Restoring My ROTA P45R - First Timer Here - Pics
Old 09-18-2011, 05:49 PM
OC_Nooby's Avatar
So, last year I got my Hyper Black P45R ROTA rims 18x9.5. I made the mistake of driving the car with no mud flaps. The rear rims got hit by anything the front wheels picked up. Since they are 9.5 wide the fronts stick out and as time went by the rims hard rock chips in them. Great!!
I finally got myself an 80 gallon compressor with a built in regulator which is damn awesome! I went to my local pricessauto and got a paint gun and orbital 6" sander (both on sale).
So I started off by sanding the lip of the rim to bare metal as that's where the majority of the rock chips where. Thank god I got the orbital sander, it helped so much and made the job easy. After the lip I just sanded the rims everywhere I could to get rid of any glossiness so the primer can stick on better. I used a 600grit sand paper.
So currently As they sit to dry, they are primered. Tomorrow i'm going to use some bondo glaze to fill any little imperfections which I have seen here and there.
This is my first time painting with a spray gun/ sanding rims. So not bad, I say .
Paint are as follows:
Tremclad: Rust Oxide for Primer
Armorcoat: Flat Black for Base
Some matte clear coat (no glossiness)
Pics:
This was how bad the rims looked like (above pic)
OC_Nooby is offline
Old 09-18-2011, 08:18 PM
OC_Nooby's Avatar
This rim will need some extra love, I used some more aggressive sand paper and it shows will touch it up and give her another coat tomorrow. All the other rims I used 600 grit.
As they sit on my lawn right now....Thank god I live in the country
OC_Nooby is offline
Old 09-18-2011, 08:38 PM
xWTFxREALLYx's Avatar
how much was the compressor and the rims? Im loving the rims
xWTFxREALLYx is offline
Old 09-19-2011, 04:19 AM
phatboislim's Avatar
damn you got into that spokes *** lol..what'd you use 60 grit?
phatboislim is offline
Old 09-19-2011, 06:52 AM
OC_Nooby's Avatar
The compressor was a steal, 800 Canadian. They run around $950 at Lowes her in Canada without the regulator/dual outputs. I did buy it from another guy but it was brand new. Came withh a reel + 50 foot of hose, an extra 50 foot hose and compressor fittings . The rims are on Ebay for like 750 or so.
600 grit all around. I only used 60 on that one rim which was to rough (can be seen in the picture). After that mistake if I had any rock chips other then on the lip I used the 60 grit, then smoothed it out with the 600 grit.
OC_Nooby is offline
Old 09-19-2011, 06:57 AM
gotcha..yea...that low grit is a beast to get smooth...when i started from 60 grit on my G35 wheels...i worked my way all the way up in the grit..but it worked eventually..that and i had to use some bondo..but oh well
Old 09-19-2011, 07:43 AM
OC_Nooby's Avatar
It a lesson that must be learnt...lol, the lower grit does the job quick but then it takes time to get it smooth. Gotta remember paint fills very very little. I'm painting the rims black so it won't show as much as if it was glossy black.
I just applied the spot putty. Will sand it off with 600grit when I go back outside. Or maybe run to the local store and get 1000grit. Think i'll do that.
OC_Nooby is offline
Old 09-19-2011, 07:53 AM
lol you might be surprised how much itll show...you should really work your way up on the grit to get that smoothed out, more time now will make you happier later.
Old 09-19-2011, 08:07 AM
OC_Nooby's Avatar
True, spot putty does wonders though
OC_Nooby is offline
Old 09-19-2011, 08:24 AM
truth
Old 09-19-2011, 12:24 PM
OC_Nooby's Avatar
second round of primer is on, hopefully the weather cooperates and I can give them 2 coats of base tomorrow
It sucks painting outside cause you can really see the small debris. Sure its not a lot but gah >_<. I'll just do a light 1500grit sand before I do the base
OC_Nooby is offline
Old 09-20-2011, 02:14 PM
OC_Nooby's Avatar
Alrighty, got the first coat of base on! I'll do 2 more coats tomorrow and finish it off with clear coat on Thursday!
Pics:
Light 1500 grit sanding to get rid of any small imperfections
Before/After
Glad I did this myself and didn't go get it painted by someone else, lots of fun!
OC_Nooby is offline
Old 09-21-2011, 04:20 AM
LOL i dont know about the fun part, except that you get to drink beer the entire time..maybe thats why it took me so long cuz i wanted to drink more looking good man
Old 09-21-2011, 07:07 AM
OC_Nooby's Avatar
Hmm your on to something
OC_Nooby is offline
Old 09-21-2011, 07:09 AM
i'm also a recovering drunk *puts down the bottle*
Old 09-21-2011, 09:26 AM
wirelessdude04's Avatar
looks great man. Be careful with them
wirelessdude04 is offline
Old 09-21-2011, 09:35 AM
tookrzy4u192's Avatar
Looks very good so far! In for finished results!
tookrzy4u192 is offline
Old 09-21-2011, 09:47 AM
The6spdMax's Avatar
Props for great restore!
The6spdMax is offline
Old 09-21-2011, 09:53 AM
mista0406's Avatar
Great job bro everything is coming along great cant wait to see the finished product and mounted much props on being a first timer
mista0406 is offline
Old 09-21-2011, 02:18 PM
OC_Nooby's Avatar
Hey, Thanks everyone! I have to redo 2 as when I was painting them outside some crap fell on them. On my last coat before clear coat It's only 2 spokes so its not bad. Also I have random super small particles here and there but you really have to look for them. Again it's because the work was done outside. At least I put them in the garage today so nothing falls on them while they dry.
Thanks for the support I'll take pics for sure when they are on the car
OC_Nooby is offline
Old 09-21-2011, 07:22 PM
that sucks cant wait to see the finished product
Old 09-22-2011, 06:43 AM
OC_Nooby's Avatar
Should be done next week hopefully or this weekend. It's just bad weather
OC_Nooby is offline
Old 09-22-2011, 06:59 AM
i hear ya on that...just started raining but i fortunately finished wet sanding my wheels so now i can put compound and polish on it inside the house *wipes brow* beat the storm
Old 09-22-2011, 06:11 PM
OC_Nooby's Avatar
Boo, I got a car tent. So that's where I'll be painting my final coat. Actually someone bought it for me. I'm painting there car ahahaha. Should be an interesting experience. Well actually its good. See if I don't sell the car It can sleep there in the winter
I'll be putting up the tent tomorrow. Supposedly its going to be nice and Saturday to next week its going to rain.
Then I can get the perfect coat of base and clear coat!
OC_Nooby is offline
Old 09-23-2011, 04:21 AM
sounds awesome man!!! you gota chk my honda thread on here to see the progress of me polishing my wheels...xoxoxoxooxox hard work, but i'd do it again...not now though, my hands hurt
Old 09-23-2011, 01:55 PM
driver1712's Avatar
wow, great job!
why didn't you do a different color?
driver1712 is offline
Old 09-23-2011, 03:10 PM
Crusher103's Avatar
you really dont restore rotas you just go buy new ones but great work.
Crusher103 is offline
Old 09-23-2011, 03:34 PM
OC_Nooby's Avatar
ahahahah, My clear coat is going to be a matte clear. So I don't think much polishing will be required.
Originally Posted by driver1712
wow, great job!
I originally wanted flatblack. The only color with black I could get was one with the red lip. So I got the hyperblack.
$60 plus my time or $800 plus the hassle to pick them up at the border (lives in Canada)
Built my car tent. Sandly it just fits my car (wish it would be a couple of feet more. Ohh wellz.
Now I can do the last few coats dust free! Should be done this weekend. Don't mind the dirt. I'll vacuum the shi t out off it
OC_Nooby is offline
Old 09-25-2011, 05:58 PM
OC_Nooby's Avatar
Finally got all my rims painted nicely, no specs of crap or anything in it. Then I start to do my clear coat. I start spraying and these random white spots are appearing on my rims. Like drywall dust (its what it looked like). omg i'm so freaking mad its retarded. I spent so much time to get this **** perfected and to have this happen on my last coat. REALLY!!!!?!?!?
Heres to hoping that tomorrow when I wet sand this mother ****er with 1500 grit that those white random *** mother ****ing specs of white don't show.
OC_Nooby is offline
Old 09-26-2011, 04:26 AM
OC_Nooby's Avatar
Morning update. I went to check on rims this morning. The white stuff can be picked off easily. Hope to have pictures up tonight of the final product if all turns out well.
Also on a side note. I think this white stuff was the latex I tried spraying my first time using the gun. I never cut it down properly and it was to thick. I spent hours trying to clean it all out without success. Guess when I was priming and base coating I never saw it because it would just change to the color of the paint. Kinda explains why I get random little sand grains look alikes. Ohh well live and learn. Just hope I can remedy this with a very light sand and I'll be happy as a kite.
OC_Nooby is offline
Old 09-26-2011, 04:36 AM
looks sexy
Old 09-27-2011, 02:13 PM
OC_Nooby's Avatar
Well the rims are done, the white stuff came off. I give them a solid 9/10. I should have them by tomorrow . I'll post pictures for sure.
OC_Nooby is offline
Old 09-29-2011, 07:36 PM
OC_Nooby's Avatar
One rim got dropped, need to redo the lip. Sigh... 3 rims are mounted. The other will be done next week when I have time to get to it.
OC_Nooby is offline
Old 09-30-2011, 05:04 AM
-_-
Old 09-30-2011, 07:35 AM
OC_Nooby's Avatar
I didn't do the dropping, but rest assured i was angry. Ohh well, am over it just have to find time to do it now.
OC_Nooby is offline
Old 11-13-2011, 11:04 PM
no more maxima...
kingrukus's Avatar
Any idea on how much these wheels weigh?
kingrukus is offline
Old 11-14-2011, 04:35 AM
wow we never got a follow up...btw ithink the p45 19s are like 24lbs/wheel..i think
Old 11-14-2011, 10:43 AM
Puppetmaster's Avatar
Nice log of what you've done. Looking forward to seeing these on the car again.
Puppetmaster is offline
Old 12-06-2011, 10:23 AM
Prophecy99's Avatar
is it me or is paint jobs like these going to chip way more easily as a factory finish. i just picture it being way more vulnerable, considering how advanced a typical factory finish is.
Prophecy99 is offline
Old 12-06-2011, 10:32 AM
they are more prone to chipping...
Quick Reply: Restoring My ROTA P45R - First Timer Here - Pics
