07-22-2007, 07:31 PM
All Show & A Little Go
Battery Relocation / True Cold Air Intake
This is the battery relocation for the 2002/2003 Nissan Maxima. However, I'm sure it will work for the other gens too since it's basically the same. I did this on my 5.5 and my boys 5.5 gen Max.
This set up is for people that already have a aftermarket intake. If you are running the Injen intake, like I was, then you can use it. Using your Injen intake you will need to get another midpipe ( berk, frankencar etc...) and another coupling.
Tools:
Sharpie.
Dremel.
Drill with 17/64 drill bit.
10mm Socket / Wrench.
Screw Driver / Flate head, Phillips head.
Pliers
(1) 17/64th sized bolt.
How To: Relocating your batter and fuse box.
1) First of all turn your wheel all the way to the right.
2) Remove your Intake and next you need to remove your battery.
3) Remove the plastic cover, this will expose the (3) screws holding down
the battery tray. Take those out.
4) After removing the screws you will need to remove the fuse box. It is
held in place by two screws.
5) Looking at the tray you will see that the Positive terminal cable is
attached. Just pinch the zip tie and push it out. You should be able to
pull the tray out.
6) When you pull the tray out you'll see that it has mounting points for the
fuse box, the positive terminal mounts and where the tray mounted to
the car. ALL of these need to be cut off. Use your dremel to accomplish
this. Now is the time for this kid to get his sanding and painting skills on.
7) Looking at where the tray was you'll see a raised piece. This needs to
get cut off to make the surface flat. Just use the dremel to cut it off. If
you look close you'll see small circle's. This is the tack weld, lightly cut
over that circle and wedge your screw driver and pry it up. Take your
pliers and start turning it in a circle motion and it will pop right off.
__________________
8) Place your battery tray to sit parallel on the mounting point. You will use on of the existing holes to mount this.
9) Once you have it aligned slightly pick up the tray and you'll see where the other screw will go. Use your sharpie to mark the spot in relation to the tray on the tray. Once this is marked take your tray off and drill out the spot where you just marked. Use the 17/64th drill bit to drill out the spot.
After you drill it out lay it in place to make sure it lines up perfectly. If it does then straight, if not check your alignment and drill it out. This is enough to secure the weight of the battery with NO problems. Do not secure the battery tray down just yet.
Next is aligning the fuse box.
10) Parallel the fuse box and push it snuggly against the battery tray. You will see where the original mounting point on the fuse box was. You are going to use it again. Take your sharpie, mark the spot and move it to the side. Take your drill and 17/64th drill bit and drill out the hole. Don't worry there is nothing there but space. Put the fuse box in place and use your 17/64th bolt to secure it down.
This is what it should look like when you are done.
07-22-2007, 07:32 PM
Now turn your INJEN WAI into a CAI. You will need a new midpipe and coupler to make this happen.
You have all this space to work with. Up underneath is open space. You will take your dremel and cut out a triangle shape, smiley face, whatever you like. J/K cut out a circle large enough for your piping to go through.
1) DO NOT go beyond this red line, you will be cutting into the frame. I found it easier to use a drill and drill holes, then take the dremel and cut the lines. Take your pliers and catch a corner and start turning in a circle. It will role up and come out easier. You can take your dremel and clean up the edges when you have finished.
2) Assemble your intake set up. Coupling, new midpipe, coupling, MAF, coupling, Long elbow of the Injen intake, coupling. You will assemble the Injen midpipe and filter inside the fender.
3) The Injen midpipe has a line for the vacuum. You will need to block this. I used some gasket making material. Also, on the long piping of the Injen there is the mounting point that you will need to cut off. You don't have to but it looks better.
4) Place your intake set up in place.
5) After extending the piping into the fender you will need to pull the fender plastic towards you. You will see the piping coming down. You will then connect the Injen midpipe and filter to the piping coming in. This completes your intake set up.
note: Make sure all your couplers have been tightened down. Also, make sure you hook the vacuum line back up.
6) Everything is finished. Put your battery tray back on, secure it in place.
7) Put your fuse box in place and bolt it down.
8) Connect your battery negative and positive and your set.
It should look like this!!!
07-22-2007, 08:31 PM
If you guys have any questions let me know. It took me about 2 hours to do this. Performance gained... meh... Don't really know yet. I do know that CAI is better then WAI.
Thanks for your time.
07-22-2007, 08:34 PM
just what i was looking for.
Certified Hooptie
That's a cutsie MAF housing.
07-22-2007, 08:42 PM
07-22-2007, 08:47 PM
Certified Hooptie
Quote:
Originally Posted by Network13
Are you blind...
07-22-2007, 08:48 PM
3-Peat!!!!!
Quote:
Originally Posted by NmexMAX
Are you blind...
he drives a neon and is trying to PW to get to 15 posts
__________________
Represented by: Graham Motorsports Media
2008 Xterra Off Road (N50 | VQ40DE | KH3)
06 Mazda 6
Maxima - A33 | VQ35DE | RS6F51A | KH3/G
NWP Engineering Thermal Intake Manifold Spacers
Hybrid Berk/Frankencar Intake | Frankencar catback | Cattman STS | ES 6-speed bushings
H&R Springs | Tokico Struts | Progress RSB | Otto FSTB | Blemco LTB | Hawks HPS Pads | Custom Front Lip
 O2 Sensor Locations and Corresponding Codes
07-22-2007, 08:49 PM
-we are your overlords-
you need to get a new line.....
__________________
2000 Maxima SE (sold) - 2009 Subaru WRX - 2008 4Runner SportEdition - 1990 Cherokee Laredo - 1970 Triumph GT6 Mk2
Eibachs*Illuminas*BlehmCo Stage 2 LTB*Truax SFCs*Stillen RSB+RSTB*Otto FSTB*Cattman Ypipe*Place Racing CAI*
Wilwood Calipers*BlehmCo 2pc Rotors*Frankencar Catback*ES Bushings*Samco Hoses*Goodridge Lines*Raxles
nice setup orgullo. Are you going to cut a hole in the filter to make it "true" CAI?
07-22-2007, 08:51 PM
where are the finished pics?
07-22-2007, 08:56 PM
i did this like last year LOL. But hey i guess everones catching on slowly.
07-22-2007, 08:57 PM
3-Peat!!!!!
Quote:
good for you...did you provide a write-up
__________________
06 Mazda 6
07-22-2007, 08:58 PM
I guess everyone is mind-reader, since you didn't make a thread about it.
BTW, you weren't the first to do it either, sorry to tell you. And you thought you were special.....
__________________
07-22-2007, 09:19 PM
Completed... Didn't think I was ever going to finish writing it up.
07-22-2007, 10:22 PM
where did you get the new midpipe from? so basically it is just a straight tube, the 45 degree bend and the injen midpipe?
07-22-2007, 10:38 PM
Oooh, this would be a good Sunday project for me and my Injen...but where did you get the midpipe...I really don't want to buy like a Berk or Frankencar or something like that...
__________________
2002 Nissan Maxima 6-speed: GAB/SSIM/Energy Suspension motor mounts/blacked out sidemarkers/headlights blacked and cleared
STL MAXIMA MEET
07-22-2007, 11:58 PM
SHIFT_In2D
Sweet thanks for the write up!  I might do this one day, when I get not so scared of cutting into the car lol.
Does the intake really stay dry down there?
Kind of scared of anything splashing up into it, but I mean hell right now it's right in front of the radiator anyways.
__________________
***Named X5-452***
Birthday: 03/11/03 (Purchase Date)
2003 Maxima GLE - Gray Luster AMD - Atlanta Maxima Drivers
| Smoked Lights | Cleared Signal | 19" A34 Nismo/Falken 452 | BC Racing Coilovers | H&R TRAK 15mm | Ichiba 5mm |
| Stillen Classic Lip | Stillen FSTB | Injen | NWP IM Spacers | Cattman Y-Pipe | Custom 2.5" & Flowsound Exhaust | Magnaflow Tips |
| 28% Tint | 20th Ann. Pedals + Door Sills | Super White Bulbs | KV3 Eyelids |
07-23-2007, 12:03 AM
what do you mean
07-23-2007, 06:55 AM
i thought about doing this and using a 3.5 altima, 6th gen stock intake and cutting the intake tube short and running a flexible intake hose into hte fender..
good right up
__________________
02' se all but navi.
stillen FSTB, catman/progress RSB, cleared h.i.d.'s, smoked front bumper lights, GLE tails, avid v4s's, magnaflow tips, G.A.B.(Fliter folder lip removed, stock paper filter), Brembo blanks & Hawks (front only), Axxtion STS & poly bushings.
07-23-2007, 06:58 AM
Certified Hooptie
07-23-2007, 08:30 AM
This is good stuff! I might have to try this one of these days. Thanks for the post and write up!
07-23-2007, 09:35 AM
http://www.maxima.org/modules.php?name=CAI
granted it's a 97, and the battery/fuse box were removed only to be replaced in the same spot. but i'm sure it's possible for 5th gen.
07-23-2007, 10:11 AM
Nightmare = Reality
my reservation about this particular write-up is that you now have no support of the intake(at least in front of the MAF) and with that wide hole and variety of roads most of us see, this could lead to ruining what most people have probably overpaid for in the first place...just to fix it :P
