will o2 sim or spark plug fouler fix codes P0138 & P1146
I show 2 codes P0138 and P1146 and know they are the bank 1 rear sensor 2 (white) and was wondering if any one has used an o2 sim or spark plug foulers in order to get rid of of these codes ?
When you go into the 5th gen forum section theres this tab that says Search this forum you click on it and search your codes
P0138 = B1 S2 = Right bank (closest to firewall) Rear sensor
P1146 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 1)
yes a simulator should fix this
heres a how to if your car is a 02-03 3.5 maxima
http://forums.maxima.org/5th-generat...tallation.html
Don't forget that if you want to complete eliminate the secondary o2's, you must use a resistor to fool the ecu to think that there is a heating element present.
I used (2) 10ohm 10watt ceramic resistors in series for each o2 sensor. Total of 4 resistors.
I bought them at Radioshack.
ballerchris510
09-23-2015 08:46 PM
chernandez1278
09-16-2015 01:18 PM
