Go Back   Maxima Forums > Maxima Discussions > 4th Generation Maxima (1995-1999)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-05-2009, 01:29 PM   #1
Easy Knock Sensor Installation! Picture Tutorial
This is how to remove and replace a Knock Sensor on a 1995 Maxima (95-99)
You can get a knock sensor off of ebay for about $40-$70 (Or LESS)
Pep Boys wanted to charge me $207.89 for a knock sensor, and $263.90 to remove and replace it. ($470!!)
That's a savings of $400 for a self installation. (Could be more or less depending on the shop)
So lets get started.
I know that there is a knock sensor tutorial online already.
http://www.motorvate.ca/mvp.php/507
But this is just a quick run down with lots of pics..
All that you will really need for this is:
1. The replacement knock sensor
2. 12mm wrench
3. Flashlight
4. Patience
5. Gloves
6. Flat head screwdriver, or needle nosepliers (to remove harness clip)
Its a pain in the *** and you will most likely bleed, especially if you have large hands. It took me about 15-20 minutes to do. The hardest part is squeezing the little wrench in the crevice and trying to loosen the one bolt. Once its loose though, it shouldn't take you more then 5 minutes to put the new one in.
1. What you need.
2. Knock Sensor Location
3. Unbolt the knock sensor with your 12mm wrench. *Hardest part, I actually got a hammer and pulled it against the wrench as a lever to get the bolt loose. Be patient, once its finally loose you can unbolt it with your finger.
SPER is offline   Reply With Quote
Old 05-05-2009, 01:30 PM   #2
Continued
4. Take knock sensor with the harness and put it on a flat surface. (On the Engine)
5. Inspect the knock sensor for damage/corrosion.
Woah this bad boy needs to be replaced. Look at that crack down the middle.
Old 05-05-2009, 01:31 PM   #3
6. With needle nose pliers or a flathead slide the metal clip on the harness up. Don't take it off though
7.
Attach the replacement knock sensor in the harness and slide the clip down to secure it.
8. Be careful not to drop knock sensor when manuevering through the crevice. Screw in the bolt by hand. And tighten it slightly.
Job done.
You just saved yourself hundreds of dollars, and a few hours of manual labor.
Old 05-05-2009, 01:39 PM   #4
Carbon Fiber addict
The n00bs should appreciate this. Nice writeup SPER.
__________________
99 Max SE 5 spd, SC'd, MEVI, Cattman Headers, LED tails, R34's with S2000 projectors, 13.1" Brembo BBK, EU.....381 HP/323 TQ
The Wizard is offline   Reply With Quote
Old 05-05-2009, 01:50 PM   #5
Send a message via AIM to ImmaSquashYou
hey, i appreciate it....does this make me a noob???
__________________
3 Threads, same question. Good Job Mantis!!
http://forums.maxima.org/infiniti-i3...ights-fit.html
Quote:
Originally Posted by JNCoRacer View Post
Good god, again?
Might I refer you here...http://forums.maxima.org/4th-generat...nto-i30-2.html
Quote:
Originally Posted by mantis40 View Post
OMG THANKS! Looks like some good info there
Quote:
Originally Posted by a33i30 View Post
^You started that thread
ImmaSquashYou is offline   Reply With Quote
Old 05-05-2009, 01:53 PM   #6
I'm still a noob, I've learned alot about my maxima though over the past couple months. Before I had this car I never even heard of a knock sensor.
Old 05-05-2009, 02:44 PM   #7
The Dirty Pearl
pmohr's Avatar
That's the same way I did, 12mm wrench and a screwdriver to pry with. Tons easier than a ratchet, extensions, and swivels (IMO).
__________________
Quote:
Originally Posted by 2damax View Post
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz View Post
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
FSMs | A32 CEL Decoder | Howto Videos
pmohr is offline   Reply With Quote
Old 05-05-2009, 02:45 PM   #8
The Dirty Pearl
pmohr's Avatar
Quote:
Really? Many cars now have them.
For a quick rundown, eBay is the easiest to see the majority: http://shop.ebay.com/items/_W0QQ_nkw...Q_fromZQQ_mdoZ
Though you'll notice that over half of them are for Nissans, heh.
__________________
Old 05-05-2009, 03:20 PM   #9
Wow $25 shipped for a knock sensor.. I feel like i got ripped off now lol, didn't know you could get one for so cheap.
Old 05-05-2009, 03:25 PM   #10
Thats mass production for you
__________________
97 Maxima GXE Totalled
96 Maxima Se Blown 3.5 New one coming
90 B12 Sentra My new winter beater
Product_Of_Korea is offline   Reply With Quote
Old 05-05-2009, 06:42 PM   #11
Thanks for posting the pics!
This definitely would've been more useful for me last week, but I got it done anyway with the help of my friend's small hands.
I ordered the generic knock sensor from eBay for ~$25 shipped and it worked like a charm!
balkan is offline   Reply With Quote
Old 05-05-2009, 08:14 PM   #12
Pardon my noobness,
but how do you know if your knock sensor is due for a change?
visual inspection?
check engin light?
symptoms?
I just got a max so im not too familiar with all that stuff
thanks guys
Ultrastar is offline   Reply With Quote
Old 05-05-2009, 08:21 PM   #13
my check engine light is on, thats how i know
maxispeed is offline   Reply With Quote
Old 05-05-2009, 08:22 PM   #14
The Dirty Pearl
pmohr's Avatar
Quote:
The KS code will NOT light the CEL.
Quote:
Originally Posted by Ultrastar View Post
Pardon my noobness,
visual inspection?
check engin light?
symptoms?
thanks guys
You'll get a code for it, generally.
__________________
Old 05-05-2009, 10:49 PM   #15
DJD
This may be a dumb question, but how does the knock sensor code not light the check engine light? Are there any other codes that won't illuminate the light? I believe you though because I just had the CEL come on in my 96 and pulled the codes and there were two, one for the KS and one for an O2, and I highly doubt they went out on the same day.
__________________
For Good Deals on Tires & Nationwide Shipping:
www.campbellperformancetires.com
DJD is offline   Reply With Quote
Old 05-05-2009, 10:55 PM   #16
The Dirty Pearl
pmohr's Avatar
Quote:
How does it not? It just...doesn't. The ECU doesn't light the MIL for that code, simple as that.
Replace the O2, clear the codes, then check again. The KS code seems to be thrown by emissions DTCs.
__________________
Old 05-05-2009, 10:57 PM   #17
knock sensor is a ghost code, your O2 sensor could have set off the knock sensor. There are other ghost codes that are known. Another common one seem to be the evap. Don't know why the knock sensor won't light a code, but it doesn't. But if you sense a loss in power, you might want to check for a code. But other than that, it doesn't do any harm to your car.
edit***damn, pmohr can type faster than me and i thought that i can type fast....
__________________
Good god, again?
Old 05-05-2009, 11:30 PM   #18
DJD
That's strange. I understand how a faulty emissions sensor could set a KS code. But I'm more familiar with GM's and a KS fault alone will definitely give you a CEL in one of their vehicles. You learn something new everyday I guess.
Just out of curiosity, do you fellas know of any other ghost codes that won't give a CEL?
__________________
Old 05-06-2009, 12:27 AM   #19
about the easy way to change the KS, wat i did was take the IM off, its not that hard...
__________________
1996 Nissan 240SX sold
1995 BMW 740 IL totaled
1995 Nissan Maxima SE sold
2005 Acura RSX type-s crashed
1995 Nissan 240SX blown engine
1997 Nissan Maxima GXE Current
and im just 18
whiteSE is offline   Reply With Quote
Old 05-06-2009, 03:47 AM   #20
Quote:
I changed mine for about 4-5 min. I am sure you can't do it faster with taking the manifold off
__________________
Signature pictures are to be no larger than the allowed size of 550 x 325 pixels
tosheto is offline   Reply With Quote
Old 05-06-2009, 10:50 AM   #21
ah ok,
thanks for the response guys,
great tutorial btw,
will come in handy
Old 05-06-2009, 02:57 PM   #22
i kno this isnt the point of the thread but jsut a quick comment...
Quote:
Originally Posted by ImmaSquashYou View Post
... Another common one seem to be the evap....
i got a CEL for EVAP and KS only.. The EVAP could be my gas cap but im not really sure ( if that makes ne difference).
__________________
Warpspeed SS y-pipe, test pipe, Bosal b-pipe, magnaflow muffler. Ebay FSTB. Aluminum oil cap
JVC hu, 2 12" sony xplod subs ported box, Alpine componenets in front doors, 6.5" Alpines on rear deck. Audiobahn cross over, Kenwood mono amp, Sony 4 channel amp.
ThreePointO is offline   Reply With Quote
Old 05-06-2009, 03:05 PM   #23
boost me.....
96blackmaxSE's Avatar
NICE WRITE UP!
__________________
SHIFT_SIMPLICITY
FOR SALE: Custom boot/ armrest set: http://forums.maxima.org/4th-generat...stitching.html
"SECURITY" OEM Light:http://forums.maxima.org/4th-generat...led-light.html
00VI'd, Exhaust'd, Dropped, Retrofitted, Rim'd, Carbon fiber hooded, Tint'd, 5spd'd....
96blackmaxSE is offline   Reply With Quote
Old 05-06-2009, 04:12 PM   #24
good write up helpfull
__________________
Jayson89NYC is offline   Reply With Quote
Old 05-06-2009, 06:37 PM   #25
buy a car from him?
internetautomar's Avatar
Send a message via AIM to internetautomar
where was this tutorial last year when i needed it for my purple 96.
the current 96 already had it done along with the water pump
of course current 96 has an uncertain future right now.
__________________
Maxima parts catalog< Website for sale
96 Green A/T gone
94 Pathfinder POS GONE! | 79 Camaro sold
98 I30t Silver on black A/T gone | 96 Granite Pearl (AKA Purple) A/T gone
92 grey VE A/T gone | 96 I30 Black gone
92 maroon VE A/T gone | 92 white VE M/T gone
92 grey VE A/T gone | 6/84 L24E last of the RWD Maxima gone
internetautomar is offline   Reply With Quote
Old 05-06-2009, 10:41 PM   #26
this is ofcoarse the fed-spec.
__________________
FOR SALE
97-99 Headlights $100 shipped obo
Snypa is online now   Reply With Quote
Old 05-06-2009, 11:20 PM   #27
The cali got a different KS?
Max-e-MO! is offline   Reply With Quote
Old 05-06-2009, 11:23 PM   #28
Quote:
It's the same KS, just harder to get to.
Old 05-06-2009, 11:31 PM   #29
Thanks for the info man...Very helpful...
__________________
Music is my LIFE!!!
jagass is offline   Reply With Quote
Old 05-21-2009, 10:40 AM   #30
Send a message via AIM to speed3000gt Send a message via Yahoo to speed3000gt
This is great, thanks man.
Do you remember when the knock sensor went out? Did it make your car hesitate and then die? And then when you turned the car back on, did the check engine light come on?
Thats what happened to my car yesterday night.... This morning the car drives but with the check engine light on... So I unplugged the knock sensor to see if that made a difference, which it didn't.... which leads me to believe its time to replace it.
Do those "fuel injector additives" cause any damage to the knock sensor? I just put some in 5 days ago and this happens.
__________________
1997 I30
speed3000gt is offline   Reply With Quote
Old 05-21-2009, 10:41 AM   #31
The Dirty Pearl
pmohr's Avatar
A KS will not cause the engine to stall. Simple as that.
Have you not pulled the codes? A KS code will not light the CEL.
__________________
Old 05-21-2009, 10:45 AM   #32
Carbon Fiber addict
Knock sensor is not causing your problems. And did you even bother to check your code(s)?? KS doesn't trigger a CEL btw.
Your method of diagnosing your problem is not methodical.
Fuel injector additives will do nothing to your KS. You're talking apples and oranges here bro.
EDIT: Pmohr beat me to it.
__________________
Old 05-21-2009, 11:00 AM   #33
Yeah the codes that came up were 1) MAF sensor and 2) Knock sensor.
I just installed some NGK Platnium G-Power plugs 3 days ago and am wondering if thats what caused this. These NGK platnium plugs were only $3 compared to the other NGK (stock plugs) for $11..... What the hell are the G-Power plugs? Im going to put the factory plugs back in and see if anything changes... if it does, make a sticky to AVOID the NGK G-Power Platniums ( read in another thread that the G-power plugs did the same thing to someone elses maxima)
__________________
1997 I30
Old 05-21-2009, 11:03 AM   #34
Carbon Fiber addict
It's not the spark plugs either....it's clearly your MAF. Chances are, the KS is piggybacking the MAF code, thus throwing a false KS code. Fix the MAF problem, and I bet both codes will go away.
__________________
Old 05-25-2009, 07:27 PM   #35
Send a message via AIM to MuNcH357 Send a message via Yahoo to MuNcH357
I agree... I wasted more time with the extentions and u-joints than just cramming a 12mm wrench in the blackhole and using a screwdriver on the open end for leverage...
__________________
"Take these words home and think it through, or the next rhyme I write might be about you.."
MuNcH357 is offline   Reply With Quote
Old 05-26-2009, 10:42 AM   #36
Is there a place we can re-locate it to ? (like this 300zx) http://www.youtube.com/watch?v=EZoOcHtv-LI
__________________
1997 I30
Old 05-26-2009, 10:47 AM   #37
The Dirty Pearl
pmohr's Avatar
...why would you want to? Move it anywhere but where it was from the factory, and you're likely going to end up with a lot less sensitivity to knock. Might as well just throw a resistor in the harness, IMO.
Did you search? A few people have relocated it, and there have been several threads on it.
__________________
Old 05-26-2009, 12:46 PM   #38
The Dirty Pearl
pmohr's Avatar
How in the hell did you fit your hand in there to screw in the bolt?!! I guess this method wont work for people who can palm a college basketball?
I got in there no problem
Remember, to be an import mechanic you also have to be a contortionist.
__________________
Old 05-26-2009, 12:50 PM   #39
192.168.1.1
gtr_rider's Avatar
about the easiest way to take out a KS, i've done numerous times and I have baseball gloves for hands.
__________________
VQpower.com
Need work done:
Suspension, Engine, Brakes, Cosmetic, Headlight Retrofits
gtr_rider is offline   Reply With Quote
Old 05-26-2009, 01:41 PM   #40
pmohr, funny you mention the resistor thing, I was going to do that exact thing on my daughters 97 Altima until I can get a new KS. Have you seen this done and do you remember the value used? I seem to remember that it's somewhere in the 600K region.
jdooley is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
