clicking noise when turning wheel, help!!!
Old 09-24-2001, 10:10 PM
MAXTOUT's Avatar
Here is the deal. My CV boot tore and a couple weeks later it started making this clicking noise so I assumed the CV joint was shot. The thing is that I replaced the drivers side axle with a reman. and everything went fine, but it still makes the same noise. It does not happen when I am moving though(I did the test where you drive in a hard circle both directions at low speed, and it did not make noise). It only seems to make this noise when I am turning the wheel either way. Does this sound like a problem with the steering components? When I get a little extra time I will jack the car up and take off the wheel and listen for this noise with a small diameter hose when the wheel is being turned. Can anyone suggest anything else to check while I have it on the stands. Any help is greatly appriciated. Thanks, TED
MAXTOUT is offline
Old 09-24-2001, 10:53 PM
Eric L.'s Avatar
Couple of ideas:
1) Spring is not set correctly on the perches and is binding as you turn the steering wheel
2) Strut bearing is worn out
3) Make sure the strut mounting bolts (upper and lower) are torqued correctly
Eric L. is offline
Old 09-25-2001, 05:25 AM
njmaxseltd's Avatar
Strut Bearings
Sounds like the strut bearing. I had to replace mine after I put H&R springs in. I destroyed them by putting them in upside down. what an idioit. Thats what happens when you have to many people helping you with a job.
njmaxseltd is offline
Old 09-26-2001, 02:36 PM
radiohead75243's Avatar
Re: clicking noise when turning wheel, help!!!
If you determine the cause to be a worn strut bearing, do not simply re-grease the bearings: Replace them. I performed this job using the following site as a guide, and ignoring the Haynes manual advice of replacing the bearings. The re-greasing lasted two weeks before the clunking returned. Once the grease breaks down, the bearings tend to break down also. This site is helpful, as long as you replace the bearings.http://www.motorvate.ca/auto/maxima/strut_bearing/strut_bearing.htm
radiohead75243 is offline
trasmadean
02-01-2017 08:20 PM
boomerbrian
11-08-2015 05:10 PM
official_style
08-29-2015 10:10 AM
bc992164
08-26-2015 12:19 PM
jhontelj
08-17-2015 04:07 AM
Quick Reply: clicking noise when turning wheel, help!!!
