Oil in rear spark plug cylinders
Old 06-02-2012, 12:15 PM
csh711's Avatar
My car has been idling rough and having some start up issues, so I went to check the spark plugs. All three of the rear spark plug cylinders were almost completely filled with oil. What could be the problem?
csh711 is offline
Old 06-02-2012, 12:52 PM
asand1's Avatar
You need to replace the valve cover gaskets and spark plug tube seals. Fel-pro has a nice kit with everything everything you need besides the plenum (upper intake) gasket. I sugest you get a throttle body gasket as well, so you can pop the TB off rather than disconnect all the hoses and lines.
Do a search for rear valve cover gasket. Also look around for coil or spark plug boots. the hot oil has deteriorated the boots and caused them to leak spark. This is most likely the cause of your rough running.
asand1 is offline
Old 06-02-2012, 01:02 PM
csh711's Avatar
Thank you for the response. So I need get the valve cover gaskets and the spark plug tube seals...and are you saying I will need to get some new spark plug boots as well?
csh711 is offline
Old 06-02-2012, 02:34 PM
Shift_A32B's Avatar
http://www.amazon.com/Fel-Pro-VS5049...1997&carId=004
Shift_A32B is offline
Old 06-02-2012, 02:42 PM
asand1's Avatar
Fel-pro has a kit with gaskets, tube seals, and valve cover bolt grommets.
Fel-pro Part # VS50494R
and #MS91253
When I did mine, I bought from NAPA, because after shipping, you wont save much and NAPA is next day delivery.
asand1 is offline
Old 06-02-2012, 02:49 PM
asand1's Avatar
and http://napaautoparts.com/Catalog/Cat...439_0259735654
NAPA# BEL 702439
asand1 is offline
Old 06-02-2012, 03:53 PM
csh711's Avatar
You guys are awesome! Thanks for the links.
csh711 is offline
Old 08-20-2012, 11:12 AM
maxinout93's Avatar
one Question? My rear valve cover is leaking, and I only need that rear gasket, not the whole set. Is it possible to just get one gasket with the spark plug tube seals?
maxinout93 is offline
Old 08-20-2012, 11:49 AM
asand1's Avatar
The front is so easy to do, why would you do half a valve cover job? If the rear needs work, how long do you think the front will last?
asand1 is offline
Old 08-20-2012, 02:24 PM
dwapenyi's Avatar
Taking the upper manifold off is alot of work. Once done, the valve covers, spark plug grommets, knock sensor, IACV, and EGR are right there ready for the taking. Do them all if you can.
Your car has gone you well over a decade of solid, fun, reliable service. Give it some love, yo!
DW
dwapenyi is offline
Old 08-19-2013, 07:30 PM
Aburn95's Avatar
Why is the plenum gasket set more than the intake manifold set? The manifold set, which looks to me includes the plenum gasket, costs $3 less.
Aburn95 is offline
Old 08-21-2013, 07:42 PM
BlackThornDemon's Avatar
Here's a good thread to get you started.
http://forums.maxima.org/4th-generat...im-w-pics.html
BlackThornDemon is offline
Old 08-24-2013, 08:22 PM
simmers96's Avatar
If you take upper manifold amd rear valve cover off might as well swap in an 00vi. Hahaha. Rock auto has good price and shipping is cheap.
Check the boots they may be cracked. If not cracked make sure they aren't hard.
simmers96 is offline
Old 08-25-2013, 01:25 PM
Aburn95's Avatar
As far as the boots go, which side is the Right side? Side closest to the firewall? I assume that because they are more expensive, which I assume means they are longer.
Aburn95 is offline
Old 08-25-2013, 07:41 PM
gruesome's Avatar
Funny, checked the napa site, searched coil packs, all I going were hydraulic hoses
gruesome is offline
Huttig2009
09-25-2015 03:31 PM
Maxboy23
08-21-2015 11:02 AM
Turbobink
08-15-2015 07:20 AM
1992maximase30
08-05-2015 09:27 PM
maxima297
08-03-2015 12:50 PM
Quick Reply: Oil in rear spark plug cylinders
