, had much higher resistance than the new updated ones. Maybe that’s one of the reasons of why the old ones are failing at such a high rate.
Also with the exception of one coil, #1, the bad coils had dramatically different results that the good ones. That bad coil, #1, came from my car and was making my car run so bad, that when I unplugged it the car didn’t even change one bit.
So if anyone else has some coils laying around please test them and send them my way. I think there is a pattern starting here, so keep them coming.
Fat
__________________
Old 02-15-2006, 03:54 PM   #28
celestialking23's Avatar
Man Thanks 4 Da Info.
__________________
Impending Nights
celestialking23 is offline   Reply With Quote
Old 02-15-2006, 08:09 PM   #29
doesnt seem to work for me... I only get response form (+1, -2) and (-1, +2) from all 6 coils. all the rest read infinite.
trigger005 is offline   Reply With Quote
Old 02-15-2006, 09:05 PM   #30
Fat
Thank you for your write up.
My car has the gray dot coil but number 6 is still bad and car ran real rough.
Got it change and fix now, resetting the SES light and hopefully in the morning all clear.
once again thanks.
exunaja is offline   Reply With Quote
Old 02-16-2006, 07:23 PM   #31
bigfatty's Avatar
Quote:
Hmmm I guess I will start by asking that your meter is set to 20k on resistance or Ohms? If it is did you get code p1320 and if you did, did you get more than one? Are your coils the new, gray dot, ones or are they the old ones, no gray dots? Finally what are getting for readings on your six coils?
Fat
__________________
Old 02-17-2006, 10:48 AM   #32
Quote:
Fat
All are Non-grey dotted. Bought them off eBay from guy who had to replace his. Said the dealer told him there was "1 bad coil". (I just bought it cuz it was a steal so I thought it'd b good 2 have for backup).
Resistance is around 1.57 for all of them. I also tried 2K resistance and got some readings, but it was consistent through all 6 coils. I thought it might be because they were not grey-dotted but Irish posted that he got readings to work off of them...
Then I thought... maybe they're all bad and I got owned. But that doesnt seem to be consistent with your guys' readings for bad coils. idunno
Old 02-25-2006, 10:07 AM   #33
Fat, thanks for the great writeup.... I just bought my car 2 months ago and have already found issues with it. The coils not failed on me yet but i think the time will come....
cuk133 is offline   Reply With Quote
Old 02-25-2006, 02:49 PM   #34
Hmm... i checked at the nissan dealer my car was originally bought at and he said theyve never been done, although they look pretty clean and new (i guess they wouldnt be cracked and burnt though haha) are they probly originals? Or is that unheard of in a 5th gen with 79k miles on it
Old 02-25-2006, 09:01 PM   #35
retired moderator
2000 Nissan Maxima
My Garage
irish44j's Avatar
if they are not the originals, they will have the gray dot on them. The originals do not have the gray dot.
__________________
Old 02-25-2006, 10:55 PM   #36
i have no grey dot
basically i should be putting coils in soon eh
Old 02-27-2006, 04:36 PM   #37
Send a message via MSN to 75jihyun
Thanks~ It's awesome~
I will try at this saturday~
Thanks again~
75jihyun is offline   Reply With Quote
Old 02-28-2006, 10:08 PM   #38
bigfat, I need a little more in depth testing info from you. On your chart you have -2,+3 and +2,-3...
When doing this test are you simply swapping the two test leads backwards??
Since your only checking continuity I don't really understand how the results would differ with the leads reversed. Maybe I'm mis understanding part of the testing procedure??
I'm getting ready to test mine in the next week or so and have scope readings to compare to as well. Assuming the resistance readings differ accordingly with the scope readings it shoud give us pretty definitive evidence that the resistance tests holds value.
Once I get everything completed I will add my results to this thread.
Old 02-28-2006, 10:42 PM   #39
just curious, ive been having a wierd idle in the mornings.. do i nessasarily have to have a SES light to have a bad coil?
OutMaxxed is offline   Reply With Quote
Old 03-01-2006, 05:32 AM   #40
bigfatty's Avatar
You got it, I am just swapping the leads. I don't have an answer on how they would be different but on every coil they are. I absolutely agree that you would "think" that they would be same but it doesn't turn out like that. Test away man and send the results my way man, thanks.
Fat
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
