Go Back   Maxima Forums > Regional Maxima Groups > Washington D.C. area
Washington D.C. area DC, MD, NC, VA, WV Maxima owners.
Thread Tools Display Modes
Old 09-02-2008, 03:37 PM   #1
Send a message via AIM to btvenom
Suspension Trouble? Need Help ASAP
UPDATED INFO
It seems, that the inner boot I believe is where its disconnected, as I've circled in the photo, so now I need to figure out the easiest way to reconnect this into the tranny/axle, where ever it goes...
Hey, fellow .org members, I need you guys help so bad, I was in the process of installing my KYB GR-2's struts, with the stock springs, and ran into some trouble with the Driver front, I cannot get the Rotor back into the vertical position as seen in the photos me and my dad both messed with it for at least an hour straight, I know the axle couldn't have popped out becuase, when i turn the pass front tire it turns...
Guys Please help me, I dont know what's wrong with it, I've tried everything and I'm without a car..
If any one is local to Cary, NC I would be willing to pay for someone to get this fixed for me.
Driver Front Problem
This is what it should look like (This is the pass front complete)
The Car from further away
I've checked these boot's and nothing feels loose, but havent taken them apart.
btvenom is offline   Reply With Quote
Old 09-02-2008, 03:39 PM   #2
Another Picture of the Driver Front
Old 09-02-2008, 03:44 PM   #3
PMmeFor411AboutMaxus
alicious's Avatar
Send a message via ICQ to alicious Send a message via AIM to alicious
que Irish44j
alicious is offline   Reply With Quote
Old 09-02-2008, 03:48 PM   #4
V1SuperCharger
Stillen Maxima's Avatar
Send a message via AIM to Stillen Maxima Send a message via MSN to Stillen Maxima
Its the axle out of place. Trust me.
Stillen Maxima is offline   Reply With Quote
Old 09-02-2008, 03:53 PM   #5
Quote:
How do i get the axle back in place then?, also if i turn the passenger front rotor, the driver front move's so how can the axle be out of place?
Old 09-02-2008, 04:37 PM   #6
Blown
Send a message via AIM to cardana24
^^^ he is right. That happens all the time when you take the strut off of the nuckle. It gets bound up, usually you can just wiggle to the rotor and it will slip back in. It's not a big deal.
cardana24 is offline   Reply With Quote
Old 09-02-2008, 04:44 PM   #7
Ok well what if i cant get it slipped back in?, I've rotated and jiggled the rotor and I cant get the strut nuckle to line back up, and if the axle slipped out I cant get that to slip back on either.
Old 09-02-2008, 05:30 PM   #8
bump anyone?
Old 09-03-2008, 06:31 AM   #9
Blown
have you tried turn the rotor/wheels to get it into a different position, then try the same wiggle/jiggle thing?
Old 09-03-2008, 06:45 AM   #10
V1SuperCharger
^^^^ Exactly what he said. You have to do it slow, cant go crazy or else you will spend another hour trying to get the axle into the threads
Old 09-03-2008, 10:03 AM   #11
Yes, I have treid turning the rotor/wheels to get it into a different position, and hopefully line up the axle into the threads, but what Im going to do on Fri, after I get out of school, is try taking the Axle nut bolt off, and pulliing it out a little bit, so I can see if it will slide back into the correct position. Even if the axle did pop out, I should be able to get it back into the correct position by hand... Or am I wrong, also what could have happened worst case senario when the rotor and steering knuckle fell down like that? I know its on the tranny side, so it will be more work.
When I had this issue on the pass front side, we just jiggled it for like 20 min and it managed to pop right back into place... This is not the same outcome of the Driver front...
Old 09-03-2008, 10:12 AM   #12
n00b
Tuna's Avatar
Send a message via AIM to Tuna
Correct me if I'm wrong, but I remember something about one side having to be out before being able to take the other side out. Maybe it works the same going back in and you need to take the passenger side out before you can put the driver's side back in?
Tuna is offline   Reply With Quote
Old 09-03-2008, 10:48 AM   #13
Blown
Quote:
no
Old 09-03-2008, 10:52 AM   #14
Blown
That can work too. It just seems like more work. I assume you have an impact wrench and a 36mm socket so you can take the nut off? You are not going to be able to use a breaker bar since the strut is un hooked.
__________________
Hey Karim, you still on Blackplanet?
Old 09-03-2008, 08:51 PM   #15
bump
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
