Cost to clean EGR buildup (CEL 0302)?
Old 06-17-2009, 12:12 PM
Obespalov's Avatar
After searching the forum, I've decided that I'd rather pay a mechanic to fix my CEL 0302, which I'm presuming will be cleaning the small EGR tube that I've read so much about.
Does anyone know what a reasonable price for the work should be from the mechanic? Also, should I ask him to clean it or replace it (i.e. will it cost me cheaper to replace it than pay the labor for cleaning it)?
Thanks!
Edit: My local dealership wants $500
Obespalov is offline
Old 06-17-2009, 12:51 PM
max ride 41's Avatar
actually, the dealer has a service that will clean out the egr tube for a cheap price from what i remember. i replaced mine cause i did'nt know and spent a little over 300.00 to do it. there is a write-up on how to do this yourself somewhere in the stickies.
max ride 41 is offline
Old 06-17-2009, 01:36 PM
If you search you can find that it can be cleaned by yourself for cheap. All you need to do is remove the EGR (I suggest removing the IAVC and TB as well), some carb cleaner, and a tooth brush to get all the gunk off.
ChrisMan287 is offline
Old 06-17-2009, 02:01 PM
Obespalov's Avatar
Chris, I have 0 mechanical skills (e.g. I don't change my own oil). I will likely cause more damage and hurt myself, so I'd rather find out how much a place should charge to fix it.
Old 06-17-2009, 02:08 PM
I don't change my oil either. Anyway, I can't tell you how much a shop should or is going to charge. They're gonna charge you whatever they want. I suggest that you do some research on how to clean the EGR etc. or be prepared to pay.
Old 06-17-2009, 02:26 PM
Obespalov's Avatar
Someone must have gotten lazy on this board and paid someone to do it? Otherwise, would you have a link to the "official" writeup for this job? Maybe I can get my dad to work on it with me. I've seen a scattershot of pics and partial write ups from my search but haven't seen one definitive THIS IS THE WAY TO DO IT type write up. Also, can I assume my '96 I30 will have the same setup?
Old 06-17-2009, 03:20 PM
soseihin's Avatar
Did you search for a write-up? Here's a couple helpful links from my first page of hits (the keywords in my query were clean, EGR, & tube):
http://forums.maxima.org/4th-generat...e-removal.html
http://forums.maxima.org/4th-generat...alve-tube.html
If you can reach the nuts that secure the EGR guide tube, it is a pretty easy job. Just a matter of getting your wrench behind the intake plenum.
soseihin is offline
Old 06-17-2009, 06:50 PM
ATTappman's Avatar
Alldata quotes 1.3 hours of labor and $43 for a new EGR guide tube.
This job is too involved for somebody with no mechanical skills. The bottom bolts on the guide tube are difficult to reach, even with the entire intake manifold collector and throttle body removed.
ATTappman is offline
Old 06-17-2009, 08:00 PM
i can tell you its more than 1.3 hours even if you know what your doing. like i said, the dealer has a service that isnt too expensive and it takes a little over an hour.
Old 06-17-2009, 09:33 PM
nafddur's Avatar
Plus, just a word of warning - While the tube might need to be cleaned, it might not resolve your EGR problem. I kept getting the DTC 32, even after having the tube cleaned (and with over 190K miles, mine was virtually plugged solid). Changing the EGR & Canister control solenoid valve (a little over $90 from the dealer and VERY easy to change) took care of my DTC 32. This solenoid is way easier to replace than either the EGR or the EGRC-BPT valves.
nafddur is offline
Old 06-17-2009, 10:36 PM
J RO 9's Avatar
My dealer charged $300 to do this. That included all of the new gaskets and cleaning the EGR. They had to remove the intake manifold and a bunch of other stuff. I felt the difference as soon as I pulled out the lot
J RO 9 is offline
Old 06-20-2009, 08:27 AM
Camfantasy's Avatar
dealer quoted me like $700 and almost a day of labor for this. needless to say the lights still on haha
Camfantasy is offline
Old 04-05-2012, 09:31 AM
hungtdao's Avatar
Check on this website or search for egr parts, look for parts # 14120G and 14120GA for the guide tube gaskets.
http://www.courtesyparts.com/maxima-...1785_1797.html
Here is instruction I posted on another website:
If you don't take out the EGR Guide Tube (part # 14713) to clean, then it will likely happen again as my case after one year. Spraying with a throttle body cleaner is not enough. Some other parts need to be removed before the guide tube can be accessed and removed easily such as 1) EGR sensor, 2) Air filter housing and MAF box, 3) some coolant tubes, 4) one end of EGR tube that connects to the EGR Valve. Make sure to keep all bolts and nuts in order.
1) Remove the guide tube by removing bolts part # 01826-821E and 08911-1081A. It is hard but can be taken out by twisting the guide tube at the right movement and right angle, then at a same time pushing down the tube (part# 14120). You don't need to remove the EGR Valve (#14710). Purchase two new gaskets (#14120G, #14120GA).
2) You can use cloth hanger to clean but I suggest to use a metal tube brush. The first time I cleaned without removing the sensor. So, it lasted only 20k-30k miles. This time, I removed the sensor which has wire connects to the guide tube. I found a lot of carbon built-in there too. I hope this time it will be lasted for 100k and plus.
Tube has been cleaned but not enough.
More carbon found after unscrewed the sensor tip.
These metal brush were bought at my local Harbor Freight store
hungtdao is offline
Old 04-05-2012, 10:32 AM
Shift_A32B's Avatar
Try WOT every 2 weeks to burn off carbon built up. That's what I do. Doesn't hurt.
Shift_A32B is offline
Old 04-05-2012, 05:05 PM
eddie982's Avatar
If you don't take out the EGR Guide Tube (part # 14713) to clean, then it will likely happen again as my case after one year. Spraying with a carburator cleaner is not engough. So, I did removed the guide tube. It was tough but I finally got it out by twisting the guide tube at the right movement and right angle, then at a same time pushing down the tube (part# 14120). I did not remove the EGR Valve (#14710) this time.
I bought two gaskets (#14120G, #14120GA).
Some other parts need to be removed before the guide tube can be accessed and removed easily such as 1) EGR sensor, 2) Air filter housing and MAF box, 3) some coolant tubes, 4) one end of EGR tube that connects to the EGR Valve. Make sure to keep all bolts and nuts in order. After I successfully got the guide tube out, I used cloth hanging line then clean inside the tube with a spraying carburator cleaner. I found a lot of carbon built in-side the tube. So, clean with the tube taken out is a whole better and a must. Also spraying on areas that connect to the tube ends before you put it back. Now my car is running again without Service Engine Soon light on.
It has been lasted for about 30k miles, now the code has come back. This time, I will buy a long reflexible brush (metal type) stick to clean it instead of using a cloth hanger.
All this trouble to get the SOB cleaned and it only lasted 30k!!! Wow, i wonder if it's the same for everybody??
eddie982 is offline
Old 04-05-2012, 05:38 PM
infinimax96's Avatar
clean the egr sensor. Block it off and leave the sensor plugged in, call it a day. Shouldn't have any egr problems after that.
infinimax96 is offline
Old 04-06-2012, 12:30 AM
ummmm, way to bump a 2 year old thread? im sure he figured it out by now.....
shilov
02-19-2024 09:40 PM
JoshG
51
09-21-2015 10:41 PM
bumpypickle
09-19-2015 01:07 AM
DarjeelingRose
09-15-2015 01:20 AM
Quick Reply: Cost to clean EGR buildup (CEL 0302)?
