2nd gear grind
2nd gear grind
I know there is the famous 3rd gear grind, but this post is about the 2nd gear grind.
Has anybody experienced it?
Mine goes as follows:
Temperature here has been around 15-25F.
If I start the car, let it warm up for only like 15-30 seconds, then take off in first naturally and shift at about 2500rpm's, it either is kind of hard to get in second but it will defenitely go into second, or it will do a quick short grind into second. I only experience this once in a blue moon though. If I let the car warm up for a lot longer, then it doesn't do it.
I'm running MT-90 just recently changed about 3 months ago.
Other than that, tranny shifts normal. By normal I mean, with the normal notchiness that is common among these trannies.
heard this was a common problem especially in the 5th gen m5/6. Try letting the car sit for about 2-3 minutes and then try. I've heard the famous 3rd gear and also alot of people have posted about shifting problems in the cold. Usually clear out once the car warms up. Park it in a garage if u have one. If not let it warm up and keep us posted.
gl
gl
Problem is no matter how long you let it warm up the transmission won't warm up until you drive it. Until it's in motion nothing is moving in the tranny to warm it up.
well the tranny is connected to the engine so as the engine heats up i believe the tranny will warm up a little. if i try and put it into first a few seconds after starting, its almost impossible to get it in without some muscle. if it sits and warms up a couple minutes then its fine.
The tranny does warm up if left long enough idling. I let my car warm up for aleast 5 mins when it real cold here and it shifts fine. The Input shaft is spinning the whole time the car is warming up. I'm not gonna pretend to know how the tranny works inside, but I believe the syncros are located on the input shaft.
every other car i have had has grinded on the 1-2 shift when cold but not my max. i would just skip 2nd for a few cycles or a couple of minutes so the fluid could warm up.
by the way i am running mt-90 too and have been fine down to about 5 degrees this winter, it just sounds like your second gear syncro is wearing down
What if there is a constant grinding of metal on metal sound, not when switching but when accelerating in gear. This happens for my 1,2 and 3; and strange spinning type grinding sound when just idling. When I engage the clutch, that spinning grind goes away, and when I put in gear and start driving with a smooth switch, the hard metal against metal grind begins. It sounds so horrible. Is it more likely to be the Clutch or the Transmission. Have to fix this asap!!! (this happens when the car is fully warmed up too). Thanks guys.
Sounds like your ISB.
have you by chance checked your tranny fluid level?
Well, since the input shaft is splined into the clutch disk, while in neutral, the input shaft spins, which spins the countershaft inside the trans, so in theory all gears are spinning inside the trans. Just that the fluid will not warm up as fast because there is no load from the engine. Load creates heat faster. So, if I let it warm up for a while, it never grinds. Just when cold.
I think your 95% correct about the input shaft bearing, thats what the mechanic said today when I went to get it checked out. Also did a diagnostic for the CEL and the code was "O2 Heating Circuit". Is it common for the heater to turn on by it self (as in its coming from the engine) when you accelerate rather quit to 3rd? No signs of over heating though, new radiator and new coolant.
Thanks guys.
Thanks guys.
Thanks guys.
Then no, that's not normal or common.
It sounds like the blower motor turns on but you cant actually feel the air coming from the vents but it sounds as if its on "3" setting of the manual climate control. Strange.
For people wondering about the Energy suspention bushings that they eliminate the notchiness. Well I didn't think so But I did like the idea of a firmer more positive shifting motion so I bought them and installed them and it defenitely firms up the shifting which I like. However the notchiness is still there. I heard different things about the bushings curing the notchiness and thats why I'm reporting.
My old thread is here:
http://forums.maxima.org/5th-generat...tkins-sts.html
Anyway, I have some rough shifting in terms of the shifter going from 1-2-3 and back down, cold or warm. Actual engagement is fine though. Might be time to look for a new transmission.
I would agree that they don't eliminate the notchiness but just provide a more precise and solid, less sloppy shifting feel.
So I'm gonna let it be.
Now, the STS piece, can you tell me what that's about? i wasn't aware of such piece existing.
It decreases shifter throw, just like any STS. You can do it yourself for free very easily (the one on the shifter tower, not directly beneath the shifter itself).
The baulk rings were updated, IIRC. That's why the A34 doesn't have the 3rd gear grind issue (or at least as prevelant as the A33).
knight_yyz
11-01-2015 01:34 PM
