bose sound system
Old 05-25-2012, 03:45 PM
ibracey's Avatar
bose sound system
i got my wiring kit in the other day and i got it hooked up but for some reason i keep getting a popping sound when i change stations, also my headunit keeps turning on and off by itself. i was wondering has anyone had this problem with theirs??
ibracey is offline
Old 05-25-2012, 04:20 PM
DennisMik's Avatar
I don't know what external factors could make a head unit turn on & off by itself. Maybe it doesn't have a good ground to it and that might be causing both the popping and turn on/off problems.
What brand/model headunit did you put in? Maybe you didn't wire the Metra adaptor correctly.
DennisMik is offline
Old 05-25-2012, 05:44 PM
ibracey's Avatar
i have a sony and i un-wired it and re wired it back up tonite now i will try it tomorrow and see what happens
ibracey is offline
Old 05-26-2012, 10:18 AM
ibracey's Avatar
ok so i got everything hooked up and it works great but i have to turn the sound almost all the way up just to get it to play loud. did i hook something up wrong on what is happening??
ibracey is offline
Old 05-26-2012, 11:07 AM
DennisMik's Avatar
What model Sony? I want to look up the wires coming out of it.
Also, did you replace the Bose speakers or what?
Old 05-26-2012, 12:24 PM
ibracey's Avatar
its a sony XPLOD CDX-GT71W and no i left the bose in and got the right wiring kit
ibracey is offline
Old 05-26-2012, 02:14 PM
DennisMik's Avatar
Here is a chart for wiring the sony headunit to a Metra adaptor and then plugging into a 1998 Nissan maxima originally equipped with a Bose. In this chart, The Metra wiring adaptor I used is not the same one you bought. I could not find the wiring chart for yours so I used another Metra, hoping it would be the same.
Code:
1998 Sony to Bose Radio Wiring
                                        Metra              Nissan Wire
Signal               Sony Harness       Nissan Adaptor     Harness - Bose,   Pin #
Ground               Black              Black              connect to chassis grnd
Radio power          Red                Red                Blue               10
Station Memory       Yellow             Yellow             Pink/blu Stripe     6
Illumination         Orange/wht stripe  Orange             Red/blu stripe      8
Antenna              Blue               Blue               Black/red stripe    5
LF Speaker pos       White              White              Yellow              2
LF Speaker neg       White/blk stripe   White/blk stripe   Brown               1
RF Speaker pos       Gray               Gray               Purple              4
RF Speaker neg       Gray/blk stripe    Gray/blk stripe    light green         3
LR Speaker pos       Green              Green              Red                14
LR Speaker neg       Green/blk stripe   Green/blk stripe   Green              13
RR Speaker pos       Purple             Violet             Pink               16
RR Speaker neg       Purple/blk stripe  Violet/blk Stripe  Blue               15
Amplifier Remote On  Blue/wht stripe    Blue/wht stripe    green/wht stripe   12
Amplifier Ground                        Black/wht stripe
Dimmer                                  Orange/blk stripe  Red/yel stripe      7
Phone Mute           Light Blue         Brown
The colors listed for the Nissan adaptor are for an after-market adaptor and are NOT the
color of the Nissan wiring harness.
The Bose Nissan wire harness uses 2 connectors for the radio; M109, a 10 pin connector
and M108, a 6 pin connector.
M109 contains wires numbered 1 through 10 and M108 has wires numbered 11 through 16.
Old 05-26-2012, 04:08 PM
ibracey's Avatar
yea its pretty much the same. i dont know what is wrong with it maybe its nothing and just me. its lud enough when i turn it up so o well
ibracey is offline
Old 05-26-2012, 04:41 PM
Amerikaner83's Avatar
the bose speakers has a different voltage going into it (lower iirc) than aftermarket. Something about 2 ohm speakers instead of 4 ohm or something like that iirc.
Amerikaner83 is offline
Old 05-26-2012, 05:08 PM
99LakeshoreSE-L's Avatar
For low sound you need this
http://www.scosche.com/car-audio/product/999
or this
http://www.crutchfield.com/p_142C4NN...r.html?tp=3486
Probably cheaper on ebay. Make sure you ground everything properly for the poping. I just installed a new HU about a month ago. I had the same problem you did. Its all good now. Good luck.
99LakeshoreSE-L is offline
Old 05-26-2012, 05:26 PM
Jayson89NYC's Avatar
I put in a nice JVC unit on my 97 GLE with bose and it was very very loud
Jayson89NYC is offline
Old 05-26-2012, 05:32 PM
ibracey's Avatar
or this
i have the wiring kit with the RCAs on it for the preamps already thou so i dont think i need that. plus its the bose in it and i wouldnt know how to get it hooked up right
ibracey is offline
Old 05-26-2012, 05:54 PM
You gotta search bro.
http://forums.maxima.org/audio-elect...nt-thread.html
maxinout93's Avatar
just a general question since were talking about the bose system. I have a head unit from out of my 93 max and was gonna install it in my 95 max. the 95 has three plug ins plus the antenna connector. My aftermarket pioneer will only connect to two of the three plugs and the antenna thinggy. When i do plug the wires up, the cd player comes on, but there is no sound, Do I need to get a nissan wire connection? are they different years??
maxinout93 is offline
Old 05-26-2012, 07:50 PM
ibracey's Avatar
ok method 2 is what i have on my head unit but i have to turn my volume up to like 25 to really hear it
ibracey is offline
Old 05-26-2012, 08:07 PM
ibracey's Avatar
i am thinking about ordering 2 of these when i get the money. what do you all think?? http://www.ebay.com/itm/Pre-Amp-RCA-...4d49ce&vxp=mtr and how hard is it to replace an antenna??
ibracey is offline
Old 05-27-2012, 08:49 PM
DennisMik's Avatar
I replaced my antenna mast because it got snapped off. The motor was good so I just replaced the mast. $12 and not that hard at all. I took the entire motor and everything out to clean and lube it (which I could have not bothered with) and if I was replacing the entire antenna assembly, that's real easy.
Old 05-27-2012, 09:33 PM
ibracey's Avatar
i pulled mine out this morning and the guts were shot. there was alot of water in it and everything was rusted up. i am goin to put an aftermarket one on from like auto zone or something
ibracey is offline
Old 05-27-2012, 09:35 PM
ibracey's Avatar
yea i pulled mine out and it was water logged so i am goin to put an aftermarket one in from auto zone or one of those places like it
ibracey is offline
Old 05-28-2012, 10:36 AM
DennisMik's Avatar
This is the place I got my amtenna mast from. They have good directions on their website and I think you can call them for help, too. They have the whole assemblies as well as just masts. Here is the link:
http://www.antennamastsrus.com/Nissa...01995-1999.htm
The whole assembly is at the bottom of the page.
Old 05-28-2012, 03:21 PM
ibracey's Avatar
yea but i dont really want the power antenna nemore. i dont think its a good look at all
ibracey is offline
DJLAX152
05-04-2021 11:46 AM
03-12-2020 12:06 AM
RWCreative
09-21-2015 11:01 AM
TheMafia
09-04-2015 08:26 AM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: bose sound system
