Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-26-2007, 08:38 PM   #1
Prodeje79's Avatar
Send a message via AIM to Prodeje79
Brake upgrades for 16 inch rims?
I have three sets of 16 inch rims:
stock 5 spoke
300zx NA
RX7
I am running some Brembo rotors, SS lines, and hawk HPS pads.
Are there any ROTOR or CALIPER options I can use and still keep my rims?
I prefer to not use longer studs or spacers as a 'fix'.
I did search and failed to find a good thread. If you have found a good discussion, please post it.
__________________
-Prodeje79
Prodeje79 is offline   Reply With Quote
Old 05-26-2007, 08:42 PM   #2
PM me for LCA's!
SNOMAX's Avatar
I'd go with J30/Q45 calipers and rotors. You will have to get the rotors milled down a few mm to fit. But you can use your maxima's brake pads (cause you have hawks--don't change). You can also keep your rims. However, they are really heavy iron calipers. Go to www.rockauto.com if you want to skip the junk yards.
You can't really do a rotor upgrade due to your 16" rim limitations. You would need at least 17"s to clear a 12.6 or 13" rotor upgrade.
Hope that's the info you need.
SNOMAX is offline   Reply With Quote
Old 05-26-2007, 11:34 PM   #3
Send a message via AIM to !PrjctMax!
Why don't you get the 300ZX TT f/r calipers? front is 4POT and rear is 2POT, not sure what rotors you would be able to fit on those, but the calipers are 30mm and are made out of aluminum, so they are pretty light as well
__________________
Stopped in on 10/29/09.
!PrjctMax! is offline   Reply With Quote
Old 05-26-2007, 11:36 PM   #4
IMO your best bet would be to try Z32 front brakes. You'll still have to mill the front rotors a few mm in order to fit, but they should probably clear the Z32 wheels.
Someone at some point was looking into a caliper reloacation kit to fit some 12" TL calipers, but they never got around to it.
MorpheusZero is offline   Reply With Quote
Old 05-27-2007, 06:36 AM   #5
You can't friend yourself
Kevlo911's Avatar
Your best bet is J30/Q45 NOT 300zx. 300zx will clear 300zx 16" wheels and that is about it. They won't clear your SE wheels and I highly doubt they will clear the Mazda wheels. I would go J30/Q with Hawk Pads and RTP 3mm milled rotors.
Kevlo911 is offline   Reply With Quote
Old 05-27-2007, 06:38 AM   #6
Ah true, I missed the part about keeping all sets of wheels. My bad.
Old 05-27-2007, 08:30 AM   #7
Send a message via AIM to speed racer
Go with the J30 calipers. you need to mill the diameter at least 3mm. You need the J30 torque member and pads as well. You will also need to mill down or grind the control arm next to the ball joint to prevent scoring of the inner rotor. Stopping power is great and the rotors can handle the abuse since there thicker. I believe 25mm.
speed racer is offline   Reply With Quote
Old 05-29-2007, 03:14 PM   #8
Prodeje79's Avatar
I appreciate everyone's help!
If I were to put my 97s SE wheels on my 95, and take the 17" Altima wheels off it for my 97, would that help anything?
I will search for some good write-ups on the j30/q45 installs. I do not know if I am comfitable with "milling" though :>
Old 05-29-2007, 03:29 PM   #9
8600RPM and Counting!!!!
Zack342's Avatar
Send a message via AIM to Zack342
Well have a qualified machine shop do it. I know 98blackmaxse had his rotors milled for $40 for the pair. As for a write up you probally will not find one since there is nothing difficult to this upgrade. Once you have the milled rotors just install those as you work any rotors and the Q45 caliper will bolt to the hub/spindle in the stock location and it will use the stock brake lines. I did quite a bit of research on this upgrade but never followed up because I purchased a new car. From what I have read this upgrade is very favorable since it will not throw off you brake bias too much.
P.s: if you interested i am selling a pair of Q45 front calipers .
__________________
2003 Nissan Maxima SE - Majectic Blue 6MT HLSD Meridan Edition, Titanium Editon-Dynoed 206.61whp and 219.54wtq...Stock
17 Degree Timing Advance*Apexi/Berk Short Ram Intake*Cattspeed Y-pipe*Cattman 2.5 B-Pipe*HKS Sport Exhaust*Cattman Ti FSTB*Progress RSB*ES Poly Front Sway Bar Bushings*HKS Grounding kit*Axxtion STS
Zack342 is offline   Reply With Quote
Old 05-29-2007, 04:33 PM   #10
If anyone is trying to do this project...you should invest in a die-grinder with a burr bit to remove metal.
This is the complete write up with pictures
http://forums.nycmaximas.org/showthr...&highlight=j30
Old 05-29-2007, 07:24 PM   #11
Zack342's Avatar
Q45 calipers and J30 calipers ARE NOT THE SAME
Old 05-29-2007, 09:35 PM   #12
ok....so you got a write up since there not the same???
Old 05-30-2007, 01:50 PM   #13
Zack342's Avatar
Quote:
No the write up you provided will work. I just wanted to clarify that they are no the same calipers.
__________________
Old 05-30-2007, 02:18 PM   #14
SomePsychoGuy
SPiG's Avatar
Send a message via AIM to SPiG
They are very close, but not the same, not sure what the exact differences are though. As for installing them, it should be close enough.
SPiG is offline   Reply With Quote
Old 05-30-2007, 07:40 PM   #15
Kevlo911's Avatar
Looks different, functions the same, Ithink they use the same pads as well.
Old 05-31-2007, 05:25 AM   #16
Wanna Go Muddin?
Greeny's Avatar
96 J3093 Q45
Greeny is offline   Reply With Quote
Old 05-31-2007, 07:15 AM   #17
^^^^Looks very similar to me. What you guys think???
I believe the Q45 is heavier than the J30 Calipers
Old 05-31-2007, 12:55 PM   #18
'Trynna' is not a word
mtrai760's Avatar
FYI, I believe they require a small spacer, but 3rd gen RX7 rims WILL work with the Z32 calipers. SX7R used to run them.
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 05-31-2007, 10:47 PM   #19
Zack342's Avatar
Can anyone check the Part #'s for the J30 and for the Q45?
Old 09-20-2009, 03:58 PM   #20
I need recommendation,
We got accepted in the 24 hours of Lemons race. We gave a 1997 Maxima. The seller of the car put on 17" wheels. The rules allow for "open" brakes. I was wondering what "cheap" (front) brake upgrade can we do with 17" wheels? should we just upgrade the pads? is the there another nissan rotor/caliper package that would fit that we can pick-up used?
cherlas-son is offline   Reply With Quote
Old 09-22-2009, 04:28 PM   #21
STFU n00b!
For LeMons, the stock brakes will be up to the task assuming you put some good pads on it. Porterfield R4 or Hawk HT-10 or maybe even some Hawk HP+ would do the job.
Which track are you planning to race at? The Texas event runs on a pretty small/tight track where you don't ever build up a lot of speed, so you don't need much brake.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 10-07-2009, 12:25 PM   #22
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
A spacer will pretty much be required to fit Z32s behind FD3S wheels. There was a small decrease in distance from the spoke to the outside of the caliper when I ran mine.
__________________
Fr33way™ is offline   Reply With Quote
Old 10-07-2009, 12:27 PM   #23
Wild for Width
Fr33way™'s Avatar
Quote:
Originally Posted by Greeny View Post
96 J3093 Q45
A part of the difference in that picture of the 45s is the bracket for the electronic wear sensor that is only on one (driver's side) caliper.
__________________
Old 10-29-2009, 10:00 PM   #24
Auto Tech Performance
rroderiques77's Avatar
Send a message via AIM to rroderiques77 Send a message via Yahoo to rroderiques77
How about Z33 TT calipers and A34 rotors?
__________________
94 F22B2 CD6 G77M 5MT- daily bucket
Will be one day modded
02 A33B KT3 6MT
241whp/227wtq
ET...14.480
Interested in owning/operating an automotive repair franchise?
P/M me for details.
rroderiques77 is offline   Reply With Quote
Old 10-30-2009, 07:00 PM   #25
STFU n00b!
Z32 or Z33?
__________________
Old 11-02-2009, 05:32 PM   #26
Quote:
Originally Posted by Matt93SE View Post
Z32 or Z33?
Excuse me, Z32
__________________
02 A33B KT3 6MT
241whp/227wtq
ET...14.480
P/M me for details.
Old 11-04-2009, 04:48 PM   #27
guys, im looking to geting the q45 brake upgrade, but im not clear what is needed is this pretty much correct??
The year is 90 - 96 q45 calipers and rotors . Are these 12 inch rotors? I can use my own lines, removed or cut the dust shield and they will bolt right up? or do i need to mill the rotor? By milling the rotors is it making the diameter smaller or what exactly are you milling?
aic96max is offline   Reply With Quote
Old 11-06-2009, 05:28 PM   #28
Send a message via AIM to sergofast
i just posted this in the 4th gen forum....shoulda known better to look here.
What is the Biggest brake upgrade that you can fit under a stock 97 SE rim? The J30 i know will fit (the rotor diameter is the same, you just have to play around with clearancing the torque member).
What about a 5.0 or 5.5? I have read that they will fit on a 16" rim....but not specifically the 97-99 SE 16" rim.
Im not talking about increasing the size of the rotor (at least not so much that I have to get aftermarket rims) but getting better calipers than stock (ie more surface area or 2 pot instead of one).
sergofast is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
