How To Do The 07-08 Swap & What's Needed For Install
Old 01-30-2010, 08:38 AM
thealliance43's Avatar
Hey Guys,
I've been getting a lot of e-mails lately on people asking how to do the 07-08 and what's needed/not needed for install.
Here's What's needed for a complete install:
07-08 Headlights: Avg. $250-$500
(They make both HID headlights and Halogen so beware when buying)
07-08 Hood: Dealership Price $300-$400
(One of the hardest parts to find. If you can find one Grab it!)
07-08 Fog lights: Avg. $200
(One of the easier things to find, I have a pair if anyone needs it)
07-08 Fog light Covers : Avg $20
(These are the cheapest and easiest to get)
07-08 OEM Or Aftermarket Grille Oem Avg. $30 Aftermarket Avg. $200
07-08 Bumper Avg. $200
As you can see it can be a pricey modd. But WELL worth it. This and the led modd are by far the best two modds on my car. But now to clarify acouple of things people are worried about:
Do you need to get the 07-08 Hood?: Yes/No. You can get yours modded but that will take the autobody place you go to at least 1-2 weeks. If you are trying to cut costs you can use your 04-06 hood but there will be gaps. I admit i drove around for about a month looking for a hood before I found one. It's almost like your car has slanted evil eyes.
Do you need new fenders?: No way! I don't know who ever said that. But I keep getting asked and thats False information. Your stock 04-06 Fenders will work fine. No need to modd them.
Are the headlights Plug and play?: Yes. They are completely plug and play. Only thing that won't work is your parking lights and your fogs. You'll have to re-wire them. Check the bottom of this thread for more info.
How's the Bumper Bolt Up? It's directly the same fitment as the 04-06 bumper.
Are all 07-08 headlights factory Xenon/HID?: No! Be careful what you buy and make sure they are HID if you want to upgrade or stay with HID fogs. You won't lose any lighting if you stay with HID. I highly recommend getting HID headlights if your converting.
What's needed with these fogs?: The fogs are H11. I personally just bought an H11 6000k HID kit. I recommend searching for an H11 harness so if you want to convert back to stock or have your HID's plug and play you can do that. H11 harness is rather cheap depending on where you get it.
How Do I Wire These Things up? Well, Lucky for you I made a thread and will include it for you lol. Check out my step by step method of fixing the parking light problem and fogs.
Figure i'd write up a little "how to" on installing fogs from a 6thgen to a 6.5gen
Step 1: Disconnect wiring harness from your headlights....
Cut back the black tape/tubing so you can see your color wires
You see there's a black wire (Ground) and a white wire (Pos) for the fogs...
Cut them from the harness...
It's the corner part of the wiring harness....
now extend these wires about 2 feet down to you have some slack and test your fogs...
NOTE: I actually had the connectors so it was easier for me to test... some of you might need to make your own harness or get H.I.D.'s to finish this step...
once you did that your pretty much done... make sure your connections are good and sealed tight...
also make sure you test everything out
If you guys decide to get the 07/08 headlights you will notice once you plug it in to the stock harness the parking lights will not light up. In order to fix this you must take the original harness to the car and cut the ORANGE and THE RED N BLUE wire and splice them together. This will eliminate the problem and the parking light will function normally.
If you guys are still having some problems. I helped out acouple of members do the install and I'm always down to help anyone else out.
Just PM me. I live right on Long Island.
Good luck! Hope this helps out some people
thealliance43 is offline
Old 01-30-2010, 08:41 AM
Here you go guys....
The long awaited modd is almost fully complete
SAY GOODBYE TO THE 6TH GEN FRONT! :ashamed:
THE OLD BUMPER! :ashamed:
OH SH*T! My CAR'S BEEN JACKED! lol
IT'S NIGHTTIME AND I'M STILL AT IT...WHAT A SHOCK LOL
Old 01-30-2010, 08:43 AM
I3LAZEN's Avatar
STICKY STICKY STICKY
I3LAZEN is offline
Old 01-30-2010, 11:15 AM
RAZ76's Avatar
Good stuff, he helped with my swap but there's something I like to add if the OP doesn't mind.
Remember on the 04-06 we have the side lights that come on whenever we use the turn signal. You will have to do that on the 07-08 heads. On the 07-08 heads that light is inside the head. Easy fix if you know how to re wire some stuff.
This is what I did. I extend the wires coming from those side lights to my harness(car side) and connected to the wires that the fog lights were. The ones you cut to extend to your 07-08 fogs.
In other words, two wires go down to the fogs now and two up.
RAZ76 is offline
Old 01-30-2010, 12:01 PM
timwdv's Avatar
great write up
timwdv is offline
Old 01-30-2010, 12:07 PM
slvrmax7's Avatar
Nice job man!
slvrmax7 is offline
Old 01-30-2010, 06:55 PM
awdturbo325's Avatar
Awesome writeup !! Greatly appreciated! I look forward to completing my 07/08 front end swap now that I know everything involved, just need to decide if I want to spend a little extra swapping headlights and hood or just modify the contour lines on my 04 hood.
awdturbo325 is offline
Old 01-30-2010, 09:34 PM
PetitFrereMaxima's Avatar
I am really impressed by how some people share some very great infos like this. Do we need to pay you? I mean, as generous as it is, I wish you could be compensated in some way. Well, God will bless your kindness.
Keep up the great work.
PetitFrereMaxima is offline
Old 01-31-2010, 06:58 AM
slvrmax7's Avatar
I would HIGHLY reccomend getting the 07/08 hood as well man! The lines in it are awesome and flowi n to the bumper in a sharp way...JMO
slvrmax7 is offline
Old 01-31-2010, 09:39 AM
SHIFT_my stick
lblackonblackl's Avatar
awesome write up... im actually in the process!!!
lblackonblackl is offline
Old 02-01-2010, 07:35 AM
Yea after browsing through pics for the last several hours I think I am now 100% sold on a full on 07/08 conversion. Judging by prices i've been seeing maxima bumpers, hoods, lights. and grills sell for in the classifieds, on 6thgen forums, ebay, and junkyards I think I may be able to somewhat break even (excluding paint cost and fogs) after selling off my 04 parts so I may not lose the arm and leg I originally expected!
Along w/ the front swap, I'm looking for 07/08 mufflers since mine are dented anyway. Thanks previous owner! My '04 rear bumper also has a 4" crack, albeit not that noticeable, from bottom lip passenger side. So probably a 07/08 rear bumper in the future as well. This, along with the front end swap, will complete the full-on 07/08 exterior conversion correct?
Old 02-01-2010, 03:44 PM
hmr1979's Avatar
Anyone have pix of 06 headlights with 07-08 bumper. I am wondering if it looks good, to save some bucks.
hmr1979 is offline
Old 02-01-2010, 04:09 PM
slvrmax7's Avatar
Yes-search the 07-08 front lip prototyping thread, there is a white 6 gen with them on the first page it is I believe. I Strongly recommend getting the 08 lights though- otherwise you will be slamming your hood to close over the 04 lights. Also there are gaps around parts of the 04 lights that I had to "fill" with black garage door sealant foam lol.....get the 08 lights man.
slvrmax7 is offline
Old 02-02-2010, 04:20 PM
hmr1979's Avatar
LOL I guess i need to shop for some black garage door sealant foam soon huh
And yeah, that hood is no where to be found.
hmr1979 is offline
Old 02-03-2010, 10:10 AM
xTeCaOx's Avatar
definitely get the 07-08 hood when doing the swap.... when i did mine i just got the bumper, hood and c-mod grille to complete mine, i kept my 05 lights because i had already modded them (took out amber lens, painted, and angel eyes).... check out sig for pics
xTeCaOx is offline
Old 02-03-2010, 07:45 PM
Any problems w/ closing the hood? Maybe I will start w/ hood, bumper, and grill and swap headlights down the road when I stumble onto an HID 07/08 pair at a cheap price.
Old 02-03-2010, 08:05 PM
wow thank you for the kind words. I'm just here to help some ppl out. Glad I could help alot of members...I mean your more then welcome to pay me though lol
Old 02-03-2010, 08:34 PM
RAZ76's Avatar
I got everything but the hood. That is the hardest to find. I called my local dealer and it's 468 + tax. If nothing comes along when time comes, I might just have to go the dealer route.
Only thing left is the hood for me. Aready rewired the heads and run the fog wires. Blacked out the heads. Im going to paint the bumper in few weeks.
RAZ76 is offline
Old 02-07-2010, 02:33 PM
Propa Teknique's Avatar
I want to finally complete this mod but I had a question. Being I have a 6th gen and our original fogs are in the headlights, I wanted to convert those to HID along with the ones that I will put in the bumper. If I cut the black and white wires from the headlight harness will this mess up the foglights in the 6th gen headlights from working?
To get both sets of foglights (in headlight & in 6.5 bumper) working correctly, will I need to splice the wires from each set together??
I'm totally confused on this stuff. Any help is appreciated.
Propa Teknique is offline
Old 02-07-2010, 03:25 PM
timwdv's Avatar
thats just sex! it looks so much better
timwdv is offline
Old 02-07-2010, 07:23 PM
xTeCaOx's Avatar
I have to close the hood a little harder then before but not enough to bother me...... But overall weeeeell worth the conversion
xTeCaOx is offline
Old 02-15-2010, 06:10 PM
FenderGuy's Avatar
Asked earlier about this wow good thread
FenderGuy is offline
Old 02-16-2010, 12:48 AM
eK9aT10pSi's Avatar
so when u did the hood, i didnt have to modify it at all? that was the only thing holding me back but it looks real nice.
eK9aT10pSi is offline
Old 02-16-2010, 11:50 AM
you can't you'll just keep blowing the fuse. I already tried this with spencer's maxima. You'd have to chose either fogs from the bottom or the 04-06 fogs.
Old 02-16-2010, 12:16 PM
Jammmaxx's Avatar
Or he may choose to run a seperate switch for the fogs in the bumper.
Jammmaxx is offline
Old 02-16-2010, 02:53 PM
Hmmmmmm.... Really? Interesting.... How so @ Jamm??/ Please let me know!
Old 02-16-2010, 07:37 PM
yes thats true he can do that.. just run a separate line from the battery bridging a switch and u'll be fine
Old 02-17-2010, 05:06 AM
Wait, I think you just started speaking Klingon on me... I dont know what any of that means... Can you please in "dumb man" terms?
Old 02-24-2010, 07:37 PM
cwkim's Avatar
You can use a relay with a fuse on it and run the main power from the battery and use the wire from the harness as the trigger. That way you can switch them on and off with your stock switch and forego any overload problems.
cwkim is offline
Old 02-24-2010, 07:49 PM
cwkim's Avatar
You can buy 12v relays from radio shack, home depot, etc. maybe 5 bucks
Connections:
30 - to positive battery terminal with 20amp in-line fuse
85 - to negative battery terminal
86 - to WHITE wire (+) on headlamp harness (splice into it, having the black wire continue to power the fog lights in the headlamp assy - this will be the trigger for the relay)
87 - to positive wires of fog lights in bumper
87a - no connection
hope this helps. pretty much the relay uses a trigger (the WHITE wire on harness) which tells it to supply your fog light with power directly from the battery, as long as the trigger has a 12(+) current. when you turn on your stock fog lights, your bumper fog lights will also turn on, the relay acting like an automatic switch - that way you don't need a seperate switch. if you do want a seperate switch, you can connect the trigger wire to the switch instead. using a relay is the safest method in powering high current circuits.
cwkim is offline
Old 02-25-2010, 05:55 AM
ray08max's Avatar
any1 kno where i can get side mirror with turn signal lights for my 2008 max? and smoking ur lights they fade off over time?
ray08max is offline
Old 02-25-2010, 08:24 AM
RAZ76's Avatar
NO they wont fade..
RAZ76 is offline
Old 02-25-2010, 01:13 PM
they don't make them for the 04-08. You can retro-fit 2009 maxima mirrors though. Many members have done that.
Old 02-25-2010, 06:55 PM
Connections:
86 - to black wire (+) on headlamp harness (splice into it, having the black wire continue to power the fog lights in the headlamp assy - this will be the trigger for the relay)
87a - no connection
hope this helps. pretty much the relay uses a trigger (the black wire on harness) which tells it to supply your fog light with power directly from the battery, as long as the trigger has a 12(+) current. when you turn on your stock fog lights, your bumper fog lights will also turn on, the relay acting like an automatic switch - that way you don't need a seperate switch. if you do want a seperate switch, you can connect the trigger wire to the switch instead. using a relay is the safest method in powering high current circuits.
Thanks @ CW. I'm still dont understand wiring too well but I'll give this a good. If I need some help, though, I'll be bugging you if you dont mind!
Old 02-25-2010, 07:00 PM
cwkim's Avatar
no prob. feel free to ask.
cwkim is offline
Old 02-25-2010, 07:04 PM
cwkim's Avatar
sorry, i made mistake. the trigger wire shoud be WHITE NOT BLACK. it should be the positive wire.
cwkim is offline
Old 07-22-2012, 03:10 PM
FenderGuy's Avatar
Quick question....I just bought a front bumper cover 2007, do I really need the full bumper set up from a 2007 or can I bolt up this cover to my 2004?
Old 07-22-2012, 03:22 PM
smokin5s's Avatar
what is the LED mod?
smokin5s is offline
Old 08-24-2012, 08:07 PM
smokin5s's Avatar
How does it look if you just do the bumper and grill? Is there gaps or does it line up well?
smokin5s is offline
smplyamzng
12-13-2015 01:19 PM
maxima-junky
10-21-2015 05:17 PM
TonyJr
08-20-2015 12:14 AM
maxima-junky
08-13-2015 09:59 AM
Quick Reply: How To Do The 07-08 Swap & What's Needed For Install
