5th gen parts fit 6th gen?
Old 01-15-2009, 05:35 PM
silverbeast2004's Avatar
hey guys i'm pretty sure it's been asked and discussed and i've searched but found nothing. will 5th gen performance parts fit 6th gen? for example, headers? thanks in advance!
silverbeast2004 is offline
Old 01-15-2009, 05:41 PM
04MAX_ILLIN's Avatar
Im gonna have to say i doubt it but this is with no knowledge of the 5th gen at all. Reason being that if 5th gen headers fit the 6th gen then nearly ALL of us on the A34 side would have headers on our cars already.
04MAX_ILLIN is offline
Old 01-15-2009, 05:49 PM
yea i was thinking the same thing. But if i'm not mistakened, the 5th gen has the same engine, or is very similar to the 6th gen engine.
Old 01-15-2009, 06:17 PM
Feldman's Avatar
i think the 5.5 gens technically would bolt up to the 6th gens but i think i remember cattman having trouble with clearance issues and cel's on the 6th gens so i bet they arent swappable
Feldman is offline
Old 01-15-2009, 08:31 PM
Hmm that sounds more like it actually. I think the difference is egr and no egr. No egr on the 5.5 The 6th gen does have 1.
Old 01-16-2009, 05:44 PM
So then it's basically just the clearance. And can't we always get an egr port put on so it fits?
Old 01-16-2009, 06:46 PM
KC's FINEST
KCMAXX's Avatar
You'd be better off asking the fifth genners.
There's also a performance/motor section.
KCMAXX is offline
Old 01-16-2009, 07:03 PM
Puppetmaster's Avatar
You can't use 5.5 Gen headers on a 6th Gen or Alti, at least, not the way they come from the manufacturers. Take a look under each and you will see why.
4th, 5th, and 5.5 Gen Maximas have a subframe piece commonly referred to around here as a cross member while the 6th Gens have a cradle looking subframe. The y-pipes therefore have to be completely different. You could use the headers with a custom y-pipe, but I'm not sure how cost effective that would be as opposed to just buying a set from Cattman. Even then I'm not sure the angle at which the collectors from each bank comes down would work, because the headers are designed to go with a specific y-pipe.
5.5 Gen (Derrick2k2SE and mine):
6th Gen (chernmax's):
From here: http://forums.maxima.org/4189488-post131.html
Puppetmaster is offline
Old 01-16-2009, 07:09 PM
The headers LOOK similar in the pictures, but they are different. The main difference is still the y-pipe though.
Compare here:
http://forums.maxima.org/5th-generat...es-4-38mb.html
And this picture of Gen II Cattmans for the prev gens:
Vs chern's picture of his old Hotshots here:
You can see that the rear bank collector flange on the 6th Gen headers curves toward the front of the car while the 5.5 Gen header collector flanges point straight down, from what I can see from the pics.
Old 01-16-2009, 09:19 PM
*moderator*
jsmithsole's Avatar
I would assume if the 5th gen headers did fit there'd be alot of us that would of had them along time ago and Cattman would not have taken the time to develop 6th gen headers....
jsmithsole is offline
Old 01-17-2009, 06:51 AM
That's the short answer.
Old 01-18-2009, 05:14 PM
Maxpwr13's Avatar
All good information...Thank's
Maxpwr13 is offline
CRizz
41
06-07-2021 05:42 AM
Finkle
09-27-2015 09:53 PM
ef9
08-27-2015 07:21 AM
2k0to2k3
08-18-2015 09:59 AM
kirkhilles
08-08-2015 10:53 AM
Quick Reply: 5th gen parts fit 6th gen?
