who installed thier own o2 sim?
okay so I just received my dual output o2 sim courtesy of hustle (thanks). It came with instructions but it doesnt really make any sense to me. Before I start hacking up wires and soldering this in I am hoping somebody out there can point me in the right direction.
Background: I just installed obx v2 headers and was not able to weld in the extra bung needed for the last o2 sensor. Currently that sensor (the one with harness behind VIAS) Is plugged in and held off to the side with a zip tie. As a result I have SES and am running extremely rich.
Am I supposed to wire the sim on the harness that has the unplugged o2 sensor? Will this correct my a/f ratio and clear the SES? OR will it just clear the SES and I need a piggyback to fix my AF ratio?
Is it as straight forward as it looks? black to black, red to red, and white to white and then just leave the extra white loose or plug it into another sensor?
I have read a few write ups on how to do this but am still confused. The instructions are not consistent so I'm not sure which applies to me. Most of the write ups show for a car that has all the harnesses in front of engine cover. (mine has 3 in front and 1 behind engine).
I know there are some electrical gurus out there... can somebody please help me?
You're going to want to wire the sim to both of your downstream sensors, for which the connectors are both on the front of the engine. They are 4-wire connectors, not the three wire like the primaries. You will wire the power to just one of the sensors, but connect the white to both sensors. Also, you will want to either install the right resistor in the circuit or leave the o2's plugged in so that you don't get a heater circuit code
okay yeah so I just realized that sensor I have that isnt hooked up only has 3 wires...
So I hook it in the two that have 4 wires? So right now I dont have one of the 3 wire ones hooked up (I guess that is a primary)... so Should I unscrew one of the secondary ones to plug in the primary that is unhooked? Will this fix my AF ratio?
and I can just splice these wires on and I dont actually cut the wires is that right?
Locate the two secondary sensor harnesses and start from there; the one in the back by the firewall is a primary for the rear bank, so you don't need to even touch that. You will need to cut and intercept the signal wires from the secondary O2s, tapping will not simulate the correct signal.
I'm pretty confident that my write up is correct, I hope this helps:
http://forums.maxima.org/5th-generat...tallation.html
PM me if you have questions, because I haven't had time to check in here as much as I used to.
Getting that primary o2 back in should be your main concern. It should fix the afr. Right now it's reading like there's no gas going into those 3 cylinders, so it's probably just dumping as much fuel as the ecu is willing to. Plug that sucker in, then worry about the sim
Also, is an 02 sim capable of allowing my Max to pass emissions? I won't be getting emissioned for another year, but I'm just making sure I am ready when the time comes. Otherwise, the solution below seems to be able to:
http://forums.maxima.org/5th-generation-maxima-2000-2003/600107-good-god-works.html
For those more knowledgeable than me, what are the pros and cons of each solution?
Oh, and apparently, the last method above, is used as a trick to save on gas: http://www.energeticforum.com/renewa...n-foulers.html
Man I really scewed this up, I have the wrong sensor plugged in wtf Im an idiot lol
So, if I understand correctly, you don't have the rear primary bung relocated, which is like my install. For my install, I extended the primary o2 wires a couple feet and put the sensor in the bung that's kind of in the middle of the turn on the pipe. Then wire in the secondary o2's and plug in those sensors, then leave them ziptied somewhere.
alright I have a graphic to explain what I have right now and hopefully this can all be cleared up.
I have the front primary in bung 1, secondaries in positions 2 and 3.
Can somebody explain what the proper setup would be using this diagram and numbered positions?
yes. the sim will get rid of the light youre likely getting from the secondary sensors. those sensors are meant to detect the precats (basically) and will throw codes if you remove the precats (install headers). you just need to sim them
after i gave the man his only itrader, he wont return the favor... geesh man, i'd like to keep my rep positive u know... can somebody tell this guy what the itrader is, and share it after a sale lol... nzelinsky is cool dudes though lol
Alright man chill on this one. I haven't done it because I am preoccupied with trying to fix my car. And I have no idea what itrader is... how do I do it? shoot me a pm ur muckin up my thread
O2 Sim Installation guide
Here's a diagram of a homemade O2 simulator, but also illustrates the proper installation of an O2 sim. It also includes installation of the heater resistor, for complete removal of the O2 sensor. Some have had luck with the 20Ohm/20Watt resistor, others, 2 15Ohm/10Watt resistors in series.
Update 12/20/09:
I built the above circuit and passed inspection today in NJ. Just thought I'd let you guys know.
Update 12/20/09:
MaxLife17
06-27-2019 01:37 PM
