09 Maxima Specific Oil!
Old 08-12-2009, 09:59 AM
  #121
Giantbob's Avatar
$120 oil change!
I'm leasing my car from Kingston Nissan in Kingston NY.
They told me my oil changes would be $120 each and I HAD
to get my oil changed there or I would void my warrenty.
Any thoughts on what I can do about this would be appreciated.
Giantbob is offline
Old 08-12-2009, 10:08 AM
  #122
ANNINO's Avatar
That is a load of crap. You can change your oil anywhere. If you are leasing all they care about is the condition of the car when you return it to them. And $120 an oil change?? What are they putting in there, bits of diamonds? I think my dealer charges around $30 for a regular oil change (not synthetic)
ANNINO is offline
Old 08-12-2009, 01:46 PM
  #123
bomaxima's Avatar
Check your lease's fine print. If having the oil changed by Kingston isn't mentioned, then you're golden. I would save receipts when you change it in case you need to battle.
bomaxima is offline
Old 08-12-2009, 07:40 PM
  #124
Muslenutz's Avatar
what to do what to do, any dealer experiences with warranty void?
Muslenutz is offline
Old 08-13-2009, 08:34 AM
  #125
maxed's Avatar
In Canada they would have to prove neglect. Since we didn't have ready access to ester based oils, they recommend Mobil-1 Syn, but will accept any oil if changed regularly. Of course Nissan is now in bed with Mobil - so go figure on their choice
maxed is offline
Old 01-06-2010, 05:32 PM
  #126
Leeno's Avatar
Anyone use a synthetic blend to break in their car?
Leeno is offline
Old 01-06-2010, 05:41 PM
  #127
cobradb's Avatar
following the car owner's man is important for oil,,,a lot of testing is done to determine what lubs are needed,... cars off the production line that require syn oil are built with materials and engine tolerances to accept syn oils.
cobradb is offline
Old 01-06-2010, 07:57 PM
  #128
2young2retire's Avatar
When I had my first oil change done at around 3500 miles and the dealer used Quaker State Synthetic Blend 5W30. I changed it again at 10000 miles and used Mobil 1 5W30 full synthetic.
2young2retire is offline
Old 01-06-2010, 11:17 PM
  #129
lightonthehill's Avatar
You may be fine going to a blend, but what cobradb said is very important. I would recommend not switching to synthetic, even a synthetic blend, very early in the life of a car that was engineered for, and came with dino.
I would suggest not switching away from dino until at least the second oil change, and even then would avoid the full synthetics until I knew the engine was fully broken in, which could be between 10K and 20K miles. I would think what 2young2retire did would be the 'fastest track' I could recommend anyone use with this Maxima.
Be aware there is nothing 'magical' about synthetic oils, especially in engines designed to run with dino. I have run Maxima engines 206,000 miles in miserable Atlanta commuter traffic using nothing but dino oil, and the engine was still running smoothly and quietly, and using no oil, when I traded it in for a later generation Maxima.
I may consider going to a synthetic blend around 20K miles, but, with my driving style, plus the fact I will be getting my oil changed every 3750 miles no matter what type oil I am using, dino oil would work just as well for me.
lightonthehill is offline
Old 01-07-2010, 09:26 PM
  #130
67whitegoat's Avatar
The dealer can not void your warranty. Tell them to refer to the federal Consumer Product Warranties law, Magnuson-Moss Warranty Act , which states, in part, in Title 15, United States Code, Section 2302, subdivision (c), as follows:
“No warrantor of a consumer product may condition his written or implied warranty of such product on the consumer's using, in connection with such product, any article or service (other than article or service provided without charge under the terms of the warranty) which is identified by brand, trade, or corporate name; except that the prohibition of this subsection may be waived by the [Federal Trade] Commission if –
(1) the warrantor satisfies the Commission that the warranted product will function properly only if the article or service so identified is used in connection with the warranted product, and
(2) the Commission finds that such a waiver is in the public interest. The Commission shall identify in the Federal Register, and permit public comment on, all applications for waiver of the prohibition of this subsection, and shall publish in the Federal Register its disposition of any such application, including the reasons therefor.”
Under this federal statute, a manufacturer, who issues a warranty on your motor vehicle, is prohibited from requiring you to use a particular brand of air filter, oil filter, or other service or maintenance item, unless such item is provided, free of charge, under your warranty or unless the Federal Trade Commission (FTC) waives this prohibition against the manufacturer.
By the way...I use Amsoil 0w-30 with OE filter.
67whitegoat is offline
Old 01-07-2010, 09:37 PM
  #131
And if it is mentioned, your still golden because that would be a violation of Federal Law.
Old 01-13-2010, 09:16 AM
  #132
ranmax's Avatar
$40 here in queens ny... i'm at about 1920 miles .. i asksed and they said for the first change 3ooo miles is ok.. there is a shop closer by that does it for about $28 and that includes a car wash at a station right across the street.. proly go there
after all this reading , i think i 'll stick wtih the dino for first 10k then synthetic
ranmax is offline
Old 03-23-2010, 10:32 AM
  #133
carwasher62's Avatar
fyi the oil filter media used is important as well. Mobil 1 filter uses a sythectic fibers that filter smaller particles, better filtration better protection. Amasoil and royal purple make good filters too.
carwasher62 is offline
Old 07-14-2010, 07:48 AM
  #134
nykbob's Avatar
Just spoke to my dealership to get my first 3000 oil change for free. I asked about them using ester based oil and the first person did not even know what I was talking about. The second person said that they use regular Chevron (dino) oil and that that was fine unless I wanted synthetic. I asked if using regular oil affects my warranty and he said no as that was all they used at this dealership. So unless they are voiding everyone's warranty I don't think there should be a problem. I plan to go with dino this time and then at 6K switch to synthetic at 10 K. They I change oil every 5 K after that just to keep it simple.
nykbob is offline
Old 07-14-2010, 01:42 PM
  #135
WhitefrostMax's Avatar
im using Mobil One 5W30 everything runs the same...
WhitefrostMax is offline
Old 07-14-2010, 03:53 PM
  #136
smarty666's Avatar
I've been using Valvoline SynPower since the 7500 mile oil change and the engine hasn't been having that burning oil odor anymore and seems to run a little better with the full synthetic! I don't think you can go wrong with any of the big name brand full synthetics though.
Of course, if you really want to baby your Max and pay a little bit more, Amsoil is the way to go!
smarty666 is offline
Old 06-08-2011, 11:48 PM
  #137
ToroMax's Avatar
Shout out to this thread, learned a lot about oil and its differences. Oldie but a goody
Going in for my 1st oil change @ 1,600M on my "11, will have to ask what kind of oil they use. Going to the Dship and hoping it goes well, any advice from the Org is appreciated. Will report back by the weekend
ToroMax is offline
Old 06-09-2011, 07:21 AM
  #138
Dubl-A's Avatar
Originally Posted by bk2k3max
Just did a change the other day and got Mobil 1 Synthetic, cost $35 with filter, flush and fill, car runs great.
Ditto, I just dont like the hidden filter. But otherwise a snap
Dubl-A is offline
Old 06-29-2011, 06:56 AM
  #139
tommy20020's Avatar
I just did first oil change on my 2011 Maxima @2700M.
Dealer say there is recommendation from Nissan to use syntetic oil on Maxima's 09 and up. I did what they recommended. $57 for syntetic is not that bad.
tommy20020 is offline
Old 07-22-2011, 05:25 AM
  #140
DINMax82's Avatar
Waiting on my first oil change at the dealer. They mentioned that a month or so ago that Nissan changed the oil requirement to synthetic on the 09+ Maximas as some engines were having problems. First change is free so I was cool with it but was hoping to use dino until 10k.
DINMax82 is offline
Old 07-23-2011, 05:11 AM
  #141
Dan0076's Avatar
Originally Posted by STARR
With your maintenance package you get an oil change every 3750 miles
I know I'm coming in late to this conversation. I purchased my '09 in Sept '08. I got a maintenance package that covered the oil change at 3750 miles and rotated my tires every other time.
The first few times I had the oil changed, the service dept at the dealership I bought my car from just used regular 5w30. I told them that it required Ester oil as specified in the manual. The adviser said he had never heard of that. I stopped going there after the second or third oil change.
I then started taking my car to the closest Nissan dealership to my house. There they knew what Ester oil was and were sure to use that every time. I still remember starting the car after having the correct (as specified by the maker) oil used. The engine sounded like it was just a bit smoother.
After my maintenance plan ran out at 100k miles (I'm at just over 136k now and change the oil every 10k), I started doing my own oil changes. I use Mobile One High Mileage with a Mobile One oil filter. And yes, after the first oil change it sounded like the engine ran even smoother on the Mobile One.
Dan0076 is offline
Old 09-06-2011, 05:25 PM
  #142
4 door GT-R's Avatar
What oil to use ????
Hey guys hows it going. New on this form and with Nissan's. I have a 09 Maxima and my service package is almost up and was wondering what you guys had to say about Amsoil oil or Royal purple. This is my 1st import that you can say I've babied like I do my V8's. So I wanted to see what you guys thought about those two oils. I read the 1st two pages of this post and didn't see anyone bring up the two oils I've been using on my other cars so I figured I'd ask and get some input before buying some oil for the MAX. Thanks again
4 door GT-R is offline
Old 09-07-2011, 07:16 AM
  #143
gizzsdad's Avatar
Of those two - I would take Amsoil every time.
gizzsdad is offline
Old 09-07-2011, 08:12 AM
  #144
williammmurphy's Avatar
ok oil ester oil is better it will protect the uper end u may notice a bit more noise not using ester oil but the good news is u do not have to use this ester oil using sinthedic oil extended performance this one because it has more sinthedic stuff and engine protectors than any other tipe of moble 1 this is why it says u can put more miles on the motor before a change of oil . so as i do use this oil. dont beleve me read the reviews on extended perfornance and comparisons. comparisons of oil does make a diffrence on witch weight of oil your reading about. all oils and difrent weight of oil are nor created equal. ester oil is a new tec of oil that leves a film of oil longer on the parts and breaks down slower. u could mix the ester oil with moble 1 . bottom line the first few oil changes in break in i did use ester iol now oi use moble 1 extended performance 5-30 it has extra protection more than amosoil 5-30 and roil perpole 5-30 remember weight of oil makes a difrence i will admit amosoil and roil perpole is very good oil amosoil in more weights of oil is best rated but not in every weght of oil. any issue of warentee does not mean u have to use ester oil period dont be fooled.
williammmurphy is offline
Old 09-07-2011, 12:37 PM
  #145
STARR's Avatar
I would go with Amsoil, everything I read about Royal Purple says it's an OK oil, and your paying more for the name and advertising, it's like paying more for Mobil1.
Used oil Analysis are no different then any other off the shelf synthetics, so only buy and use if you get it at a good deal
STARR is offline
Old 09-07-2011, 03:31 PM
  #146
Thanks for the info guys. Looks like I might go with the Amsoil if my Dealer gives me a good deal on the stuff. I use to buy the stuff by the gal. When I had a Diesel. I never ran Amsoil oil on a gas auto that I owned only ran Purple in them. But it is an expensive oil so I might go with the Mobil oil. I did read another page about this topic and it seems everyone runs mobil or ester oil. I've never heard of that oil either but will see where I can find that kind of oil as well. Thanks again guys
Old 09-09-2011, 10:56 PM
  #147
MaxLoverAz's Avatar
If you want a great deal on Amsoil you can purchase it from a sponsor here on the forum, member "talkinghorse" is really great, I can't recommend him enough.
http://forums.maxima.org/group-deals...ubricants.html
MaxLoverAz is offline
Old 09-11-2011, 11:00 AM
  #148
vlaframboise's Avatar
will try royal purple on next oil change.... very rough with my engine so i'll see how it goes with it.
vlaframboise is offline
Old 09-11-2011, 09:29 PM
  #149
Thanks for the link I will check it out when Im ready to order. Going in for my last service this weekend so will order my supply then.
Old 10-02-2011, 06:44 PM
  #150
Will's Avatar
I have about a quart of Nissan Ester Oil. Do you guys think it will be compatible with dino oil to put into my 5.5gen VQ35DE??
Will is offline
Old 10-03-2011, 06:34 AM
  #151
gizzsdad's Avatar
Not a problem at all.
gizzsdad is offline
Old 10-03-2011, 10:30 AM
  #152
DraKhen99's Avatar
I've been using Mobil 1 Full Synthetic since 5k, when I first had the oil changed. I've also used Nissan or Mobile 1 oil filters, changed with the oil. Oil changes every 5k miles, and with 21k on the clock, no problems yet.
I got the recommendation for Mobile 1 Full Synthetic right here in the 7th Gen forum.
I know I'm still at relatively low mileage, just thought I'd share.
DraKhen99 is offline
Old 12-08-2011, 05:34 PM
  #153
Torchcorvette's Avatar
Plenty of good info and reading here.
On the 2007 car, I cut over from dino to M-1 5W30 when the freebie LOFs ran out at about 15,000 miles. Car now has 85,000 trouble free miles. Intend to do the same with the brand new 2012 car. Also use the OEM 15208-9E000 filter in both cars.
Makes it easy for me...all 3 cars take same M-1 5W30 oil....now selling at Walmart for $26.62 for 5 qt jug.
Torchcorvette is offline
Old 10-31-2012, 04:00 AM
  #154
DA_BOI_D_DERRTY's Avatar
factory rims
anybody know where i can buy factory rims or if your selling yours? 2009 nissan maxima
DA_BOI_D_DERRTY is offline
Old 10-31-2012, 05:38 AM
  #155
PalmettoFellow's Avatar
A thread regarding oil and warranty service is not the place to ask about people selling rims. There is a section for that here, but I must admit, I can't point you to it...as I don't care about that section of this forum yet. Maybe someday
PalmettoFellow is offline
Old 03-03-2014, 08:16 AM
  #156
Ndirish147's Avatar
Auto Entry/Exit
I just purchased and 09 sv sport. How do i turn of the auto entry/exit if i dont have the navigation? thanks for the help
Ndirish147 is offline
Old 03-03-2014, 08:42 AM
  #157
Richard66's Avatar
Without Nav, turning it off is not an option.
Richard66 is offline
Old 03-03-2014, 10:12 AM
  #158
Ross2893's Avatar
Quiet frankly, Pennzoil Ultra 5W-30 is the best oil that can be put in this car or any car (with viscosity changes). Nothing compares and most just have a reputable name ie. Mobile1
Ross2893 is offline
Old 03-03-2014, 06:54 PM
  #159
pdub34's Avatar
Mobile 1 since 18k and at 78k no problems. As long as u don't use castrol u should be fine!
pdub34 is offline
Old 03-04-2014, 05:30 AM
  #160
silberma's Avatar
BMW dealers recommend Castrol synthetic in their turbo-charged engines. That oil is good for 12,000 miles or 1 year between oil changes. What is it that you know that BMW does not?
silberma is offline
Quick Reply: 09 Maxima Specific Oil!
