Steering wheel shake...Highway ? brakes
Usually happens at higher speeds like 75-80 on the highway..the steering wheel shakes pretty bad when Im on the brakes and Alittle bit when Im off them..I just got my front end alligned and its still there and I did the brakes about a year and 3 months ago. I called the guy that did the allignment and he said its probably brake related but I thaught that you feel that in your foot if it was brake related ?? please help..If its brake related Im going to get new roters and all new pads
-Matt
-Matt
Re: Steering wheel shake...Highway ? brakes
-Matt
-Matt
If its the whole car that shakes then ur rotors are prolly warped. I had this problem, but mine were really warped. You can go to pepboys and get them resurfaced for like $50 or something, or just get new rotors.
Also, if your lug nuts are on too tightly that could be causing the shaking when you put on brakes...my stock wheels were on really, really tight and when i put my rims on 2 weeks ago, we didn't tighten the lug nuts as tight as they were on my stock rims. now my steering wheel doesnt shake. hope it helps!!
the rotors warm too much
-Matt
-Matt
Re: Re: Steering wheel shake...Highway ? brakes
Originally posted by 96_vqmax
Does the steering wheel shake when you were cruising or does it only shake when you were braking?If it's only shaking when you cruised at certain speed like 75-85 then your tires are prolly out of balance.If it's only shaking when you apply your brake then your rotor prolly warped.Hope this will help.
Re: Re: Re: Steering wheel shake...Highway ? brakes
Originally posted by Bgohan
Do a search on this steering shake problem here: Slight shaking at 75-80 it is a common problem with 4th gen Maximas with some milelage on them. But the reason is as-yet unknown. A bad shake at a certain RPM is likely tires or tire balance, but it can also be caused by brakes or rotors, CV joint, suspension parts, or even wheel bearings.
What about the carrier bearings??
I've noticed this wobble too, but It's always remained after mods that have replaced everything else discussed so far. I have another common 4th gen. problem, the leaking differential seal caused by excessive carrier bearing play. If you grad the inboard cv joint and try to move it you can feel 2-3mm of play. I think this could easily cause the slight wobble at speed. I feel the wobble at all speeds, and this is the last thing besides the wheel bearings that I can think of.
Originally posted by camaro1698
this is a common problem in 4th generation maxima's. It's a pain in the *** and Nissan has no idea how to fix it, that's why next time I'll be purchasing a better built vehicle!
As far as build quality goes... I've had 8 cars in the last 8 years. My I30t, basically a 4th gen Max, is by far the most durable of them all. It has over 140K, and I drive the $*#@ out of it every time I drive. It's only problem has been the carrier bearing.
My list of cars goes as follows:
1) 91 Camaro convertible w/5.0L V8 (GM junk, problems...)
2) 92 25th Anniversary Camaro w/5.7L (More GM junk)
3) 93 Honda Accord Coupe (Good car, but I got bored)
4) 94 Honda Accord Coupe (Better car, alternator kept going out...)
5) 95 Honda Prelude VTEC (Water pump went bad, $1200)
6) 93 Mitsubishi Eclipse GSX (Fast, but the transmission gave up)
7) 96 Toyota Tacoma TRD (Got it stuck in a river... bye, bye)
8) 97 Infiniti I30t (Got it new in early 98 and haved loved it since)
How do you fix bearing preload, is it just an adjustment or does the bearing have to come off. I checked motorvate.ca and they didn't say anything about a wheel shimmy caused by bearing preload. Any info is appreciated. Thanks
It would be pointless to go in and re-shim the original bearings because by the time you notice and problems, the bearings have 60-70K on them and are already going.
Re: Re: Re: Re: Steering wheel shake...Highway ? brakes
If it's CV joint, suspension parts, or even wheel bearings,then it's more likely happen at all speed.
But then again, it was mostly under accelleration - not his problem I see.
I'm going to go hand tighten mine and see if that helps.
I have 47,000 miles on my 98 Max. I have always had my steering wheel shake at around 70 - 75 mph (bought it with 36,000 miles). I do have warped rotors, but they only shake when the brakes are applied, even when brand new I had a shake at 75mph.
I had my tires balanced and it did nothing, I recently got a new set of wheels/tires, balanced, and still have the shake.
Does that sound like the carrier bearing? I really have no clue about this but it drives me crazy, its not horrible, just very annoying.
Anyone?
u see if ur strut might be loose?
i had same problem and got new struts but the place didnt tighten them good enough so my car shaked real bad between60-80
but u said u balanced...
but see if struts are loose...
kinda out there.. but why not?
I'm an auto. The last time my car was in the shop they told me that my boots were cracked so I don't know. How would I tell if my strut is loose?
It's fairly easy to tell if your strut is loose. You should be able to avoid jacking the car up if you simply open the hood so that you can see the strut tower, and shake the car from side to side by pushing on the fender. If its loose it will move very slightly with this side to side motion.
If you want to be really sure, jack it up and give the suspected strut a good tug...
If its really loose it'll make noise over bumps and potholes.
lowpost99
05-16-2021 11:18 AM
