Go Back   Maxima Forums > Maxima Discussions > 5th Generation Maxima (2000-2003)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-18-2006, 10:12 PM   #1
Super Moderator
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
O2 Simulator Installation
USE THIS WRITE-UP AT YOUR OWN RISK, I AM NOT RESPONSIBLE FOR ANY DEATH/INJURY/DAMAGE SUSTAINED BY YOUR USING THIS
O2 Simulator Installation (this is really just a rehash of BlackbirdVQ's write-up but for the fact that I included pictures that I took tonight)
This should work on all Cali spec Maximas. When dealing with codes P0420 and P0430, whether its voluntary removal of or just bad pre-cats, the O2 sim helps keep your SES/CEL/MIL light off and typically also prevents the ECU from storing any related codes. Rear 02 sensors only monitor if the cats work and do not affect the long or short trim fuel so basically, they do not affect drivability or the air/fuel ratio. Since the ECU is monitoring catalyst efficiency using the rear O2 sensors and the O2 sim simulates the proper voltage for the ECU to think that the cats are working. For more info, see www.o2sim.com.
The wires tapped into are the wires BEFORE the connectors for the rear/downstream/secondary O2 sensors (so the length of wiring going from the ECM to the connectors). The dark blue connector connects to the WHITE wire shroud/harness and this is for the Bank 1 (rear bank) downstream O2 sensor. The green connector connects to the RED wire shroud/harness and is for the Bank 2 (front bank) downstream O2 sensor. Cut back the black wrap before each connector and you should see 4 wires:
Black: Ground
White: Signal
Red/Yellow: Power
Red/Blue: Heater
If you are going to simulate BOTH secondary O2 sensors, be sure to have bought a dual output sim with one black wire (ground), one red wire (power), and two white wires (signal).
The installation for a single output sim is the same, except you just tap into the signal of the sensor you want to simulate instead of both.
On ONE O2 sensor harness:
Using a wire stripper, strip about half an inch to expose the copper wires under the ground and power wires.
Tap the black wire from the O2 sim to the black (ground) wire.
Tap the red wire from the O2 sim to the red/yellow (power) wire.
Cut the white signal wire and connect one of the white wires from the O2 sim to the end that is going back to the ECU.
On the other O2 sensor harness:
Cut the white signal wire and connect the second white wire from the O2 sim to the end that is going back to the ECU.
Heater wires:
Leave em intact and both secondaries plugged into their respective connectors, the ECU still needs to read these or it will throw a code for heater malfunction or something.
You can now either solder the joints and wrap them up in heatshrink or electrical tape, or you can clear the codes and start the car to see if the sim is doing its job before soldering. The yellow LED on the sim should be blinking when the car is on/running.
Other links:
BlackbirdVQ's write-up: Dont purchase HID's from "Maximabest"
If you want to completely remove and simulate your secondary O2 sensors, even the heater wires: http://forums.maxima.org/showthread.php?t=435399
Puppetmaster is offline   Reply With Quote
Old 04-18-2006, 10:14 PM   #2
Super Moderator
Looks almost stock now:
Almost:
Old 04-18-2006, 10:26 PM   #3
Super Moderator
Btw, I was throwing a CEL for P0037 and P0057 (I did the self diagnose procedure and counted the SES/CEL blinks) codes before, since my secondaries were completely unplugged and off the car. After installing the dual output sim and reseting the ECU (the procedure was a pain in my arse), the CEL is gone. I still have to drive it around some to make sure it stays off, so we'll see how that works out.
And yes, my secondary O2s are just ziptied under my engine cover.
Old 04-19-2006, 06:05 AM   #4
So if I plugged my secondary O2 back into its harness, and left the heater wire untapped, tapping the 12v, ground, and signal, I could let the O2 "hang" outside the exhaust w/o a SES?
__________________
http://www.cardomain.com/ride/2290351
Progress*GAB*FSTB*RSB*17 Degrees*Topspeed y-pipe*
18" Muranos*Blacked tails*Infinity*Kicker*MTX components*
Gapp is offline   Reply With Quote
Old 04-19-2006, 08:11 AM   #5
Super Moderator
Quote:
Yes, since the signal wire from the sensor itself has been intercepted, the ECU is reading the voltage that the sim is putting out, and not the voltage that the O2 sensor is reporting when it measures catalyst efficiency. So it doesn't matter if the sensor is plugged in or not. It just has to be in the wire harness.
Old 04-19-2006, 09:19 AM   #6
So a resistor is only needed if the sensor is not hooked up at all to the harness? The reason I ask is because I disconnected my sensor and ruined it trying to take it out of the bung. It's the rear aft. cat (fed spec) sensor so luckily I only throw a SES with no other issues. I don't have the sensor anymore. If I'm not mistaken, I can hook a resistor up to ground on one end and to the heater wire on the other. (And I thought I was over with experimenting )
__________________
Old 04-19-2006, 09:34 AM   #7
Super Moderator
That is correct.
For more info on completely removing the O2 sensor (not having it plugged into the harness), see the thread I linked to in the All Motor forum.
Old 04-19-2006, 10:55 AM   #8
I Know Kwaliti
igzy's Avatar
Puppetmaster - Great write-up and nice pics too!
One note I would like to mention is that you may not need to tap into the main wiring harness before the connector going to the sensor. I installed mine by tapping into the wiring after the connector, just before the sensor itself and the simulator works fine. I used a single output sim on the secondary O2 after the main cat on fed spec...
igzy is offline   Reply With Quote
Old 04-19-2006, 11:13 AM   #9
Super Moderator
The main reasons for my doing the tapping and cutting before the harnesses are:
1. It it will be easier to cover up when I go back to stock since all I have to do is remove the sim and tape everything back up (and resolder the white wires). When you have to rejoin O2 sensor wires, its hard to fit the colored shroud/wrap back over the joints (unless you can do it with really thin layer of solder and thin heatshrink/tape). Then again, I'm not an expert with soldering, so maybe you people who are good at this won't face this issue. I just think leaving the O2 sensors intact is a good thing.
I also liked how neatly I could tape the sim back with the wiring.
2. I find that the copper wires before the harness are much easier to work with than the steel or whatever wires on the O2 sensor itself. I cut off one of my O2 sensor's wires, and I hated soldering those slippery wires back together. So I would just rather not have to deal with the O2 sensor wires as far as possible. And once again, maybe those better at dealing with such wiring may not find this a problem.
Old 04-19-2006, 01:36 PM   #10
I Know Kwaliti
igzy's Avatar
You brought up some good points there. I guess that would work the best for cases when sensors need to be extended or there are no holes provided for them (in cases of headers and Y upgrades)...
My case is slightly different in that the sensor itself went bust and I couldn't remove it (nicely welded in) so I decided to tap into the sensor wire instead of the main harness as I didn't want to mess with the main too much and in case I get a torch that I can pull out the sensor itself and replace it properly only the sensor would be affected (as wires would get replaced with it). Besides, I did not solder anything, I used quick-tap connectors with some insulation tape and it works like a charm...
In any case, you did an outstanding job in describing how it can be done!
Old 04-19-2006, 02:16 PM   #11
Send a message via AIM to 6spd_Hayes
Here is my addition to the pictures. This is from my install.
#1 Picture of closeup of connector
#2 Pic of heat shield after cutting
#3 Pic of wire pulled out
#4 Pic of Heater wire separated
6spd_Hayes is offline   Reply With Quote
Old 04-19-2006, 02:20 PM   #12
#5 Close up of heater wire seperated Bank 1 (I think)
#6 Close up of heater wire separated Bank 2 (I think)
#7 Finished product (got hasty wanting to finish this project so I didn't take any shots of the soldering)
__________________
Old 04-19-2006, 11:20 PM   #13
Need A Light?
steven88's Avatar
Send a message via AIM to steven88
ahhh, nice job joel...now i see how you removed the black tape in the front...to gain more slack for the front primary baby blue connector....i'll be doing this when i get the chance
steven88 is offline   Reply With Quote
Old 05-01-2006, 12:59 PM   #14
so i got the simulator from cattmans. is the led suppost to blink or stay on? i just want to make sure the simulator is working. i have a cel light on now but thats because i installed the simulator after i was driving around with the headers. so i think i need to do the reset procedure but that takes like 6 hrs so i will do it when i go to bed. so yeah, is my simulator light suppost to stay on? or blink? cause thats what its doing.
DUKEE is offline   Reply With Quote
Old 07-11-2006, 06:55 AM   #15
Super Moderator
Bump for a homemade simulator solution, see:
http://forums.maxima.org/showthread.php?t=481430
Old 07-11-2006, 10:08 PM   #16
What we have here is a failure to communicate
Snolife's Avatar
Got a question. During a smog test, does the cover get pulled off, meaning the engine cover? Just curious. If they saw my o2 sim like this pic below, would they say something? Should it be "tucked" under the cover? Just curious so I can be prepared in the next few years.
Snolife is offline   Reply With Quote
Old 04-16-2007, 11:45 AM   #17
Hi guys, I'm just kinda visiting in because i am considering buying a maxima, either 02 or 03. All of this 02 sim stuff is cool, but i am just wondering (because it works on sentras) can you just use and 02 sensor spacer? Since i have not found it on this forum, you just use 2 spark plug non foulers and drill one out to fit the 02 sensor, and plug it in to the undrilled one, and after you put it back on the aftermarket headers the 02 sensor recieves less exhaust because of the spacer and does not throw a code. This works for almost all sentras, and wrx owners use it too. just wondering if this would work for a maxima too because it literally takes about 5 minutes and 4 dollars to make one and they work great. Instead of spending like an hour rigging up wiring. Thanks guys!
Jessed87 is offline   Reply With Quote
Old 04-16-2007, 11:54 AM   #18
Super Moderator
Yeah, the fouler is great and works on VWs too. The issue isn't so much as to whether we can use the foulers, its that aftermarket headers for these cars do not have bungs for the secondary O2s. You could add bungs, but that would cost you more than a $20 O2 sim. And IMO, it really does not take an hour and I'd hardly call the install "rigging up wiring". Trust me, it is really easy to do.
But anyways, for people who are doing this to solve a CEL, and who still have the stock y-pipe in place, my guess is that the fouler/spacer method could possibly work. I'm not sure if anyone around here has tried that yet.
Old 04-19-2007, 06:28 PM   #19
Simulator Install
Hello Puppetmaster,
I was talking to you a few months ago about installing o2 simulator. I just got one from www.o2sim.com. After reading your post I have a few questions. Your post is for your 2002 maxima. I have 2001 maxima. The connector colors are a little different. See attached picture. I am getting the P0420 code. (Secondary sensor Bank 1 is third connector from left). The wire harness at bottom of connector is white. The 4 wires coming out the top of connector are (White - Black - Pink - Red/Yellow). Am I correct in saying the following. (White = SIGNAL) (Black = GROUND) (Pink = HEATER) (Red/Yellow = POWER). I can follow your post for hooking simulator to connector. I just need to know if I am labeling the 4 wires correctly.
Thanks,
Pugman
Pugman is offline   Reply With Quote
Old 05-12-2007, 06:26 AM   #20
huffdaddy2008's Avatar
Send a message via AIM to huffdaddy2008
im sure youve read this: http://forums.maxima.org/showthread....ighlight=P0430
Seems like it will help the problem. Go for it, watch out for an o2 sensor going bad next. I need a new heated o2 sensor or a resistor and ive only had my sim in for 3 months. Currently have P0154, P0152 and P1168. Others have had better luck though. Hope all goes well.
huffdaddy2008 is offline   Reply With Quote
Old 05-16-2007, 01:17 PM   #21
Super Moderator
Quote:
Originally Posted by Gennady7
I am guessing that one person did this and everyone else is confused?
Does anyone know which sensor to purchase?
The dual ouput sim is used to simulate the secondaries for both front and rear banks. You can probably get away with a single output sim since you only have a code for the front bank precat.
That being said, have you looked into the root cause of the problem? ie. the precat (or O2 sensor) that is tripping the DTC? Just curious...
Old 05-16-2007, 02:50 PM   #22
Send a message via AIM to Gennady7
I recently changed the O2 sensors and I also had the car serviced by the dealership. They told me that the cat needed to be replaced.
I dont have the money for it right now and would prefer to get the dual output O2 simulator in case the pre-cat goes too.
Gene
Just wondering, the model I listed as the dual output sim is what I need to get the job done?
Gennady7 is offline   Reply With Quote
Old 05-17-2007, 11:47 AM   #23
I installed an O2 sim that I made using some circuit diagrams on the web on my G20. Work great (almost a year now).
I just wanted to throw out the suggestion that you install the Sim inside the cabin, right next to the ECU. This way saves you're engine bay harness from prying eyes, makes for a 'cleaner' install and keeps the Sim out of the elements. I know some of those Ebay sims don't look any better than the circuit I soldered up, and may not hold up under the various temps/ water, found in the engine bay.
All you need is the ECU pinouts from the FSM, and splice in your signal wires from there... Just an idea.
LoSt180 is offline   Reply With Quote
Old 05-20-2007, 11:52 PM   #24
Thats a great idea, but I never found where the ECM is on the maxima.
Also, does anyone know if Pugman labeled the sensors correctly for the 2000/2001 maxima?
Thanks guys!
Old 05-23-2007, 04:06 AM   #25
Super Moderator
Sent you a PM but I'll also post it here for others' benefit...
Looks like the picture from Pugman is correct, based on the position of the O2 sensors, but double check the colors based on the second diagram, which is from the TSB. Reason being I've seen O2 sensors have their positions switched around for whatever reason, either by the owner or dealer, and so the "middle two" aren't always the secondaries.
The colors indicated in the TSB diagram refer to the color of the wire shroud under the heat wrap. You can sort of see the red of Bank 2 Sensor 2 in the photo. The other one should be white.
Hope this helps.
Let me know if you have more questions...
Old 09-29-2008, 07:09 PM   #26
Send a message via AIM to wyche89
just looking for an update.. so puppetmaster and others, you've used this setup successfully with no SES light coming back in over a year?
__________________
2003 6 speed TE
Looks: Superwhite LEDs Inside Smoked Side Markers
Performance: Stillen Intake with Custom MAF-TB Pipe, NWP Phenolic Intake Spacers, NWP Block Off Plate, Cattman Gen 3 Headers, Custom 3" Magnaflow Cat-back Exhaust
Suspension: Tokico Illumina Struts, Ebay FSTB, Progress RSB
"I feel the need... the need for speed!"
wyche89 is offline   Reply With Quote
Old 09-29-2008, 08:12 PM   #27
the one that puppet used i had only lasted a few months, the new one from 02sim.com has been on my car for almost a year, no prob
Quote:
__________________
2K2 SE 6 speed Grey Lustre SE Every option minus navi, black leather, HLSD, Hotshot headers, Cattman Catback, Frankencar WAI, HP autoworks STS, ES motor mount inserts, ES shifter bushings, FSTB, RSB. JIC FLA-1 coilovers, A34 Brakes Hawk HPS pads, TR Motorsports MT1's, Toyo 4s, 64,000 original owner miles.
HotshotVQ35 is online now   Reply With Quote
Old 11-03-2008, 08:40 AM   #28
UnPr3d!cT@bL3 M@X !!!
JonBlz's Avatar
Send a message via AIM to JonBlz
is the 00-01 write-up the same for a 99 maxima because i need this
__________________
Y0u kNoW Wh@T !t !$ !!!!! Money/Cash
V2 S/C kit 11PSI | 01 AE de-k 40k engine | V-afc2 | headers | air-intake | full exhaust | KYB GR2'S | eibach springs | fidanza light flywheel | Stage 3 SPEC clutch | FSTB | RSTB | RSWB | Z32 Brakes | 13" Cobra Rotors | SS brake lines front & rear | 01 AE Vlsd tranny | Stillen front & rear spoiler kit | Sarona sideskirts | 18" Azul rims hyperblack/polished lip | ES inserts front & rear mounts | poly filled left & right mounts | etc......
JonBlz is offline   Reply With Quote
Old 12-07-2008, 09:55 AM   #29
I was wrong, the colors above are correct. I had done some of the installation wrong.. should be good to go now.
Slag
slag is offline   Reply With Quote
Old 01-17-2009, 06:06 AM   #30
Send a message via AIM to viperboy
I just ordered a test pipe, and I'm going to order an 02 sim and I'm glad I found this guide. But I just want to make sure I do this right. I only need to simulate 1 02 sensor correct? And just follow the first part of the guide to do that? Just want some clarification. Thanks
viperboy is offline   Reply With Quote
Old 01-17-2009, 07:50 AM   #31
Super Moderator
Quote:
If you have a 2002 like it says in your profile, you don't need an O2 sim if you're getting a test pipe - there are no O2 sensors after the main cat. There are two primaries before the precats and two secondaries after the precats, that's it.
Old 01-17-2009, 09:59 PM   #32
Quote:
Ok, thanks for clearing that up
Old 02-08-2009, 04:40 PM   #33
bumpidy bump baby! just wanted to say that i did this today, and everything went pretty smoothly.. i twisted, capped and taped the ends of the 2 white wires, and just twisted and taped the connections between the red and black wires.. the green LED was blinking slowly, so i assume it's doing its job?
i went to autozone today to have the codes cleared, and i'm waiting for my SES light to come back on (for other reasons).. when it does, i'm gonna scan it to make sure the O2 sensor codes are gone, then tape up all the wires with electrical tape.. i wanted to leave the wires un-taped until i was sure that the O2 simulator was doing its job.. as of now, the wires are sitting loose under the engine cover, but all the connections are either taped or capped and taped.. it's ok if the insulated wires are left un-taped for the time being until the light comes back on, and i can scan it again right?
__________________
2003 6 speed TE
Old 02-08-2009, 04:42 PM   #34
BTW... nice writeup puppetmaster
__________________
2003 6 speed TE
Old 02-09-2009, 06:48 AM   #35
ok.. well maybe somebody can tell me.. if i go to get it scanned today, will the O2 sensor codes show up if no SES light is on? I really wanna get these wires taped up, but i wanna be sure the simulator is working properly first
__________________
2003 6 speed TE
Old 02-09-2009, 11:36 AM   #36
Super Moderator
The codes don't always come back right away, neither does the CEL, so just drive around more to give it some time.
There is basically what they call "Two Trip Detection Logic" or something like that and if a DTC is picked up the first "trip", it won't trigger a CEL but the DTC is recorded to memory. Only if the issue is detected again on the second trip is the CEL triggered.
It also depends on the ECM readiness state after the codes have been cleared. It has to do some self-diagnostics before it diagnoses DTCs. This is why you can't just clear the codes and run to the inspection station, because the system readiness test (SRT) will say it is incomplete and the tester will reject the vehicle until the SRT is complete. For the SRT to be complete, there is a mix of driving conditions that has to be met, but I can't remember exactly off the top of my head.
Old 02-09-2009, 02:44 PM   #37
I have a 00 cali spec and Im wondering how many O2 sims I have to do? Im getting the P0430 code and want to get rid of it. Im also putting on a new Y-Pipe, dose that make a difference in how many I have to put in? Im also wondering do I have to pull the O2 sensors out after putting in the sim's or can I leave them in the exhaust? I dont have a huge engine cover to hide them under :-) LOL.
Basicly what do I need to buy to get rid of this? Remember I also have heaters.
__________________
SHIFT_spray
~Bad clutch slip in 3rd on the dyno
~132k
~11 bottles 75 shot (no smoke & good compression)
Still made 240hp 315tq
Revs2Hard is offline   Reply With Quote
Old 02-12-2009, 06:53 AM   #38
Super Moderator
You need only one simulator regardless, just depends on whether it is single output (to simulate one sensor) or dual output (to simulate two sensors). If you just had the P0430 and nothing else, you could just do a single output sim for that bank and nothing else. Check that the honeycomb in the precat isn't rattling around because if those pieces are in there, you should probably get them out, ie. replace the front precat, before something gets sucked back into your motor. On a Cali spec, the y-pipe does not eliminate the front pre-cat.
Along with the y-pipe, I'd just get a dual output sim to be safe. This will simulate working secondary sensors/proper cat functioning on both front and rear banks.
If you go with the dual output sim, you can leave the sensors in the bungs or take them out, it is up to you, but you need the harness connectors plugged in if not you will get a CEL for the heater circuits. In your case, I'd just leave em plugged in.
Old 02-13-2009, 06:50 PM   #39
i used the dual output simulator on a 2000 cali car to get rid of the p430 code to pass inspection,drove car for 65 miles to get all monitors up, car passed inspection
next i need 2 get rid of cats
solis is offline   Reply With Quote
Old 02-15-2009, 11:58 AM   #40
ONE THING EVERYONE SHOULD KNOW ABOUT THIS INSTALL:
Be careful where you put your O2 sensors. Because they get REAL hot and start to burn through things... like wires... not that I would know from experience or anything...
Puppetmaster, you don't have a problem with your O2 sensors burning/melting anything under there?
__________________
2003 6 speed TE
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
