Front windows don't roll down
Hey guys, I’m having a problem here and I've tried searching as well. I even had my friend take a look at it and he's a forum member as well. A couple days ago, I had taken off my front passenger door panel to check why my power folding mirror didn’t fold. When I checked it my windows rolled down but after I put everything back together that same night, both my driver side and passenger side front windows won’t roll down anymore. When I push the master switch, I can hear both switches click but neither of my windows roll down. I’ve taken both door panels off and checked to make sure all my plugs are snapped in. I have no idea what the problem could be. Right now I’m guess maybe my window regulators might have gone out? Any suggestions would be helpful at this moment as I have no clue what else to look for.
well idk if this well help but mine used to get stuck and my mechanic sprayed the motors and stuff with wd-40 because they were dry.. idk if it will help but this is what i did and didnt have any problems afterwards..
I doubt it's the regulators. You need to check for power going to the master switch. I'm not sure of the polarity, but you should get 12v when button is pressed in.
If you got no power to the master switch, you may have an issue with the alarm module (I forget the technical term).
If you do have power up to the master switch, then the switches are bad.
I know our power windows once and awhile when you apply the auto up, they go up and then drop back down about 3" ... this is normally resolved by removing the door panel and down deep in the door there is a reset button ... have you attempted to use the reset button to resolve that your windows will do neither up/down function? Just curious I guess if the reset button will fix this issue as well.
sorry took me a couple of minutes to find a thread with a diagram, don't even know if it will help but was a thought.
http://www.nissanclub.com/forums/200...dow-reset.html
also:
http://www.nicoclub.com/archives/max...ow-repair.html
You could also have an issue with the "Smart Entrance System module"
Link to the FSM's for the 03's the info is in the EL section pages 251-265
http://www.nicoclub.com/FSM/maxima/2003/
also:
I also see that there is a fuse in the driver side junction box, well at least it is showing the fuse #13 is for the power windows ... but puzzled by that you can operate the rear windows ... so it also could be the switch itself.
Also found this thread on the window topic http://forums.maxima.org/5th-generation ... oblem.html
I checked the fuses and that isn't the problem. I also don't think it is the switch as when I use the master switch to try and open the front passenger side window, I can hear the front passenger side window switch click.
AhHhhhh!!! I hate not being able to roll down my windows..........
vingodine
45
05-21-2016 12:46 PM
KGMtech
08-18-2015 09:21 AM
