Injectors 1,3,5 have no power
Old 07-22-2008, 02:44 PM
Amillyon's Avatar
I have recently found out that injectors 1,3,5 are not getting any power. I check the harness and it check out good, I even flipped the entire inector rail and used the 2,4,6 harness to make sure the injectors where not bad and they work pefectly. I need to know what are the chances of the ECU being bad and how to go about troubleshooting the issue.
Amillyon is offline
Old 07-22-2008, 02:46 PM
MaximaN00b's Avatar
Clogged fuel rail? Idk, shot in the dark.. sounds odd that one entire bank is not getting power.
Youre misfiring on 3? God, that must sound like death unleashed, no??
MaximaN00b is offline
Old 07-22-2008, 02:51 PM
Amillyon's Avatar
Hey MaximaNoob, I verified the the rail was good also when I used 2,4,6 harness. I saw injector 1,3,5 spray.
Amillyon is offline
Old 07-22-2008, 02:54 PM
Dhunterx's Avatar
Well, it's worth a shot, but try getting the 135 harness from a junk yard. You could just splice in the new harness without having to removing much, and if it sprays, then that was your problem.
Dhunterx is offline
MaximaN00b's Avatar
Ooo my bad, so you were saying the harness isnt powering them..
k gotcha..
Old 07-22-2008, 02:59 PM
Amillyon's Avatar
Hey Dhunterx I did a continuity check on the harness from end to end and it's good.
Amillyon is offline
Old 07-22-2008, 05:39 PM
MaximaN00b's Avatar
check the ecu codes?
http://forums.nicoclub.com/zerothread?id=126534
you sound like you know what the hell you're doing.. so I cant be much help, other than that list of codes the ecu can throw out.
Old 07-22-2008, 06:13 PM
Dhunterx's Avatar
Thats weird that you're getting power on all of em, yet one side is getting juice... I'm gonna leave this up to the experts of the forums. That is a weird issue.
Dhunterx is offline
Old 07-22-2008, 06:55 PM
Amillyon's Avatar
Dhunterx, I'm only getting power to 2,4,6. To run a test on the injectors 1,3,5 I simply hook the 2,4,6 harness to see if they would fire and they did. This let me know there was no power getting to injectors 1,3,5. I also check the wire harness for 1,3,5 that plugs to main harness and the continuity was good from end to end.
Amillyon is offline
Old 07-22-2008, 07:06 PM
akurtzer57's Avatar
Check your pinouts for #1 is 101 #3 is 103 #5 is 105 on ecu. You should have power there just simply test to make sure you have correct voltage coming out of those. If not check your ground. If Your ground is ok but have power coming out and no power to injectors You can simply splice a new wire and bypass the whole mile those wires run through the car. I had very similar problem and just ran the power wires for 2 and 6 straight to ECU and worked just fine. If you look by ECU there is a blue and a white plug injector wires go through there and beyond there don't know where they go. They switch colors few times so don't worry if colors don't match up by the Chiltons schematic. Let me know if that doesn't work.
akurtzer57 is offline
Old 07-22-2008, 07:35 PM
Jesus was a Zombie.
BenStoked's Avatar
are you simply not getting a positive to each, or are you not getting a reading off of both pins? what I mean is, I believe that all 6 get positive power all the time, and are triggered by the ecu completing the circuit by grounding them.
this could be wrong, but I am too tired to search.
BenStoked is offline
Old 07-22-2008, 07:51 PM
akurtzer57's Avatar
I don't think he has checked what has power just knows front arn't working most likely just don't have power is the most common problem with them.
Old 07-23-2008, 03:54 PM
CMax03's Avatar
Have you checked the injector grounds for the rear bank? Is the ECU providing power at the ecu for the injectors? Is this a VG or VE? If its a VG check your distributor optical timing wheel maybe 1,3,5 have something blocking it? Swap out you knock sensor with another! Use a noid tester.... on those injector plugs
CMax03 is offline
Old 07-24-2008, 04:17 PM
Amillyon's Avatar
After doing some checks I found that I have power at injectors 1,3,5 when I have the ignition switch on. When I grounded my test light I heard the injector fire which tells me there is a problem with the ground. So if this is the case is there a possibility that the ECU is not providing the ground to close the circuit? I also have continuity from each connector back to the battery with the positive lead to the battery unhooked.
Amillyon is offline
Old 07-24-2008, 06:34 PM
akurtzer57's Avatar
very well could be an injector but not guarantee
Old 07-24-2008, 08:19 PM
Amillyon's Avatar
It's not I have already checked them.
Amillyon is offline
Old 07-25-2008, 01:36 AM
CMax03's Avatar
Sounds like possible ECU as you stated b4.....
CMax03 is offline
Old 07-25-2008, 06:47 AM
mod or sell?
internetautomar's Avatar
sounds like a bad harness to me.
internetautomar is offline
Old 07-25-2008, 12:24 PM
Amillyon's Avatar
Here's the update, I swapped out the ECU and still no luck to injectors 1, 3, 5. I'm about to pull my hair out on this one, I have a red/blue, red/yellow and red/black with a peppermint colored wire going into another harness (the main harness). This is connected to green/spotted silver, a green/brown with spotted silver and one brown wire that go back to the ECM. The continuity from the ECM connector to each wire is good (a few inches past the connector). I did get a high reading on the spotted silver between the connector that plugs into the injector harness and the other side right before it goes in the car. With the ignition on and each injector unplug I get power to each wire except 3 and 5. I get power to 3 and 5 only when 1,3,5 are connected. If anyone can make sense of this please post.
Amillyon is offline
Old 07-25-2008, 08:43 PM
Amillyon's Avatar
Ok, my ECU is throwing a code 34 Knock sensor would this keep injectors 1,3,5 from spraying? If anyone sees raeqwon28 online please tell him I'm having the same issue he was having in this post >>>> http://forums.maxima.org/3rd-generat...e-harness.html I'm sure he could tell me what the problem is!!
Amillyon is offline
Old 07-26-2008, 12:21 AM
CMax03's Avatar
sounds about right! There jobs is to retard timing or cut down cylinders when detonation is sensed, try to unplug it replace it and try to start it! Knock sensors can do some weird things!
CMax03 is offline
Old 07-26-2008, 11:28 AM
Call me Wookiee Goldberg
CapedCadaver's Avatar
but why would that just cut off 3 of them?
CapedCadaver is offline
Old 07-26-2008, 03:45 PM
CMax03's Avatar
I can't tihink of anything else that would retard timing or drop a cylinder via the ECU.....
CMax03 is offline
Old 07-26-2008, 04:15 PM
i've never even heard of the KS making injectors shut off, ever.
Old 07-26-2008, 06:33 PM
Amillyon's Avatar
Capedcadaver, we've spoken before a few months back I'm in Durham,NC. To give you a run down of what happened. I have injectors 1,3, and 5 not spraying, so far I have swapped the ECU and the injectors ohm out at 11.5. I have power to all the injectors when the connectors are on each injector. If I disconnect all of the connections from each injector I have power at all except 3,5. I only get power to 3 and 5 when 1 is connected to the injector along with 3 and5. If I ground the 1,3,5 injectors with my test light then I hair each one spray. The continuity was good from the ECU/SMJ connector to a inches passed it on the brown/spotted silver, green/spotted silver and Green/black striped wire. What could be keeping my injectors from spraying?
Amillyon is offline
Old 07-26-2008, 07:33 PM
CMax03's Avatar
Unwrap your Harness the power wires of injectors 1,3,5 are spliced together and more than likely those Nissan factory crimps are coming apart! The 1,3,5 all have a wht/blu power wire....
CMax03 is offline
Old 07-26-2008, 07:58 PM
well it seems you have some sort of kentucky fried wire situation then. the injectors will show proper continuity individually.... but what you need to see is if injector 3 on one end continues to both 3 and 5 on the other end, etc. it seems that they are somehow messed up in that mannner, to where they are sharing continuity. also don't use a test light for anything on the injector circuits on the ECU. it'll kill your ECU. use a noid light (has like 11.5ohm so it pretends to be an injector) or use a multimeter.. not a test light.
i apologize for not remembering you either... there's a lot of members and it's hard to remember who's where. i just put my location under my avatar so it's easy to see at a glance. anyhow are you a VE or a VG?
Old 07-27-2008, 01:47 PM
Amillyon's Avatar
Hey Capedcadaver, thanks for the response I have a 94 GXE. I'm going to do some checks and will post some pictures.
Amillyon is offline
Old 07-27-2008, 03:04 PM
that thread you linked me doesn't work
Old 07-27-2008, 03:30 PM
Amillyon's Avatar
Ok, I thought so. I tried to use the old thread command in the link but still nothing. Just to let everyone know I recently put a tranny in this car. I saw a thread where someone else was having the same problem with injectors 1,3,5 not working on an 89SE. The question that was asked was :
"Be sure you don't have the wiring harness for the front injectors flipped around with the wiring harness for the nuetral/reverse sensor coming from the tranny. Yes they fit in each other, yes it cuts out the front 3 cylinders, yes I've done it.
For all three to be out that'd be one of my guesses if you ever unhooked those wires. They're easy to flip around if you don't know the wires too well." mtcookson
Could this happen on a 94 GXE being that I just put a tranny in?
Amillyon is offline
Old 07-27-2008, 03:45 PM
the FRONT injectors are 2 4 and 6.... that is how you are labelling them correct? you are not getting power from the rear ones?
http://forums.maxima.org/3rd-generat...hats-next.html read that entire thread
Old 07-27-2008, 03:54 PM
Amillyon's Avatar
Firewall
246
135 <-------- Not working (connected to a sub harness) Wire Red/black Red Yellow, Red/Blue
Front of the car
Amillyon is offline
Old 07-27-2008, 04:03 PM
Firewall
135
246 <-------- Not working (connected to a sub harness) Wire Red/black Red Yellow, Red/Blue
Front of the car
free fix. look at the number on the distributor cap and follow the wires to their destinations.
i thought you were talking about the rears the whole time.
http://i164.photobucket.com/albums/u...t/IMG_1631.jpg see the #s on the wires? ignore the turbo that i used as a photo-op/joke
Old 07-27-2008, 04:42 PM
Amillyon's Avatar
I'm at work at the moment, so standing in front of the car the closest three cylinders are 2,4,6 ? Another thing is that the harness that is attach to the those injectors have 4 wires, One red/white wire that they all share and then Red/black, Red Yellow, Red/Blue which is now plugged into a connector that only has three wires Brown, green and green/black..... something isn't connected. That post you sent me makes me think I have something hooked up wrong for sure.
Amillyon is offline
Old 07-27-2008, 05:16 PM
brown and greenblack and green are all tranny inhibitor wires. redblue redyellow redblack and redwhite are injectors. swap that shyte pronto mang. and pray you haven't nuked and/or fried anything else when stuff was basically shorted out by the misplug.
Old 07-27-2008, 05:33 PM
Amillyon's Avatar
I'm very relieved to know exactly what the problem was. My tranny inhibitor wires are attached to my front row of injectors WOW!! The connectors are the same shape and it's very easy to get them mixed up if you don't pay attention. I would like to thank everyone who gave their input and stuck it out to the end. Capedcadaver I'm right here in Durham if ever need some help just hit me up. I have a boat load of tools and don't mind getting my hands dirty. If you have an instant messenger ID send me a private message, everyone thanks again!
Amillyon is offline
Old 07-27-2008, 05:36 PM
if you've got a good jack and an extra pair of jackstands i can borrow for a week that'd be kinda cool..... i don't have any good jacks so i can't lift my car up as high as i need to most of the time.
did you swap them and now it runs right?
Old 07-27-2008, 05:40 PM
Amillyon's Avatar
Well capedcadaver I'm at work here in Cary at the moment, so I'll have to swap them when I get home tonight. Yes, I have a two ton shop jack and some heavy duty jack stands I got from Harbor Frieght tools.
Amillyon is offline
Old 07-27-2008, 05:44 PM
ugh i used to work in cary at this thinly-disguised door-to-door marketing (not sales, because we were soliciting free estimates). worst job ever. i quit it a week before i started my 5spd swap. anyhow maybe tomorrow or something we can do that. i wouldn't want to make you drive from cary all the hell back to durham, and THEN back out here to freaking east raleigh (that'd be like 70 miles of driving by the time you got home) so late at night and all.
Old 07-27-2008, 05:50 PM
Amillyon's Avatar
Yeah not mention I have to put my car back together...lol
Amillyon is offline
jmlee44
10-02-2022 02:13 PM
aw11power
10-10-2021 04:57 AM
leatherneck
09-30-2015 09:16 PM
Quick Reply: Injectors 1,3,5 have no power
