Just bought 03 maxima. Would like pointers
#44
#46
Working on bolt on mods like y pipe, intake spacers, vias block off plate for now
But yea eventually I will lower it and switch the wheels out with G35 18s
#48
http://www.nwpengineering.com/
http://www.letmegooglethat.com/?q=Ma...+throw+shifter
[URL="http://www.letmegooglethat.com/?q=magnaflow+resonator"]http://www.letmegooglethat.com/?q=magnaflow+resonator[/URL
http://www.letmegooglethat.com/?q=O2+simulator+install
#49
I ask myself the same question since im doing the 5pc intake spacers, dont know if its worth buying the bigger tb
#50
#51
Literally just finished watching it and came on here.
Watch "Why I Removed My NWP Spacers" on YouTube
#53
Im looking into intake exhaust and maybe 75 mm if Im confident enough that its worth it. Another thing I wanna figure out is a good clutch. I read fidenza with a 350z stock clutch is a good combo.but that's later on.and I wanna get a good suspension combo.
Im not sure still doing research on it.same boat as you. That guy might of had defected spacers or it just could be a problem more people have.what kind of intake are you using?
Well I already ordered and will be installing spacers myself. Most people have had no trouble. Hopefully it works well.
As for the clutch im thinking the same thing. I give my clutch about another 2k miles before I switch out
Using that for now, switching to short ram though
Let me know how the spacers work out. Im changing my plugs so might as well do that too.
#54
OP- don't worry about power down low, you want to get more power up top.
Spend less that $200 and do these following upgrades
VIAS BOP plate from NWP
Spacer Kit from NWP
STS mod
(all can be done in your driveway with a couple/few hours and simple tools)
Then I'd recommend Headers, exhaust, suspension, RSB or brakes
Don't worry about the throttle body unless you plan to upgrade your intake manifold
Spacer Kit from NWP
STS mod
#55
#56
One idea to try is to use 2 OEM gaskets for the LIM/UIM for easy installation because that RTV is a to get off, especially if you plan on re-using it.
http://forums.maxima.org/5th-generat...ml#post8194111
http://forums.maxima.org/5th-generat...p-spacers.html
#57
That's a very rare case. And I did mine successfully 5-6 years ago with no problems. Also removed them and put them on another manifold 2x, still no problem.
Picked these up the other day on CL. Havent thrown them on cause the front tires are shot
#59
Are you kidding me? Am I the only one who thinks the tubing on this intake looks really small, not smooth/constant diameter, and like it is sucking hot air from behind the radiator? I can't be sure, though, because it is hard to determine such details only from a picture.
#60
What brand is most recommended?
#61
https://www.siliconeintakes.com/
http://www.bpi-us.com/stacks.php
http://www.spectreperformance.com/ca...?cat=C00000271
http://bloxracing.com/shop/index.php...ory&path=59_83
http://www.aemintakes.com/dryflow_air_filters.htm
http://www.sbfilters.com/index.php/p...l-filters.html
A GAB is better than what you have there, and I'd be willing to say a stock airbox is better too.
#62
JWT POP charger or similar. (AKA build your own)
Anyone know of a write up on making a cold air intake? Can't find it. Need something that shows locations and if I have to relocate the battery
#64
Violator
09-09-2015 10:14 AM
