Go Back   Maxima Forums > Classifieds > Group Deals / Sponsors Forum
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-02-2006, 09:09 AM   #1
Maxima.org Sponsor and Donating Maxima.org Member
AMSOIL Synthetic Lubricants
Certified AMSOIL Direct Jobber, Maxima.org Sponsor and Donating Member offering complete line of AMSOIL Synthetic Lubricants and premium Ea filters, Wix filters, NGK spark plugs and ignition components, Trico wiper blades and Mother’s Car Care products. Wholesale pricing available. Over 25 year experience with AMSOIL synthetic lubricants. Nissan/Maxima enthusiast with over 20 years hands-on Nissan experience.
AMSOIL synthetic lubricants are formulated with premium base stocks and very robust additive packages. This chemistry enables the lubricants to provide superior protection in the most demanding operating conditions over extended drains. AMSOIL lubricants have been proven to maximize engine efficiency, reduce engine wear, maximize fuel economy, reduce emissions and prolong engine life. AMSOIL synthetic motor oils are ideal for both hot and cold climates. AMSOIL flows readily on cold-starts and it resists high-temperature breakdown much better than conventional oils do. AMSOIL synthetic motor oils resist the formation of sludge and varnish, keeping internal engine components sparkling clean, running cooler and most efficient. All AMSOIL synthetic lubricants are formulated for extended service life, thereby reducing the adverse environmental impact of waste oil.
AMSOIL XL Synthetic Motor Oils: AMSOIL’s “XL” (Extended Life) line of oils clearly outperform all petroleum oils and other brands of synthetics commonly available on the market today. These oils are recommended for the longest drain interval specified by the OEM. AMSOIL XL oils are API certified and are more cost effective for customers wanting a premium synthetic oil while maintaining the OEM’s recommended oil drain intervals. Available in 5w-20, 5w-30, 10w-30 and 10w-40, in quart or gallon containers. http://www.amsoil.com/lit/databulletins/g1404.pdf
AMSOIL "100% Synthetic Motor Oil": the original extended drain oil. Formulated for performance, not to a price. Delivers extraordinary lubrication in all types of automotive gasoline engines. Withstands the stress of higher horsepower, higher heat and complicated emission control systems. Delivers long-lasting performance and protection and can be used to extend drain intervals far beyond those recommended for conventional oils. Formulated for up to 25,000 miles or 1-yr of use (12,500 mi/1 yr in severe operating conditions). Its unique synthetic formulation and long drain additive system are very stable, resisting oxidation and neutralizing acids. These oils are an outstanding value in terms of quality, price and performance. Available in 0w-20, 5w-30 and 10w-30 in quart or gallon containers. 10w-30 also available in 2.5 gallon containers.
http://www.amsoil.com/lit/databulletins/g335.pdf
http://www.amsoil.com/lit/databulletins/g288.pdf
http://www.amsoil.com/lit/g1971.pdf
AMSOIL Signature Series 0w-30 replaces Series 2000 0w-30. Supplemented with a proprietary ashless antiwear system for improved heat and viscosity control and it boasts a 10 percent increase in TBN (13.2). Contains specialized anti-wear technology resulting in unsurpassed protection against wear under the most severe operating conditions. Thermally stable with a strong resistance to high temperature volatility (burn-off). Heavily fortified with detergent and dispersant additives to prevent sludge deposits. Formulated for up to 35,000 miles/1 year of use (17,500 mi/1 yr in severe service). Exceeds the requirements of modern, high-performance engines and is recommended for use in place of other 0W-30, 5W-30 and 10W-30 motor oils. Available in quart or gallon containers http://www.amsoil.com/lit/databulletins/g2445.pdf
Automatic Transmission Fluid: Meets Nissan-matic D, J and K specs. Excellent in demanding environments. Lasts much longer than conventional fluids for extended drain intervals. Superior hot and cold weather performance. Improves efficiency and can reduce operating temperature by as much as 50 deg F. ATF is available in quarts, gallons, and 2.5 gallon continers. http://www.amsoil.com/lit/databulletins/g173.pdf
AMSOIL Synthetic GL-4 75w-90 Gear Oil. Specifically formulated to provide proper synchromesh operation, smooth shifting and maximum gear protection. Not corrosive to yellow metals commonly used in synchromesh systems. Excellent cold-shift winter performance and outstanding protection in the most demanding high temp, high stress situations. Keeps seals pliable. http://www.amsoil.com/lit/databulletins/g2077.pdf
AMSOIL Brake Fluid: AMSOIL now offers Series 500 High-Performance DOT 3 and Series 600 DOT 4 Racing Brake Fluid. AMSOIL Brake Fluids provide superior high-temperature performance in auto/light truck, high-performance, racing and powersports applications. AMSOIL brake fluids are formulated with the best zinc-based anti-corrosion additives and pH stabilizers. They are specifically designed for high-temperature stability, yet they flow easily at low temperatures. The additive package used in these fluids provide good lubrication throughout the system and can raise boiling points to more than 232°C (450°F). It keeps water in suspension, slowing its effects on the brake system. AMSOIL Brake Fluids have high boiling temperatures, ensuring maximum life and reliable braking power, even in extreme conditions. AMSOIL Series 500 High- Performance DOT 3 Brake Fluid has a dry ERBP of 274°C (525°F) and wet ERBP of 156°C (313°F). AMSOIL Series 600 DOT 4 Racing Brake Fluid has a dry ERBP of 304°C (580°F) and wet ERBP of 210°C (410°F). Packaged in 12 oz bottles. http://www.amsoil.com/lit/databulletins/g2476.pdf
AMSOIL EaO Oil Filters: The most efficient oil filter on the market today. 98.7% efficient at 15 microns; and an amazing 98% efficient at 10 microns. Premium construction and components... Full, premium-grade synthetic nanofiber filtering medium provides outstanding efficiency, capacity and flow characteristics. Silicone anti-drainback valve. Guaranteed for 25,000 miles/1 year when using AMSOIL synthetic motor oil under normal service. http://www.amsoil.com/lit/databulletins/g2192.pdf
WIX Oil Filters: A top tier filter oil filter ideally suited for use with AMSOIL XL oils or at more traditional drain intervals. Provide 7500 miles or more of protection.
AMSOIL EaA Air Filters: Unique nanofiber technology has air flow characteristics comparable to a wet gauze filter yet it is 50X more efficient and has 15X the dirt capacity. Uses new nanofiber technology for superior efficiency, air flow and cleanability. Dry-type filter uses no oil so it is safe for MAF sensors. Easy to clean with low-pressure shop air or with a vacuum cleaner...no expensive cleaning kits required. Guaranteed 4 years, 100,000 miles. http://www.amsoil.com/lit/databulletins/g2175.pdf
AMSOIL EaAU Cone-type Air Induction Filters: Same nanofiber technology described above. These filters are designed to replace stock oil-wetted gauze or foam conical filters that were supplied with popular induction systems. These filters are of excellent quality; they offer much better efficiency, excellent air flow and they are easily cleanable. Pls refer to my web site at www.lubedealer.com/lonestarlubes , "Shop-On-line", "Air filters", for sizing. http://www.amsoil.com/lit/databulletins/g2241.pdf
http://www.amsoil.com/lit/databulletins/g2585.pdf
WIX Air filters, Fuel Filters and In-Cabin Micro-filters; Trico Wiper Blades: Complete Line Available
Mothers Car Care Products: Complete product line available in one place, discounted. http://www.amsoil.com/lit/g2310.pdf
Complete line of AMSOIL synthetic motor oils, two-cycle oils, filters, grease, fuel additives, suspension fluids and other products available for cars, trucks, HD equipment, motorcycles, ATV's, boats, jet skis, snowmobiles, lawn and garden equipment, etc. Data Bulletins and Specialty catalogs available for free upon request.
To view detailed product information on-line, visit my website at www.lubedealer.com/lonestarlubes
Outstanding, personal service; excellent feedback/references. Please contact me directly at eandersonjr@satx.rr.com or send PM for additional information, Preferred Customer membership benefits & pricing, and personalized price quote. Please include state of residence or zip code so I can calculate the sales tax/shipping. PayPal & VISA/MC/AMEX/Discover accepted.
talkinghorse is offline   Reply With Quote
Old 07-12-2006, 07:51 AM   #2
Price quote for 5 quarts of AMSOIL synthetic 75W-90 GL-4 oil shipped to 72173 please. Thanks!
Timothios is offline   Reply With Quote
Old 07-12-2006, 07:42 PM   #3
Quote:
Sent you a PM with the cost and ordering info...pls let me know if I can help.
Old 07-20-2006, 07:27 PM   #4
Amsoil 5sp. oil
Email quote 5 quarts 5sp. oil shipped to 45242
gatmax97 is offline   Reply With Quote
Old 07-21-2006, 06:02 PM   #5
Quote:
Sent you an e-mail with the price and ordering info. Please let me know if I can help.
Old 07-21-2006, 07:16 PM   #6
What we have here is a failure to communicate
Snolife's Avatar
Email quote for one case 100 % synthetic 5w-30, stock Oil and air filter for 03 Max. to 90670.
Not sure how many quarts I need for a transmission flush, one?
thanks.
Snolife is offline   Reply With Quote
Old 07-22-2006, 07:37 AM   #7
thanks.
Sent you an e-mail per your request...pls let me know if you don't receive it.
Concerning your transmission, Manuals do not need to be flushed and they take 5 quarts of GL-4 gear oil. Automatics can be serviced either by draining and refilling or by doing a complete flush. I generally recommend folks have 6 quarts of ATF on hand to do a drain/refill, and a case (12 qts) for a complete flush. Any left-over fluid can be used in your power steering system...the synthetic ATF also works great in there. Let me know if you have any additional questions or if you want to order...very easy process :-)
Old 09-01-2006, 02:37 PM   #8
Send a message via AIM to PakiPlaya07
Sent you a PM.
PakiPlaya07 is offline   Reply With Quote
Old 09-01-2006, 11:11 PM   #9
Mr.Duck's Avatar
Send a message via AIM to Mr.Duck Send a message via MSN to Mr.Duck
hey i need 4 quarts of 100% synthetic oil, and an Ea oil filter... PM me price please
Mr.Duck is offline   Reply With Quote
Old 09-02-2006, 06:49 AM   #10
Send a message via MSN to Blackwind
Price quote for 5 quarts of AMSOIL synthetic 75W-90 GL-4 oil shipped to 98012,
thanks
Blackwind is offline   Reply With Quote
Old 09-02-2006, 07:34 AM   #11
Quote:
thanks
PMs sent to you and Mr Duck. Let me know if I can help. thx
Old 09-02-2006, 10:43 AM   #12
Send a message via AIM to four
Ed,
I just sent you payment via paypal for 6 QTs of Amsoil ATF.
Let me know if you got it. I couldn't reply to your PM for some reason, so I'm just letting u know here.
Thanks for the hook up.
Noel
four is offline   Reply With Quote
Old 09-04-2006, 03:26 PM   #13
5.5 gen stock air filter replacement shipped to 33177 please.
ShIft_uR FacE is offline   Reply With Quote
Old 09-08-2006, 11:08 AM   #14
Quote:
Sent you a PM with the price and ordering info. These are very high quality filters. Please let me know if I can help.
Old 09-12-2006, 07:02 AM   #15
Send a message via AIM to 96mAx2fast
Good morning,
How many quarts of tranny fluid (gear fluid) would I need for my 5-speed, 96 maxima SE. Is this something like redline MT-90? Im looking for something to significantly improve my shifting and help my tranny, as it has 112k miles on it and I'm replacing the clutch and flywheel very shortly...
Please let me know how much it would be shipped to Harrison, NJ 07029
Waldemar
__________________
For Sale: Tons of 4th gen Maxima Parts
Inquire via email:wg00@optonline.net
*Minutes from NYC*
96mAx2fast is offline   Reply With Quote
Old 09-12-2006, 08:04 AM   #16
Send a message via AIM to speed racer
Ed,
I sent you a pm yesterday. I would like to order a case (12 quarts) of 5W-30 fully synthetic to 10465.
speed racer is offline   Reply With Quote
Old 09-12-2006, 05:20 PM   #17
Quote:
Originally Posted by 96mAx2fast
Good morning,
Waldemar
You will need 5 quarts of gear oil for your transmission. Sent you a PM with the cost and ordering information. AMSOIL MTG is a high quality 75w-90 GL-4 synthetic lubricant I sell a lot of it to our members. Here is a link to some product information: http://www.amsoil.com/StoreFront/mtg.aspx Please let me know if i can help...
Old 09-12-2006, 05:23 PM   #18
Quote:
Originally Posted by speed racer
Ed,
Sorry, but I didn't receive the PM...thanks for posting. Sent you a PM with the cost and ordering information. Let me know if you don't receive it. thx
Old 09-12-2006, 09:13 PM   #19
5.5 gen air filter replacement shipped to VA, 22046 please.
hogey228 is offline   Reply With Quote
Old 09-13-2006, 06:44 PM   #20
Quote:
Sent you a PM with the cost and ordering info. Please let me know if I can help. thx
Old 09-13-2006, 07:50 PM   #21
air filter, oil filter (x2), and a case of full synth shipped to 40503
-for a 2002
jtmoor002001 is offline   Reply With Quote
Old 09-13-2006, 09:08 PM   #22
air filter payment sent via paypal. thanks
Old 09-14-2006, 04:20 PM   #23
Quote:
-for a 2002
Your ability to receive PMs is disabled. Please send me an e-mail (address in the original post) and I will respond with the quote and ordering information. thx
Old 09-14-2006, 10:12 PM   #24
email sent thnx
Old 09-14-2006, 11:31 PM   #25
what can my max do for me
please send a quote for 5qts of GL-4 shipped to 08043
thank you
__________________
October, 2009 - the conversion to electric begins.
for sale - anything related to internal combustion is up for sale
DaWifey's90 is offline   Reply With Quote
Old 09-15-2006, 04:06 PM   #26
Quote:
thank you
Done... Please let me know if I can help. I think you will be very happy with the oil...I sell a lot of it to our members. thanks...
Old 09-16-2006, 11:46 PM   #27
Send a message via MSN to 96blkonblkse
AMSOIL Synthetic GL-4 75w-90 9 quarts shipped to V3W6J5, Vancouver, BC, Canada. If you could PM me a price quote with shipping.
96blkonblkse is offline   Reply With Quote
Old 09-18-2006, 08:02 PM   #28
Quote:
Sent you a PM with some options. Pls let me know if I can be of further assistance. thx
Old 09-19-2006, 06:39 AM   #29
I received your request for money...
Payment sent! Please email me the tracking number.
__________________
*Minutes from NYC*
Old 09-19-2006, 11:16 AM   #30
Send a message via AIM to mitch33x
Quote:
Ed,
I sent you an email, I need 5 quarts of the Amsoil Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4 shipped to 08502. Please let me know the exact cost and I can PayPal you ASAP. Thanks.
__________________
97 SE Daily Driver/Weekend Road Racer
mitch33x is offline   Reply With Quote
Old 09-19-2006, 05:20 PM   #31
Ordered today, shipped today, will be delivered tomorrow. Sent you an e-mail with the tracking number :-) thx
Old 09-19-2006, 05:23 PM   #32
Quote:
Originally Posted by mitch33x
Ed,
Info sent per your request...let me know how I can help.
thx, ed
Old 09-22-2006, 06:49 PM   #33
Send a message via ICQ to DuMKuH Send a message via AIM to DuMKuH Send a message via Skype™ to DuMKuH
Hi, I need 5 quarts(how much do I need for 98 Maxima) of gear oil GL-4, whats the best viscosity numbers also? I am in NYC. Thank you.
DuMKuH is offline   Reply With Quote
Old 09-22-2006, 07:18 PM   #34
Quote:
You will need 5 quarts of GL-4 Gear oil and the best viscosity would be 75w-90. Sent you a PM with the cost and ordering info...pls let me know if i can help.
Old 09-30-2006, 04:43 PM   #35
IN IRAQ MAXIMA.ORG-ING :)
Engine Oils: AMSOIL 100% Synthetic 5w-30 $63.00/case ($83.40 retail)
Transmission Fluid: AMSOIL ATF $76.20/case ($104.40 retail)
a case of both... shipped to 07013... how much
KabirUTA13 is offline   Reply With Quote
Old 10-01-2006, 06:12 AM   #36
Sent you a PM with the cost and ordering information. Please let me know if I can be of help. thx
Old 10-04-2006, 04:50 PM   #37
Livin dreams thru his Maxima
alleydawg6's Avatar
AMSOIL Synthetic GL-4 75w-90 Gear Oil shipped price for 6 quarts to 07501 .... thank you
__________________
alleydawg6 is offline   Reply With Quote
Old 10-04-2006, 05:22 PM   #38
Quote:
Sent you a PM with the cost of 6 quarts and for 5. Please let me know if I can be of help. thx
Old 10-04-2006, 07:20 PM   #39
charr82's Avatar
Send a message via AIM to charr82
Price quote for a case of transmission fluid and air filter.
Shipped to 43302
2003 GLE
Thanks!
charr82 is offline   Reply With Quote
Old 10-05-2006, 03:25 PM   #40
How much for 5 quarts of the 75w-90 GL-4 MTF shipped to 42122? Thanks
whitemax21 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
