Fuel Injector Wire Harness
I'm need of some help. I did an engine swap with a Japaneese Import Engine and everything is runing ....but its running on 3 injectors. The reason its not working all 6 is due to a pin missing in(I belive) the female harness that is connected to the firewall(The big wireharness that runs to the firewall). I tried looking for my old fuel injector but had already scrap the old engine. Looking for the pics is there anyway I could add a female slot inside this wire harness or is there any adapter that could work?
This is a view of the fuel injector wire harness male pin side
This is the fuel injector wire harness
a view of the female side of the fuel injector wire harness this runs to the firewall
Excuse the bigs pic. any help would be greatly appreciated.
2 plug has a red wire with a blue strip and a white wire with a purple strip
3 plug has a red wire with a yellow strip and a white wire with a green strip
that's kinda weird to have 6 colors and just 3 pins at the plug. what colors are the wires on the harness-plug end?
oops i meant the one with just 3... so i guess that's the car-side plug. i'm assuming your white/x one is missing from the car-side which is the power to the injectors. ECU pulls grounds.
Solder-in-Solution. Its not forbidden or shameful to cut and paste wires...
I think thats the ground for the injector signals, they share the same one. Slip out the male and see if you can ground it. They come out when you put a very tiny screwdriver inside and press on a tab, look up the 9007 headlight swap because there is a similar technique used there.
I would hook everything up and probe those three wires for 12v and see if any are hot. I would venture to guess that they will not be, in which case you can simply provide an ignition switched +12v supplied to the injectors as previously stated and all should be well if those existing 3 wires are indeed the individual grounds for the 3 non-firing injectors.
Kingofmaximas24
11-12-2015 04:40 PM
