Quote:
Originally Posted by Larrio Motors
Correct me if i'm wrong... but a catback couldn't affect emissions because it is a "cat-back", and hence already AFTER the catalytic converter.
So i'm not really sure what a CA spec cat is in this case.
Just for clarity...I replaced EVERYTHING including the cat. Sorry about the wording there.
Yes, car is running fine. Just earlier this week I was going over 90 on the 10 without missing a beat. To me the car seems to be running great. Let me add this, as a work around to my air temp sensor issue I had in the other post I kind of just "tucked" the sensor into the filter (between the MAF and filter) because I didn't have anywhere to drill a hole to fit it. Would this lack of "vacuum" cause my off readings? It seems like and EGR valve is fairly easy to change, I'm up for trying that if it is recommended.
Also, I remembered after the fact. I had to let my car sit cold for like 10 minutes while another car finished. If I run it hotter when I get there, the CAT should burn off more of the "gases" and give a lower reading (I would think).
