Tranny Swap
Old 01-14-2009, 11:03 AM
bluebriscoe's Avatar
Tranny Swap
I need a new tranny and i found one from an 3.5 (auto) but my car is a 2001 3.0 so will the 3.5 tranny wrk on the 3.0?
bluebriscoe is offline
Old 01-14-2009, 11:11 AM
No more Maximas...
pmohr's Avatar
Did you search?
http://forums.maxima.org/5th-generat...k-my-00-a.html
http://forums.maxima.org/5th-generat...e-00-03-a.html
http://forums.maxima.org/5th-generat...to-2000-a.html
pmohr is offline
Old 01-14-2009, 11:52 AM
Those did not answer the question yes or no....it jus tells me that some parts are identicle but will it work or not?
Old 01-14-2009, 11:53 AM
No more Maximas...
pmohr's Avatar
There's the thing. AFAIK it hasn't been done. If you want to give it a shot, go ahead. It should work.
pmohr is offline
Old 01-14-2009, 11:54 AM
'Trynna' is not a word
mtrai760's Avatar
Definetly maybe.
mtrai760 is offline
Old 01-14-2009, 12:00 PM
okay so whats the difference that make it maybe?
Old 01-14-2009, 12:03 PM
No more Maximas...
pmohr's Avatar
Did you search or did you only look at the threads I listed? There's been quite a few threads on it.
pmohr is offline
Old 01-14-2009, 12:12 PM
ive searched and non have completely said yes or no just it should or maybe
Old 01-14-2009, 12:14 PM
No more Maximas...
pmohr's Avatar
As I said above, no one's done it before. Almost all of those threads list what's similar or different.
Answer to your thread: no one knows for sure.
pmohr is offline
is it possible if i asked nissan if the would know?
No more Maximas...
pmohr's Avatar
Not very likely. You'd be asking someone who would never attempt such a thing.
pmohr is offline
Old 01-14-2009, 12:34 PM
what other cars uses the same tranny as the one in the 2001 maxima
Old 01-14-2009, 12:36 PM
No more Maximas...
pmohr's Avatar
A32 4AT is virtually identical. That's about it.
pmohr is offline
Old 01-14-2009, 12:41 PM
thanks for the help man
Old 01-14-2009, 07:28 PM
Herofmine's Avatar
i was thinking is it possible to swap 2001 AT maxima tranny to 5 speed or 6 speed MT tranny? and what has to be done? i know i have to replace transmission computer and what else?
Herofmine is offline
Old 01-14-2009, 07:31 PM
No more Maximas...
pmohr's Avatar
Seriously?
http://forums.maxima.org/all-motor/3...edure-faq.html
http://www.dynomagic.com/5spd_conversion.htm
pmohr is offline
Old 01-15-2009, 06:48 AM
On this site for used transmisions it says the 3.5 tranny can be used on 00s an 01s
http://www.automotix.net/transmissio...d-re4f04b.html
Old 01-15-2009, 09:55 AM
No more Maximas...
pmohr's Avatar
Well there you go, go ahead and give it a shot.
pmohr is offline
Old 01-15-2009, 07:26 PM
arthur glazier's Avatar
I thought that 03 had a 5 sp auto? or am I wrong?
arthur glazier is offline
Old 01-15-2009, 09:38 PM
No more Maximas...
pmohr's Avatar
The first RE5F22A (5AT) was used in the '04 SE and above, up until what, '07 when they went to the CVT. The '04 SL still used the same RE4F04B (4AT) as the 02/03 Maximas, which is a slightly modified RE4F04A (95-01 4AT).
pmohr is offline
Old 01-27-2009, 05:44 PM
Okay guy I have an update the 3.5 4spd auto does fit on 3.0s the thing thas diffrent so far is the starter which isnt that big of a deal.I will have more tomorrow when i install the right starter.
Old 01-27-2009, 05:50 PM
No more Maximas...
pmohr's Avatar
Well the front housing, as well as most parts are all the same part number, so we know it bolts up (not to mention all of the Maxima VQ30/VQ35s being the same bolt pattern).
The Nissan OE part numbers are different for the starter, but all aftermarket companies list it as the same for the A33 and A33B autos. What's different about it?
Since the front housing is the same, the starter should be as well. They don't really look different, you just can't see the nose on the VQ35 starter in this pic.
You can see the VQ30 starter on top (same for 4AT/5MT), VQ35 starter on bottom (4AT):
pmohr is offline
Old 01-27-2009, 07:10 PM
the plugs are diffrent and the shape of the part that spins is diffrent.The starter from the 3.0 will drag if you try to use it.
Old 01-27-2009, 07:30 PM
P. Samson's Avatar
I believe the flywheel starter ring gears are different (teeth number). Don't forget that the Gen. 5.5 trannies are the same model number as the '01 non LSD trannies only. The LSD trannies ('01 AE) have a different model no.
P. Samson is offline
Old 01-27-2009, 07:32 PM
but im using my same flywheel.
Old 01-27-2009, 07:49 PM
P. Samson's Avatar
It was just in answer to pmohr.
Old 01-27-2009, 07:59 PM
o ok
Old 02-01-2009, 08:55 PM
IT WORKS! IT WORKS! IT WORKS! it shifts smoothly as everthing is the same nothing was diffrent even the starter( i realized my starter cable was messed up so thats why it was dragging) so guy now you are able to use the 4spd auto from 3.5s
Old 02-02-2009, 05:20 PM
WOW thats great news. Now I wonder how hard it would be to install a 5sp auto?
Old 02-02-2009, 05:22 PM
No more Maximas...
pmohr's Avatar
New wiring and electronics, possibly new axles.
pmohr is offline
Old 02-07-2009, 06:47 PM
Herofmine's Avatar
Overall i'm wondering i have 2001 Maxima (auto) and currently i'm having ECU computer and having problem to find 01 ECU with traction control, and i'm thinking to swap it with 2003 Maxima 6MT is it possible? anybody ever done this be4?
Old 02-07-2009, 07:15 PM
No more Maximas...
pmohr's Avatar
Search, yes people have swapped to a 6MT.
If you want to use the '03 ECU, you're going to have to get an '02/03 engine harness.
pmohr is offline
Old 02-07-2009, 08:33 PM
Herofmine's Avatar
I don't think so that i need 03 ECU for 6MT i just need 01 Manual trans Ecu, but there is separate Transmission computer (i don't know manual trans has it or not) and i can't use 03 ECU on my 01 max Engine cuz' it's 3.0
Old 02-07-2009, 08:41 PM
No more Maximas...
pmohr's Avatar
Wait, what?
There's no trans computer for a 6MT...what could it do? Nothing.
I know you can't use the '03 ECU on a VQ30.
So are you just trying to swap in a 6MT, or the VQ35+6MT?
pmohr is offline
Old 02-07-2009, 08:51 PM
Herofmine's Avatar
Wait, what?
ok, then regular VQ30 engine ECU for M/T is ok! no i don't want VQ35 it's too much work and $$$ better sell this car and get another one with VQ35, today i saw 04 Engine for very cheap price but still a lot of work! i just want 6MT from VQ35 to my VQ30, and what kind of parts i should get for manual trans ? i know taht Manual tarns has different Axels then Auto that i have to change
Old 02-07-2009, 08:52 PM
No more Maximas...
pmohr's Avatar
ok, then regular VQ30 engine ECU for M/T is ok! no i don't want VQ35 it's too much work and $$$ better sell this car and get another one with manual, today i saw 04 Engine for very cheap price but still a lot of work! i just want 6MT from VQ35 to my VQ30, and what kind of parts i should get for manual trans ? i know taht Manual tarns has different Axels then Auto that i have to change
Again, search. It's been done, there are threads on it.
pmohr is offline
Old 02-07-2009, 08:54 PM
is invisible
CoolMax's Avatar
CoolMax is offline
Old 02-24-2009, 04:39 PM
denny_1986's Avatar
so u just bought an 03 tranny from a junkyard and slapped it on your 01 max? Is it as simple as that? I'm planning on doing the same thing later down the line when my tranny goes. 02-03 trannys seem to be better built....(or are they lol)
denny_1986 is offline
Old 03-04-2009, 06:38 PM
Fireonice's Avatar
What about buying a auto lsd tranny and swaping it with a non lsd tranny. Would there be any complications because of the lsd or the vlsd?
Fireonice is offline
Old 03-04-2009, 06:54 PM
No more Maximas...
pmohr's Avatar
Are you a 5th gen, or 5.5?
The RE4F04B was beefed up slightly for the VQ35, best as I know. The RE4F04V you want to put in there wasn't designed for it, but it should handle it just fine, if it's been treated well.
All you need is a VLSD driver's side axle.
pmohr is offline
Quick Reply: Tranny Swap
