Knock Sensor Code not clearing?
Has any one ever had the problem of not being able to clear a code? My 1995 GXE is throwing a knock sensor code, so I bought a new sensor and replaced it. Before I replaced the sensor I tried clearing the code with my actron scanner and it would not clear. I would press erase on my scanner and the results would come back saying that there was still one code remaining and it was the knock sensor code. So I got a new sensor. I put the new sensor in over the weekend, and drove the car a little bit. I am still getting the same thing. It will not clear with my scanner. Its not like I am clearing the code and it keeps coming back, but rather it will never clear. Has any one had this problem before? What was it?
the car is a 95 GXE with an 00VI, and JWT ecu.
....now that I think about it, my brother did splice into the knock sensor wire when he put my VAFCII in...I need to check that.
I checked the connection for the VAFCII, and every thing looked fine. So I reset the codes with the ecu screw. Still the same thing. The knock sensor code will not clear. What gives?
http://forums.maxima.org/showthread.php?t=515963
Do you have an Air fuel computer hooked to your system? Is the KS wire tapped? Let me know, I am going to check my wiring and I may do away with that connection for my VAFCII if I don't need it.
may have overtorqued it and cracked the new one.
and wizard, you have tride to "erase" the code without installing a new knock sensor. and you wonder why it wont go away? (that is the gist I got from your other thread anyhow).
knock sensors dont care if you feel they are bad or not. you are getting the KS code for a reason. and you cant erase the code for a reason. THE KNOCK SENSOR IS BAD.
I've got the same problem... Just so you guys understand what he is saying...I'll do a write-up titled...
Cardana24's Problem for Dummys...
He hooks the actron scanner up to his car...he pushes the erase button with the engine OFF...then he waits for the scanner to do its job... then it says DONE or the more expensive Actron it says (FAILED...2 codes remain)...THE WHOLE TIME HIS ENGINE IS OFF...So he rechecks his codes and OH NO!!! THEY ARE STILL THERE!!!! Damn... That means it can't be the knock sensor... So he asks himself "WTF????"...."Maybe Maxima.org knows...???"
He he he.... sorry guys just gotta slow the bus down for some of the slow ones.... The code won't erase...NO MATTER WHAT!!!!
alright, the problem was my VAFCII, I had a wire hooked up wrong. I cut that wire and now i was able to clear the code. hopefully it stays away. thanks for all the advice.
I am having the same problem "can not erase the KS code even with a scanner". The check engine light went on for 02 sensor and KS, I first replace the 02 sensor and then try to ereae the code. O2 code is cleared but the KS code just doesn't get clear. I have tried it many many time but it still does not clear the code. Do I need to replace the KS before I can clear the code???? I always think that the code can be clear with the scanner even wihout fixing it (I also understnad the code will come back again in the future). Anyone can help me with this????
I've seen walk throughs around here that even have pictures. I thought it was simple until I saw that it was nearly impossible to do on my car but I got it done with a swivle joint and a hanger to use as hands.
http://www.youtube.com/watch?v=R2ntaxi7bXk
Video - Part 2:
http://www.youtube.com/watch?v=fPIMOIwLISc
Step-By-Step How-to:
http://forums.maxima.org/4th-generat...-tutorial.html
What you need to do is disconnect the harness and then clear the code with the computer. After it is cleared, connect it back and start the car and scan for codes again. If it reappears, you would need to check the knock sensor for proper installation.
Video - Part 1:
I laughed out loud at that one.
ballerchris510
09-23-2015 08:46 PM
