Poor acceleration ONLY after warming up (2003 Maxima)
Poor acceleration after warming up (2003 Maxima)
For the past year I have had a problem with my 2003 Maxima as I've lost a huge amount of acceleration power.
I tried many of this forum's suggestions with no luck.
I don't usually FLOOR my car when it is COLD but this morning I pulled out of my garage and into the street and just FLOORED IT! ...and WOW!... the car accelerated extremely STRONG. The engine just blasted off, felt like a new car again.
Sadly, as I watched the temperature gauge climb up I found that my newly found performance quickly disappear as engine reached operating temperature.
I let the car cool down for 3 hours and tried it again with the same results.
Basically, my car runs like a dream in the first minute it is cold then runs like crap when it is fully warmed up.
I quickly ran to the dealer and got them to replace the Coolant Temp Sensor but that didn't fix it, should I have replaced the thermostat too?
Kind of excited because it seems like I'm close to discovering the cure but I'm not sure where else to look.
I would appreciate your help in piecing this puzzle together. Thank you.
Some of the parts already replaced for other reasons or to troubleshoot this particular issue:
* Coolant Temp Sensor
* MAF
* Spark plugs
* Transmission
* Throttle Body
* Pre-Cat
* Rear O2 Sensor
UPDATED: (The following were replaced for troubleshooting purposes per advice from YOU after this thread was started)
* Fuel Filter
* PVC Valve
* MAF
* Spark plugs
* Transmission
* Throttle Body
* Pre-Cat
* Rear O2 Sensor
* Fuel Filter
* PVC Valve
Clearly, there's some kind of sensor or something that is messed up in our car that is incorrectly telling the ECU/engine to slow down and under-perform after the car is warmed up for whatever reason.
Exactly!... way too huge of a difference in performance. When I FLOOR it when cold, my Cold Air Intake absolutely SCREAMS sounding almost like a damn fighter jet but as soon as the car is all warmed up the Cold Air Intake sounds very weak like it's not even there.
have you cleaned your MAF? try to clean it see if the power gets better.
^I have the injen cai, which is a great location for cold air (not near the block). I am looking into replacing my MAF because I heard cleaning it really doesnt do a thing.... Its either get the 80 dollar 00-01 MAF or the 400 dollar MAF for the 3.5....Already talked to Dave about it as well...not sure what I want to do...or if this will even fix the issue.
Also I cleaned my old MAF then also got a brand new MAF last week and same thing.
I was mad at the $tealer$hip for charging me $400 for a part that is really worth only <$80 so I returned the $80 one with my $400 MAF receipt and got my $400 back so now I have a $400 MAF for $80. Greedy stealerships, trying to charging hundreds of dollars more for the same part.
you havent tried it and you already know it doenst do a thing?http://forums.maxima.org/5th-generat...10-w-pics.html
Its not by the block, and its way down there, but im assuming you know that already.....
Yes I am well aware of this thread and how to clean the maf...I spoke with Dave B on the phone and after speaking with him he said its pretty much useless...I highly doubt he was just trying to get me to buy a new maf from him...I know this part regulates the air to fuel ratio, and it is found behind air filter and can be cleaned although is very sensitive and can sometimes make things worse.
Yes I'm aware that all the heat is dissipated at the radiator, with that, the radiator needs a purpose, if the motor was cool then there would be no need for a radiator. The motor is hot so it radiates heat just like the radiator does. I'm aware most of these intakes if not all are jokes (they sound cool though...lol)..I highly doubt that a intake is part of our issue. To test however I can put my stock box back on and see.
I would definitely say the MAF is ruled out. Now what about the fuel you are using? A hot engine is more likely to knock. If you have lower grade/watered down gas it might not be knocking when it is cold, but it may start to when warmed up causing the knock sensor to pull ignition timing thus your poor performance.
Also, you mention the intake not being as loud when it is warmed up? The only thing that affects the amount of noise coming from the intake is the throttle opening. Since you are VQ35, the computer controls the opening of the throttle body electronically. Perhaps this goes back to the fuel issue or whatever, but perhaps the computer isn't opening your throttle body 100% for some reason.
As for intakes, do you 5th gen guys have no space in the fenderwell? For my 4th gen I bought an intake and filter off of Ebay for 30 dollars and all I had to do was cut away some sheetmetal behind/underneath the battery and my filter is in the fenderwell behind the drivers side foglight and it gets NO hot air from the engine or radiator whatsoever.
I think it's something to do with fuel...when my BMW's fuel filter got really old/clogged it was doing the exact same thing...car ran great when cold, and it was really slow once it warmed up. During open loop operation the car runs very rich, which means more fuel is being injected per cycle. If there is clogging going on, the vacuum system that your fuel runs on will be able to push the fuel more efficiently through the lines/injectors, giving your car a better combustion. When it switches to closed loop, it starts to pull fuel in order to lower emissions. By doing this, the amount of vacuum pushing the fuel through the lines is decreased and can't easily get by whatever is blocking the line, and you'll get less fuel to burn, which means the car will run like crap.
That's at least my theory...what I would start with if I were you would be replacing the fuel filter (it's about $25 and not difficult at all to replace) then getting the nissan fuel injector service done. I believe it's around $110 and they hook up a high pressure system to clean out everything leading to the injectors.
And just a little correction: engines are actually more efficient when they're warmed up, which is why the running temperature of modern engines is higher than old engines as we find new ways of keeping the engine as resistant to wear as possible (ie: the development of new materials). Your engine should not run better when your oil is cold, so there is definitely an issue that needs to be solved. Good luck!
Thank you, this sounds like a very good theory. The only problem I have is that I heard the fuel filter is in the fuel tank and so I don't know how you would think that is easy at all? I've called the dealer before and asked about the fuel filter and they go crazy saying how it's not replaceable, too hard to get to, etc...
All I know is I will be taking mine to the dealer to see if they can run some tests and the injector service may be a good idea. I recently replaced the plugs and ignition coil due to leaking valve cover seal.....
LA02MAX,
Thank you, this sounds like a very good theory. The only problem I have is that I heard the fuel filter is in the fuel tank and so I don't know how you would think that is easy at all? I've called the dealer before and asked about the fuel filter and they go crazy saying how it's not replaceable, to hard to get to, never clogs because it's not even a filter, that they never replace that, bla bla. When I face them with the question that if it is only a large open mesh and not fine filter then how does car filter crap of fuel they just ignore me.
Is it easy for you because maybe you have something else other than a 5.5 Gen or specifically a 2003 Maxima? Thanks.
Here's an extremely detailed write-up on how to do it: http://www.shiftice.com/fuel_filter.html And definitely check the rest of that site out good. He's a member on the .org and his write-ups are excellent.
Yeah definitely try the injector service. My car was running fine and I did it, and noticed a definite improvement. It idled much smoother than before and it seemed like I got more of my low end power back. Just MAKE SURE that you tell them you want the fuel system FLUSH, where they hook up the machine; not just the crappy fuel injector liquid they pour into the gas tank.
I didn't do the injector service but the dealer did claim that they checked the " fuel line pressure... " or something like that and they said it's fine. But then again they don't really troubleshoot for performance they just micky mouse things and if the car starts and no codes they send you away.
The fuel filter literally took me 15 minutes to do. The bottom of the rear seat just snaps off (there's a little lever in the center that you push and the seat bottom just pulls off) then the fuel sending unit is exposed. Remove a couple bolts and the sending unit comes out, and a couple of snaps later, you have your fuel filter off. Dealer's are just lazy, but several people have taken apart their used filters and seen things that should NEVER be labeled "lifetime". haha.
I think I'll do the fuel filter replacement too and report back with the results.
How about that large piece that the fuel filter goes into, is that the fuel pump? If that is the fuel pump can I just replace the whole fuel pump if not too expensive in case it is to weak to pump or something?
Call Dave Bournette(Parts Dep.) @ SouthPoint Nissan (866-941-2048) to order these parts: (Price quotes as of 4/2/2009)
Fuel Filter - 164002Y505 - $11.19
O-Ring - 1734201A00 - $7.34
Dave B. does a lot for the org and its members. He also works on comission. Unless you are in desperate need of a part today he's the guy to buy from. We need to take care of the people who take care of us, not figure out ways to get around them.
UPDATE: Installed the new fuel filter myself and that did NOT fix the issue.
I still have lack of power but the lack of power that I do have is very smooth thanks to the new fuel filter.
What should I replace next? Thermostat? Does the Thermostat do anything that could affect? Can someone elaborate on the Thermostat, what exactly it does, how easy it is to replace, can I do it myself and is it even at all relevant to our symptoms here? Thank you.
It was pretty cool to see an open oasis of gasoline in the middle of the back seat.
I actually thought about just driving like that with open access to the gas tank so my back-seat passengers can use the round gasoline puddle as an ash tray. I don't see any problem with that at all because if the filter gets clogged with ashes I'll just replace it because now I know how.
I had also found all these threads and have been sifting through them to see what I should do.
http://forums.maxima.org/5th-generat...m-i-think.html
http://forums.maxima.org/5th-generat...ower-loss.html
http://forums.maxima.org/5th-generat...uld-wrong.html
Give this product a shot http://www.seafoamsales.com/motorTuneUpTechGas.htm
I have a 2002 and I'll pull the vac line going to the brake booster which comes off the intake manifold. Dunk the hose with the engine on into a cup with a small amount of the seafoam, allow the suction to pick up the liquid, then immediately shut off the engine. Wait about 5-10 minutes with the engine off. Start engine and rev the engine a few times, you'll get smoke out of the tail pipe but your injectors/cylinders are clean(er) haha.
UPDATE: I just replaced the PVC Valve with my bare hands while engine was HOT ...but the issue of lack of VQ-fighter-jet type power/acceleration still exists.
Thank you.
Thank you.
