I did alright considering I am just running my 1 - 12" subwoofer.. My first run was the best.. I hit a 141.5 db the first time and the second run was lower.. I didn't place but was happy with the subs performance.. You got to check out the new system sometime.. Or I will try to post up some pictures.. Peace
Originally posted by Chitwista I did alright considering I am just running my 1 - 12" subwoofer.. My first run was the best.. I hit a 141.5 db the first time and the second run was lower.. I didn't place but was happy with the subs performance.. You got to check out the new system sometime.. Or I will try to post up some pictures.. Peace
Its a Rockford Fosgate Power Hx2 2000 Watt Woofer.. Dual Voice Coil - 2 Ohms each voice coil.. Running off of a Crossfire VR1000d amp at 1 Ohm or about 1000 watts (amp runs great at one ohm). The box is ported down to 37hz and slams at the low frequencies.. I am happy with the setup actually I think it out preforms the system in my 1989 Maxima (check link below) and that had 4 - 12" woofers..
Originally posted by Chitwista Its a Rockford Fosgate Power Hx2 2000 Watt Woofer.. Dual Voice Coil - 2 Ohms each voice coil.. Running off of a Crossfire VR1000d amp at 1 Ohm or about 1000 watts (amp runs great at one ohm). The box is ported down to 37hz and slams at the low frequencies.. I am happy with the setup actually I think it out preforms the system in my 1989 Maxima (check link below) and that had 4 - 12" woofers..
