Go Back   Maxima Forums > Maxima Discussions > 6th Generation Maxima (2004-2008)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Closed Thread
Thread Tools Display Modes
Old 06-29-2005, 06:18 AM   #1
my rear view mirrors flap like a f-ing bird
Tek-Niq's Avatar
Send a message via AIM to Tek-Niq Send a message via Yahoo to Tek-Niq
6th Generation Modification Information
with the entire forum revamp, to see old links: change "showthread" to "oldthread" in your address bar after clicking the link. http://forums.maxima.org/showthread.php?t=537445
make sure to visit the other forums of the org dealing with Advanced
Performance:
http://forums.maxima.org/forumdispla...sprune=-1&f=54
feel free to dicuss here: 6th gen mods
Suspension:
#2 FSTB (Front Strut Tower Brace)
#3 RSB (Rear Sway Bar)
#4 Coilovers
#5 Lowering Springs
#6 Adjustable Struts/Shocks
Performance:
#7 Y-Pipe
#8 UDP (Under Drive Pulley)
#9 Exhaust
#10 Mufflers
#11 Intakes
#12 Intakes Cont.
#13 Short Throw Shifter
#14 Phenolic Thermal Intake Manifold Spacers
Mods vs. Warranty
Make sure to also visit the "How To" Sticky to see detailed write-ups and other ideas.
Click the link above or scroll through the thread to appreciate the hard work of members and options for the 6th Gen Maxima. Links are provided for discussion on each modification.
Please PM Tek-Niq or NismoMax80 to contribute any info on installation/results.
try and do it in this fashion:
MOD:
PRICE:
a web site of WHERE TO GET IT (the more sites the better)
HOW DOES IT PERFORM:
install DIFFICULTY: (here put a * for difficulty..... 5 being the hardest * * * * *)
comment:
Links to existing Threads:
posted by: (your name here)
Tek-Niq is offline
Old 06-29-2005, 06:24 AM   #2
Tek-Niq's Avatar
Strut Bar
Mod: Front Strut Tower Brace (FSTB)
Price: $42-$149
Available: at www.stillen.com , www.ebay.com
Performs:
One of the most common upgrades on a modified car is mounting Strut Bars. A Strut Bar (also known as strut tower bar or strut brace) is designed to tie the two opposing strut towers together as a single solid unit. The purpose of a strut tower bar is to reduce flex that these towers experience during hard cornering. When taking a turn a car's strut towers normally flex, resulting in bodyflex and losing some traction.
As Strut Tower Bars are designed to keep your strut towers from flexing, they distribute the pressure applied to one strut tower when taking a turn to both towers instead of just one.
Install Difficulty: * (5 being the hardest)
http://forums.maxima.org/showthread....highlight=FSTB http://forums.maxima.org/showthread....ut+bar+rubbing
pic by: Chernmax
Tek-Niq is offline
Old 06-29-2005, 06:29 AM   #3
Tek-Niq's Avatar
Rear Sway Bar
Mod: Rear (Anti-)Sway Bar
Price: $139-$159
Available: www.stillen.com , www.cattman.com
Performs:
A component that's often used in a suspension system to control body roll. A sway bar may be used on the front and/or rear suspension to help keep the body flat as the vehicle rounds a corner. This greatly improves a vehicle's cornering agility. Replacing the sway bar with one of a larger diameter can increase it even more.
The Maxima comes stock with a light-hollow oem RSB. This upgrade will eliminate most body roll (lean) in hard turns.
Install Difficulty: * * (5 being the hardest)
Stillen: hollow yet stiffer/heavier than stock, only fits 04, use stock rubber bushings (try to buy G35 bushings).
Progress (Cattman): solid, even stiffer and obviously heavier than hollow ones. fits 04 & 05, Polyurethane bushings, powdercoated.
http://forums.maxima.org/showthread....&highlight=rsb Where is your radar detector mounted? wtb: stock y pipe
pic by: Chernmax
upgrade your RSB endlinks:
http://forums.maxima.org/showthread.php?t=473375
http://forums.maxima.org/showthread.php?t=475817
Tek-Niq is offline
Old 06-29-2005, 06:44 AM   #4
Tek-Niq's Avatar
Coilovers
Mod: Coilovers (K-sport, D2)
Price: $1,100- 1,200 (org group buy $740)
Available: group deals here on the ORG www.ksportusa.com , www.nolimitmotorsport.com
performs:
Coilover Kits provide the ultimate in suspension technology featuring its 36-way adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. The Coilovers has been designed with professional road racing in mind offering extremely high value and performance.
Coilovers replace springs and front struts and rear shocks. They allow you to adjust ride height and stiffness.
Install Difficulty: without air tools * * * * *, with air tools * * (5 being the hardest)
**side note: do some research before buying a spring and strut set up.. look around for coilover deals, there is a possibility you can get a fully adjustable suspension set up for less than a normal spring/strut set up.. sometimes a few dollars more.. 880 for a regular set up vs the 740(if you get a deal) for a full adjustment coilover set up..**
http://forums.maxima.org/showthread.php?t=406790
pics installed here
Tek-Niq is offline
Old 06-29-2005, 08:11 AM   #5
Tek-Niq's Avatar
Springs
Mod: Lowering Springs
Eibachs-(front drop 2.0", rear drop .08"), H&R-(front drop 1.4", rear drop 1.3)
price: $220-$307
available: www.stillen.com , www.ebay.com (google for lower prices)
performs: **pm me with your opinion**
Most install lowering springs for a low cost means of reducing wheel gap and lowering their car.
Install Difficulty: * *(with proper tools, harder with out)
Curb Rash Bye bye! 19" HP Evo Lightings
pics installed here
Eiback issue fix: http://forums.maxima.org/showthread.php?t=437937
Tek-Niq is offline
Old 06-29-2005, 08:18 AM   #6
Tek-Niq's Avatar
Active tuning Struts
Mod: Koni Struts (front) KYB AGX Shocks (Rear)
Price: front-$375, rear-$255
available: www.activetuning.com
performs: **pm me with your opinions**
When lowering the Maxima, this mod ensures you do not blow your oem struts or shocks which are not designed for a lowered ride. You can adjust the ride from soft to stiff. This is a cheaper alternative than coilovers.
Install Difficulty: * * (with proper tools)
Tune-up
Tune-up http://forums.maxima.org/showthread....78#post3310678
Tek-Niq is offline
Old 06-29-2005, 08:32 AM   #7
Tek-Niq's Avatar
Y-pipe
Mod: Y-pipe
Price: $300
Available: www.customenterprise.com
performs:
The long wait is over, Custom Enterprise is proud to announce the newest item to our product line, a high flowing race y-pipe for your 2004+ Maxima. Once again Custom Enterprise is the first to offer this product on the market today. The 2004 3.5L Maxima engine already is the fastest stock Maxima ever, now you can make it even faster. With precise mandrel bends, tig welding and stainless steel construction, you are sure to have precise fitment and maximum horsepower gains. Other companies have attempted to design this part with minimal success due to the fact that their y-pipes make the exhaust extremely loud. Not ours, adding the Custom Enterprise Y-Pipe will add little if any additional noise to your exhaust system, the competition can't say that. The flex section on our y-pipe also sets it apart from the competition. Many other y-pipes on the market save on cost by using a cheaper lower quality flex section, this results in an annoying “bee buzzing” sound under acceleration. We are sure you have heard one of your Maxima buddies complaining about this before. The Custom Enterprise y-pipe flex section was manufactured to ensure a smooth even flow with no “bee buzzing” sound.
Be the first to have this long sought after part. We recommend having a second set of tires on hand, because you will be spinning your tires real easy!!
OEM(factory)
CE pipe
pics by: Chermax
Tek-Niq is offline
Old 06-29-2005, 08:40 AM   #8
Tek-Niq's Avatar
Under Drive Pulley
Mod: Southwest Autoworks and Unorthodox UDP
Price: $95-$190
available: www.customenterprise.com, redlinemax.com, www.sportcompactonly.com
performs:
Our Underdrive Series of pulley sets provide power gains through weight loss and through the underdriving of all the accessories (which accounts for about 15% additional gain).
However, we do not push underdriving for two main reasons. First, it is important to keep charging systems, air conditioning, power steering, and water pumps moving fast enough for every day driving. Second, not much horsepower is gained from extreme underdriving.
In most applications all of our underdriving is done with the crank pulley, not the accessory pulleys. This is done so maximum weight loss can be achieved at the crank where most of the horsepower gains are found.
Power gains are still achieved with these billet aluminum pulleys. The reduced rotational mass allows for more power transfer to the drive wheels. 80% of the gains seen with racing pulleys is from weight loss.
thanx to: Chernmax
Info on Benefits
Belts needed: http://forums.maxima.org/showpost.ph...0&postcount=43
Install difficulty: **pm me with your opinions**
INSTALL HOW TO<---click
http://forums.maxima.org/showthread.php?t=357166
pic by: Ramberg
Tek-Niq is offline
Old 06-29-2005, 08:51 AM   #9
Tek-Niq's Avatar
Exhaust
Mod: Greddy Sp-ll Catback Exhaust, Stillen Exhaust, Cattman
Price: around $620-$900
Available: www.customenterprise.com, www.stillen.com
Performs: **pm me with your opinions**
FS: Brand New 4th Gen Oil Pressure Switch
Greddy system:
Greddy:
pic by: Ramberg
Greddy:
pic by: Chernmax
Cattman:
pic by: Deusexmaxima
Tek-Niq is offline
Old 06-29-2005, 09:00 AM   #10
Tek-Niq's Avatar
Magnaflow Mufflers
Mod: muffler section only
Price: $100- $140
available: www.magnaflow.com www.ebay.com (google for info)
Install Difficulty: **pm me with your opinions**
part# 14830
pic by: 04redopmax
part# 14816
pic by: K.C. maxx
Tek-Niq is offline
Old 06-29-2005, 09:21 AM   #11
Tek-Niq's Avatar
Intakes
Mod: Berk, Frankencar, Injen, Jim Wolf, NISMO (04-05 yes, MAXIMA!), Stillen, Weapon R, AEM
Price: $265 and under
available: www.stillen.com , www.ebay.com , www.berktechnology.com , www.jimwolftechnology.com , www.frankencar.com www.redlinemax.com (google for info)
Discussions:
Oil cooler on an SCed Maxima.... can we use our existing oil feed line?
BFG Drag Radials 225/50/R15
http://forums.maxima.org/showthread.php?t=432786
**need pics of the rest please**send me a pm with you site.. or e-mail pito3061@yahoo.com
injen:
pic by: Ramberg
Install
injen w/ MR Tech:
Berk:
pic by: Jsmithsole
Stillen:
pic by: Blaxima
Stillen CAI:
Tek-Niq is offline
Old 07-27-2005, 02:29 PM   #12
Tek-Niq's Avatar
Intakes continued
JWT pop charger:
pic by: Nick Wolff
AEM:
pic by: Doctor Wicked
MOD: NISMO COLD AIR INTAKE(Altima version--Maxima now available)
PRICE: $269.00
a web site of WHERE TO GET IT: www.performancenissanparts.com Jerry Rome Nissan
HOW DOES IT PERFORM: Good, read link
install DIFFICULTY: *
comment: Too many pieces to the unit.
Links to existing Threads: http://forums.maxima.org/showthread.php?t=432805
posted by: MAXIMAM
Weapon R
pic by: Kicks26
FUJITA
plus sound clip:
http://tekniq.homelinux.net/video2/tekniq_dyno.wmv
pic by:Tek-Niq
Tek-Niq is offline
Old 07-27-2005, 06:15 PM   #13
SuPeRmOd
NismoMax80's Avatar
Short Throw Shifter
MOD: Short Throw Shifter
PRICE: $159
Available: at www.ActiveTuning.com www.stillen.com
Performs:
This shifter is easily installed onto the transmission in under an hour with simple hand tools, and reduces the fore and aft throw by 37% for fast, smooth shifts.
install DIFFICULTY: * * * (5 being the hardest)
comment: This shifter is easily installed onto the transmission in under an hour with simple hand tools, and reduces the fore and aft throw by 37% for fast, smooth shifts.
Howto: Y-pipe Install for cars that see winters
NismoMax80 is offline
Old 11-29-2007, 06:16 PM   #14
SuPeRmOd
NismoMax80's Avatar
Mod: NWP Engineering Phenolic Thermal Intake Manifold Spacers
Price: $225
Available: at www.nwpengineering.com
Performs: The NWP Engineering Thermal Intake Spacers are made of a high quality durable type of phenolic and prevents heat from transferring to the intake manifold. The intake manifold temperatures decrease by 40 degrees on AVERAGE and the spacers yield an average dyno proven gain of 10hp and 12ft-lbs of torque. Your car will no longer feel sluggish due to heat soak after it warms up!
The kit comes with 5 spacers which include two Lower Intake Manifold Spacers, an Upper Intake Manifold Spacer, an Elbow Spacer, and a Throttle Body Spacer. The kit also includes all the fasteners and hardware needed as well as printed installation instructions.
All spacers are CNC Machined to the highest tolerances and are port matched. Port matched intake spacers is a very important aspect, since the poorly sized OEM intake gaskets are no longer used. This drastically improves airflow over stock! Also, the spacers can be reused as many times as you like since they will not misshape, soften, or warp over time. They will easily outlast the life of your vehicle!
Installation Difficulty: * * (2-3 labor hours)
Links to Existing Threads:
Phenolic Spacer Development for VQ35s
Thermal Phenolic Intake Spacer Kits - ELIMINATE HEAT SOAK!! - 10hp and 12ft-lb GAIN!!
Closed Thread
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
