5th Generation Maxima (2000-2003)Learn more about the 5th Generation Maxima, including the VQ30DE-K and VQ35DE engines.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Remove the MAF:
1. Clean the area around the MAF and blow away the dust on it.
2. Press the clip on the socket and pull upwards to dissconnect the MAF.
3. Unsrew to screws that hold the MAF using the Torx screwderiver #15. Pull the MAF upwards to remove from the housing. If it's difficult to pull it out, twist the MAF 90 degree, so you can pull it out with your both hands.
4. Remove the MAF carefully from the housing and make sure you don't drop it. Clean the housing and cover it with a damp towel to prevent dust getting in.
__________________
Life would be boring without the Maxima.
Clean the MAF:
1. A MAF has two air tunnels on it, so you have to clean both of them.
( red arrows show how air flows through the MAF)
2. Take you MAF cleaner and put the pipe on it, so you can reach small areas. When you clean the MAF, DO NOT touch anything in side the tunnel with the pipe because that can damage the sensor.
3. Keep blowing the cleaner for 2-3 seconds to each tunnel, and you can also clean the resistor at the same time. After cleaning the MAF, let it sit for 15 minutes to dry. I prefer to put it like this, so dust won't get in.
Reinstall:
When you put the MAF back, just make sure the air flow direction is correct, with two tunnels/holes facing to the air filter.
Relearn procedure:
After putting the MAF back to the car, perform the ECU reset and Idle relearn procedures.
__________________
I have yet to see maf cleaner work on the 5.5 gen maf. But on other vehicles it works great.
__________________ 2002 Infiniti I35 Sport Package
Progress RSB, Otto FSTB, Michellin Pilot Sports A/S, Eibach Springs, Illumina Shocks, Fx35 Brakes Rotors/Calipers, Custom SFCs 1989 Mazda Rx7 GTU
Ls1/T56 W/ Ported TB and Full Exhaust
11.67 at 120mph 3rd time out
So... any thoughts after it was cleaned? Because I sprayed mine with the CRC too and did nothing. Perhaps mine is already gone... but I ordered a new one and JUST received it via FedEx from DaveB as I'm typing this reply lol. Imma install it @ lunch! w00t w00t! Fingers crossed! Hopefully no more 15-17mpg!
i wouldnt recommend doing this in your bathroom dont u need a well ventilated area when usin the cleaner j/k with ya nice lil write up. any difference after the clean up?
thorttle responses better and rev harder. idle is smoother then before.
__________________
I just install my new MAF and maxi is pulling like a champ! I guess I had a bad MAF the whole time with no codes. Moral of story is... it doesn't matter how you clean it or what you clean it with... when it craps out, it's just out, period! <--- That's the case for me at least. Time to see what MPG I gonna get!
But anyways! Mad props for the step by step with color pix!
Worked fine on mine. After installing a K&N panel filter, I noticed a slight bog on light to moderate acceleration around 2500 rpm. Pulled out my MAF, sprayed it down with CRC, let it dry, reinstalled it and no more bog.
Didn't reset the ECU or do an idle relearn either. Cleaning the MAF didn't seem to affect anything other than getting rid of the bog.
You don't have to worry too much about how you reinstall the MAF, it only bolts up with it in the correct position.
__________________
2002 Maxima SE, OSCAI, GAB, K&N panel filter, Vibrant FSTB, grounding kit.
Hey! Great write-up op! You made the process so easy I immediately ran to my car and brought my MAF inside to clean...however, to my surprise I noticed that my MAF was slightly different than yours...there is no resistor as yours has shown in the picture! I was wondering if you could tell me the value that yours is reading across that resistor? If anyone knows the value of the resistor that is on the MAF please let me know I would like to put a replacement in before I order a new MAF....might as well try! Thanks
__________________
SHIFT_Infinitely
Mods:
-Retrofitted Maxima HIDs
-20% tints including sunroof
-White climate control and stereo displays
-Painted grill with silver graphite paint, left infiniti symbol chrome (looks hott)
-Clear front signal markers and headlights.
-791XV with r/s and trunk pop
Or is this a Thermistor of some type??? Is it replaceable? The help is much appreciated
EDIT: This is the thread that I read about a Thermistor that is the main difference between 2k2 and 00 MAFs...I have an 00 is this the reason there is no "therm/resistor in that spot?
Mods:
LOOKING FOR SIDE SKIRTS AND I35 GRILLE!!!
Jason: Did this cure your throttle lag problem you posted in another thread?
BTW:Good write up and excellent pics.
it does cure the throttle lag a little, but not very much, I think my MAF is about to die or somehow.
but this is a good write up for those who want to clean their MAF.
__________________
what is your car?
I think the Nissan X-Trail uses the same MAF because I used to drive that car, and I had the MAF replaced.
I don't know if the QR25DEs use the same MAF as ours, but the X-Trail was QR25DE.
__________________
I've got a 2000 I30. I am thinking that it's just a thermistor as stated in Upgrading to stronger 2k1 MAF?....the pictures don't work on this page so I couldn't be exactly sure from the pictures. Thanks for the help everyone, and sorry for the pestering I just want to be absolutely sure. Thanks
__________________
SHIFT_Infinitely
Mods:
coming from someone who in no way claims to be mechanically suave, would you recommend for me to do this? i just don't want to mess anything up... I drive a 2000 Max and it has roughly 133k miles.
cleaned the MAF last night while we installed an RSB on my buddies accord
took 20 minutes all together and most of that was waiting for it to dry
DEF feel a difference
no more hesitation from a stop, and more consistent power curve. I dont feel as many jumps in power, now its a smooth acceleration
thanks for the write up, ive wanted to do it but was tooooooooooooo lazy to get off my *** and do it until this write up
