Go Back   Maxima Forums > Maxima Discussions > 3rd Generation Maxima (1989-1994)
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-21-2009, 07:29 PM   #4041
Quote:
Originally Posted by CapedCadaver View Post
hmmm..... try pulling the thing with the wires off the steering column. it looks like it might've broken out of the back of the 2-post wheel...... note the 4 holes that match up with the holes in the back of the wheel?
i like the PRND2L lights on the cluster. what're the 2 oval-shaped buttons next to the comfort/power switch? also i would get SO confused trying to indicate in your car since in the US the headlight/indicator switch is on the left side of the wheel.
nah the thing hanging off the steering column i unscrewed from the back of the old half moon steering wheel.
well the comfort/power switch is actually hold/normal/power. the hold button holds the gears so you can drive it like a manual. the 2 buttons beside it are for the adjustable suspension, comfort and sport.
ramlee is offline   Reply With Quote
Old 08-21-2009, 08:04 PM   #4042
:squint:
BenStoked's Avatar
Send a message via AIM to BenStoked
the thing with the wires, the back doesn't match the new wheel? interesting....
where are you from (what country)?
what year do you have?
BenStoked is offline   Reply With Quote
Old 08-21-2009, 08:09 PM   #4043
nah it's completely different (pix on previous page).
it's a 1989 JDM Maxima, they came with the 4 spoke wheel as well and the 4 spoke wheel is identical at the back (the brass rings) as the 300ZX wheel, but my 2 spoke is completely different.
i can't understand why they would be different, i mean what is the point in have the same car with different wheel assemblies? it just makes no sense
Old 08-21-2009, 08:13 PM   #4044
:squint:
BenStoked's Avatar
hmm... well, I will pull the wheel off my usdm 89 (4-spoke), see if it's different from my 91max, and s13/z31/z32/others-that-I-don't-know wheels.
Old 08-21-2009, 08:19 PM   #4045
idle problems
Hi,
I’ve been having a few problems getting a smooth idle at the correct RPM on my J30 maxima with VG30E. I’ve been following the FSM procedure except there are a few strange things happening. I have searched for this exact same issue but could find reference to it. Firstly, when the idle is set in “N’ at 700RPM with IACV closed, even 750RPM, there is quite a vibration that develops through the car when at lights for a while and there is also always a slight unevenness to the idle. If at the lights for a couple of minutes, it is ok for about a minute but then the revs noticibly drop (to about 700-750) and the vibration starts. I’ve checked the engine mounts and they look fine. I’ve tried to reset idle numerous times (a little higher than recommended) but the problem doesn’t go away. The idle in N seems to get higher when adjusted but in D it doesn't seem to "stick". Also during the procedure, when closing IACV valve for setting the baseline RPM, then revs don’t always noticibly drop. I have checked the resistance across the IACV terminals and all are within spec. I’ve also taken the IACV out and cleaned it. The other issue is that when trying to hold the revs at 2000 during the procedure the engine seems to suddenly drop back to 1500. It keeps doing this when trying to hold around 2000. I end up having to hold at about 2200 to overcome this. The other thing I’ve noticed is that when first starting the car from cold the timing seems to sit around 20 degrees for quite a while before dropping back to 15 (maybe they are supposed to do this?). But when it does drop back it is always fluctuating between about 13 and 17. The FSM does state 15 +or – 2 degrees, but I didn’t think that it should fluctuate like this. I get the feeling that all these issues may be related. The car is very well maintained and in otherwise excellent condition. It has never shown any error codes.
mark77 is offline   Reply With Quote
Old 08-21-2009, 08:21 PM   #4046
Sweet. this is the back of the std steering wheel with the bits screwed on
and the back of the 4 spoke wheel again for comparison
Old 08-21-2009, 08:27 PM   #4047
Call me Wookiee Goldberg
CapedCadaver's Avatar
ramlee - if you get ahold of a USDM stalk switch mount (with the 3 slipring buttons built in), then you can just bolt your headlight and wiper switches into that, splice the 3 wires for the cruise buttons/horn onto the USDM stalk mount, and put the 4-post wheel on. Where are you located anyhow? I have a spare but if you're not in the US, international shipping MIGHT be a biyatch...
__________________
PieceOut.FallToPeaces New to the forum? CLICK HERE!!!!
1985 Nissan 300zx 2-seater: VG30E | 5spd Swap | Bilstein | 5-lug conversion | Polyurethane everything | Resurrection-in-progress!
2004 Honda Civic EX Coupe: 1.7L VTEC | 5spd | CAI soon | LED tails and Projectors soon | ES Poly Motormounts soon | 'bad weather' car/backup for teh Z
1990 Nissan Maxima GXE: VG30E | VLSD-5 swap | Exedy | NWP | a33b(F)/z31(R) BBK | ES poly | SE susp swap | 2k2SE 17s | retired Aug 28th '09
2005 Nissan Maxima SE: VQ35DE | 6spd | Carolina Panthers front lisence plate | Brother's car, not mine | <-- Therefore still 100% stock
Quote:
Originally Posted by JasonOksa View Post
Horsepower, torque and speed are all known by The State of California to cause cancer, birth defects, and reproductive disorders.
Quote:
Originally Posted by bigleman View Post
how much would it cost to resleeve?
how does an aluminum motor form rust on the cylinder walls???
DO NOT PM ME ABOUT PROBLEMS WITH YOUR CAR UNLESS I TELL YOU TO. THAT'S WHAT THE FORUM IS FOR
CapedCadaver is offline   Reply With Quote
Old 08-21-2009, 08:30 PM   #4048
i'm in New Zealand so it might cost quite a bit in shipping lol. i just wanted to cheaply upgrade the wheel since the 2 spoke one is just plain nasty, thinking that the 4 spoke one should bolt right on no worries, but i guess it looks like i'll be stuck with it :/
Old 08-21-2009, 08:40 PM   #4049
well... how about can you cut out the back of the 4post wheel and drill 4 holes and screw the JDM wire thing into the back of it the way it came out of your stock wheel?
__________________
Old 08-21-2009, 08:45 PM   #4050
hmm that's a thought. i'll have a better play of it tomorrow, and since it's unlikely i'll be able to sell it won't matter if it gets hacked up a little haha
Old 08-21-2009, 08:55 PM   #4051
:squint:
BenStoked's Avatar
Quote:
Originally Posted by mark77 View Post
Hi,
mark, you may want to try the "spark plug test", see if the idle changes.if you find a cylinder that doesn't make it change, you aren't getting spark, or your injector is going bad. let let us know, okay?
Old 08-21-2009, 08:59 PM   #4052
:squint:
BenStoked's Avatar
This is the pic i find interesting... there are holes on that black wheel. that looks to me like some optical sensor, and I cannot think of a logical reason to have them there, at least, in a car that's 20 years old.
....then again, it's getting late, I am tired, and my mind is on installing a new OS on my server...
Old 08-21-2009, 11:31 PM   #4053
I bought the wire harness for the car. I hooked up every wire to its corresponding color. I'm no electrician at all. For the wire harness it has two (-)grounds that i connected both to the ground on my new stereo. And the (+) to (+), (-) to (-). But i didnt use the dark blue(power antenna) wire(I dont have a power antenna set up.) and i didnt use the orange wire(Dimmer/illumination). When i put the negative terminal back on the battery, the wires started to make clicking noises and the stereo was flashing colors and didnt work.i used these(http://www.qcsupply.com/images/produ...ctors-w280.jpg) to connect the wires and the wires that were not the same size, i tied em together and put electrical tape around them.) Help please. Sorry for Wall of text. lol
seans90maxima is offline   Reply With Quote
Old 08-21-2009, 11:47 PM   #4054
:squint:
BenStoked's Avatar
Quote:
you sure the radio worked before? also, try to run a wire from the radio's chasis, to a ground on the car (there is a metal bracket the radio bracket will screw to. good ground point.)
Old 08-21-2009, 11:57 PM   #4055
Quote:
Its a new stereo..
Old 08-22-2009, 12:38 AM   #4056
Hi,
"mark, you may want to try the "spark plug test", see if the idle changes.if you find a cylinder that doesn't make it change, you aren't getting spark, or your injector is going bad. let let us know, okay?"
By spark plug test do you mean unplug the leads one at a time while the engine is running to see if it makes a difference? I would have thought if one cylinder was not getting spark then performance would suffer. The car seems to run well above idle. If this is the test you mean then i'll do it and let you know.
Old 08-22-2009, 02:43 AM   #4057
Alright, This is what i did, sorry if its confusing.. But i get a clicking noise from the wires even when the car is not on. Artist's rendition, ofcourse
Old 08-22-2009, 05:51 AM   #4058
:squint:
BenStoked's Avatar
do you still have bose? if you do, you are trying to amplify a signal that has been amp'd. you will need to unhook hte speaker wires, and tap into the line out of the head unit.
if you don't, remove the blue/white stripe from the equation.
did you try running a new ground, yet?
Old 08-22-2009, 02:05 PM   #4059
I tried a ground and nothing happened. the only time i get any sound is if the three ground wires are together and i touch the amp wires together but the stereo itself still won't come on.
Old 08-22-2009, 02:31 PM   #4060
sean, have you verified proper voltage from the yellow and red wires yet (dashboard side)?
__________________
Old 08-22-2009, 04:23 PM   #4061
Yeah. what i dont understand is why the harness has two (-)grounds.
Old 08-22-2009, 07:13 PM   #4062
Here's my problem: car is bogging down at low RPM's ocassionally sputtering, no funny sounds other than one whirring belt and no vibrations. as soon as it gets over 1500 RPM or so it's fine it just seems like it struggles to rev up. I've ohmed all the injectors and they're all around 13 ohms.
Here's what i've done:
Had a new flex section welded in and the exhaust checked for leaks.
Put in New NGK plugs
Cleaned the Air filter
Changed the Fuel Filter
Ran fuel injector cleaner through it
__________________
CAI, EGR removed, FSTB, DZ springs, SS brake lines, Cross Drilled Rotors, ES Poly bushings, 9007 upgrade, Front lip and repaint, fogs, 2x alpine type s 10's, pioneer HU Alpine Amp,
Garf is offline   Reply With Quote
Old 08-22-2009, 08:03 PM   #4063
:squint:
BenStoked's Avatar
how's the dizzy cap/rotor? any build up?
Old 08-22-2009, 10:21 PM   #4064
totally clean, wires are fine too, no green corrosion anywhere.
__________________
Old 08-23-2009, 06:09 AM   #4065
Hi,
Hi again,
I did the test to see if each cylinder was getting spark and they were. Next I checked the resistance for each injector harness. They were quite corroded with blue copper powder. To start with i couldn't even get a reading on the multimeter. I cleaned them off and they were all within spec (about 12 ohms). So i don't think they were causing my original problem. Curiously i was out this afternoon after doing all this and for the first time ever the car hesitated. I opened the hood and noticed that one of the leads was arcing against the engine under acceleration. It was properly attached. I took the plug out (NGK) and it looked fine. I swapped it with the plug next to it and checked again. Still same lead was arcing. Maybe i disturbed the last bit of life it had in it. I'm guessing i new set of leads is the solution. Still not convinced the original problem will go away though.
Mark
Old 08-23-2009, 11:23 AM   #4066
fuel tank leak
I don't mean to change the topic, but I have noticed a fuel leak coming from the drivers side near the tank. One day with a full tank I parked on a friend's steep driveway and came out a couple minutes later and there was fuel literally dripping down from under the car. I probably lost 2-4 ounces of fuel in a couple minutes. I moved the car to a smooth area and it stopped but I could still hear something sounding like bubbling so i opened the tank to let out the pressure. the noise went away.
I have looked under the car and I noticed there is always a little fuel on the place where it was dripping.
I don't know exactly where in this picture it was leaking, but it looks like you can see fuel stains.
Where is it coming from, do I need to fix anything, and if so, what?
codyl1992 is offline   Reply With Quote
Old 08-23-2009, 12:34 PM   #4067
Send a message via AIM to 99sidude
Quote:
Originally Posted by James92SE View Post
You can actually test the rears at the harness, which was news to even me until just recently
It's been my luck on two VE's that it's always an injector on the rear that goes bad
I know you said they tested fine, but are the coilpacks cracked?
Also, are you sure it's misfiring and not just getting "heat soaked"? VE's are notorious for bad knock sensors that really, really bog the car down once the engine warms up
Good Call!!! 2 of the rear injectors are showing 45-75 ohms. That is way over the 10-14 the fsm qoutes. Thanks again.
99sidude is offline   Reply With Quote
Old 08-23-2009, 04:12 PM   #4068
:squint:
BenStoked's Avatar
Quote:
Originally Posted by internetautomar View Post
what year are you dealing with?
there is a difference in the USDM wheels because the slip ring (top pic) is for non airbag vehicles. airbagged vehicles come with a clock spring that is hardwired with connectors.
he said "89"
Old 08-24-2009, 01:57 PM   #4069
dose anyone know where i can get a short shifter for my 93 se pacesetter cut production
jimbot18 is offline   Reply With Quote
Old 08-24-2009, 03:40 PM   #4070
I have a few questions about my 92 Maxima SE (5-spd). PLEASE REPLY
I own a 92 Maxima SE (the supposedly rare 5-speed manual version.) It is an extremely fast car. On paper, it does 0-60 in 6.6 seconds and finishes the quarter mile in 15.1 according to:
http://www.zeroto60times.com/Nissan-0-60-mph-Times.html
If you can please take a look at that site and look the car that's right under mine, which is the 1994 Nissan Maxima SE (Auto). It says that the automatic version does it in 8.7, which is much, MUCH slower than mine. Does that sound realistic? So does that mean that manuals shave off 2 seconds in 0-60 acceleration? WHY?
Also, I recently tested my car's 0-60 and I managed to get it in 6.9 seconds bone stock. Will a short ram intake or a cold air intake make it any faster? Much appreciated guys!
Victorious_One is offline   Reply With Quote
Old 08-24-2009, 04:28 PM   #4071
thats weird, ive always been told that auto is technically faster than 5 speed.
Youve got a 92 SE so you have the VG30E, same as my GXE, yet the 94 SE would have the VE with a extra 30hp. somethings up with that site then
__________________
1992 GXE l 414,000km on original tranny and original VG30E l Pioneer Premier 12" 3500w subwoofer l 600w amp l JVC H/U l aftermarket fog lights l 2.5" Magnaflow catback exhaust l Momo summer rims l Stock winter rims l Sparco Sprint driver/passenger seat w/drivers 6 point harness l Sparco Volanti steering wheel l Castrol Syntec oil/premium Vpower gas
Future mods- 5spd swap, Z31 turbo w/intercooler
This winters mods- Z31 hood scoop, digital cluster swap, lowering springs
chrome91 is offline   Reply With Quote
Old 08-24-2009, 05:43 PM   #4072
ntrly....... my vg5 was a tenth faster than AM_BlackMax's VE auto in the 1/4mile. he had a faster r/t so he got the win, but my ET was better.
and learn your model/year combos.... VE is 92-94SE, not just 94.
the only time a/t is faster is in drag racing when you have alot of power (able to go faster than 14s in a 1/4mile), because it delivers the power more smoothly and multiplies the torque through the torque converter. otherwise m/t is faster 99% of the time.
__________________
Old 08-24-2009, 06:07 PM   #4073
Hey, Guys, We have a '90 GXE with 178K miles on it. The transmission has been slipping for a couple months now and we have checked the fluid and one the tests to no avail. I LOVE the old car, but, the hubby says it must go( Oh, it is red and we have all the original papers being the 3rd owners. What do u think that might be a fair price with a good body, a/c and 4 brandnew tires?? TKS for any help u can give!!
oldbitty is offline   Reply With Quote
Old 08-24-2009, 06:23 PM   #4074
:squint:
BenStoked's Avatar
Quote:
unfortunately, with a bad auto, the price is pretty negligable. I would estimate about $400 (US), if the tires are new. maybe $500 if the body is in real good condition. if you live up north, and it's semi-rusty, you may get more. if you live in the south, and it's semi rusty you will get less.
I spent $250 on an 89 SE, with a bad auto, nice body, great interior (minus some parts, on both). I almost picked up a 93 VE with a bad engine for $100, but didn't have the cash(%&!* the luck...).
Old 08-25-2009, 06:07 AM   #4075
Hey guys, just scored a leather wrapped auto shifter. It would've been installed, but I've ran into a problem. How the hell does the old one come out? I've skimmed through my FSM, but haven't found anything on the dissembling of the auto shifter.
*edit* Nevermind, figured it out after more trial and error, got the new leatherwrapped goodness installed.
__________________
89 Maxima GXE
Mods: Rear Disc Conversion, Front Strut Tower Brace, Brembo's all around (Slotted Front), SE Tails - Hopefully more to come!
Dhunterx is offline   Reply With Quote
Old 08-25-2009, 11:16 PM   #4076
I havent had my subwoofers running since early this year, i wired my 3rd gen in July last year and it was all good, bought a bigger sub later that year with my first amp being still used. Early this year, i bought a new amp, and when i installed it, no power. I tried wiring up my original amp that 100% worked before, and that wouldnt get power.
I never pulled any wires swapping and my connections are good, and everytime i messed around with the wires i swapped fuses on the amp. Could a fuse on the car itself be causing my amp not to power up? if so, which one?
__________________
Old 08-26-2009, 04:01 PM   #4077
Send a message via Yahoo to vgkid
sorry to change the subject on here but i wanted to know what is the torque specs needed for the exhaust manifold screws *the ones that hold the headers in the head*
and has anyone else had the problem of the dimmer not working? i checked the switch and thats not it
vgkid is offline   Reply With Quote
Old 08-26-2009, 07:38 PM   #4078
My 89 GXE would make noises around the front suspension while driving the car. At the beginning of August after changing the front strut, strut mounts, thrust bushings and end link bushings, the noise reduced but it would still come up. Looking around, I found out the nut that holds the left lower control arm and the gusset was not that tight, and the noise went away after tightening it. Now it is making noise again but I haven't checked if the nut has gotten loose again. But I am wondering where else I should look at?
jbbons25 is offline   Reply With Quote
Old 08-26-2009, 09:08 PM   #4079
I just bought a 1992 SE the other night and when I jacked it up to change the oil today, I noticed the previous owner had run over something and messed up the exhaust manifold and y pipe, some of the bolts are missing, some stuff is bent up, and I think at least one of the manifold studs is missing or broken off. I can definitely hear some exhaust leaks, and figured if I'm going to buy new stuff I may as well buy some headers and a decent y pipe. My question is...are there any good 50 state smog legal kits out there? Or anything I can do to keep it smog legal? Thanks
supersymmetry is offline   Reply With Quote
Old 08-26-2009, 09:30 PM   #4080
:squint:
BenStoked's Avatar
Quote:
there are a couple of brands that make headers, Pacecetter being one. Avoid them, unless you don't mind hacking them up to make them fit. I don't remember who the other brand is, but I know nothing of their quality.
aside from that, there is warpspeed that makes a y-pipe to fit the original manifolds. if you have to replace it anyway, this is typically the recommended way to go.
If you have broken manifold studs, check your engine mounts before replacing them; if they are bad, you may be replacing your studs again.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
