Spark Plugs DIY?
Originally posted by AGnismo
Yes, you can do this own your own. All you need to do is remove the valve cover (front spark plugs) and then unscrew the coil (one cover each spark plug). Make sure you have plenty of extensions for the spark plug bolt.
Originally posted by medicsonic
One problem with that, you are going to need a Torx screwdriver to get the valve cover off, but they usually come with a tool kit anyways.
Re: Spark Plugs DIY?
Originally posted by hbsprite
Has anyone installed their own spark plugs. I am an amateur with basic mechanical knowledge. Should I attempt it or leave it to the professionals?
or you can do what i did.. just do it and when your done it always works...... maybe its just cause im so good though?!!!
Read the Sticky
Re: also..
Originally posted by NYCe MaXiMa
Basically, read the sticky and the directions...
http://forums.maxima.org/showthread....threadid=45742
Re: Re: also..
Originally posted by bill99gxe
Exactly. Another wasted thread.
pretty sad huh?
During the past year at least 90% of all possible "general" questions have been asked before.
Originally posted by 1Phat Max
do i have to get torque wrech for doing this or can i just tighten them with basic commen sense that not to tighted that much and also not to leave it loose? thanx
06-06-2017 02:01 PM
magiconthetire
10-26-2015 09:03 PM
Need help
23
10-02-2015 08:56 AM
