Help! My battery and brake lights light up randomly while driving...
My battery and brake dashboard lights light up randomly while driving, as the car vibrates and shakes and recently the Cruise Control light on my dashboard randomly lights when I press the brake pedal.
I have checked under the hood for crossed wires, with no luck. This is driving me nuts since I don't want my car to catch fire or just get worse due to this short.
They do not. Actually, revving it causes vibration which will cause the random lighting to increase in frequency. Also, I run the car with both the a/c and the headlights on all the time with no problems. Also, the mechanic checked for proper charging and the test passed.
http://forums.maxima.org/4th-generat...-1500-rpm.html
Maybe, maybe not, worth looking at anyhow. Good luck man.
Man my experience with mechanics is don't let them have the last word. These guys here and myself have went thru alternators being dead or going dead and the one thing I know is when you have a battery and brake light going at the same time that's a sign of the alternator going bad or something related to it like bad ground, loose belt, wire hardness to the alternator. I can tell you the mechanic did not do a extensive search or road test. he check voltage and maybe battery and told you everything's ok and sent you on your way with charging you for doing jack. You listen to these guys and you will get your car fixed. Power to the ORG.
This is also happening to me. The lights wont be on until i have been driving for more than 10 15 min and then they will stay on until my gears shift at like 30 or 3500 rmps and then its back on. Sometimes itll turn off randomely and when it returns it feels weaker or if power is being cut. I had it tested and it all checked out and it was fine. So im thinking that it might be faulty wiring or loose connections something along those lines.
Each time this happen to me, it was the faulty diode in the alternator... I mean if you don't mind riding around with those lights flashing... cool but you will be getting another alternator sooner or later. Trust me on that.
Nearly fixed! :)
Ok, took another look under the hood and made better progress. This time I actually looked at the alternator (the previous time I was, stupidly, inspecting the starter motor. I should know better since I once replaced it myself!) and fiddled with the wires going into it. One wire seems to have a slit in the rubber insulation. Then I drove my car and, voila!, the dashboard lights flickered on way way less. Today I'll wind those wires in electrical tape and I'm sure the issue will be fixed.
You win some you lose some. During this inspection I realized my air intake plastic is cracked so my engine's getting unfiltered air. Also, I realized a boot on my rack and pinion came loose.
tsi6001
10-03-2022 10:23 PM
Dennis Twohy
10-01-2015 06:01 PM
JMag90
08-25-2015 09:17 AM
