Tire Size Work???
Tire Size Work???
I have been offered a shot at very new blizzak winter snows for 100.00 for (4) of them. I know this is a great deal but i have 225/50r17 and these others im looking at are 235/45r17 will these fit my 2001 Max?????
Thanks or your help
Thanks or your help
Re: Tire Size Work???
Yes, they will fit. No, they are not in spec. But, if you live in a climate that necessitates Blizzaks, you probably don't push the car too hard in the winter anyway.
If you don't want them, I'll buy them.
Thanks or your help
Thanks or your help
Interesting
I tried the search before and didnt find this until i went to the FAQ's
1) Is it OK to mount 235/45R17 tires on OEM 5th Gen Maxima SE rims? The answer is NO! The reason is that the 5th Gen SE rim is only 7" wide. The minimum acceptable rim width for 235/45R17 tires is 7.5". There are no exceptions to this regardless of the tire's make or manufacturer. Once again, check the manufacturer's web site for confirmation.
http://forums.maxima.org/showthread....5&pagenumber=3
Re: Interesting
OK, everyone FREEZE!!! Step away from your keyboard. Let it go people. Let it go. It's not worth it.
Re: Re: Interesting
it'll fit
there is no clear yes or no answer to this question, but in my experience, i install a lot of wheels and tires, the tires should fit on the rims safely, they may bulge out a bit beyond the rim but it takes a lot of bulging to simply make the wheel/tire combination unsafe, and a +2 tire size is not a huge difference approx 20mm.not even an inch. the sidewall integrity may not be as strong but who is putting massive side loads (cornering) on frickin snow tires? put em on the car, if you have a problem you can kick me square in the nuts.hope this helps
Re: Interesting
Re: Re: Interesting
Originally posted by y2kse
You stopped reading the FAQs too soon, MAAXDOUT. Keep going until you've read ALL the tire-related threads in the FAQs. Then make up your mind.
I just installed Dunlop SP 5000's on my OEM 17's. I have to say that the fit is VERY close to stock. Just a slight bulge in the sidewall and a little more tread on the ground. Really, it is hardly noticable at all. Before making my decision, I called Tire Rack and asked them to give me the tread width and section width for the OEM RE92's and also for the various tires I was considering. I discovered that the actual size variations were, in most cases, very small. In fact, the Michelin MXM4 had a wider section width and tread width measurement than a number of the 235/45 tires I asked about . . . interesting!
That's all very interesting, ABS and maseo77. But it doesn't eliminate the fact that running 235/45R17 tires is out-of-spec on 7.0"-wide rims, period. I have no argument with those who choose to run out-of-spec tires on their rims. I'd simply suggest that they be aware of what they're doing and take the precautions outlined in my last post in the FAQs if they decide to do so.
Thanks or your help
Thanks or your help
Cheers
AA
Re: Re: Interesting
everything, and i mean EVERYTHING, you want to know is on page 5 of the FAQ (thanks y2kse)!
Re: Re: Tire Size Work???
I've had white 18 x 7.5 inch Katana T5 rims wrapped around Falken Ziex 235/40 tires on my 95 maxima. No problem at all, I have my new 2k3 maxima se 6spd w/ just the kombat bodykit alone. I'm plannin to slap on 19 inch Roja_Motegi gun metal rims, they'll cost my a$$ 2800, but its well worth it
-Rey
-Rey
I could not agree with you more. I spent a LOT of time researching and evaluating the options, including reading many posts on the .org, prior to making my decision. Now that I have the new tires on the car, I have to say, I believe I made the right decision for my purposes.
Really, the problem here is not so much with the tire manufacturers or even with us, the customers, but rather with Nissan. Nissan chose to use a very non-standard size tire on the Maxima. Had they only given us 7.5" rims, then none of this would have ever been an issue.
From reading some of your other posts, I can see you have had success contacting Tire Manufacturers regarding which sizes are in/out of spec. Perhaps you would be willing to contact Nissan for us and let them know how they've really screwed every Maxima owner who has 17" rims? Just a thought . . .
Originally posted by jjs
They would probably care about as much as they do about the paint and other issues.
True. Unfortunately, most buyers of Nissan products have no idea about this issues until after they've already made their purchase (I'm a perfect example). Had I known, I might have purchased a WRX, an A4, or a TL instead of the Max. Oh well . . .
The 225/50R17 tire is actually a good choice from a manufacturer's perspective. It's a relatively wide tire with a large aspect ratio. That allows it to be mounted on a relatively narrow rim. Narrow rims cost less to manufacture than wide rims. That keeps the manufacturer happy. And most consumers don't know the difference anyway.
Although I agree with you that Nissan was probably "trying" to cut costs, I find it hard to believe that it would have cost Nissan much more money to add .5" of metal to each Maxima rim. Not to mention, if they used a wider rim, then they might have been able to use a tire that cost them less than the RE92 . . . Just compare the retail price of the 225/50/17 RE92 to the Dunlop SP5000 in the 235/45/17 size and you'll see what I mean.
In doesn't matter much anyway since we are all stuck dealing with the issues generated by having a 7" versus 7.5" rim.
Mostly agreed . . .
Mostly agreed . . .
The fact is, 90% of Maxima owners probably don't know or care about the fact that they're running on sh!tty tires. They never push them hard enough to find out. And when it's time to buy new ones, they're just as likely to buy another set of RE92s as any other tire. And I doubt they'd ever consider changing tire sizes.
Let's get real. Org contributors represent a decided minority of Maxima owners. To think that how we feel about our Maximas can be attibuted to the average Maxima owner is a wee bit unrealistic, to put it mildly.
You may be right, ABS. But my suspicion is that you are not. I'd suggest to you that most people who buy Maximas couldn't care less about whether they're running on Michelins or Goodyears or Dunlops. While this may be a bit much to stomach, I suspect that the Maxima is purchased by most people as a family sedan. Yes, it has a little more sex appeal than a Toyota Camry or Honda Accord, but I doubt that owner demographics differ very much among the three vehicles.
Yes, the .org does represent a minority. Even the average Joe Maxima owner would rather pay $100 per tire versus $190 or $200 per tire.
Y2KSE, I don't want to be rude, but I think even the worst drivers (even the idiots) would realize how crappy the RE92's are particularly in wet driving and in snow and they would want something better.
http://forums.maxima.org/showthread.php?threadid=171043
where are you guys getting $200? What people here do isn't real world. 99% of people are going to go to their local tire place and say "I need new tires" and the tire monkey is going to say "what size?" and the clueless person will give that "deer-in-the-headlights" look. The tire monkey will go outside or read a computer/book to see 225/50r17 and give the clueless person 5 options, ranging from "you should replace it with a comparable ... blah blah blah... $200" to "these $114 ones will work, too." And Mr. Clueless will buy the $114 tires and they'll work fine.
Or, if the place doesn't have the $114 tires, tire monkey will say "or you could use 235/45r17" and start talking about the 8 more options doing that will get him, and Mr. Clueless will say (he'll actually make the noise) "huh?" then say "how much?"
Either way, there are plenty of $114 tires that will "fit".
ah2002
03-09-2016 01:42 PM
jerrod99_se-l
08-27-2015 08:27 PM
