Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Thread Tools Display Modes
Old 07-28-2008, 10:42 PM   #1
Send a message via AIM to 95BLKMAX
HOW TO- 5.5 Gen Front Brakes on 4th Gen
I wanted bigger brakes, but I didnt want to spend a fortune (as much as one would spend, say for a Z32 upgrade, or the 6th gen rotors with Z32 calipers, etc...) for just front brakes. Plus I dont autoX, I just do alot of highway spirited driving; so I wanted a beefier setup that wouldnt break the bank.
COST-
Calipers and caliper mounting brackets used- $100
RPT plated/ X-Drilled Rotors, Axxis Metal Master Pads, 2 liters of ATE Blue Racing Fluid- $185shipped
Ubber Drill Bit- $35
Bolts and lockwashers- ~$10
SPECS-(per 1995 FSM and 2003 FSM)
4th gen Rotors (mm/ inches)
280x22/ 11.02x0.87
5.5 gen Rotors (mm/ inches)
296x24/ 11.65x0.94
4th gen Caliper Pot (mm/ inches)
57.2/ 2.252
5.5 gen Caliper Pot (mm/ inches)
57.2/ 2.252
HOW TO- (I write this assuming you already know how to do a brake job, this how to made with attention to the work specifically related to the conversion process of being able to install these bigger brakes)-
* Remove wheels, calipers (disconnect the lines from them but have a bottle near, they will leak alot of fluid), caliper mounting brackets and pads
* Have this ubber drill bit...
It cost me $35 locally at a "nothing but nuts and bolts- specialized hardware store (Mitchell Supply Company)
also 4 of these Metric bolts with lock washers (stock 4th gen on left, new 5.5gen on right)...
I bought them so long ago I dont recall the specs, so just go to the hardware store with the caliper mounting bracket for thme to check
* With the Ubber drill bit, drill out the two holes on the hub. Try your best to keep it straight. Go slow with the bit at first because if it gets caught up, the drill WILL fling around and it could cause bodily harm depending of how strong of a drill you have. Once it started boring the hole out just go downtown on them. They should look like this afterwards...
* Make a few cuts along the shield's overlap up to the vertical part and with pliers bend the overlap up to vertical. The 5.5gen rotors wont fit otherwise...
* Now with that done, the installation is the exact same as a normal brake job, only that you're using the 5.5 gen parts. Hook up the lines and you will have to bleed ALL 4 calipers. At least with me, I let so much fluid drain that air got into the master cylinder, thus my line for the rear brakes had air, so I had to bleed all 4 corners. Break them in and enjoy the noticeably improved braking over that of the 4th gen parts :-D
__________________
My car for sale February, all Mods go with it- $6000 OBO
Here's the F/S Thread
PM Me for any SERIOUS Inquires only. Spread the word!
LS1 here I come!
95BLKMAX is offline   Reply With Quote
Old 07-28-2008, 10:43 PM   #2
All Buttoned Up!
From a distance with the light against me, lol
Up Close
__________________
LS1 here I come!
Old 07-28-2008, 10:54 PM   #3
Send a message via AIM to xkazik
nice nice , can you see any difference ?
__________________
Warpspeed y-pipe,5 Gen Muffler,Brembo pads and rotors, 4300k HID kit,Sony MEX-BT2600 and amplifier,alpine speakers,Rockford Fosgate Punch P3 Subwoofer.
xkazik is offline   Reply With Quote
Old 07-28-2008, 11:05 PM   #4
Send a message via AIM to Hexon
Is the that orange hawtness of ksports I see? Neat project. I am interested to hear if you have notice an increase in breaking. And how much did this cost?
__________________
Hexon is offline   Reply With Quote
Old 07-28-2008, 11:18 PM   #5
Quote:
Well in all honestly, my old brakes were worn to hell. Pads on the passenger side had about 2mm of material left. Almost down to the metal backing. So yes its definitely worlds better. However, I DO remember what these brakes felt like 3 yrs ago whenI changed them, and yes, these 5.5gen brakes ARE noticeably stronger as far as initial bite and just orerall braking power. Its like adding a turbo to the engine... but to the brakes, LOL. The second time I slammed them from 80 on the highway during the break-in, car felt like it was going to flip forward, lol.
Quote:
Nope, those are blown 6yo+ AGXs lol. Coilovers are not worth the cost for MY uses.
__________________
LS1 here I come!
Old 07-29-2008, 05:27 AM   #6
Mod her. Ate her.
phenryiv1's Avatar
I am going to add this to the stickys.
Great write-up!
__________________
Patrick Henry
2008 Subaru Legacy 2.5i SE 5MT (DD) 1992 BMW 318i 5MT (Project)
Past: 2003 Sentra SE-R SpecV, 2000 Maxima SE 5MT, 1997 Infiniti I30t 5MT VLSD
phenryiv1 is offline   Reply With Quote
Old 07-29-2008, 07:21 AM   #7
blah, blah, blah...
internetautomar's Avatar
Send a message via AIM to internetautomar
so you swapped in 5th gen calipers, and rotors by boring out the original caliper bolt holes and cutting the backing plate?
__________________
Maxima parts catalog
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
Quote:
Originally Posted by Benstoked
he is worth his weight in platinum plugs
internetautomar is offline   Reply With Quote
Old 07-29-2008, 07:37 AM   #8
Send a message via AIM to black_maxed95
cool job, good to see something new. But Im wondering about the difference in brake power. The specs show that the 5.5 and 4th gen calipers are the exact same. Wouldnt that mean the braking is the same? Are the 5.5 pads bigger? If not its the same surface area contact and brake pressure, right?
__________________
I like to "do it myself"
5MT SE 96er:
MEVI + NWP Spacers, Full Exhaust, Flywheel, lotsa more:
MOD LIST
black_maxed95 is offline   Reply With Quote
Old 07-29-2008, 08:25 AM   #9
Quote:
Caliper's pot is the same size, but the body of the caliper itself is bigger (as relevant as that may be). The increase in braking power comes front he larger pads (more surface area), and the fact the caliper is located a bit higher away from the center of the hub to clear the larger diameter rotors (more torque). The two combined made it worth it to me, given how little I spent. Great bang for the buck.
**** I added a cost breakdown to the original thread****
__________________
LS1 here I come!
Old 07-29-2008, 08:32 AM   #10
ok I understand where the braking power comes from. I wasnt sure if the pads were bigger on a 5.5 and I didnt think about the larger torque. I agree, definately a great bang for the buck. Great alternative for those that dont want/need a bbk.
__________________
5MT SE 96er:
MOD LIST
Old 07-29-2008, 10:24 AM   #11
Send a message via AIM to NiZMo1o1
Nice upgrade E !!!
__________________
NiZMo1o1 is offline   Reply With Quote
Old 07-29-2008, 12:33 PM   #12
nice upgrade, for a great price. Good job!
vilmaxima is offline   Reply With Quote
Old 07-29-2008, 03:47 PM   #13
192.168.1.1
gtr_rider's Avatar
I was wondering when you were going to install those things, they were sitting at my house for a hot minute..
__________________
VQpower.com
Need work done:
Suspension, Engine, Brakes, Cosmetic, Headlight Retrofits
gtr_rider is offline   Reply With Quote
Old 07-29-2008, 04:04 PM   #14
How about clearance issues? Are there any?
__________________
OEM RIMS FTW!
WhiteA32 is offline   Reply With Quote
Old 07-29-2008, 04:11 PM   #15
Where did you order all of your stuff at that price?
Old 07-29-2008, 05:49 PM   #16
Send a message via AIM to MDeezy
well hot damn, seems like every week your installing something new and adding a write up.
good job on these. I might have to look into this
__________________
1996 Nissan Maxima 5MT 3.5 (Getting a fresh remix)
1995 Nissan Maxima 4AT "Champagne Coolie" *Sold*new home in FL
1997 Nissan Maxima "Powder Fresh" 5MT 3.5 (performance built)(*new plans*)
MDeezy is offline   Reply With Quote
Old 07-30-2008, 09:03 AM   #17
Send a message via AIM to MOHFpro90
Goodness man...Im gonna have to talk to you on aim about this. Nice job.
__________________
FOR SALE: Ksport coilovers! $225 + s/h!
00VI | 5.5Gen BBK | Axxis Ceramic | Raxles | Ksports | 00 5 spokes | AE'd | Cleared Tails | Shortram | 9007 conversion | LED interior | SNOMAX's LCAs
MOHFpro90 is offline   Reply With Quote
Old 07-30-2008, 10:14 PM   #18
Thunder go b00m.
CapedCadaver's Avatar
so, with the whole drill bit thing... would a stepped bit be good to use to get it started (1 step deep) and then finish it off with a straight bit?
__________________
PieceOut.FallToPeaces
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Fidanza | Exedy | WSP | NWP | a33b front & z31 rear BBK | ES bushings | SE suspension swap | 2k2SE rims | Toyo Proxes4
fu*k a fight, I will just hit him with burhan's car, and tie him up with string cheeze, that way he can chew his way out and he wont starve
New to the forum? CLICK HERE!!!! <-- I see what some mod did there.....
CapedCadaver is online now   Reply With Quote
Old 07-30-2008, 10:52 PM   #19
Quote:
go for it
Quote:
seriously- and I'll give all the credit to the bit's construction, you dont need a step bit at all. This particular bit cut through the iron hub like butter. Just go slow at first. Once you're about 1mm into it, it wont skip around so you can just push it right through no problem
__________________
LS1 here I come!
Old 07-30-2008, 11:14 PM   #20
Thunder go b00m.
Quote:
Originally Posted by 95BLKMAX View Post
go for it
cool. so any-old-bit won't do tho will it? i was wonderin' if you could loan me the thing for $35 and then give $30 back when i mailed it back maybe? kinda 'spensive for something i'm only gonna use once.
__________________
Old 07-31-2008, 12:44 AM   #21
Send a message via AIM to nyc96max
nice write up and good upgrade
__________________
WTB : Vortech supercharger kit
nyc96max is offline   Reply With Quote
Old 08-01-2008, 05:36 PM   #22
Send a message via MSN to Blackwind
how could you make this work for the newer q45 caliper? or is that way off the wall?
__________________
98 SE Black on Black. 5spd swap,budget Ypipe,MEVI,CAI,Clear corners,H&R/Kyb gr2, Flowmaster,FSTB,X-drilled/slotted front and rear,2k2 SE wheels,Stillen Lip,Ionics sides,Fog light rewire,corner light mod,SS Clutchline,15% tint all around 02 Pathfinder 6disc in dash,2k2 max center console.-Production date 09-97 My daily driver.
98 SE Black on Black Auto w/ABS. 2k2 se wheels,Clear Corners,Corner light mod,Rewired foglights,FSTB.-Production date 12-97 Wifes daily driver.
Blackwind is offline   Reply With Quote
Old 08-01-2008, 10:33 PM   #23
not off the wall just teh q45/j30 need a wider rotor. I cant say ya or nay for sure but I know those calipers dont bolt up to stock 4g rotors etc, which is why we needed to buy Jeffs brackets
Old 08-02-2008, 06:54 AM   #24
KRRZ350's Avatar
Send a message via AIM to KRRZ350
YES! I've been waiting/wondering why no-one has done this!! AWESOME!
Also, a little tip, you can avoid having to bleed all 4 by very lightly pinching the line with visegrips until you are ready to install and bleed.
KRRZ350 is online now   Reply With Quote
Old 08-02-2008, 10:45 AM   #25
Quote:
ok. that makes sense. this is a next on my list.
__________________
Old 08-02-2008, 02:34 PM   #26
Nrw
Send a message via AIM to Nrw
Any idea if these will fit under the stock SE 16's?
__________________
