Audio and ElectronicsDiscuss in-car entertainment systems, audio and video systems, car alarms and other electronics topics.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
The BOSE Radio/Speaker Replacement/Intergration/General Knowledge Thread
I am building this thread in order to help all those with stock BOSE questions as far as replacement questions goes. If you know what to search for, your answers can be found quickly. But, for most this can be a tedious procedue. Below I will post some helpful hints, tips, and knowledge on how to deal with your premium BOSE system. This thread pertains to Infiniti's 96-99 with a BOSE premium sound system, if this is expandable to other years, send me a PM. THIS THREAD IS MORE GEARED FOR 96-99 INFINITI I30's, BUT YOU MAXIMA OWNER CAN BENEFIT TOO!!!
PLEASE, IF YOU DONT GET AN ANSWER QUICK ENOUGH ON HERE, PLEASE AIM ME @ SuBZeRo69069 and i will get to u ASAP
WHEN I EDIT THIS THREAD I WILL PUT A PARAGRAPH AT THE BOTTOM OF PAGE STATING WHAT I EDITED.
TOPICS THUS FAR: Q1.I have a stock Premium Bose Sound System in my car, what does this mean? Q2.My stock premium sound system headunit has died, what do I do. Q3.Ok so now that I have chosen an aftermarket headunit and the wiring harness of my choice, what other items do I need? Q4.How will my aftermarket radio fit into my car. I have a 1 din radio, what do i do? Q5.MY BOSE amp died on the back of one of my speakers, can i use the power from my headunit? Q6.Can i replace a BOSE speaker with a different brand speaker and connect it to the BOSE amp? Q7.Why are there so many damned colors? Q8.WHOA OMG, WTF. I have an extra black wire eminating from my METRA harness 70-7551, who what and why is it there and what do i do with it? Q9.My harness comes with crimp tubes, are these any good? Q10.How is My BOSE Headunit grounded? Q11.Ok so now that you have explained these confuzzling ground wires, how the hell do i ground my new aftermarket headunit? Q12.Ok i have an annoying whining noise and/or other static/pop noises comming through my speakers what can I do? Q13.How do I remove my headunit from my center console? Any update on the RCA low volume issue?
The Q and A:
A1. You have a Clarion headunit(even though bose is plastered all over it) which integrates to individual BOSE amplifiers which feed power to each BOSE speaker.
(AKA 4 speakers, 4 amplifiers. Front speakers are components consisting of 6.5 inch woofers with 2 inch mounting depth and tweeters on the pillars. Rear Speakers are full range 6.5 inch speakers.)
A1. You have choices. Get it repaired, which can be costly and far from time efficient, or purchase a headunit of your choice. There are 2integration harnesses that allow you to send a signal from your new headunit to the BOSE amps behind each speaker.
Method 1:
Amp Integration Harness Metra Part 70-7550 as shown here: Metra Part 70-7550
This harness is all well and good, but it is taking the raw power signal from your headunits internal amp and sending it to the BOSE amplifiers. This harness is geared for aftermarket headunits without 4 sepaker preamp out jacks. This method will work, BUT, you get alot of distortion because it's a high level signal. TOO much signal produces distortion, too little signal will prevent the volume from reaching a decent level. As I said before, this will work, but you will get a crappier signal.
This harness is the best harness you can get. This harness utilizes the low level RCA preamp outputs of your new headunit to produce a clear signal to your BOSE amplifiers. With this harness you bypass your headunits internal amplifier and use only the preamp outs. This method supplies the proper amount of signal to eliminate distortion presented by direct amplifer hookup like with the Metra 70-7550.
This adapter will allow your stock antenna wire to work with th aftermarket antenna wire found on the rear of your aftermarket headunit.
A4.You need to get a dash kit. There are several companies that sell dash kits to fit your stereo, but for the sake of keeping everything from the same company we will use METRA as our source for this dash kit.
For infiniti purposes, you will not use most of the pieces floating around that center section. YAY!
Dash Kit 2:
Now if you so decided to be a baller and purchase a 2 DIN aftermarket headunit you can purchase the 2 Din dash kit Metra part 95-7417 2 Din Multi Kit Metra Part 95-7417
A5. NO, NO,NO. Bose runs their speakers at 1ohm. Aftermarket headunits run their channels at 4ohms unless otherwise stated. 99% of the time it will be 4ohms.
A6. NO, NO, NO. Once again, the speaker runs on 1ohm, most, 99% of aftermarket speakers run on 4ohms. You will ruin the amp or your speaker, whichever comes first.
Q7.Is it hard to intergrate the wiring harness?
A7. Not at all. When you intergrate the wiring harness of your choice you are not splicing any part of the existing harness. The harness that is attached to your car remains the same. The intergration harness you purchased will plug into your car's harness. From here you have wires on the opposite end that need to be attached to the wiring harness that cames with the aftermarket headunit you chose. Both the headunit and and Metra cable come with directions specifying what color wires are for what. The Metra cable packaging has the wire designation on the back so do not throw the packaging away. Somewhere in your headunit manual will be the wire color designations for their harness.
A7. So many colors because of so many connections. Most aftermarket manufacturers follow the same wire color schemes to keep things more uniform. It is easier on everyone'es part when it's this way. HOWEVER, this is not true in 100% of the cases. Always double check to make sure that the colors match so that when you hookup your accessories you dont ruin anything.
A8. Ok here's the deal. After alot more research i am fixing this answer. The deal is, there are 2 ground wires, 1 per harness. Unfortunately, there will most likey be no place to connect these to on your new aftermarket headunit because these wires are grounds for the bare negative wire which travels along side your + and - signal cables to your amps at your speakers. This method is called shield wiring because this single bare negative wire removes electrical pulses from its environment and grounds them. This prevents interference on your signal. Basically, now that you know this you should ground these two wires to the chassis as close as possible to the HU. I haven't done this yet because i just figured it out so i will fix the end of this and tell you all where i put my grounds for them.
A9. The crimp tubes are fine. The metra harness's don't have crimp tubes to my knowledge but many times, in the case with my alpine headunit, the headunit harness has crimp tubes. You can use these tubes and things will work fine but it is always recommended that you twist the wires together and cover it with something to protect the bare wire. I always ditch the crimps and twist the wires together and then use heatshrink tubing. You should solder the wires together as well and then cover with shrink tubing, but you dont have to. Make sure the wires are firmly together. If you chose to forego the shrinkwrap, use electrical tape. Choice is up to you, i just find shrinkwrap tubing to be more of a finished look.
A10. The way your BOSE headunit grounded is via the metal case. In other words, your headunit is screwed into the cage which is screwed into the dash which is connected to the chassis which is a common ground to your battery.
A11. Well, there are options. Chances are you new aftermarket headunit will come with a black ground lead on it. In the case of our cars, ground the wire to the chassis spot of your choosing. Your new aftermarket headunit may grounditself to the chassis via its metal casing but make sure that the black ground wire from your new headunit is grounded to the chassis.
A12. When you have a whine comming through your speakers that means that somewhere in your car is a ground loop. This is a rather commong occurance unfortantely and is caused when there are multiple grounds to a negative and electricity could travel either path causing noise in the system. Atkeast that is what i have gathered from the readings i have done. I haven't been able to find anything laid out nicely to explain it. Now the whining you hear is the alternator spinning and you will notice the noise is louder at higher RPM, so that means its proportional to how fast the alternator spins. My assumption is that the whine is caused by the alternators recharging and supplying of power back into the system. Just some more information, alternators have diodes on them so as to prevent electricty from flowing back in. DIodes limit electricty to one path, so electricty cant go back. Now in some cases the diode or diodes on the alternator get burned out or just break and this can cause the whine as well. Usually this is an absolute last thing to check is a more rare occurance. Now that you read this whole speal you are probably wondering what you can do to fix the issue. Well i have a solution that has worked for me and many others but isn't a 100% sure. You can buy ground loop isolators which this method is for those using the RCA jacks on your aftermarket headunit. You need to purchase 2 isolators because each has a l and r channel and your have 4 channels to you need 2. These help to eliminate the noise in the circuit. When i have time i will read up on they work and give an explanation.
A13.Its very easy, the tough part is not breaking anything while doing it. For you to get at your Bose headunit you need to take the center console apart a little bit. The wood trim by the gear shifter is held downt o the console with pain in the *** v-clips. The first time I took it up i did it with my fingers, i was able to fit my fingers in on the inside of it and pull up towards one of the corners. You can take a flathead screwdriver and use a cloth to help not damage the trim to pry it up. When you get it up, you are left with the cigarette light attached to it. Just pull the cord off the back of the light, it just pressure fits more or less. After that, the ashtray is there, there are two screws holding this in, one on the left and one on the right. To get it out, you need to open it and pull it out, the light for it is connected and u can throw it to the side of disc it. After that, you can get access to both of the bottm screws that hold the cage that holds the tray, HU, and AC controls. You need to remove the top vent and disc the wires from thir harness, its kind of a ***** to leave it conected and sit the vents on your dash tbh. Getting the vents out cant be troubling, my method was to put my fingers into the vents at the bottom up to about my second knuckles and press down and pull out. The vents stay by being force fit in and held in with lil pieces of plastic that let u push it back in but not pullit out easy. After the vents are remove, you now have access to the two top screws of the cage, remove those and you can now pull out th whole cage and you can get access to the wires and screws holding the HU in.
The low sound issue resulting from the preamp voltage: I didnt find any cheap method before i traded my car in, the best thing you can do is buy a preamp line driver. TRU Tech makes a good one, very expensive $300, this is what Nismos recommends. You can find cheaper line drivers like the ones memphis makes that are about 60-120.
It really comes down to cleanliness of sound and quality of signal. Your aftermarket HU will produce a great RCA signal compared to the raw signal at the trade off of amplitude (strength of the signal and the result of what you hear). I know there are converter packs you can buy which take the raw power signal or the HU and convert it to RCA, i dont know if the signal strength is higher than that of the metra harness. These converters i think from what i remember were like 35-80 bux.
If you want to poke around for other car shiz, check out Installer.com. That is where i purchased my harness, they have everything you need to do a great intsallation. http://forums.maxima.org/audio-elect....Installer.com
Edit: 2/24/08
Ok, after consulting with the mechanics manual for the car with alot of trying to figure out the wiring schematic i have come to this. I have no idea what the popping noise yet, BUT I HAVE ALTERNATOR WHINE. yes quite annoying, but i have learend a couple good things.
Fixed Q8, it was alll wrong, damn you metra almost perfect but it helps to consult with your mechanics guide in the electrical section. Also added some new info
I still have a popping noise, havent figured it out yet. I have some slight alternator whine. I am assuming that this was there originally for me but was inaudible due to the original type of harness used on my radio. Now that i am using RCA's it is much clear, but the whine is now audible. I am assuming this has to do with my currently ****ed up grounding situation. So as soon as things are properly grounded we should be good i hope. As a side note, i never had alternator whine until i had my new headunit installed. So it has to be it.
EDIT: 3/30/08
I added question 12 on alternator whine elimination and getting rid of other possible noise comming through your speakers.
EDIT: 4/23/09
Added a little shpeal on how to get to the HU and more on the low volume issues.
Wiring Harness Wire Guide:
This is as if you were looking at the harness connected to your car dead on with you holding the connectors with the top row missing 2 connection points in the middle. These numbers are verbatim from the mechanics book for a 1996 infiniti i30 with a bose premium sound system.
Smaller Harness:
16_______12
15_14_13_11
11 = Shield Wire Ground (ground wire runs with signal cables(+ and -) for rear BOSE amplifiers to shield their signal)
12 = Amp On Signal Wire (turns on all 4 BOSE amplifiers)
13 = Left Rear -
14 = Left Rear +
15 = Rear Right -
16 = Rear Right +
Larger Harness:
10_8 ___4_2
9_7_6_5_3_1
1 = Front Left -
2 = Front Left +
3 = Front Right -
4 = Front Right +
5 = Power Antenna
6 = Battery (this ensures you keep your presets when your car is turned off)
7 = Illumination Constant (wont dim when lights are on, most cases you would use this)
8 = Illumination Switch (will dim your radio when your lights are on)
9 = Shield Wire Ground (ground wire runs with signal cables(+ and -) for front BOSE amplifiers to shield their signal)
10 = ACC/Ignition (the red wire)
DISCLAIMER:
I take no responsibility for you messing up your car or electronics. The info above was supplied as guidelines for you to make good decisions and to help aid you in your purchases and install. If you feel that you cannot or feel that you do not possess the knowledge and ability to make the right choices, go to a professional installer.
Hey all, if you are reading this thread and it is helping you, awesome, i am happy to see this thread still alive. I HAVE TRADED MY I30 IN, it needed around 3k+ in work and my parents and i decided to joint lease a 2008 altima and i would be it off lease. I don't check the ORG too much anymore, it's sad, i really miss my car. I DO check in here and there and answer PM's and answer some of the most recent posts. THE BEST WAY FOR YOU TO CONTACT ME IS VIA AIM @ SuBZeRo69069. Leave me a message if i dont answer you i am prob out and about working, schooling or chilling. I will get back to you ASAP. I am a lil rusty but i am sure i will be able to help.
thanks man, i posted it in the i30 forum and thought that it would benefit more people in here as well. I will update both threads at the same time so updates will be concurrent. I keep adding and editing them with more info, better info, and better pictures. BOSE is a funky thing but can be worked with.
what about sub replacement, my bose sub is cutting out and I was thinking of just replacing it with another free-air 8" aftermarket sub, what does that entail to do such a thing, like the wiring and such.
__________________ 04 Supercharged American and 01 Turbo Swede
Simply replacing the sub may not stop the skipping.
well that aside, I hit it and it comes back the moment i hit it. but what about wiring how direct is connecting the aftermarket sub to the stock wiring, is it straight foward.
I'm thinking about getting a Kicker or whatever is available 8" free-air sub
I have to chime in on this one, since I started the whole Bose collection 6+ years ago. If you can't find it here or in the Audio Forum's FAQ, search for posts by me. I've documented the mess out of the Bose systems, including issues with the 2002-2003 HUs, etc.
didntean to jack your threads at all, i have just searched hi and low for the info i am posting here and have always had a hard time finding anything laid out like this. I figure if i am having trouble find answers so are other people. I don't want people to be afraid of their electronics, especially, BOSE, its a beast at first but can soon be tamed.
Ha, ha, ... it's all good. I've still got people sending PMs, etc about the old-school PAC kit, back before the AOEM-NIS2 and ROEM-NIS2 kits existed, where you had to buy the OEM-1 and the other parts seperately and build it yourself. Let me know if you need more info, but it looks like between the two of us, we've summed up 95% of it all.
haha well, i am working on getting rid of my alternator whine due to my radio install, i know its the radio cause i never had it before lol. any suggestions?
and he used the PAC ROEM-NIS2 adapter connected to the speaker level outputs.
Subxero used the Metra 70-7551 connected to the pre-amp outputs as described in this thread.
I am trying to decide which adapter to go with. Do either of you know enough about both adapters to do a little comparison between the two (i.e. Ease of installation, sound clarity, volume, issues since installation (alternator whining), etc.)
I know the PAC adapter is more expensive, but I would rather spend the extra $30 if its ends up with a better product.
The pac is not necessarily better. The bottom line is, if you get a headunit that has preout voltage greater than 4 volts, the metra 70-7551 is all you need!
Ok, heres the deal. Some headunits require you to have your internal amp switched off in order to utilize the preamp outs, including the subwoofer rca's. In my case, i got no signal from the hu to my subs the original way because my internal amplifier was enabled. This was a second reason why i switched harness's. (read your headunit manual)
you can stick with the 7550 harness and get a pac converter and not use the rca's and the signal will be just as good. pac converters really do wonders to the quality of sound, i had one connected to my subwoofer amp originally feed off the signal from the rear deck. Huge different in comparison to highlevel inputs.
Go with the 7551 if you want, it is easier to install, basically same price as the 7550, choice is up to you and what you feel like doing.
Currently i am having popping issues with my headunit and the 7551 harness but i am attributing it to my poor ground that i have now with the headunit. I wouldnt consider the harness the issue.
overall suggestion, go with the 7551 harness. its easier, faster, will sound better. If you encounter issues, we are here to help. As always i have my aim sn on here so if you have questions, feel free to contact me
i have an alpine cda-9883. the preamp outs for the subs are not enabled while internal amp is on. The preamp channels for the speakers are enabled either way it seems, on or off.
i like how my bose speakers sound at low volume but mid to high the amp push them too hard.
i was thinking of getting some 4" pioneers for the front and 6x9's for the rear...
or just get newer ones from the j/y..
A 4 ohm speaker on a bose amp will not ruin anything, it will/may just be quieter. A 2 ohm speaker would utilize the power a big better. It's doable, the results will just be poor.
what my screen name says 92 maxima se.
when my sub was'nt acting right and i was lazy to fix it i just put all the bass for the speakers.
the fronts hit nice and hard and it can control it.
the rears though is a different story.
at a specific volume level they don't distort they have the trunk rattle.
the bose is set at 1 ohm hooking up aftermarket speakers won't harm the amp.
they'll just be lower.
ok so my newest issue is that my headunit is being currently grounded by my antenna cable, like wtf. i keep weeding down issues. I took my heu out to make sure that the chassis wasnt grounded and disc'ed all the other neg wires to make sure and it was grounded through the antenna. Currently i dont have any antenna setup due to the fact that it got trashed in a car wash cause im a dumb *** so the antenna was disconnected.
rarble
It's supposed to be grounded through the antenna. If you disconnect the antenna, the radio will not turn on.
"ground is supplied through the case of the radio."
"also, radio and cd player terminal 12 is grounded to body grounds m13 and m73 throughaudio amp relay terminals 1 and 2"
sorry in advance.......serious car audio noob here again.....
Does the rear sub have its own amplifier in the stock set-up? Looking at the metra 70-7551 adapter, it appears to have only 4 rca connections. My guess would be FR, FL, RR, RL, one for each speaker. If the headunit has a separate sub preamp connection, is it possible to run the stock sub directly from that? Or does it run off of the other speakers?
Specifically, I am looking into the alpine 9886 HU which has 3 sets of preouts and was wondering how that would work with the stock subwoofer.....
So I changed my mind and am going to get the alpine cda-9885. I was going to get it through crutchfield. The harness that they want to give me for free is the metra 70-7550. I sent them an email asking if i could get the 70-7551 instead. This is what they replied with:
Thanks for shopping the Crutchfield web site.
I will be glad to help with your question about purchasing the Alpine CDA-9885CD receiver, which you'll find on our site here:
The Bose radio in your Maxima doesn't have RCA preamp outputs, and the Bose amplifier does not have RCA preamp inputs. The factory amp is actually connected via speaker-level connections. When replacing the factory radio in your Maxima, if you plan to continue using the Bose speakers and amplifier, you actually need a special OEM amplifier integration adapter, which you'll find on our site here:
In terms of the Metra 70-7551 amplifier integration adapter, our research file on your Maxima doesn't list this particular harness as being compatible in your car.
A crimp tool and crimp connectors can help make your receiver installation go more quickly - you will need to connect the wires from the new receiver securely to the wires of the custom harness we offer. We have a crimp kit available that's perfect for this job, and you can find it on our web site at the following address:
